    4. Test Adapter Meteoalarm v2.0.x
    • jackblackson
      jackblackson @Guest last edited by
      @ilovegym Ich hab nochmal einiges nachgebessert. Könntest du bitte mal das Update über Github installieren? https://github.com/jack-blackson/ioBroker.meteoalarm
        A Former User @jackblackson last edited by A Former User
        @jackblackson
        Hi, gerade mal schnell am Tablett das Update gemacht, der Fehler ist jetzt anders:
        meteoalarm.0
        2022-09-15 20:15:02.667 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
        meteoalarm.0
        2022-09-15 20:15:02.666 debug Plugin sentry destroyed
        meteoalarm.0
        2022-09-15 20:15:02.665 info terminating
        meteoalarm.0
        2022-09-15 20:15:02.652 error Cannot read properties of null (reading 'val')
        meteoalarm.0
        2022-09-15 20:15:02.652 error TypeError: Cannot read properties of null (reading 'val') at saveAlarmsForLater (/opt/iobroker/node_modules/iobroker.meteoalarm/main.js:907:39) at getData (/opt/iobroker/node_modules/iobroker.meteoalarm/main.js:295:31)
        meteoalarm.0
        2022-09-15 20:15:02.645 error unhandled promise rejection: Cannot read properties of null (reading 'val')
        meteoalarm.0
        2022-09-15 20:15:02.644 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        meteoalarm.0
        2022-09-15 20:15:02.033 debug 0: Existing alarm objects at adapter start: 0
        meteoalarm.0
        2022-09-15 20:15:01.904 debug XML Language: de-DE
        meteoalarm.0
        2022-09-15 20:15:01.903 debug Sentry aktiv - Breadcrumb gesetzt
        meteoalarm.0
        2022-09-15 20:15:01.902 debug Setup found: country DE and region DE047 - Kreis Darmstadt-Dieburg und Stadt Darmstadt
        meteoalarm.0
        2022-09-15 20:15:01.901 debug Language: de
        meteoalarm.0
        2022-09-15 20:15:01.883 info starting. Version 2.3.0 (non-npm: jack-blackson/ioBroker.meteoalarm#8dfb718522b496c18249f8927edd9b6c535229b3) in /opt/iobroker/node_modules/iobroker.meteoalarm, node: v16.17.0, js-controller: 4.0.23
        meteoalarm.0
        2022-09-15 20:15:01.616 debug Plugin sentry Initialize Plugin (enabled=true)
        jackblackson 1 Reply Last reply Reply Quote 0
        • jackblackson
          @ilovegym Sorry, da hat sich noch ein Fehler eingeschlichen - kannst du bitte nochmals aktualisieren?
            @jackblackson Hi,
            Jetzt läuft er, keine Fehler mehr, und hat auch die alten Alarme und Verzeichnisse gelöscht.
            Top!
            Vielen Dank!
              @jackblackson
              Nach dem Update auf 2.31 ist der Fehler wieder da, in der GitHub Version vorher war er weg…
              • jackblackson
                @ilovegym Der letzte Fehler mit „cannot read..“?
                  A Former User last edited by
                  @jackblackson
                  Hmm seit heute ist der Fehler wieder weg, kann das am Server gelegen haben?
                  Hab weder n Update noch n reboot gemacht..
                  • jackblackson
                    @ilovegym Ist sehr komisch, weil es eigentlich nur passieren konnte, wenn man noch alte Alarme hatte, die mit Version vor 2.3.0 erstellt wurden.
                      @jackblackson ja, ist auch seitdem nicht mehr aufgetreten. Version 2.3.1 laeuft!
                      • N
                        neunteufels last edited by
                        Hallo.
                        Seit zwei Tage habe ich folgenden Fehler im Log.
                        Der Fehler tritt für beide Instanzen auf.
                        Version: 2.3.3
                        Das ganze ist jetzt Wochen und Monate stabil gelaufen und jetzt plötzlich der Fehler.
                        Neustart von Instanz, IOBroker und des ganzen Systems hat nichts gebracht.
                        Aufgefallen ist es mir, weil aktuell eine Windwarnung sein sollte, aber nichts gekommen ist.
                        TypeError: Cannot read properties of undefined (reading 'indexOf') at /opt/iobroker/node_modules/iobroker.meteoalarm/main.js:420:76 at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18) at Parser.emit (node:events:513:28) at Parser.emit (node:domain:489:12) at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:262:26) at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35) at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5) at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7) at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13) at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:323:31)
                        Was kann ich noch probieren? @jackblackson
                        Danke vorab.
                        lg
                        Latzi jackblackson 2 Replies Last reply Reply Quote 0
                        • Latzi
                          Latzi @neunteufels last edited by Latzi
                          @neunteufels
                          versuch´s mit Version 2.3.4 (im latest Repo) - ich hatte ein ähnliches Problem am Wochenende.
                          Edit: aktuell gibt´s schon eine 2.3.5
                          • jackblackson
                            jackblackson @neunteufels last edited by
                            @neunteufels Wie @neunteufels sagt, sollte dir das Upgrade auf 2.3.4 (bzw. inzwischen 2.3.5) helfen - dies sind bisher aber nur im Beta-Channel verfügbar. Ich vermute du bist auch aus Österreich. Aus meiner Sicht wurde hier gestern bzw. vorgestern eine Windwarnung herausgegeben, die nicht ganz dem bisher definierten Format entsprochen hat - daher ist der Adapter abgeschmiert. Mit der neuen Version sollte es aber keine Problem mehr geben. Ich werde die 2.3.5 dann in 2-3 Tagen auch für alle freigeben.
                            N 1 Reply Last reply Reply Quote 1
                            • N
                              neunteufels @jackblackson last edited by
                              @jackblackson @Latzi
                              2.3.5 hat das Problem gelöst.
                              Danke.
                              • Chris76e
                                Chris76e last edited by
                                Für meinen Landkreis in Deutschland werden keine Warnungen mehr angezeigt obwohl auf der Webseite von meteoalarm.org eine Warnung vorhanden ist. Das ist schon seit ein paar Tagen so. Nutze seit heute die Version 2.3.5.
                                • jackblackson
                                  jackblackson @Chris76e last edited by jackblackson
                                  @chris76e Welche Version hattest du davor? Und um welche Region handelt es sich?
                                  Chris76e 1 Reply Last reply Reply Quote 0
                                  • Chris76e
                                    Chris76e @jackblackson last edited by
                                    @jackblackson Funktioniert wieder, habe gestern um 18:20 Uhr wieder Warnungen bekommen.
                                    Kann dir leider nicht sagen welche Version ich vorher hatte, bin aber im stabel unterwegs.
                                    Region ist Kreis Heinsberg.
                                    • N
                                      Hallo.
                                      Mir ist gerade auf gefallen, dass keine Benachrichtigung via Telegram kommt, wenn keine Warnungen mehr anstehen.
                                      Das hat doch schon mal funktioniert, oder?
                                      "Keine Warnungen" senden ist angehakt.
                                      Was kann ich machen damit ich die wieder bekomme?
                                      lg
                                      • jackblackson
                                        @neunteufels Ja, sollte schon funktionieren. Könntest du bitte kurz ein Issue anlegen, dann schau ich es mir gleich an. Dann sehen es Andere auch, wenn sie das selbe Problem haben.
                                        • N
                                          @jackblackson
                                          Issue habe ich vor einer Woche erstellt.
                                          Hattest du schon Zeit die Sache zu checken?
                                          Diese Woche war es wieder so, dass die Benachrichtigung NICHT gekommen ist. 😞
                                          Danke!
                                          • rtwl
                                            rtwl last edited by
                                            @jackblackson ich kann bestätigen, dass ich auch keine "keine Wetterwarnung" Meldung mehr bekomme. (Österreich)
                                            412
                                            82502
