    3. Off Topic
    4. apt full-upgrade Error
    • Negalein
      Negalein Global Moderator @Thomas Braun last edited by
      @thomas-braun sagte in apt full-upgrade Error:
      sudo du -a / | sort -n -r | head -n 20
      nega@ubuntu:~$ sudo du -a / | sort -n -r | head -n 20
      [sudo] password for nega:
      sort: write failed: /tmp/sortRETx9S: No space left on device
        crunchip Forum Testing Most Active @Negalein last edited by crunchip
        @negalein sagte in apt full-upgrade Error:
        sudo apt autoremove
        um mal die überflüssigen Pakete zu entfernen
        libfwupdplugin1 libxmlb1 linux-headers-5.4.0-139 linux-headers-5.4.0-139-generic linux-image-5.4.0-139-generic linux-modules-5.4.0-139-generic linux-modules-extra-5.4.0-139-generic
        @Negalein hast du die gelöscht?
          Thomas Braun Most Active @Negalein last edited by Thomas Braun
          @negalein
          Oh, jetzt wird es wirklich eng, wenn so kleines Zeug nicht mehr geschrieben werden kann.
          Vermutlich der apt cache voll.
          sudo apt clean
          • Negalein
            sudo apt clean
            das lief ohne Error.
            Aber dann noch immer
            sort: write failed: /tmp/sortlztpTO: No space left on device
              @negalein
              df -h
              • Negalein
                Negalein Global Moderator @crunchip last edited by
                @crunchip sagte in apt full-upgrade Error:
                sudo apt autoremove
                nega@ubuntu:~$ sudo apt autoremove
                Reading package lists... Done
                Building dependency tree
                The following packages will be REMOVED:
                0 upgraded, 0 newly installed, 5 to remove and 96 not upgraded.
                After this operation, 380 MB disk space will be freed.
                Do you want to continue? [Y/n] Y
                (Reading database ... 188197 files and directories currently installed.)
                Removing linux-headers-5.4.0-139-generic (5.4.0-139.156) ...
                Removing linux-headers-5.4.0-139 (5.4.0-139.156) ...
                Removing linux-modules-extra-5.4.0-139-generic (5.4.0-139.156) ...
                Removing linux-image-5.4.0-139-generic (5.4.0-139.156) ...
                /etc/kernel/postrm.d/initramfs-tools:
                update-initramfs: Deleting /boot/initrd.img-5.4.0-139-generic
                /etc/kernel/postrm.d/zz-update-grub:
                Sourcing file `/etc/default/grub'
                Sourcing file `/etc/default/grub.d/init-select.cfg'
                Generating grub configuration file ...
                Found linux image: /boot/vmlinuz-5.4.0-146-generic
                Found initrd image: /boot/initrd.img-5.4.0-146-generic
                Found linux image: /boot/vmlinuz-5.4.0-144-generic
                Found initrd image: /boot/initrd.img-5.4.0-144-generic
                Found linux image: /boot/vmlinuz-5.4.0-137-generic
                Found initrd image: /boot/initrd.img-5.4.0-137-generic
                done
                Removing linux-modules-5.4.0-139-generic (5.4.0-139.156) ...
                nega@ubuntu:~$
                df -h
                nega@ubuntu:~$ df -h
                Filesystem                         Size  Used Avail Use% Mounted on
                udev                               947M     0  947M   0% /dev
                tmpfs                              199M 1016K  198M   1% /run
                /dev/mapper/ubuntu--vg-ubuntu--lv  8.8G  8.0G  362M  96% /
                tmpfs                              992M     0  992M   0% /dev/shm
                tmpfs                              5.0M     0  5.0M   0% /run/lock
                tmpfs                              992M     0  992M   0% /sys/fs/cgroup
                /dev/loop1                          56M   56M     0 100% /snap/core18/2714
                /dev/sda2                          974M  306M  601M  34% /boot
                /dev/loop0                          56M   56M     0 100% /snap/core18/2721
                /dev/loop2                          64M   64M     0 100% /snap/core20/1828
                /dev/loop3                          64M   64M     0 100% /snap/core20/1852
                /dev/loop4                          92M   92M     0 100% /snap/lxd/23991
                /dev/loop5                          92M   92M     0 100% /snap/lxd/24061
                /dev/loop7                          50M   50M     0 100% /snap/snapd/18596
                /dev/loop6                          50M   50M     0 100% /snap/snapd/18357
                tmpfs                              199M     0  199M   0% /run/user/1000
                nega@ubuntu:~$
                crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                  362M
                  nun bisserl Platz😁
                    @negalein
                    Im npm cache liegt auch gerne viel herum.
                    sudo -H -u iobroker npm cache clear --force
                      crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                      @thomas-braun wenns ne iobroker VM ist/wäre
                        Thomas Braun Most Active @crunchip last edited by
                        @crunchip
                        Stimmt. Hatte ich jetzt angenommen.
                        Und ohne den ganzen Desktopkrempel wäre da auch mehr Platz...
                        crunchip Negalein 2 Replies Last reply Reply Quote 0
                        • Negalein
                          nun bisserl Platz
                          ja, ein bisserl 😁
                          dafür spinnen jetzt ein paar Switche und lassen sich nicht einbinden. 😞
                          nega@ubuntu:~$ sudo -H -u nega npm cache clear --force
                          sudo: npm: command not found
                            @thomas-braun sieht mit eher nach nem unifi controller aus
                            • Negalein
                              ok, das ist schon ewig her. Damals hab ich nicht darauf geachtet.
                              Wie bringt man den Desktop wieder weg?
                              • Negalein
                                Jep, ist er
                                Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                  Und der Unifi-Controller ist 8GB schwer?
                                  Keine Ahnung was der alles benötigt und anschleppt.
                                  crunchip Negalein Dr. Bakterius 3 Replies Last reply Reply Quote 0
                                    @negalein wenn du nicht zurecht kommst, könntest ja auch ein backup vom Controller machen, VM neu aufsetzen und backup wieder einspielen
                                      hatte den mal im LXC laufen, aber 8GB reichen eigentlich locker
                                      • Negalein
                                        ja, das ist der letzte Ausweg.
                                        Sobald die Switche wieder laufen, versuch ich https://indibit.de/ubuntu-partition-vergroessern/
                                        • Negalein
                                          ist das richtig mit init 3, oder wird hier nur umgeschaltet und der Desktop nicht deinstalliert?
                                            @negalein
                                            Da wird nur der Zustand geändert, die Software bleibt dennoch auf dem System.
                                            3117
