    3. Off Topic
    4. apt full-upgrade Error
      crunchip Forum Testing Most Active @Negalein last edited by crunchip
      @negalein sagte in apt full-upgrade Error:
      sudo apt autoremove
      um mal die überflüssigen Pakete zu entfernen
      libfwupdplugin1 libxmlb1 linux-headers-5.4.0-139 linux-headers-5.4.0-139-generic linux-image-5.4.0-139-generic linux-modules-5.4.0-139-generic linux-modules-extra-5.4.0-139-generic
      @Negalein hast du die gelöscht?
        Thomas Braun Most Active @Negalein last edited by Thomas Braun
        @negalein
        Oh, jetzt wird es wirklich eng, wenn so kleines Zeug nicht mehr geschrieben werden kann.
        Vermutlich der apt cache voll.
        sudo apt clean
        • Negalein
          Negalein Global Moderator @Thomas Braun last edited by
          @thomas-braun sagte in apt full-upgrade Error:
          sudo apt clean
          das lief ohne Error.
          Aber dann noch immer
          sort: write failed: /tmp/sortlztpTO: No space left on device
            @negalein
            df -h
            • Negalein
              Negalein Global Moderator @crunchip last edited by
              @crunchip sagte in apt full-upgrade Error:
              sudo apt autoremove
              nega@ubuntu:~$ sudo apt autoremove
              Reading package lists... Done
              Building dependency tree
              The following packages will be REMOVED:
              0 upgraded, 0 newly installed, 5 to remove and 96 not upgraded.
              After this operation, 380 MB disk space will be freed.
              Do you want to continue? [Y/n] Y
              (Reading database ... 188197 files and directories currently installed.)
              Removing linux-headers-5.4.0-139-generic (5.4.0-139.156) ...
              Removing linux-headers-5.4.0-139 (5.4.0-139.156) ...
              Removing linux-modules-extra-5.4.0-139-generic (5.4.0-139.156) ...
              Removing linux-image-5.4.0-139-generic (5.4.0-139.156) ...
              /etc/kernel/postrm.d/initramfs-tools:
              update-initramfs: Deleting /boot/initrd.img-5.4.0-139-generic
              /etc/kernel/postrm.d/zz-update-grub:
              Sourcing file `/etc/default/grub'
              Sourcing file `/etc/default/grub.d/init-select.cfg'
              Generating grub configuration file ...
              Found linux image: /boot/vmlinuz-5.4.0-146-generic
              Found initrd image: /boot/initrd.img-5.4.0-146-generic
              Found linux image: /boot/vmlinuz-5.4.0-144-generic
              Found initrd image: /boot/initrd.img-5.4.0-144-generic
              Found linux image: /boot/vmlinuz-5.4.0-137-generic
              Found initrd image: /boot/initrd.img-5.4.0-137-generic
              done
              Removing linux-modules-5.4.0-139-generic (5.4.0-139.156) ...
              nega@ubuntu:~$
              df -h
              nega@ubuntu:~$ df -h
              Filesystem                         Size  Used Avail Use% Mounted on
              udev                               947M     0  947M   0% /dev
              tmpfs                              199M 1016K  198M   1% /run
              /dev/mapper/ubuntu--vg-ubuntu--lv  8.8G  8.0G  362M  96% /
              tmpfs                              992M     0  992M   0% /dev/shm
              tmpfs                              5.0M     0  5.0M   0% /run/lock
              tmpfs                              992M     0  992M   0% /sys/fs/cgroup
              /dev/loop1                          56M   56M     0 100% /snap/core18/2714
              /dev/sda2                          974M  306M  601M  34% /boot
              /dev/loop0                          56M   56M     0 100% /snap/core18/2721
              /dev/loop2                          64M   64M     0 100% /snap/core20/1828
              /dev/loop3                          64M   64M     0 100% /snap/core20/1852
              /dev/loop4                          92M   92M     0 100% /snap/lxd/23991
              /dev/loop5                          92M   92M     0 100% /snap/lxd/24061
              /dev/loop7                          50M   50M     0 100% /snap/snapd/18596
              /dev/loop6                          50M   50M     0 100% /snap/snapd/18357
              tmpfs                              199M     0  199M   0% /run/user/1000
              nega@ubuntu:~$
              crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                362M
                nun bisserl Platz😁
                  @negalein
                  Im npm cache liegt auch gerne viel herum.
                  sudo -H -u iobroker npm cache clear --force
                    crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                    @thomas-braun wenns ne iobroker VM ist/wäre
                      Thomas Braun Most Active @crunchip last edited by
                      @crunchip
                      Stimmt. Hatte ich jetzt angenommen.
                      Und ohne den ganzen Desktopkrempel wäre da auch mehr Platz...
                      crunchip Negalein 2 Replies Last reply Reply Quote 0
                      • Negalein
                        nun bisserl Platz
                        ja, ein bisserl 😁
                        dafür spinnen jetzt ein paar Switche und lassen sich nicht einbinden. 😞
                        nega@ubuntu:~$ sudo -H -u nega npm cache clear --force
                        sudo: npm: command not found
                          @thomas-braun sieht mit eher nach nem unifi controller aus
                          • Negalein
                            ok, das ist schon ewig her. Damals hab ich nicht darauf geachtet.
                            Wie bringt man den Desktop wieder weg?
                            • Negalein
                              Jep, ist er
                              Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                Und der Unifi-Controller ist 8GB schwer?
                                Keine Ahnung was der alles benötigt und anschleppt.
                                crunchip Negalein Dr. Bakterius 3 Replies Last reply Reply Quote 0
                                  @negalein wenn du nicht zurecht kommst, könntest ja auch ein backup vom Controller machen, VM neu aufsetzen und backup wieder einspielen
                                    hatte den mal im LXC laufen, aber 8GB reichen eigentlich locker
                                    • Negalein
                                      ja, das ist der letzte Ausweg.
                                      Sobald die Switche wieder laufen, versuch ich https://indibit.de/ubuntu-partition-vergroessern/
                                      • Negalein
                                        ist das richtig mit init 3, oder wird hier nur umgeschaltet und der Desktop nicht deinstalliert?
                                          @negalein
                                          Da wird nur der Zustand geändert, die Software bleibt dennoch auf dem System.
                                          • Negalein
                                            ok, dachte ich mir. 😞
                                            Kann der Desktop überhaupt nachträglich deinstalliert werden?
                                            In deinem Baukasten steht nur was zum Pi.
                                            3117
