    3. Off Topic
    4. apt full-upgrade Error
    • Negalein
      Negalein Global Moderator @Thomas Braun last edited by
      @thomas-braun sagte in apt full-upgrade Error:
      sudo apt clean
      das lief ohne Error.
      Aber dann noch immer
      sort: write failed: /tmp/sortlztpTO: No space left on device
        Thomas Braun Most Active @Negalein last edited by
        @negalein
        df -h
        • Negalein
          Negalein Global Moderator @crunchip last edited by
          @crunchip sagte in apt full-upgrade Error:
          sudo apt autoremove
          nega@ubuntu:~$ sudo apt autoremove
          Reading package lists... Done
          Building dependency tree
          The following packages will be REMOVED:
            linux-headers-5.4.0-139 linux-headers-5.4.0-139-generic linux-image-5.4.0-139-generic
            linux-modules-5.4.0-139-generic linux-modules-extra-5.4.0-139-generic
          0 upgraded, 0 newly installed, 5 to remove and 96 not upgraded.
          After this operation, 380 MB disk space will be freed.
          Do you want to continue? [Y/n] Y
          (Reading database ... 188197 files and directories currently installed.)
          Removing linux-headers-5.4.0-139-generic (5.4.0-139.156) ...
          Removing linux-headers-5.4.0-139 (5.4.0-139.156) ...
          Removing linux-modules-extra-5.4.0-139-generic (5.4.0-139.156) ...
          Removing linux-image-5.4.0-139-generic (5.4.0-139.156) ...
          /etc/kernel/postrm.d/initramfs-tools:
          update-initramfs: Deleting /boot/initrd.img-5.4.0-139-generic
          /etc/kernel/postrm.d/zz-update-grub:
          Sourcing file `/etc/default/grub'
          Sourcing file `/etc/default/grub.d/init-select.cfg'
          Generating grub configuration file ...
          Found linux image: /boot/vmlinuz-5.4.0-146-generic
          Found initrd image: /boot/initrd.img-5.4.0-146-generic
          Found linux image: /boot/vmlinuz-5.4.0-144-generic
          Found initrd image: /boot/initrd.img-5.4.0-144-generic
          Found linux image: /boot/vmlinuz-5.4.0-137-generic
          Found initrd image: /boot/initrd.img-5.4.0-137-generic
          done
          Removing linux-modules-5.4.0-139-generic (5.4.0-139.156) ...
          nega@ubuntu:~$
          df -h
          nega@ubuntu:~$ df -h
          Filesystem                         Size  Used Avail Use% Mounted on
          udev                               947M     0  947M   0% /dev
          tmpfs                              199M 1016K  198M   1% /run
          /dev/mapper/ubuntu--vg-ubuntu--lv  8.8G  8.0G  362M  96% /
          tmpfs                              992M     0  992M   0% /dev/shm
          tmpfs                              5.0M     0  5.0M   0% /run/lock
          tmpfs                              992M     0  992M   0% /sys/fs/cgroup
          /dev/loop1                          56M   56M     0 100% /snap/core18/2714
          /dev/sda2                          974M  306M  601M  34% /boot
          /dev/loop0                          56M   56M     0 100% /snap/core18/2721
          /dev/loop2                          64M   64M     0 100% /snap/core20/1828
          /dev/loop3                          64M   64M     0 100% /snap/core20/1852
          /dev/loop4                          92M   92M     0 100% /snap/lxd/23991
          /dev/loop5                          92M   92M     0 100% /snap/lxd/24061
          /dev/loop7                          50M   50M     0 100% /snap/snapd/18596
          /dev/loop6                          50M   50M     0 100% /snap/snapd/18357
          tmpfs                              199M     0  199M   0% /run/user/1000
          nega@ubuntu:~$
          crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
            crunchip Forum Testing Most Active @Negalein last edited by
            @negalein sagte in apt full-upgrade Error:
            362M
            nun bisserl Platz😁
              @negalein
              Im npm cache liegt auch gerne viel herum.
              sudo -H -u iobroker npm cache clear --force
                crunchip Forum Testing Most Active @Thomas Braun last edited by crunchip
                @thomas-braun wenns ne iobroker VM ist/wäre
                  Thomas Braun Most Active @crunchip last edited by
                  @crunchip
                  Stimmt. Hatte ich jetzt angenommen.
                  Und ohne den ganzen Desktopkrempel wäre da auch mehr Platz...
                  crunchip Negalein 2 Replies Last reply Reply Quote 0
                  • Negalein
                    nun bisserl Platz
                    ja, ein bisserl 😁
                    dafür spinnen jetzt ein paar Switche und lassen sich nicht einbinden. 😞
                    nega@ubuntu:~$ sudo -H -u nega npm cache clear --force
                    sudo: npm: command not found
                      @thomas-braun sieht mit eher nach nem unifi controller aus
                      • Negalein
                        ok, das ist schon ewig her. Damals hab ich nicht darauf geachtet.
                        Wie bringt man den Desktop wieder weg?
                        • Negalein
                          Jep, ist er
                          Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                            Und der Unifi-Controller ist 8GB schwer?
                            Keine Ahnung was der alles benötigt und anschleppt.
                            crunchip Negalein Dr. Bakterius 3 Replies Last reply Reply Quote 0
                              @negalein wenn du nicht zurecht kommst, könntest ja auch ein backup vom Controller machen, VM neu aufsetzen und backup wieder einspielen
                                hatte den mal im LXC laufen, aber 8GB reichen eigentlich locker
                                • Negalein
                                  ja, das ist der letzte Ausweg.
                                  Sobald die Switche wieder laufen, versuch ich https://indibit.de/ubuntu-partition-vergroessern/
                                  • Negalein
                                    ist das richtig mit init 3, oder wird hier nur umgeschaltet und der Desktop nicht deinstalliert?
                                      @negalein
                                      Da wird nur der Zustand geändert, die Software bleibt dennoch auf dem System.
                                      • Negalein
                                        ok, dachte ich mir. 😞
                                        Kann der Desktop überhaupt nachträglich deinstalliert werden?
                                        In deinem Baukasten steht nur was zum Pi.
                                          Natürlich. Ist aber nicht so ganz trivial. Welcher ist denn da überhaupt am Start?
                                          • Negalein
                                            das seh ich wie?
                                            3385
