    3. Off Topic
    4. apt full-upgrade Error
    • Negalein
      Negalein Global Moderator @Thomas Braun last edited by
      @thomas-braun sagte in apt full-upgrade Error:
      Passiert da nix im log? apt ist eigentlich recht gesprächig.
      doch, quasselt wie ne Oma 😉
      ein sehr kurzer Auszug
      Selecting previously unselected package libcaca0:amd64.
      Preparing to unpack .../334-libcaca0_0.99.beta19-2.1ubuntu1.20.04.2_amd64.deb ...
      Unpacking libcaca0:amd64 (0.99.beta19-2.1ubuntu1.20.04.2) ...
      Selecting previously unselected package libdv4:amd64.
      Preparing to unpack .../335-libdv4_1.0.0-12_amd64.deb ...
      Unpacking libdv4:amd64 (1.0.0-12) ...
      Selecting previously unselected package libgstreamer-plugins-good1.0-0:amd64.
      Preparing to unpack .../336-libgstreamer-plugins-good1.0-0_1.16.3-0ubuntu1.1_amd64.deb ...
      Unpacking libgstreamer-plugins-good1.0-0:amd64 (1.16.3-0ubuntu1.1) ...
      Selecting previously unselected package libiec61883-0:amd64.
      Preparing to unpack .../337-libiec61883-0_1.2.0-3_amd64.deb ...
      Unpacking libiec61883-0:amd64 (1.2.0-3) ...
      Selecting previously unselected package libmp3lame0:amd64.
      Preparing to unpack .../338-libmp3lame0_3.100-3_amd64.deb ...
      Unpacking libmp3lame0:amd64 (3.100-3) ...
      Selecting previously unselected package libmpg123-0:amd64.
      Preparing to unpack .../339-libmpg123-0_1.25.13-1_amd64.deb ...
      Unpacking libmpg123-0:amd64 (1.25.13-1) ...
      Selecting previously unselected package libspeex1:amd64.
      Preparing to unpack .../340-libspeex1_1.2~rc1.2-1.1ubuntu1.20.04.1_amd64.deb ...
      Unpacking libspeex1:amd64 (1.2~rc1.2-1.1ubuntu1.20.04.1) ...
      Selecting previously unselected package libshout3:amd64.
      Preparing to unpack .../341-libshout3_2.4.3-1_amd64.deb ...
      Unpacking libshout3:amd64 (2.4.3-1) ...
      Selecting previously unselected package libtag1v5-vanilla:amd64.
      Preparing to unpack .../342-libtag1v5-vanilla_1.11.1+dfsg.1-0.3ubuntu2_amd64.deb ...
      Unpacking libtag1v5-vanilla:amd64 (1.11.1+dfsg.1-0.3ubuntu2) ...
      Selecting previously unselected package libtag1v5:amd64.
      Preparing to unpack .../343-libtag1v5_1.11.1+dfsg.1-0.3ubuntu2_amd64.deb ...
      Unpacking libtag1v5:amd64 (1.11.1+dfsg.1-0.3ubuntu2) ...
      Selecting previously unselected package libtwolame0:amd64.
      Preparing to unpack .../344-libtwolame0_0.4.0-2_amd64.deb ...
      Unpacking libtwolame0:amd64 (0.4.0-2) ...
      Selecting previously unselected package libv4lconvert0:amd64.
      Preparing to unpack .../345-libv4lconvert0_1.18.0-2build1_amd64.deb ...
      Unpacking libv4lconvert0:amd64 (1.18.0-2build1) ...
      Selecting previously unselected package libv4l-0:amd64.
      Preparing to unpack .../346-libv4l-0_1.18.0-2build1_amd64.deb ...
      Unpacking libv4l-0:amd64 (1.18.0-2build1) ...
      Selecting previously unselected package libvpx6:amd64.
      Preparing to unpack .../347-libvpx6_1.8.2-1build1_amd64.deb ...
      Unpacking libvpx6:amd64 (1.8.2-1build1) ...
      Selecting previously unselected package libwavpack1:amd64.
      Preparing to unpack .../348-libwavpack1_5.2.0-1ubuntu0.1_amd64.deb ...
      Unpacking libwavpack1:amd64 (5.2.0-1ubuntu0.1) ...
      Selecting previously unselected package gstreamer1.0-plugins-good:amd64.
      Preparing to unpack .../349-gstreamer1.0-plugins-good_1.16.3-0ubuntu1.1_amd64.deb ...
      Unpacking gstreamer1.0-plugins-good:amd64 (1.16.3-0ubuntu1.1) ...
      Selecting previously unselected package libxv1:amd64.
      Preparing to unpack .../350-libxv1_2%3a1.0.11-1_amd64.deb ...
      Unpacking libxv1:amd64 (2:1.0.11-1) ...
      Selecting previously unselected package gstreamer1.0-x:amd64.
      Preparing to unpack .../351-gstreamer1.0-x_1.16.3-0ubuntu1.1_amd64.deb ...
      Unpacking gstreamer1.0-x:amd64 (1.16.3-0ubuntu1.1) ...
      Selecting previously unselected package libcheese8:amd64.
      Preparing to unpack .../352-libcheese8_3.34.0-1ubuntu1_amd64.deb ...
      Unpacking libcheese8:amd64 (3.34.0-1ubuntu1) ...
      • Negalein
        gleich ist er wieder tot 😞
        Processing triggers for man-db (2.9.1-1) ...
        /usr/bin/mandb: can't write to /var/cache/man/12626: No space left on device
        /usr/bin/mandb: can't create index cache /var/cache/man/12626: No space left on device
          Thomas Braun Most Active @Negalein last edited by
          @negalein
          Brech den Prozess ab, lösche den apt cache, hoffe das die Datenbank nicht schief ist und hau den xserver raus.
          • Negalein
            Negalein Global Moderator @Thomas Braun last edited by Negalein
            war fertig, hab dann das mit dem x-Server gemacht.
            Dann nochmal sudo apt clean
            nega@ubuntu:~$ df -h
            Filesystem                         Size  Used Avail Use% Mounted on
            udev                               947M     0  947M   0% /dev
            tmpfs                              199M  1.1M  198M   1% /run
            /dev/mapper/ubuntu--vg-ubuntu--lv  8.8G  8.4G     0 100% /
            tmpfs                              992M     0  992M   0% /dev/shm
            tmpfs                              5.0M     0  5.0M   0% /run/lock
            tmpfs                              992M     0  992M   0% /sys/fs/cgroup
            /dev/sda2                          974M  306M  601M  34% /boot
            /dev/loop3                          64M   64M     0 100% /snap/core20/1852
            /dev/loop0                          56M   56M     0 100% /snap/core18/2721
            /dev/loop1                          56M   56M     0 100% /snap/core18/2714
            /dev/loop2                          64M   64M     0 100% /snap/core20/1828
            /dev/loop5                          92M   92M     0 100% /snap/lxd/24061
            /dev/loop4                          92M   92M     0 100% /snap/lxd/23991
            /dev/loop6                          50M   50M     0 100% /snap/snapd/18596
            /dev/loop7                          50M   50M     0 100% /snap/snapd/18357
            tmpfs                              199M     0  199M   0% /run/user/1000
            Sollten eigentl. 400 MB frei sein.
            Sagt aber 0 MB verfügbar.
            Hab jetzt mal einen Reboot gemacht.
            hat nichts gebracht 😞
            Last login: Tue Mar 28 20:35:34 2023 from 10.0.1.31
            /usr/bin/xauth:  unable to write authority file /home/nega/.Xauthority-n
            /dev/loop6                          50M   50M     0 100% /snap/snapd/18357
            /dev/loop7                          50M   50M     0 100% /snap/snapd/18596
            tmpfs                              199M   12K  199M   1% /run/user/117
            tmpfs                              199M  4.0K  199M   1% /run/user/1000
            nega@ubuntu:~$ sudo apt remove xserver-xorg-core
            [sudo] password for nega:
            Reading package lists... Done
            Building dependency tree
            Package 'xserver-xorg-core' is not installed, so not removed
            0 upgraded, 0 newly installed, 0 to remove and 84 not upgraded.
            nega@ubuntu:~$ sudo apt autoremove
            nega@ubuntu:~$
            • Negalein
              Backup eingespielt und etwas gesäubert
              The following packages will be REMOVED:
                linux-headers-5.4.0-139 linux-headers-5.4.0-139-generic linux-image-5.4.0-139-generic linux-modules-5.4.0-139-generic
                linux-modules-extra-5.4.0-139-generic
              0 upgraded, 0 newly installed, 5 to remove and 96 not upgraded.
              After this operation, 380 MB disk space will be freed.
              Do you want to continue? [Y/n] Y
              (Reading database ... 188197 files and directories currently installed.)
              Removing linux-headers-5.4.0-139-generic (5.4.0-139.156) ...
              Removing linux-headers-5.4.0-139 (5.4.0-139.156) ...
              Removing linux-modules-extra-5.4.0-139-generic (5.4.0-139.156) ...
              Removing linux-image-5.4.0-139-generic (5.4.0-139.156) ...
              /etc/kernel/postrm.d/initramfs-tools:
              update-initramfs: Deleting /boot/initrd.img-5.4.0-139-generic
              /etc/kernel/postrm.d/zz-update-grub:
              Sourcing file `/etc/default/grub'
              Sourcing file `/etc/default/grub.d/init-select.cfg'
              Generating grub configuration file ...
              Found linux image: /boot/vmlinuz-5.4.0-146-generic
              Found initrd image: /boot/initrd.img-5.4.0-146-generic
              Found linux image: /boot/vmlinuz-5.4.0-144-generic
              Found initrd image: /boot/initrd.img-5.4.0-144-generic
              Found linux image: /boot/vmlinuz-5.4.0-137-generic
              Found initrd image: /boot/initrd.img-5.4.0-137-generic
              done
              Removing linux-modules-5.4.0-139-generic (5.4.0-139.156) ...
              tmpfs                              199M 1016K  198M   1% /run
              /dev/mapper/ubuntu--vg-ubuntu--lv  8.8G  7.9G  460M  95% /
              Morgen dann mit hier dann vergrößern.
                Thomas Braun Most Active last edited by
                @negalein
                Gerade nochmal geschaut. Das Paket heißt bei Ubuntu xorg.
                sudo apt remove xorg
                • Dr. Bakterius
                  Dr. Bakterius Most Active @Thomas Braun last edited by
                  @thomas-braun, @Negalein Bei mir reichen für den Unifi-Controller 3 GB. Da hat es also definitiv etwas anderes.
                  • Dr. Bakterius
                    Dr. Bakterius Most Active @Negalein last edited by
                    @negalein Warum sicherst du die Einstellungen (und Statistiken) nicht einfach, setzt alles neu auf und spielst das Backup wieder zurück?
                    Negalein 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @Dr. Bakterius last edited by Thomas Braun
                      @dr-bakterius sagte in apt full-upgrade Error:
                      Ja, sowas um den Dreh würde ich in einer 'rohen' VM erwarten, in der sonst nichts anderes noch mitläuft. Ohne Desktop-Overhead dann auch nochmal deutlich weniger.
                      • Negalein
                        Negalein Global Moderator @Dr. Bakterius last edited by
                        habe ich für heute geplant.
                        Und dann gleich in einem Proxmox LXC und weg von Synology VM.
                        • Dr. Bakterius
                          Dr. Bakterius Most Active @Thomas Braun last edited by Dr. Bakterius
                          @Thomas-Braun Bei mir ist kein Desktop installiert - wozu auch? Leider habe ich oben RAM und HD verwechselt. Die HD ist mit 5 GB belegt (wobei die logs fast 1 GB ausmachen und die Backups und der Cache ein weiteres GB). Also doch gut 3 GB. 😏
                          • Negalein
                            Servus
                            Da du auch Unifi hast, könntest du mir eventuell eine Frage beantworten. 😉
                            Wenn ich den LXC aufsetze und den Controller installiere, muss beim Restore der alte Controller aus sein?
                            Und muss der neue Controller die selbe IP wie der alte haben?
                            • Dr. Bakterius
                              @negalein sagte in apt full-upgrade Error:
                              Es kommt darauf an. Siehe weiter unten wie ich das meine.
                              Müssen nicht. Du wirst deine Unifi-Geräte (wahrscheinlich auch bei gleicher IP) im neuen Controller adoptieren müssen. Daher davor die Geräte mit dem alten Controller zurücksetzen. Dann sollten sie bereit sein sich mit dem neuen Controller zu verbinden. Falls das nicht klappt, kann man sich auch per Console mit dem Gerät verbinden und dort die Adoption anstoßen. Wie das geht findest du sicher über eine Suchmaschine.
                              Aber du kannst es auch mit der gleichen IP versuchen. Dann sind sie vielleicht gleich automatisch verbunden. Da darf dann der alte Controller aber natürlich nicht mehr laufen.
                              Ich musste die Restore-Funktion zum Glück noch nie verwenden.
                              3117
