    4. Got unexpected ID: hm-rega -Benötige Hilfe
      Tomate @Homoran last edited by
      Hier mal der LOG Inhalt vom iobroker um diesen Zeitraum.
      hm-rega.0 2023-03-30 14:46:44.080	warn	Script "dom.GetObject(3914).State(false)" ignored, because still pending.
      hm-rega.0 2023-03-30 14:30:13.513	warn	Script "dom.GetObject(3914).State(false)" ignored, because still pending.
      hm-rega.0 2023-03-30 14:30:13.510	warn	Script "dom.GetObject(2908).State(false)" ignored, because still pending.
      hm-rega.0 2023-03-30 13:56:35.064	warn	Script "dom.GetObject(3914).State(false)" ignored, because still pending.
      hm-rega.0 2023-03-30 13:56:35.061	warn	Script "dom.GetObject(2908).State(false)" ignored, because still pending.
      hm-rega.0 2023-03-30 13:45:09.359	warn	Script "dom.GetObject(3914).State(false)" ignored, because still pending.
      hm-rega.0 2023-03-30 13:36:07.929	warn	Script "dom.GetObject(3914).State(false)" ignored, because still pending.
      hm-rega.0 2023-03-30 13:36:07.927	warn	Script "dom.GetObject(2908).State(false)" ignored, because still pending.
      hm-rega.0 2023-03-30 13:10:28.930	info	deleted 0 programs
      hm-rega.0 2023-03-30 13:10:28.929	info	added/updated 13 programs
      hm-rega.0 2023-03-30 13:10:28.898	info	got 12 programs
      hm-rega.0 2023-03-30 13:10:28.880	info	Program received for not-known dp 4571, requesting programs
      hm-rega.0 2023-03-30 12:15:07.757	warn	Script "dom.GetObject(3914).State(false)" ignored, because still pending.
      hm-rega.0 2023-03-30 11:54:33.784	warn	Script "dom.GetObject(3914).State(false)" ignored, because still pending.
      hm-rega.0 2023-03-30 11:54:33.779	warn	Script "dom.GetObject(2908).State(false)" ignored, because still pending.
      hm-rega.0 2023-03-30 11:54:33.775	warn	Script "dom.GetObject(3913).State(false)" ignored, because still pending.
      Wo finde ich nochmal die Log Einträge der CCU?
        Homoran Global Moderator Administrators @Tomate last edited by
        @tomate was sind das für zwei Skripts und warum hängen diese beiden?
        das ccu log müsste unter Systemeinstellungen zu finden sein
          @homoran said in Got unexpected ID: hm-rega -Benötige Hilfe:
          Was, bzw. wo sind zwei Skripts?
          Im Systemprotokoll steht seit dem 27.03 nichts mehr drin.
            @tomate sagte in Got unexpected ID: hm-rega -Benötige Hilfe:
            oder was ist das
              Ich weiß nicht genau was du meist....
              Ich habe, scheinbar, diese vier Skripte, die eine Warnung ausgeben.
              2908
              3039
              3913
              3914
                @homoran sagte in Got unexpected ID: hm-rega -Benötige Hilfe:
                  Ich weiß nicht mal ob die Skripte hängen. Im Prinzip funktioniert alles wie es soll. Nur die Warnungen hätte ich gerne beseitigt, bzw. ich hätte gerne gewusst was sie bedeuten.
                    die Skripte hängen
                    bzw. die Anfrage(?) danach wird ausgesetzt, weil die letzte noch nicht bearbeitet wurde
                      .... dann ist die Ursache in der CCU?
                      Die kommt nicht hinterher oder so?
                        so was in der Art vermute ich.
                        deswegen die Frage was das für Skripte sind, was sie tun.
                        oder was hatces mit dem jeweils aufgerufenen objekt (domgetobject) auf sich?
                          Das Skript schaltet das Display von einen Thermostat um.
                            @tomate und du veränderst die sysvar über iobroker?
                            sei doch nicht so schreibfaul
                              Ich nutzte das Thermostat nur zum Temperatur "einsammeln". Die Hysterese - Verarbeitung mache im iobroker.
                              Deshalb macht ich auch die Displayumschaltung, wenn ich den Temperatursollwet zum Beispiel über VIS geändert habe, über den iobroker.
                                jetzt sind wir wieder ganz am Anfang!
                                hm-rega.0 2023-03-28 10:27:13.275 warn Got unexpected ID: hm-rega.0.2908
                                und ja, es sind Datenpunkte von Systemvariablen, die du änderst
                                Bitte lies dir alles nochmal durch, bevor wir hier im Kreis laufen und ich dir alles aus der Nase ziehen muss.
                                Bring mal Ordnung da rein und gehe das ganze strukturiert an!
                                  Des Rätsels Lösung war, dass ich auf die Systemvariable der Homematic im Sekundentakt neue Werte abgeben wollte.
                                  Das hat die Homematic, ab und zu, nicht mitgemacht. Daher die Warnung im Protokoll vom iobroker.
                                  Danke für die Hinweise. Ohne die wäre ich da nie drauf gekommen.
                                  Schönen Sonntag (-:
                                  Diese Thema kann geschlossen werden.
                                    das hab ich von Anfang an vermutet.
                                    1333
