    2. Русский
    3. ioBroker
    4. Скрипты
    5. ioBroker скрипты
    6. Скрипт для счётчика
    Скрипт для счётчика
      smoker_vvo last edited by
      Убейте меня!!! ОН НЕ РАБОТАЕТ….. Ну не пингуется этот ip, я поменял на свои......
      • I
        instalator last edited by
        @smoker_vvo:
        Убейте меня!!! ОН НЕ РАБОТАЕТ….. Ну не пингуется этот ip, я поменял на свои...... `
        библиотеки последних версии?
          Начнем с простого…. Какая IDE
            в IDE 1.5.2 гружу вот этот скетч:
            Web Server
            A simple web server that shows the value of the analog input pins.
            using an Arduino Wiznet Ethernet shield.
            Circuit:
            • Ethernet shield attached to pins 10, 11, 12, 13
            • Analog inputs attached to pins A0 through A5 (optional)
            created 18 Dec 2009
            by David A. Mellis
            modified 9 Apr 2012
            by Tom Igoe
            ! #include <spi.h>#include <ethernet.h>// Enter a MAC address and IP address for your controller below.
            // The IP address will be dependent on your local network:
            byte mac[] = {
            0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
            IPAddress ip(192,168,0, 89);
            ! // Initialize the Ethernet server library
            // with the IP address and port you want to use
            // (port 80 is default for HTTP):
            EthernetServer server(80);
            ! void setup() {
            // Open serial communications and wait for port to open:
            Serial.begin(9600);
            while (!Serial) {
            ; // wait for serial port to connect. Needed for Leonardo only
            ! // start the Ethernet connection and the server:
            Ethernet.begin(mac, ip);
            server.begin();
            Serial.print("server is at ");
            Serial.println(Ethernet.localIP());
            ! void loop() {
            // listen for incoming clients
            EthernetClient client = server.available();
            if (client) {
            Serial.println("new client");
            // an http request ends with a blank line
            boolean currentLineIsBlank = true;
            while (client.connected()) {
            if (client.available()) {
            char c = client.read();
            Serial.write(c);
            // if you've gotten to the end of the line (received a newline
            // character) and the line is blank, the http request has ended,
            // so you can send a reply
            if (c == '\n' && currentLineIsBlank) {
            // send a standard http response header
            client.println("HTTP/1.1 200 OK");
            client.println("Content-Type: text/html");
            client.println("Connection: close");
            client.println();
            client.println("");
            client.println("");
            // add a meta refresh tag, so the browser pulls again every 5 seconds:
            client.println("");
            // output the value of each analog input pin
            for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("
            client.println("");
            break;
            if (c == '\n') {
            // you're starting a new line
            else if (c != '\r') {
            // you've gotten a character on the current line
            currentLineIsBlank = false;
            // give the web browser time to receive the data
            delay(1);
            // close the connection:
            client.stop();
            Serial.println("client disonnected");
            }</ethernet.h></spi.h>
            Пинг - отличный, и веб пускает,
              в 1ю8ю2 - тоже проблем нет…...
                1ю6ю13 - полет нормальный
                и 1.0.6 - работает…...
                  IDE 1.6.13 этот скетч - работает, все пингуется и данные идут
                  `#include <spi.h> // Ethernet shield
                  #include <ethernet.h> // Ethernet shield
                  #include <pubsubclient.h> // MQTT
                  #include <servo.h>
                  #include <dht.h>
                  #include <onewire.h>
                  #include <dallastemperature.h>
                  Servo servo;
                  ! byte mac[] = { 0xC1, 0x7C, 0x38, 0x41, 0x89, 0x35 };
                  byte server[] = { 192, 168, 0, 11 }; //IP Брокера
                  byte ip[] = { 192, 168, 0, 89 }; //IP Клиента (Arduino)
                  void callback(char* topic, byte* payload, unsigned int length) {
                  payload[length] = '\0';
                  // Serial.print(topic);
                  // Serial.print("=");
                  String strTopic = String(topic);
                  String strPayload = String((char*)payload);
                  // Serial.println(strPayload);
                  callback_iobroker(strTopic, strPayload);
                  ! EthernetClient ethClient;
                  PubSubClient client(server, 1883, callback, ethClient);
                  #define id_connect "myhome-temp"
                  #define id_connect "myhome-status"
                  #define Prefix_subscribe "myhome/Temp/"
                  #define Prefix_subscribe "myhome/Status/"
                  ! ///////////////Объявляем порты ввода-вывода
                  #define ServoPin 3 //Порт к которому подключен сервопривод
                  ! const int start_DI_pin []= {2, 4, 5}; // Порты Ввода
                  int n_DI_pin = sizeof(start_DI_pin) / sizeof(start_DI_pin[0])-1; //Вычисляем длинну массива
                  ! const int start_DO_pin []= {6, 7}; //Порты Вывода
                  int n_DO_pin = sizeof(start_DO_pin) / sizeof(start_DO_pin[0])-1; //Вычисляем длинну массива
                  ! int DI[] = {0, 0, 0};
                  int old_DI[] = {0, 0, 0};
                  ! ///////////////////////////Переменные для работы с освещением//////////////////////////////////////
                  int ServoAngle = 100; //Угол сервопривода при включении
                  int flag = 0;
                  int flag2 = 0;
                  int pause = 0;
                  ! //------------------------------------------- Sensors -------------------------------------------//
                  const int MQ7_Pin = A0; // Куда подключили MQ7
                  //int MQ7Value = 0;
                  int MQ7Value = analogRead(MQ7_Pin);
                  const int foto_Pin = A1; // устанавливаем входную ногу для Фоторезистора
                  //unsigned int fotoValue = 0; // цифровое значение фоторезистора
                  unsigned int fotoValue = analogRead(foto_Pin);
                  ! #define ONE_WIRE_BUS 8
                  //#define TEMPERATURE_PRECISION 9
                  OneWire oneWire(ONE_WIRE_BUS);
                  DallasTemperature DS_sensors(&oneWire);
                  // 28 80 E9 3A 04 00 00 10
                  //T0:28 88 AD D7 02 00 00 42
                  //T1:28 14 A5 D7 02 00 00 B0
                  //T2:28 72 26 7B 04 00 00 2E
                  //T3:28 CA 1A 3B 04 00 00 CD
                  //T4:28 E6 D5 D7 02 00 00 C1
                  //T5:28 16 B4 7A 04 00 00 8A
                  //T6:28 2B 86 D7 02 00 00 CF
                  //T7:28 AB 9D D7 02 00 00 29
                  DeviceAddress addr_T1 = { 0x28, 0x80, 0xE9, 0x3A, 0x4, 0x0, 0x0, 0x10 };//кладовка
                  DeviceAddress addr_T2 = { 0x28, 0x88, 0xAD, 0xD7, 0x2, 0x0, 0x0, 0x42 };//кухня
                  DeviceAddress addr_T3 = { 0x28, 0x14, 0xA5, 0xD7, 0x2, 0x0, 0x0, 0xB0 };//детская
                  DeviceAddress addr_T4 = { 0x28, 0x72, 0x26, 0x7B, 0x4, 0x0, 0x0, 0x2E };//гараж
                  DeviceAddress addr_T5 = { 0x28, 0xCA, 0x1A, 0x3B, 0x4, 0x0, 0x0, 0xCD };//ванная
                  DeviceAddress addr_T6 = { 0x28, 0xE6, 0xD5, 0xD7, 0x2, 0x0, 0x0, 0xC1 };//улица
                  DeviceAddress addr_T7 = { 0x28, 0x16, 0xB4, 0x7A, 0x4, 0x0, 0x0, 0x8A };//спальня2
                  DeviceAddress addr_T8 = { 0x28, 0x2B, 0x86, 0xD7, 0x2, 0x0, 0x0, 0xCF };//зал
                  DeviceAddress addr_T9 = { 0x28, 0xAB, 0x9D, 0xD7, 0x2, 0x0, 0x0, 0x29 };//мансарда
                  ! float T1=0;
                  float T2=0;
                  float T3=0;
                  float T4=0;
                  float T5=0;
                  float T6=0;
                  float T7=0;
                  float T8=0;
                  float T9=0;
                  ! //dht DHT;
                  //#define DHT22_PIN 9
                  //float Hout = 0;
                  //float Tout = 0;
                  //void callback(char* topic, byte* payload, unsigned int length) {
                  // payload[length] = '\0';
                  // String strTopic = String(topic);
                  // String strPayload = String((char*)payload);
                  // callback_iobroker(strTopic, strPayload);
                  void setup() {
                  Serial.begin(57600);
                  Serial.println("start");
                  Serial.print("Locating devices...");
                  DS_sensors.begin();
                  Serial.print("Found ");
                  Serial.print(DS_sensors.getDeviceCount(), DEC);
                  Serial.println(" devices.");
                  ! // report parasite power requirements
                  Serial.print("Parasite power is: ");
                  if (DS_sensors.isParasitePowerMode()) Serial.println("ON");
                  else Serial.println("OFF");
                  //Объявляем порты Digital inputs/outputs
                  for(int i=0 ;i<=n_DI_pin; i++) { pinMode (start_DI_pin [i], INPUT); }
                  digitalWrite(5, HIGH); //Насос скважины
                  digitalWrite(4, HIGH); //Электрика
                  for(int i=0 ;i<=n_DO_pin; i++) { pinMode (start_DO_pin [i], OUTPUT); }
                  ! Ethernet.begin(mac, ip);
                  if (client.connect(id_connect)) {
                  getSensors();
                  control();
                  //client.publish("myhome/Kitchen/Change_Counter", "0");
                  //client.publish("myhome/Kitchen/Temp_room", "0");
                  //client.publish("myhome/Kitchen/Humidity_room", "0");
                  client.publish("myhome/Temp/Kladovka", "0");
                  client.publish("myhome/Temp/Kitchen", "0");
                  client.publish("myhome/Temp/Detskaya", "0");
                  client.publish("myhome/Temp/Garage", "0");
                  client.publish("myhome/Temp/Street", "0");
                  client.publish("myhome/Temp/Spalnya2", "0");
                  client.publish("myhome/Temp/Zal", "0");
                  client.publish("myhome/Temp/Mansarda", "0");
                  client.publish("myhome/Temp/Vannaya", "0");
                  //client.publish("myhome/Kitchen/Lux", "0");
                  //client.publish("myhome/Kitchen/Servo", "0");
                  client.publish("myhome/Temp/MQ7", "0");
                  client.publish("myhome/Status/Power", "0");
                  client.publish("myhome/Status/Pompe", "0");
                  client.subscribe("myhome/Temp/#");
                  client.subscribe("myhome/Status/#");
                  void loop() {
                  client.loop();
                  control();
                  getSensors();
                  if (!client.connected()) {
                  control();
                  getSensors();
                  }</dallastemperature.h></onewire.h></dht.h></servo.h></pubsubclient.h></ethernet.h></spi.h>`
                  ! А заливаем этот - и ни чего....
                  ! >! [spoiler]`[code]#include <spi.h>
                  #include <eeprom.h>
                  //#include <avr wdt.h="">
                  ! #define PWR_CTRL A2 //Контроль напряжения
                  #define LED 9 //Светодиод
                  #define CHK_ADR 100
                  #define CNT_ADR 10
                  #define PWR_ADR 20
                  #define POLL_ADR 30
                  #define RATIO_ADR 40
                  ! const char* topic_err = "myhome/test/error";
                  const char* topic_cnt = "myhome/test/count";
                  const char* topic_pwr = "myhome/test/power";
                  const char* topic_amp = "myhome/test/amp";
                  const char* topic_save = "myhome/test/save";
                  const char* topic_correction = "myhome/test/correction";
                  const char* topic_connection = "myhome/test/connection";
                  const char* topic_ip = "myhome/test/config/ip";
                  const char* topic_polling = "myhome/test/config/polling";
                  const char* topic_bounce = "myhome/test/config/bounce";
                  const char* topic_num = "myhome/test/config/num";
                  const char* topic_reset = "myhome/test/config/reset";
                  const char* topic_raw = "myhome/test/RAW";
                  const char* subscr = "myhome/test/#";
                  ! byte mac[] = { 0xDE, 0xA3, 0xBE, 0xE4, 0xDE, 0x35 };
                  byte ip[] = { 192, 168, 0, 89};
                  byte server[] = { 192, 168, 0, 15};
                  ! unsigned long cnt = 0;
                  unsigned long prev_cnt = 2;
                  unsigned long pwr = 0;
                  unsigned long prev_pwr = 2;
                  int amp = 0;
                  int prev_amp = 2;
                  int num = 0;
                  int prev_num;
                  int bounce = 10;
                  int prev_bounce;
                  int chk = 0;
                  int chk_S = 0;
                  unsigned long prevMillis = 0;
                  unsigned long prevMillis_cnt = 0;
                  int poll = 5000;
                  bool error = 0;
                  String cmd = "";
                  bool strComplete = false;
                  char buf [50];
                  char buffer[100];
                  char s[16];
                  PubSubClient client(ethClient);
                  ! void setup() {
                  //MCUSR = 0;
                  // wdt_disable();
                  Serial.println("WDT_disable");
                  cmd.reserve(100);
                  delay(10000);
                  Serial.println("Starting......");
                  ! if (EEPROM.read(1) != 99) { //Если первый запуск
                  EEPROM.write(1, 99);
                  for (int i = 0 ; i < 4; i++) {
                  EEPROM.write(110 + i, ip[i]);
                  EEPROM.write(120 + i, server[i]);
                  } else {
                  chk = EEPROMReadInt(CHK_ADR);
                  cnt = EEPROMReadLong(CNT_ADR);
                  poll = EEPROMReadInt(POLL_ADR);
                  chk_S = poll - 500;
                  if (chk != chk_S) {
                  error = 2;
                  for (int i = 0; i < 4; i++) {
                  ip[i] = EEPROM.read(110 + i);
                  server[i] = EEPROM.read(120 + i);
                  ! pinMode(LED, OUTPUT);
                  ! client.setServer(server, 1883);
                  client.setCallback(callback);
                  delay(200);
                  //wdt_enable(WDTO_8S);
                  Serial.println("WDTO_8S");
                  if (client.connect("test")){
                  digitalWrite(LED, LOW);
                  Public();
                  ! void serialEvent() {
                  while (Serial.available() > 0) {
                  char inChar = (char)Serial.read();
                  cmd += inChar;
                  if (inChar == '\n') {
                  strComplete = true;
                  ! void loop() {
                  // wdt_reset();
                  Serial.println("WDT_reset");
                  client.loop();
                  reconnect();
                  ! /if (analogRead(PWR_CTRL) < 1000) {
                  save();
                  delay(10000);
                  ! if (strComplete) {
                  digitalWrite(LED, !digitalRead(LED));
                  cmd.toCharArray(buffer, 100);
                  cnt = atoi(strtok(buffer, ";"));
                  pwr = atoi(strtok(NULL, ";"));
                  amp = atoi(strtok(NULL, ";"));
                  bounce = atoi(strtok(NULL, ";"));
                  num = atoi(strtok(NULL, ";"));
                  error = atoi(strtok(NULL, ";"));
                  client.publish(topic_raw, StrToChar(cmd));
                  cmd = "";
                  ! if (millis() - prevMillis >= poll) {
                  // wdt_reset();
                  Serial.println("WDT_reset-");
                  prevMillis = millis();
                  if (cnt != prev_cnt || pwr != prev_pwr || amp != prev_amp) {
                  prev_cnt = cnt;
                  prev_pwr = pwr;
                  prev_amp = amp;
                  client.publish(topic_cnt, IntToChar(cnt));
                  client.publish(topic_pwr, IntToChar(pwr));
                  client.publish(topic_amp, IntToChar(amp));
                  if (num != prev_num || bounce != prev_bounce) {
                  prev_num = num;
                  prev_bounce = bounce;
                  client.publish(topic_num, IntToChar(num));
                  client.publish(topic_bounce, IntToChar(bounce));
                  if (error > 0) {
                  client.publish(topic_err, "err");
                  } else {
                  client.publish(topic_err, " ");
                  ! void callback_iobroker(String strTopic, String strPayload) {
                  if (strTopic == topic_correction) {
                  cnt = atol((strPayload).c_str());
                  Serial.print("SC");
                  Serial.println(cnt);
                  client.publish(topic_correction, "0");
                  else if (strTopic == topic_save) {
                  if (strPayload == "true") {
                  Serial.println("SS");
                  save();
                  client.publish(topic_save, "false");
                  else if (strTopic == topic_polling) {
                  poll = strPayload.toInt();
                  if (poll < 1000) {
                  poll = 1000;
                  } else if (poll > 32767) {
                  poll = 32767;
                  EEPROMWriteInt(POLL_ADR, poll); //Интервал публикации
                  client.publish(topic_polling, IntToChar(poll));
                  else if (strTopic == topic_reset) {
                  client.publish(topic_reset, "false");
                  // reboot();
                  Serial.println("Reboot");
                  else if (strTopic == topic_bounce) {
                  bounce = strPayload.toInt();
                  if (bounce < 0) {
                  bounce = 0;
                  } else if (bounce > 10000) {
                  bounce = 10000;
                  Serial.print("SB");
                  Serial.println(bounce);
                  else if (strTopic == topic_num) {
                  num = strPayload.toInt();
                  if (num < 0) {
                  num = 0;
                  } else if (num > 32767) {
                  num = 32767;
                  Serial.print("SN");
                  Serial.println(num);
                  ! void save() {
                  chk = poll - 500;
                  EEPROMWriteLong(CNT_ADR, cnt); //Пишем показания счетчика в eeprom из переменной
                  EEPROMWriteInt(CHK_ADR, chk); //чек
                  ! void reboot() {
                  //save();
                  //delay(500);
                  // wdt_enable(WDTO_1S);
                  Serial.println("void reboot");
                  //for (;;) {}
                  ! char* StrToChar (String str) {
                  int length = str.length();
                  str.toCharArray(buf, length + 1);
                  return buf;
                  ! void EEPROMWriteLong(int p_address, unsigned long p_value) {
                  byte four = (p_value & 0xFF);
                  byte three = ((p_value >> 😎 & 0xFF);
                  byte two = ((p_value >> 16) & 0xFF);
                  byte one = ((p_value >> 24) & 0xFF);
                  EEPROM.write(p_address, four);
                  EEPROM.write(p_address + 1, three);
                  EEPROM.write(p_address + 2, two);
                  EEPROM.write(p_address + 3, one);
                  ! unsigned long EEPROMReadLong(int p_address) {
                  long four = EEPROM.read(p_address);
                  long three = EEPROM.read(p_address + 1);
                  long two = EEPROM.read(p_address + 2);
                  long one = EEPROM.read(p_address + 3);
                  return ((four << 0) & 0xFF) + ((three << 😎 & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
                  ! void EEPROMWriteInt(int p_address, int p_value) {
                  byte lowByte = ((p_value >> 0) & 0xFF);
                  byte highByte = ((p_value >> 😎 & 0xFF);
                  EEPROM.write(p_address, lowByte);
                  EEPROM.write(p_address + 1, highByte);
                  unsigned int EEPROMReadInt(int p_address) {
                  byte lowByte = EEPROM.read(p_address);
                  byte highByte = EEPROM.read(p_address + 1);
                  return ((lowByte << 0) & 0xFF) + ((highByte << 😎 & 0xFF00);
                  ! char* IntToChar (unsigned long a) {
                  sprintf(buf, "%lu", a);
                  return buf;
                  ! void Public() {
                  sprintf(s, "%d.%d.%d.%d", ip[0], ip[1], ip[2], ip[3]);
                  client.publish(topic_connection, "true");
                  client.publish(topic_ip, s);
                  client.subscribe(subscr);
                  void reconnect() {
                  int a = 0;
                  while (!client.connected()) {
                  a++;
                  //wdt_reset();
                  Serial.println("WDT reset");
                  if (client.connect("test")) {
                  Public();
                  } else {
                  delay(10000);
                  if (a >= 10) {
                  Serial.println("WDTO_1S");
                  }</avr></eeprom.h></pubsubclient.h></ethernet.h></spi.h>`
                  ! Ни пинга, ни данных....[/i][/i][/i][/i][/code][/spoiler][/i][/i]
                  • I
                    @smoker_vvo:
                    Начнем с простого…. Какая IDE `
                    ide 1.8.3
                    Ethernet 1.1.2
                    PubSubCliet 2.6.0
                      IDE 1.8.4, остальное совпадает…...
                      Хорошо, с программным уровнем разобрались. Теперь аппаратный.... Arduino MEGA 2560+EthernetShield W5100
                      • I
                        @smoker_vvo:
                        Хорошо, с программным уровнем разобрались. Теперь аппаратный.... Arduino MEGA 2560+EthernetShield W5100 `
                        Да какая разница какая ардуина, я на УНО и W5100 проверял
                          Хлебнуфф пивка и выкурив сигаретку, психанул и заменил Arduino MEGA на Arduino NANO- и О ЧУДО!!!! Все заработало…...
                          Теперь другие вопросы....
                          в строке RAW получаю такие значения 268494237;4294935483;0;-9325;-120;0, как их разобрать?? Что есть что??
                            ан все таки есть… Щас сборка выглядит так :
                            Нано собирает инфу от счетчика - УНО обрабатывает - В5100 - отдает на Брокера
                            В предыдущем вопле ошибочка, Мега заменил на УНО
                            • I
                              @smoker_vvo:
                              в строке RAW получаю такие значения 268494237;4294935483;0;-9325;-120;0, как их разобрать?? Что есть что?? `
                              https://github.com/instalator/Electro_C … t.ino#L278
                              https://blog.instalator.ru/archives/711
                              cnt = atoi(strtok(buffer, ";")); //счетчик
                              pwr = atoi(strtok(NULL, ";")); //мощность
                              amp = atoi(strtok(NULL, ";")); //сила тока!
                              bounce = atoi(strtok(NULL, ";")); //задержка от дребезга
                              num = atoi(strtok(NULL, ";")); //Значение передаточного числа счетчика. Количество импульсов на 1 кВт*ч
                              error = atoi(strtok(NULL, ";")); //ошибка
                              • I
                                По скрипту для счетчика меркурий вынес в отдельную тему http://forum.iobroker.net/viewtopic.php?f=26&t=8148
                                  Зенкую! Я так и понял. Но проект заглох… проработав два часа......
                                  и повторно запустить не удалось....
                                  Не могу понять по чему........
                                    Вопрос не в тему, но не знаю куда закинуть.
                                    Есть более важные задачи - наполнение септика..
                                    Для контроля использую следующий скетч:
                                    #define Trig 9
                                    #define Echo 8
                                    #define ledPin 13
                                    ! void setup()
                                    pinMode(Trig, OUTPUT); //инициируем как выход
                                    pinMode(Echo, INPUT); //инициируем как вход
                                    pinMode(ledPin, OUTPUT);
                                    Serial.begin(9600);
                                    /* задаем скорость общения. В нашем случае с компьютером /
                                    unsigned int impulseTime=0;
                                    unsigned int distance_sm=0;
                                    ! void loop()
                                    digitalWrite(Trig, HIGH);
                                    Подаем импульс на вход trig дальномера */
                                    delayMicroseconds(10); // равный 10 микросекундам
                                    digitalWrite(Trig, LOW); // Отключаем
                                    impulseTime=pulseIn(Echo, HIGH); // Замеряем длину импульса
                                    distance_sm=impulseTime/58; // Пересчитываем в сантиметры
                                    Serial.println(distance_sm); // Выводим на порт
                                    if (distance_sm<50) // Если расстояние менее 30 сантиметром
                                    digitalWrite(ledPin, HIGH); // Светодиод горит
                                    else
                                    digitalWrite(ledPin, LOW); // иначе не горит
                                    delay(10000);
                                    Подскажите как загнать его в Брокер,
                                    хочется через MQTT
                                    Для температуры использую вот это:
                                    #include <servo.h>
                                    #include <dht.h>
                                    Servo servo;
                                    int flag = 0;
                                    int flag2 = 0;
                                    int pause = 0;
                                    //int MQ7Value = 0;
                                    >! float T1=0;
                                    float T2=0;
                                    float T3=0;
                                    float T4=0;
                                    float T5=0;
                                    float T6=0;
                                    float T7=0;
                                    float T8=0;
                                    float T9=0;
                                    >! //dht DHT;
                                    //float Hout = 0;
                                    //float Tout = 0;
                                    void setup() {
                                      DS_sensors.begin();
                                        getSensors();
                                        control();
                                    void loop() {
                                      client.loop();
                                      control();
                                      getSensors();
                                          control();
                                          getSensors();
                                    И это Function
                                    >! >! ~~[spoiler]~~`~~[code]~~//--------------------------------- Functions ---------------------------------//
                                    /////////////////////////////////От Брокера//////////////////////////////////////////////
                                    void callback_iobroker(String strTopic, String strPayload){
                                      if (strTopic == "myhome/Kitchen/Servo"){
                                            ServoAngle=strPayload.toInt();
                                        if (ServoAngle >= 0 && ServoAngle <= 255){
                                              servo.attach(ServoPin);
                                              //delay(200); //ждем 2 секунды
                                              servo.write(ServoAngle); //ставим вал под 0
                                              delay(1000); //ждем 2 секунды
                                              //client.publish("myhome/Kitchen/Servo", b);
                                              servo.detach();
                                    >! ////////////////////////////////////Брокеру/////////////////////////////////////
                                    void control(){
                                           if(digitalRead(5)==HIGH && flag==0) { //если насос включен
                                              client.publish("myhome/Status/Pompe", "1");
                                              flag=1;
                                           if(digitalRead(5)==LOW && flag==1){//если насос выключен
                                            flag=0;//обнуляем переменную flag
                                           if(digitalRead(4)==HIGH && flag2==0) { // Если электрика есть
                                              client.publish("myhome/Status/Power", "1");
                                              flag2=1;
                                           if(digitalRead(4)==LOW && flag2==1){// Если эректрики нет
                                            flag2=0;//обнуляем переменную flag
                                    ///////////////////////////////Данные сенсоров////////////////////////////////////
                                    >! void getSensors () {
                                    >!   MQ7Value = analogRead(MQ7_Pin);
                                      fotoValue = analogRead(foto_Pin);  // считываем значение с фоторезистора
                                    // ServoAngle = analogRead(2);
                                    >! //Обработка данных датчика DHT22\. Подключение к порту цифровому P9 Arduino
                                    //Глобальные переменные Hout и Tout типа флоат - влажность (%) и температура (град. С)
                                    //  if (DHT.read22(DHT22_PIN)== DHTLIB_OK) {
                                    //    Hout = DHT.humidity;
                                    //    Tout = DHT.temperature;
                                    //  if (Hout == 0 || Tout == 0){
                                    //    delay (1000);
                                      //Обработка данных цифровых датчиков температуры типа DS18B20.
                                      //Шина 1-Wire на цифровой пин P8 Arduino.
                                      //Подключено 2 датчика температуры, адреса задаются в секции глобальных констант "Sensors"
                                      //Три значение температуры T1, T2, типа float (град. С).
                                      DS_sensors.setResolution(addr_T1, 9);
                                      DS_sensors.setResolution(addr_T2, 9);
                                      DS_sensors.setResolution(addr_T3, 9);
                                      DS_sensors.setResolution(addr_T4, 9);
                                      DS_sensors.setResolution(addr_T5, 9);
                                      DS_sensors.setResolution(addr_T6, 9);
                                      DS_sensors.setResolution(addr_T7, 9);
                                      DS_sensors.setResolution(addr_T8, 9);
                                      DS_sensors.setResolution(addr_T9, 9);
                                      float T1 = DS_sensors.getTempC(addr_T1);
                                      float T2 = DS_sensors.getTempC(addr_T2);
                                      float T3 = DS_sensors.getTempC(addr_T3);
                                      float T4 = DS_sensors.getTempC(addr_T4);
                                      float T5 = DS_sensors.getTempC(addr_T5);
                                      float T6 = DS_sensors.getTempC(addr_T6);
                                      float T7 = DS_sensors.getTempC(addr_T7);
                                      float T8 = DS_sensors.getTempC(addr_T8);
                                      float T9 = DS_sensors.getTempC(addr_T9);
                                      DS_sensors.requestTemperatures();
                                    //Serial.print(DS_sensors.getResolution(addr_T1), DEC);
                                      Serial.println();
                                      Serial.print("Temp T1 C: ");
                                      Serial.print(T1);
                                      Serial.println();
                                    >!   Serial.println();
                                      Serial.print("Temp T2 C: ");
                                      Serial.print(T2);
                                      Serial.println();
                                    Serial.println();
                                      Serial.print("Temp T3 C: ");
                                      Serial.print(T3);
                                      Serial.println();
                                    Serial.println();
                                      Serial.print("Temp T4 C: ");
                                      Serial.print(T4);
                                      Serial.println();
                                    Serial.println();
                                      Serial.print("Temp T5 C: ");
                                      Serial.print(T5);
                                      Serial.println();
                                    Serial.println();
                                      Serial.print("Temp T6 C: ");
                                      Serial.print(T6);
                                      Serial.println();
                                    Serial.println();
                                      Serial.print("Temp T7 C: ");
                                      Serial.print(T7);
                                      Serial.println();
                                    Serial.println();
                                      Serial.print("Temp T8 C: ");
                                      Serial.print(T8);
                                      Serial.println();
                                    Serial.println();
                                      Serial.print("Temp T9 C: ");
                                      Serial.print(T9);
                                      Serial.println();
                                    ///////////////////////Паблик данных сенсоров////////////////////////
                                     if (pause == 50 || pause == 0){
                                      char b[5];
                                    //    String char_Hout = String(Hout);
                                    //    char_Hout.toCharArray(b,5);
                                    //    client.publish("myhome/Kitchen/Humidity_room", b);
                                    //  String char_Tout = String(Tout);
                                    //  char_Tout.toCharArray(b,5);
                                    //  client.publish("myhome/Kitchen/Temp_room", b);
                                        String char_T1 = String(T1);
                                        char_T1.toCharArray(b,5);
                                        client.publish("myhome/Temp/Kladovka", b);
                                        String char_T2 = String(T2);
                                        char_T2.toCharArray(b,5);
                                        client.publish("myhome/Temp/Kitchen", b);
                                        String char_T3 = String(T3);
                                        char_T3.toCharArray(b,5);
                                        client.publish("myhome/Temp/Detskaya", b);
                                        String char_T4 = String(T4);
                                        char_T4.toCharArray(b,5);
                                        client.publish("myhome/Temp/Garage", b);
                                        String char_T5 = String(T5);
                                        char_T5.toCharArray(b,5);
                                        client.publish("myhome/Temp/Vannaya", b);
                                        String char_T6 = String(T6);
                                        char_T6.toCharArray(b,5);
                                        client.publish("myhome/Temp/Street", b);
                                        String char_T7 = String(T7);
                                        char_T7.toCharArray(b,5);
                                        client.publish("myhome/Temp/Spalnya2", b);
                                        String char_T8 = String(T8);
                                        char_T8.toCharArray(b,5);
                                        client.publish("myhome/Temp/Zal", b);
                                        String char_T9 = String(T9);
                                        char_T9.toCharArray(b,5);
                                        client.publish("myhome/Temp/Mansarda", b);
                                        //Serial.println(T1);
                                        String char_fotoValue = String(fotoValue);
                                        char_fotoValue.toCharArray(b,4);
                                        client.publish("myhome/Kitchen/Lux", b);
                                      String char_ServoAngle = String(ServoAngle);
                                      char_ServoAngle.toCharArray(b,4);
                                        String char_MQ7Value = String(MQ7Value);
                                        char_MQ7Value.toCharArray(b,4);
                                        client.publish("myhome/Temp/MQ7", b);
                                        pause = 1;
                                     else pause++;
                                    >! [/code]`[/spoiler]
                                    >! Показания от септика получаю в значениях см, типа 160 см, 100 см.....[/i][/i]
                                    13530
