    2. Русский
    3. ioBroker
    4. Скрипты
    5. ioBroker скрипты
    6. Скрипт для счётчика
    Скрипт для счётчика
    • I
      instalator last edited by
      @smoker_vvo:
      Убейте меня!!! ОН НЕ РАБОТАЕТ….. Ну не пингуется этот ip, я поменял на свои...... `
      библиотеки последних версии?
        smoker_vvo last edited by
        Начнем с простого…. Какая IDE
          в IDE 1.5.2 гружу вот этот скетч:
          Web Server
          A simple web server that shows the value of the analog input pins.
          using an Arduino Wiznet Ethernet shield.
          Circuit:
          • Ethernet shield attached to pins 10, 11, 12, 13
          • Analog inputs attached to pins A0 through A5 (optional)
          created 18 Dec 2009
          by David A. Mellis
          modified 9 Apr 2012
          by Tom Igoe
          ! #include <spi.h>#include <ethernet.h>// Enter a MAC address and IP address for your controller below.
          // The IP address will be dependent on your local network:
          byte mac[] = {
          0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
          IPAddress ip(192,168,0, 89);
          ! // Initialize the Ethernet server library
          // with the IP address and port you want to use
          // (port 80 is default for HTTP):
          EthernetServer server(80);
          ! void setup() {
          // Open serial communications and wait for port to open:
          Serial.begin(9600);
          while (!Serial) {
          ; // wait for serial port to connect. Needed for Leonardo only
          ! // start the Ethernet connection and the server:
          Ethernet.begin(mac, ip);
          server.begin();
          Serial.print("server is at ");
          Serial.println(Ethernet.localIP());
          ! void loop() {
          // listen for incoming clients
          EthernetClient client = server.available();
          if (client) {
          Serial.println("new client");
          // an http request ends with a blank line
          boolean currentLineIsBlank = true;
          while (client.connected()) {
          if (client.available()) {
          char c = client.read();
          Serial.write(c);
          // if you've gotten to the end of the line (received a newline
          // character) and the line is blank, the http request has ended,
          // so you can send a reply
          if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println("Connection: close");
          client.println();
          client.println("");
          client.println("");
          // add a meta refresh tag, so the browser pulls again every 5 seconds:
          client.println("");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
          int sensorReading = analogRead(analogChannel);
          client.print("analog input ");
          client.print(analogChannel);
          client.print(" is ");
          client.print(sensorReading);
          client.println("
          client.println("");
          break;
          if (c == '\n') {
          // you're starting a new line
          else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
          // give the web browser time to receive the data
          delay(1);
          // close the connection:
          client.stop();
          Serial.println("client disonnected");
          }</ethernet.h></spi.h>
          Пинг - отличный, и веб пускает,
            в 1ю8ю2 - тоже проблем нет…...
              1ю6ю13 - полет нормальный
              и 1.0.6 - работает…...
                IDE 1.6.13 этот скетч - работает, все пингуется и данные идут
                `#include <spi.h> // Ethernet shield
                #include <ethernet.h> // Ethernet shield
                #include <pubsubclient.h> // MQTT
                #include <servo.h>
                #include <dht.h>
                #include <onewire.h>
                #include <dallastemperature.h>
                Servo servo;
                ! byte mac[] = { 0xC1, 0x7C, 0x38, 0x41, 0x89, 0x35 };
                byte server[] = { 192, 168, 0, 11 }; //IP Брокера
                byte ip[] = { 192, 168, 0, 89 }; //IP Клиента (Arduino)
                void callback(char* topic, byte* payload, unsigned int length) {
                payload[length] = '\0';
                // Serial.print(topic);
                // Serial.print("=");
                String strTopic = String(topic);
                String strPayload = String((char*)payload);
                // Serial.println(strPayload);
                callback_iobroker(strTopic, strPayload);
                ! EthernetClient ethClient;
                PubSubClient client(server, 1883, callback, ethClient);
                #define id_connect "myhome-temp"
                #define id_connect "myhome-status"
                #define Prefix_subscribe "myhome/Temp/"
                #define Prefix_subscribe "myhome/Status/"
                ! ///////////////Объявляем порты ввода-вывода
                #define ServoPin 3 //Порт к которому подключен сервопривод
                ! const int start_DI_pin []= {2, 4, 5}; // Порты Ввода
                int n_DI_pin = sizeof(start_DI_pin) / sizeof(start_DI_pin[0])-1; //Вычисляем длинну массива
                ! const int start_DO_pin []= {6, 7}; //Порты Вывода
                int n_DO_pin = sizeof(start_DO_pin) / sizeof(start_DO_pin[0])-1; //Вычисляем длинну массива
                ! int DI[] = {0, 0, 0};
                int old_DI[] = {0, 0, 0};
                ! ///////////////////////////Переменные для работы с освещением//////////////////////////////////////
                int ServoAngle = 100; //Угол сервопривода при включении
                int flag = 0;
                int flag2 = 0;
                int pause = 0;
                ! //------------------------------------------- Sensors -------------------------------------------//
                const int MQ7_Pin = A0; // Куда подключили MQ7
                //int MQ7Value = 0;
                int MQ7Value = analogRead(MQ7_Pin);
                const int foto_Pin = A1; // устанавливаем входную ногу для Фоторезистора
                //unsigned int fotoValue = 0; // цифровое значение фоторезистора
                unsigned int fotoValue = analogRead(foto_Pin);
                ! #define ONE_WIRE_BUS 8
                //#define TEMPERATURE_PRECISION 9
                OneWire oneWire(ONE_WIRE_BUS);
                DallasTemperature DS_sensors(&oneWire);
                // 28 80 E9 3A 04 00 00 10
                //T0:28 88 AD D7 02 00 00 42
                //T1:28 14 A5 D7 02 00 00 B0
                //T2:28 72 26 7B 04 00 00 2E
                //T3:28 CA 1A 3B 04 00 00 CD
                //T4:28 E6 D5 D7 02 00 00 C1
                //T5:28 16 B4 7A 04 00 00 8A
                //T6:28 2B 86 D7 02 00 00 CF
                //T7:28 AB 9D D7 02 00 00 29
                DeviceAddress addr_T1 = { 0x28, 0x80, 0xE9, 0x3A, 0x4, 0x0, 0x0, 0x10 };//кладовка
                DeviceAddress addr_T2 = { 0x28, 0x88, 0xAD, 0xD7, 0x2, 0x0, 0x0, 0x42 };//кухня
                DeviceAddress addr_T3 = { 0x28, 0x14, 0xA5, 0xD7, 0x2, 0x0, 0x0, 0xB0 };//детская
                DeviceAddress addr_T4 = { 0x28, 0x72, 0x26, 0x7B, 0x4, 0x0, 0x0, 0x2E };//гараж
                DeviceAddress addr_T5 = { 0x28, 0xCA, 0x1A, 0x3B, 0x4, 0x0, 0x0, 0xCD };//ванная
                DeviceAddress addr_T6 = { 0x28, 0xE6, 0xD5, 0xD7, 0x2, 0x0, 0x0, 0xC1 };//улица
                DeviceAddress addr_T7 = { 0x28, 0x16, 0xB4, 0x7A, 0x4, 0x0, 0x0, 0x8A };//спальня2
                DeviceAddress addr_T8 = { 0x28, 0x2B, 0x86, 0xD7, 0x2, 0x0, 0x0, 0xCF };//зал
                DeviceAddress addr_T9 = { 0x28, 0xAB, 0x9D, 0xD7, 0x2, 0x0, 0x0, 0x29 };//мансарда
                ! float T1=0;
                float T2=0;
                float T3=0;
                float T4=0;
                float T5=0;
                float T6=0;
                float T7=0;
                float T8=0;
                float T9=0;
                ! //dht DHT;
                //#define DHT22_PIN 9
                //float Hout = 0;
                //float Tout = 0;
                //void callback(char* topic, byte* payload, unsigned int length) {
                // payload[length] = '\0';
                // String strTopic = String(topic);
                // String strPayload = String((char*)payload);
                // callback_iobroker(strTopic, strPayload);
                void setup() {
                Serial.begin(57600);
                Serial.println("start");
                Serial.print("Locating devices...");
                DS_sensors.begin();
                Serial.print("Found ");
                Serial.print(DS_sensors.getDeviceCount(), DEC);
                Serial.println(" devices.");
                ! // report parasite power requirements
                Serial.print("Parasite power is: ");
                if (DS_sensors.isParasitePowerMode()) Serial.println("ON");
                else Serial.println("OFF");
                //Объявляем порты Digital inputs/outputs
                for(int i=0 ;i<=n_DI_pin; i++) { pinMode (start_DI_pin [i], INPUT); }
                digitalWrite(5, HIGH); //Насос скважины
                digitalWrite(4, HIGH); //Электрика
                for(int i=0 ;i<=n_DO_pin; i++) { pinMode (start_DO_pin [i], OUTPUT); }
                ! Ethernet.begin(mac, ip);
                if (client.connect(id_connect)) {
                getSensors();
                control();
                //client.publish("myhome/Kitchen/Change_Counter", "0");
                //client.publish("myhome/Kitchen/Temp_room", "0");
                //client.publish("myhome/Kitchen/Humidity_room", "0");
                client.publish("myhome/Temp/Kladovka", "0");
                client.publish("myhome/Temp/Kitchen", "0");
                client.publish("myhome/Temp/Detskaya", "0");
                client.publish("myhome/Temp/Garage", "0");
                client.publish("myhome/Temp/Street", "0");
                client.publish("myhome/Temp/Spalnya2", "0");
                client.publish("myhome/Temp/Zal", "0");
                client.publish("myhome/Temp/Mansarda", "0");
                client.publish("myhome/Temp/Vannaya", "0");
                //client.publish("myhome/Kitchen/Lux", "0");
                //client.publish("myhome/Kitchen/Servo", "0");
                client.publish("myhome/Temp/MQ7", "0");
                client.publish("myhome/Status/Power", "0");
                client.publish("myhome/Status/Pompe", "0");
                client.subscribe("myhome/Temp/#");
                client.subscribe("myhome/Status/#");
                void loop() {
                client.loop();
                control();
                getSensors();
                if (!client.connected()) {
                control();
                getSensors();
                }</dallastemperature.h></onewire.h></dht.h></servo.h></pubsubclient.h></ethernet.h></spi.h>`
                ! А заливаем этот - и ни чего....
                ! >! [spoiler]`[code]#include <spi.h>
                #include <eeprom.h>
                //#include <avr wdt.h="">
                ! #define PWR_CTRL A2 //Контроль напряжения
                #define LED 9 //Светодиод
                #define CHK_ADR 100
                #define CNT_ADR 10
                #define PWR_ADR 20
                #define POLL_ADR 30
                #define RATIO_ADR 40
                ! const char* topic_err = "myhome/test/error";
                const char* topic_cnt = "myhome/test/count";
                const char* topic_pwr = "myhome/test/power";
                const char* topic_amp = "myhome/test/amp";
                const char* topic_save = "myhome/test/save";
                const char* topic_correction = "myhome/test/correction";
                const char* topic_connection = "myhome/test/connection";
                const char* topic_ip = "myhome/test/config/ip";
                const char* topic_polling = "myhome/test/config/polling";
                const char* topic_bounce = "myhome/test/config/bounce";
                const char* topic_num = "myhome/test/config/num";
                const char* topic_reset = "myhome/test/config/reset";
                const char* topic_raw = "myhome/test/RAW";
                const char* subscr = "myhome/test/#";
                ! byte mac[] = { 0xDE, 0xA3, 0xBE, 0xE4, 0xDE, 0x35 };
                byte ip[] = { 192, 168, 0, 89};
                byte server[] = { 192, 168, 0, 15};
                ! unsigned long cnt = 0;
                unsigned long prev_cnt = 2;
                unsigned long pwr = 0;
                unsigned long prev_pwr = 2;
                int amp = 0;
                int prev_amp = 2;
                int num = 0;
                int prev_num;
                int bounce = 10;
                int prev_bounce;
                int chk = 0;
                int chk_S = 0;
                unsigned long prevMillis = 0;
                unsigned long prevMillis_cnt = 0;
                int poll = 5000;
                bool error = 0;
                String cmd = "";
                bool strComplete = false;
                char buf [50];
                char buffer[100];
                char s[16];
                PubSubClient client(ethClient);
                ! void setup() {
                //MCUSR = 0;
                // wdt_disable();
                Serial.println("WDT_disable");
                cmd.reserve(100);
                delay(10000);
                Serial.println("Starting......");
                ! if (EEPROM.read(1) != 99) { //Если первый запуск
                EEPROM.write(1, 99);
                for (int i = 0 ; i < 4; i++) {
                EEPROM.write(110 + i, ip[i]);
                EEPROM.write(120 + i, server[i]);
                } else {
                chk = EEPROMReadInt(CHK_ADR);
                cnt = EEPROMReadLong(CNT_ADR);
                poll = EEPROMReadInt(POLL_ADR);
                chk_S = poll - 500;
                if (chk != chk_S) {
                error = 2;
                for (int i = 0; i < 4; i++) {
                ip[i] = EEPROM.read(110 + i);
                server[i] = EEPROM.read(120 + i);
                ! pinMode(LED, OUTPUT);
                ! client.setServer(server, 1883);
                client.setCallback(callback);
                delay(200);
                //wdt_enable(WDTO_8S);
                Serial.println("WDTO_8S");
                if (client.connect("test")){
                digitalWrite(LED, LOW);
                Public();
                ! void serialEvent() {
                while (Serial.available() > 0) {
                char inChar = (char)Serial.read();
                cmd += inChar;
                if (inChar == '\n') {
                strComplete = true;
                ! void loop() {
                // wdt_reset();
                Serial.println("WDT_reset");
                client.loop();
                reconnect();
                ! /if (analogRead(PWR_CTRL) < 1000) {
                save();
                delay(10000);
                ! if (strComplete) {
                digitalWrite(LED, !digitalRead(LED));
                cmd.toCharArray(buffer, 100);
                cnt = atoi(strtok(buffer, ";"));
                pwr = atoi(strtok(NULL, ";"));
                amp = atoi(strtok(NULL, ";"));
                bounce = atoi(strtok(NULL, ";"));
                num = atoi(strtok(NULL, ";"));
                error = atoi(strtok(NULL, ";"));
                client.publish(topic_raw, StrToChar(cmd));
                cmd = "";
                ! if (millis() - prevMillis >= poll) {
                // wdt_reset();
                Serial.println("WDT_reset-");
                prevMillis = millis();
                if (cnt != prev_cnt || pwr != prev_pwr || amp != prev_amp) {
                prev_cnt = cnt;
                prev_pwr = pwr;
                prev_amp = amp;
                client.publish(topic_cnt, IntToChar(cnt));
                client.publish(topic_pwr, IntToChar(pwr));
                client.publish(topic_amp, IntToChar(amp));
                if (num != prev_num || bounce != prev_bounce) {
                prev_num = num;
                prev_bounce = bounce;
                client.publish(topic_num, IntToChar(num));
                client.publish(topic_bounce, IntToChar(bounce));
                if (error > 0) {
                client.publish(topic_err, "err");
                } else {
                client.publish(topic_err, " ");
                ! void callback_iobroker(String strTopic, String strPayload) {
                if (strTopic == topic_correction) {
                cnt = atol((strPayload).c_str());
                Serial.print("SC");
                Serial.println(cnt);
                client.publish(topic_correction, "0");
                else if (strTopic == topic_save) {
                if (strPayload == "true") {
                Serial.println("SS");
                save();
                client.publish(topic_save, "false");
                else if (strTopic == topic_polling) {
                poll = strPayload.toInt();
                if (poll < 1000) {
                poll = 1000;
                } else if (poll > 32767) {
                poll = 32767;
                EEPROMWriteInt(POLL_ADR, poll); //Интервал публикации
                client.publish(topic_polling, IntToChar(poll));
                else if (strTopic == topic_reset) {
                client.publish(topic_reset, "false");
                // reboot();
                Serial.println("Reboot");
                else if (strTopic == topic_bounce) {
                bounce = strPayload.toInt();
                if (bounce < 0) {
                bounce = 0;
                } else if (bounce > 10000) {
                bounce = 10000;
                Serial.print("SB");
                Serial.println(bounce);
                else if (strTopic == topic_num) {
                num = strPayload.toInt();
                if (num < 0) {
                num = 0;
                } else if (num > 32767) {
                num = 32767;
                Serial.print("SN");
                Serial.println(num);
                ! void save() {
                chk = poll - 500;
                EEPROMWriteLong(CNT_ADR, cnt); //Пишем показания счетчика в eeprom из переменной
                EEPROMWriteInt(CHK_ADR, chk); //чек
                ! void reboot() {
                //save();
                //delay(500);
                // wdt_enable(WDTO_1S);
                Serial.println("void reboot");
                //for (;;) {}
                ! char* StrToChar (String str) {
                int length = str.length();
                str.toCharArray(buf, length + 1);
                return buf;
                ! void EEPROMWriteLong(int p_address, unsigned long p_value) {
                byte four = (p_value & 0xFF);
                byte three = ((p_value >> 😎 & 0xFF);
                byte two = ((p_value >> 16) & 0xFF);
                byte one = ((p_value >> 24) & 0xFF);
                EEPROM.write(p_address, four);
                EEPROM.write(p_address + 1, three);
                EEPROM.write(p_address + 2, two);
                EEPROM.write(p_address + 3, one);
                ! unsigned long EEPROMReadLong(int p_address) {
                long four = EEPROM.read(p_address);
                long three = EEPROM.read(p_address + 1);
                long two = EEPROM.read(p_address + 2);
                long one = EEPROM.read(p_address + 3);
                return ((four << 0) & 0xFF) + ((three << 😎 & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
                ! void EEPROMWriteInt(int p_address, int p_value) {
                byte lowByte = ((p_value >> 0) & 0xFF);
                byte highByte = ((p_value >> 😎 & 0xFF);
                EEPROM.write(p_address, lowByte);
                EEPROM.write(p_address + 1, highByte);
                unsigned int EEPROMReadInt(int p_address) {
                byte lowByte = EEPROM.read(p_address);
                byte highByte = EEPROM.read(p_address + 1);
                return ((lowByte << 0) & 0xFF) + ((highByte << 😎 & 0xFF00);
                ! char* IntToChar (unsigned long a) {
                sprintf(buf, "%lu", a);
                return buf;
                ! void Public() {
                sprintf(s, "%d.%d.%d.%d", ip[0], ip[1], ip[2], ip[3]);
                client.publish(topic_connection, "true");
                client.publish(topic_ip, s);
                client.subscribe(subscr);
                void reconnect() {
                int a = 0;
                while (!client.connected()) {
                a++;
                //wdt_reset();
                Serial.println("WDT reset");
                if (client.connect("test")) {
                Public();
                } else {
                delay(10000);
                if (a >= 10) {
                Serial.println("WDTO_1S");
                }</avr></eeprom.h></pubsubclient.h></ethernet.h></spi.h>`
                ! Ни пинга, ни данных....[/i][/i][/i][/i][/code][/spoiler][/i][/i]
                • I
                  @smoker_vvo:
                  Начнем с простого…. Какая IDE `
                  ide 1.8.3
                  Ethernet 1.1.2
                  PubSubCliet 2.6.0
                    IDE 1.8.4, остальное совпадает…...
                    Хорошо, с программным уровнем разобрались. Теперь аппаратный.... Arduino MEGA 2560+EthernetShield W5100
                    • I
                      @smoker_vvo:
                      Хорошо, с программным уровнем разобрались. Теперь аппаратный.... Arduino MEGA 2560+EthernetShield W5100 `
                      Да какая разница какая ардуина, я на УНО и W5100 проверял
                        Хлебнуфф пивка и выкурив сигаретку, психанул и заменил Arduino MEGA на Arduino NANO- и О ЧУДО!!!! Все заработало…...
                        Теперь другие вопросы....
                        в строке RAW получаю такие значения 268494237;4294935483;0;-9325;-120;0, как их разобрать?? Что есть что??
                          ан все таки есть… Щас сборка выглядит так :
                          Нано собирает инфу от счетчика - УНО обрабатывает - В5100 - отдает на Брокера
                          В предыдущем вопле ошибочка, Мега заменил на УНО
                          • I
                            @smoker_vvo:
                            в строке RAW получаю такие значения 268494237;4294935483;0;-9325;-120;0, как их разобрать?? Что есть что?? `
                            https://github.com/instalator/Electro_C … t.ino#L278
                            https://blog.instalator.ru/archives/711
                            cnt = atoi(strtok(buffer, ";")); //счетчик
                            pwr = atoi(strtok(NULL, ";")); //мощность
                            amp = atoi(strtok(NULL, ";")); //сила тока!
                            bounce = atoi(strtok(NULL, ";")); //задержка от дребезга
                            num = atoi(strtok(NULL, ";")); //Значение передаточного числа счетчика. Количество импульсов на 1 кВт*ч
                            error = atoi(strtok(NULL, ";")); //ошибка
                            • I
                              По скрипту для счетчика меркурий вынес в отдельную тему http://forum.iobroker.net/viewtopic.php?f=26&t=8148
                                Зенкую! Я так и понял. Но проект заглох… проработав два часа......
                                и повторно запустить не удалось....
                                Не могу понять по чему........
                                  Вопрос не в тему, но не знаю куда закинуть.
                                  Есть более важные задачи - наполнение септика..
                                  Для контроля использую следующий скетч:
                                  #define Trig 9
                                  #define Echo 8
                                  #define ledPin 13
                                  ! void setup()
                                  pinMode(Trig, OUTPUT); //инициируем как выход
                                  pinMode(Echo, INPUT); //инициируем как вход
                                  pinMode(ledPin, OUTPUT);
                                  Serial.begin(9600);
                                  /* задаем скорость общения. В нашем случае с компьютером /
                                  unsigned int impulseTime=0;
                                  unsigned int distance_sm=0;
                                  ! void loop()
                                  digitalWrite(Trig, HIGH);
                                  Подаем импульс на вход trig дальномера */
                                  delayMicroseconds(10); // равный 10 микросекундам
                                  digitalWrite(Trig, LOW); // Отключаем
                                  impulseTime=pulseIn(Echo, HIGH); // Замеряем длину импульса
                                  distance_sm=impulseTime/58; // Пересчитываем в сантиметры
                                  Serial.println(distance_sm); // Выводим на порт
                                  if (distance_sm<50) // Если расстояние менее 30 сантиметром
                                  digitalWrite(ledPin, HIGH); // Светодиод горит
                                  else
                                  digitalWrite(ledPin, LOW); // иначе не горит
                                  delay(10000);
                                  Подскажите как загнать его в Брокер,
                                  хочется через MQTT
                                  Для температуры использую вот это:
                                  #include <servo.h>
                                  #include <dht.h>
                                  Servo servo;
                                  int flag = 0;
                                  int flag2 = 0;
                                  int pause = 0;
                                  //int MQ7Value = 0;
                                  >! float T1=0;
                                  float T2=0;
                                  float T3=0;
                                  float T4=0;
                                  float T5=0;
                                  float T6=0;
                                  float T7=0;
                                  float T8=0;
                                  float T9=0;
                                  >! //dht DHT;
                                  //float Hout = 0;
                                  //float Tout = 0;
                                  void setup() {
                                    DS_sensors.begin();
                                      getSensors();
                                      control();
                                  void loop() {
                                    client.loop();
                                    control();
                                    getSensors();
                                        control();
                                        getSensors();
                                  И это Function
                                  >! >! ~~[spoiler]~~`~~[code]~~//--------------------------------- Functions ---------------------------------//
                                  /////////////////////////////////От Брокера//////////////////////////////////////////////
                                  void callback_iobroker(String strTopic, String strPayload){
                                    if (strTopic == "myhome/Kitchen/Servo"){
                                          ServoAngle=strPayload.toInt();
                                      if (ServoAngle >= 0 && ServoAngle <= 255){
                                            servo.attach(ServoPin);
                                            //delay(200); //ждем 2 секунды
                                            servo.write(ServoAngle); //ставим вал под 0
                                            delay(1000); //ждем 2 секунды
                                            //client.publish("myhome/Kitchen/Servo", b);
                                            servo.detach();
                                  >! ////////////////////////////////////Брокеру/////////////////////////////////////
                                  void control(){
                                         if(digitalRead(5)==HIGH && flag==0) { //если насос включен
                                            client.publish("myhome/Status/Pompe", "1");
                                            flag=1;
                                         if(digitalRead(5)==LOW && flag==1){//если насос выключен
                                          flag=0;//обнуляем переменную flag
                                         if(digitalRead(4)==HIGH && flag2==0) { // Если электрика есть
                                            client.publish("myhome/Status/Power", "1");
                                            flag2=1;
                                         if(digitalRead(4)==LOW && flag2==1){// Если эректрики нет
                                          flag2=0;//обнуляем переменную flag
                                  ///////////////////////////////Данные сенсоров////////////////////////////////////
                                  >! void getSensors () {
                                  >!   MQ7Value = analogRead(MQ7_Pin);
                                    fotoValue = analogRead(foto_Pin);  // считываем значение с фоторезистора
                                  // ServoAngle = analogRead(2);
                                  >! //Обработка данных датчика DHT22\. Подключение к порту цифровому P9 Arduino
                                  //Глобальные переменные Hout и Tout типа флоат - влажность (%) и температура (град. С)
                                  //  if (DHT.read22(DHT22_PIN)== DHTLIB_OK) {
                                  //    Hout = DHT.humidity;
                                  //    Tout = DHT.temperature;
                                  //  if (Hout == 0 || Tout == 0){
                                  //    delay (1000);
                                    //Обработка данных цифровых датчиков температуры типа DS18B20.
                                    //Шина 1-Wire на цифровой пин P8 Arduino.
                                    //Подключено 2 датчика температуры, адреса задаются в секции глобальных констант "Sensors"
                                    //Три значение температуры T1, T2, типа float (град. С).
                                    DS_sensors.setResolution(addr_T1, 9);
                                    DS_sensors.setResolution(addr_T2, 9);
                                    DS_sensors.setResolution(addr_T3, 9);
                                    DS_sensors.setResolution(addr_T4, 9);
                                    DS_sensors.setResolution(addr_T5, 9);
                                    DS_sensors.setResolution(addr_T6, 9);
                                    DS_sensors.setResolution(addr_T7, 9);
                                    DS_sensors.setResolution(addr_T8, 9);
                                    DS_sensors.setResolution(addr_T9, 9);
                                    float T1 = DS_sensors.getTempC(addr_T1);
                                    float T2 = DS_sensors.getTempC(addr_T2);
                                    float T3 = DS_sensors.getTempC(addr_T3);
                                    float T4 = DS_sensors.getTempC(addr_T4);
                                    float T5 = DS_sensors.getTempC(addr_T5);
                                    float T6 = DS_sensors.getTempC(addr_T6);
                                    float T7 = DS_sensors.getTempC(addr_T7);
                                    float T8 = DS_sensors.getTempC(addr_T8);
                                    float T9 = DS_sensors.getTempC(addr_T9);
                                    DS_sensors.requestTemperatures();
                                  //Serial.print(DS_sensors.getResolution(addr_T1), DEC);
                                    Serial.println();
                                    Serial.print("Temp T1 C: ");
                                    Serial.print(T1);
                                    Serial.println();
                                  >!   Serial.println();
                                    Serial.print("Temp T2 C: ");
                                    Serial.print(T2);
                                    Serial.println();
                                  Serial.println();
                                    Serial.print("Temp T3 C: ");
                                    Serial.print(T3);
                                    Serial.println();
                                  Serial.println();
                                    Serial.print("Temp T4 C: ");
                                    Serial.print(T4);
                                    Serial.println();
                                  Serial.println();
                                    Serial.print("Temp T5 C: ");
                                    Serial.print(T5);
                                    Serial.println();
                                  Serial.println();
                                    Serial.print("Temp T6 C: ");
                                    Serial.print(T6);
                                    Serial.println();
                                  Serial.println();
                                    Serial.print("Temp T7 C: ");
                                    Serial.print(T7);
                                    Serial.println();
                                  Serial.println();
                                    Serial.print("Temp T8 C: ");
                                    Serial.print(T8);
                                    Serial.println();
                                  Serial.println();
                                    Serial.print("Temp T9 C: ");
                                    Serial.print(T9);
                                    Serial.println();
                                  ///////////////////////Паблик данных сенсоров////////////////////////
                                   if (pause == 50 || pause == 0){
                                    char b[5];
                                  //    String char_Hout = String(Hout);
                                  //    char_Hout.toCharArray(b,5);
                                  //    client.publish("myhome/Kitchen/Humidity_room", b);
                                  //  String char_Tout = String(Tout);
                                  //  char_Tout.toCharArray(b,5);
                                  //  client.publish("myhome/Kitchen/Temp_room", b);
                                      String char_T1 = String(T1);
                                      char_T1.toCharArray(b,5);
                                      client.publish("myhome/Temp/Kladovka", b);
                                      String char_T2 = String(T2);
                                      char_T2.toCharArray(b,5);
                                      client.publish("myhome/Temp/Kitchen", b);
                                      String char_T3 = String(T3);
                                      char_T3.toCharArray(b,5);
                                      client.publish("myhome/Temp/Detskaya", b);
                                      String char_T4 = String(T4);
                                      char_T4.toCharArray(b,5);
                                      client.publish("myhome/Temp/Garage", b);
                                      String char_T5 = String(T5);
                                      char_T5.toCharArray(b,5);
                                      client.publish("myhome/Temp/Vannaya", b);
                                      String char_T6 = String(T6);
                                      char_T6.toCharArray(b,5);
                                      client.publish("myhome/Temp/Street", b);
                                      String char_T7 = String(T7);
                                      char_T7.toCharArray(b,5);
                                      client.publish("myhome/Temp/Spalnya2", b);
                                      String char_T8 = String(T8);
                                      char_T8.toCharArray(b,5);
                                      client.publish("myhome/Temp/Zal", b);
                                      String char_T9 = String(T9);
                                      char_T9.toCharArray(b,5);
                                      client.publish("myhome/Temp/Mansarda", b);
                                      //Serial.println(T1);
                                      String char_fotoValue = String(fotoValue);
                                      char_fotoValue.toCharArray(b,4);
                                      client.publish("myhome/Kitchen/Lux", b);
                                    String char_ServoAngle = String(ServoAngle);
                                    char_ServoAngle.toCharArray(b,4);
                                      String char_MQ7Value = String(MQ7Value);
                                      char_MQ7Value.toCharArray(b,4);
                                      client.publish("myhome/Temp/MQ7", b);
                                      pause = 1;
                                   else pause++;
                                  >! [/code]`[/spoiler]
                                  >! Показания от септика получаю в значениях см, типа 160 см, 100 см.....[/i][/i]
                                  13518
