    4. go-e Adapter
    go-e Adapter
    • Fabzap
      Fabzap @cb187 last edited by
      @cb187 Allerdings hängt sich jetzt der Adapter recht schnell auf.
      ost.raspisauen
      2023-03-19 11:48:52.535 warn Do not restart adapter system.adapter.go-e.0 because restart loop detected
      host.raspisauen
      2023-03-19 11:48:52.535 info Restart adapter system.adapter.go-e.0 because enabled
      host.raspisauen
      2023-03-19 11:48:52.535 error instance system.adapter.go-e.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.raspisauen
      2023-03-19 11:48:52.535 error Caught by controller[1]: at GoE.adjustAmpLevelInWatts (/opt/iobroker/node_modules/iobroker.go-e/main.js:793:25)
      host.raspisauen
      2023-03-19 11:48:52.534 error Caught by controller[1]: TypeError: Cannot read property 'finish' of undefined
      host.raspisauen
      2023-03-19 11:48:52.534 error Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      go-e.0
      2023-03-19 11:48:52.145 info 200 with message: OK
      go-e.0
      2023-03-19 11:48:51.990 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
      go-e.0
      2023-03-19 11:48:51.988 info terminating
      go-e.0
      2023-03-19 11:48:51.956 error Cannot read property 'finish' of undefined
      go-e.0
      2023-03-19 11:48:51.955 error TypeError: Cannot read property 'finish' of undefined at GoE.adjustAmpLevelInWatts (/opt/iobroker/node_modules/iobroker.go-e/main.js:793:25)
      go-e.0
      2023-03-19 11:48:51.954 error unhandled promise rejection: Cannot read property 'finish' of undefined
      go-e.0
      2023-03-19 11:48:51.952 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      go-e.0
      2023-03-19 11:48:51.939 info Set value 21 of id amx
        cb187 @Fabzap last edited by
        @fabzap schreibst du was in amplevel?
        Fabzap 1 Reply Last reply Reply Quote 0
          Mike Hellracer @nik82 last edited by Mike Hellracer
          @nik82
          Adapter = v.1.0.23 und die Firmware der Box = 55.0
          Cloud Verbindung ist an
          lokale HTTP API v2 ist an
          lokale HTTP API v1 ist an
          lokale ModbusTCP API ist an
          Alles wird erkannt und sauber ausgelesen
          Aber ich bekomme es einfach nicht hin, das die Box nur bei PV-Überschuss lädt. Entweder lädt sie volle Power oder gar nicht.
          Auch das Protokoll meldet noch nicht mal den Versuch einer Anpassung.
          Hier das Prokoll:
          go-e.1
          2023-03-31 13:51:24.834	debug	{"version":"B","tme":"3103231351","rbc":"248","rbt":"122758719","car":"2","amx":"10","amp":"10","err":"0","ast":"1","alw":"1","stp":"0","cbl":"20","pha":"63","fsp":"0","tma":[24.25,27],"dws":"4588847","dwo":"180","adi":"1","uby":"2","eto":"31534","wst":"3","fwv":"055.0","nrg":[227,227,228,0,91,91,92,17,16,17,0,520,83,80,84,1],"sse":"058233","wss":"Skynet","wke":"********","wen":"1","cdi":"0","tof":"101","tds":"1","lbr":"0","aho":"0","afi":"6","azo":"1","ama":"16","al1":"6","al2":"10","al3":"12","al4":"14","al5":"16","cid":"255","cch":"65535","cfi":"65280","lse":"0","ust":"2","wak":"********","r1x":"2","dto":"0","nmo":"0","sch":"AAAAAAAAAAAAAAAA","sdp":"0","eca":"6002","ecr":"25530","ecd":"0","ec4":"0","ec5":"0","ec6":"0","ec7":"0","ec8":"0","ec9":"0","ec1":"0","rca":"1","rcr":"1","rcd":"","rc4":"","rc5":"","rc6":"","rc7":"","rc8":"","rc9":"","rc1":"","rna":"Micha","rnm":"Anika","rne":"n/a","rn4":"n/a","rn5":"n/a","rn6":"n/a","rn7":"n/a","rn8":"n/a","rn9":"n/a","rn1":"n/a","loe":0,"lot":32,"lom":10,"lop":50,"log":"DBNFXQHD","lof":0,"loa":0,"lch":121943}
          go-e.1
          2023-03-31 13:51:24.833	debug	Response: 200 - OK with data as object
          go-e.1
          2023-03-31 13:51:24.613	debug	Starte Abfrage an: http://go-echarger-058233.fritz.box/status
          go-e.1
          2023-03-31 13:51:24.610	debug	Subscribe foreign object 0_userdata.0.Energiemanager.PowerPV
          go-e.1
          2023-03-31 13:51:24.609	debug	Subscribe foreign object 0_userdata.0.Energiemanager.PowerHome
          go-e.1
          2023-03-31 13:51:24.608	debug	Subscribe foreign object 0_userdata.0.Energiemanager.BatEnergy
          go-e.1
          2023-03-31 13:51:24.601	info	Intervall: 60
          go-e.1
          2023-03-31 13:51:24.600	info	Server: go-echarger-058233.fritz.box
          go-e.1
          2023-03-31 13:51:24.538	info	starting. Version 1.0.23 in /opt/iobroker/node_modules/iobroker.go-e, node: v16.19.1, js-controller: 4.0.23
          Was muss ich machen, damit die dynamische Steuerung funktioniert? Oder ggf. in der App konfigurieren?
          Muss ich in der App die Funktion "PV-Überschuss laden" oder noch etwas anderes aktivieren?
          Hier die Config des Adapter
          nik82 1 Reply Last reply Reply Quote 0
          • nik82
            nik82 Most Active @Mike Hellracer last edited by
            @mike-hellracer
            Bitte mal screenshot deiner Datenpunkte, weil du brauchst überall positive werte, nicht das du einen negativen wert hast, das ist bei meinem fronius genauso, da muss ich den wert erstmal umwandeln.
            Und mach mal den datenpunkt bei batterie erstmal raus um adapter, den kannst nachher immer noch setzen wenns funktioniert.
              @nik82
              Hi, Danke für die prompte Rückmeldung...
              Bat habe ich raus gemacht, trotzdem brummt das Ding auf 8KW obwohl der PV-Ertrag derzeit nur 4 KW hat
              anbei:
              Jetzt ist auf 3kW runter, aber der PV Ertrag ist zur Zeit nur 900Watt. Ich hatte erwartet, das der PV-Ertrag nicht überschritten wird???
              Jetzt ist er erst mal aufgeladen. 🙂 mal sehen wie es sich morgen verhällt.
              Eine Frage habe ich noch gibt es irgendwo den aktuellen Ladestand des Autos?
              nik82 Homoran 2 Replies Last reply Reply Quote 0
              • nik82
                @mike-hellracer
                Also von der Einstellung her ist alles korrekt, sofern sich deine PV Objekte auch richtig aktualisieren muss das auch funktionieren.
                Probier mal.
                P.S. Wie sich das mit der Batterieladung verhält weiß ich nicht, das hab ich nicht bei mir aktiviert.
                  @nik82
                  Ich meinte den Status meines Autos. Wie voll ist der Akku gerade.
                  Oder habe ich den Wert übersehen?
                    Homoran Global Moderator Administrators @Mike Hellracer last edited by
                    @mike-hellracer sagte in Go e-charger:
                    ja, in den Datenpunkten deines Autos.
                    Woher soll der Charger den SoC deines Autos kennen?
                    • nik82
                      @mike-hellracer
                      Musst halt einen Adapter für dein Auto suchen wenn es da einen gibt.
                      Aber die Wallbox kann sowas nicht, egal welche, das geht nicht.
                        @nik82
                        Yep, danke auf den Trichter bin ich gestern abend auch gekommen und habe den passenden Adapter installiert. 🙂
                        Jetzt habe ich das ganze mal einen Moment beobachtet und es scheint soweit zu funktionieren, das der Adapter die Box auf Max 14A stellt und der LadeWert dann bis ca 3kw runter geregelt wird.
                        Aber leider nicht ganz auf Null.
                        Das bedeutet ständiger Netzbezug, wenn die Box nachts verbunden ist.
                        Weiter oben habe ich gelesen, daß 6A minimum wären. Wie ist das, könnt ihr das bestätigen?
                        Oder wie habt ihr das gelöst?
                        Vlt. Die Ladezeiten in der Box setzen?
                        Und ich habe 2 Go-e. Sollte ich da das Lastenmanagent aktivieren oder alles über iob regeln?
                        • nik82
                          1. Ja, minimum ist 6A, wenn du ausschalten willst, dann per Blockly lösen, hab ich auch hier im Threat irgendwo mal geschrieben wie das geht.
                          2. Durch dein Lastmanagement geht die Box nur auf 14A, mach das raus und es geht auch bis 16A.
                            @nik82
                            Danke für die Antwort,
                            also entweder komplett auf das Blockly umsteigen
                            https://forum.iobroker.net/topic/30415/go-e-charger/18
                            Oder additiv zum Adapter mit deinem Blockly realisieren?
                            https://forum.iobroker.net/topic/30415/go-e-charger/605
                            (hier der Teil mit der Zeitsteuerung)
                            https://forum.iobroker.net/topic/30415/go-e-charger/613
                            Oder vlt auf OpenWB umsellen?
                            https://forum.iobroker.net/topic/30415/go-e-charger/119
                            Wahrscheinlich ist die Kombination aus Adapter und zusätzliches Blockly die einfachere. Und am besten das Abschalten dann über den Adapter des jeweiligen Autos regeln.
                            Könntest du dein Blockly nochmal komplett zur Verfügung stellen?
                            Wie ist deine Meinung?
                            Und eine Verständnisfrage habe ich noch:
                            Gebe ich unter Hausverbrauch den aktuellen Gesamtverbraucht an oder muss ich mir einen Wert ohne Wallbox erstellen?
                            • nik82
                              nik82 Most Active last edited by nik82
                              Nur zur Info:
                              Beim neuesten Adapter Update gibt es nun ein Objekt: "solarLoadOnly":
                              Hier kann man nun mit einem klick auswählen ob die PV Steuerung im Adapter aktiv sein soll oder nicht 👍
                              P.S. Danke an @MK-2001
                              • nik82
                                @nik82
                                Sorry, hab deinen Post ganz überlesen.
                                Richtig, mach doch die PV Steuerung über Adapter und den Rest per Blockly. Aber im neuen Adapter gibts ja jetzt eine neue Funktion, wie oben bei dem Post beschreiben. Funktioniert bei mir aber noch nicht, brauche da mehrere Infos wie die Logik funktioniert.
                                P.S. Hausverbrauch ist der gesamte aktuelle Verbrauch des Hauses INKLUSIVE Wallbox, brauchst also nichts extra rumstellen.
                                • nik82
                                  Muss leider nochmal einen Post machen:
                                  ACHTUNG! beim Update auf die neue Version 1.0.26 bzw. 1.0.27:
                                  Die PV Steuerung funktioniert nicht mehr so (perfekt) wie vorher:
                                  Die Wallbox schaltet jetzt (wenn kein Überschuss mehr vorhanden ist) aus, also alw=0 und nicht mehr nur auf 6A.
                                  Und schaltet die Wallbox aber auch bei Überschuss nicht mehr ein.
                                  Ich glaube nicht das dies so vom Entwickler gewünscht ist, vielleicht mache ich auch etwas jetzt falsch oder übersehe etwas.
                                  Wird sich aufklären, habe schon in Issue im Github erstellt.
                                  Kenzo 1 Reply Last reply Reply Quote 0
                                  • Fabzap
                                    @cb187 Ich hatte einen Nutzerdatenpunkt im Adapter eingetragen.
                                    Im nächsten Versuch habe ich das freigelassen und stattdessen mal versucht, aus dem Blockly Script direkt in das Feld "max_watts" zu schreiben. Es wird zwar gefüllt. Aber da bekomme ich dann die Fehlermeldung: "Error during set MaxWatts: setAmp is not defined"
                                    Zu setAmp konnte ich nichts nichts finden..
                                    Die Wallbox lädt völlig unbeeindruckt.
                                    Adapter: v1.0.27, API V1 und V2 und Cloud enabled.
                                    Settings:
                                      @fabzap
                                      ja hab ich auch gesehn in der neusten version.hatte die jetzt die tage mal getestet.
                                      Deshalb bin ich wieder auf 1.0.25 zurück wo alles wunderbar funjtioniert.
                                      Fabzap C 3 Replies Last reply Reply Quote 0
                                      • Fabzap
                                        @cb187 Wunderbar, das war's!! Danke!
                                          @fabzap said in Go e-charger:
                                          • Kenzo
                                            Kenzo @nik82 last edited by
                                            @nik82
                                            Hab ähnliche Probleme wie und würde gerne auf die 1.026 zurück gehen. Gibt es einen Weg die Vorgänger Version des Adapters zu installieren?
                                            Kenzo
                                            1020
                                            330091
