    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    • haselchen
      haselchen Most Active @Siggi0904 last edited by
      @siggi0904
      Auch kein Beinbruch, dann legste die Räume selber an.
      Rooms
      newer vacuum cleaner with the latest Home App supports the definition of rooms, see Video
      Each room in the current map has an index, which is then assigned to the room from the app. From the robot we only get a mapping with room number and index. The adapter queries these rooms every time the adapter starts and creates a channel for each room, which then knows the current room index. The same happens manually with the button loadRooms. This channel can then be assigned to the ioBroker rooms. If the button roomClean is pressed, the index of the card is determined and sent to the robot, so that it can then vacuum this room. Before that the FAN power is set for single room suction. If you don't have the possibility to name the rooms in the app yet, there is also the possibility to create such a channel manually by specifying the map index. It is also possible to add zone coordinates instead of mapIndex. If you want to clean several rooms spontaneously, you can do this via multiRoomClean by assigning the ioBroker rooms to this data point and then pressing the button.
      Siggi0904 1 Reply Last reply Reply Quote 0
      • Siggi0904
        Siggi0904 @haselchen last edited by
        @haselchen okay, das klingt vielversprechend.
        loadMap hat keine Auswirkung. Da passiert nichts.
        Wo bekomme ich denn den map index des jeweiligen Raums her?
        Welche App nutzt du? Die Xiaomi Home-App?
        Oder die Roborock-App?
        Danke.
        • haselchen
          @siggi0904
          Die Xiaomi Home App.
          Den Map Index musste ausprobieren (jedenfalls war das bei mir noch so)
          Tatsächlich gehen die bei mir von 1 bis 4. Also zum Glück gleich am Anfang. Hab auch schon User gesehen, die mussten bis 15 probieren.
          Du kannst ja mit 1 anfangen, lässt den Sauger starten und siehst ja wenn er losfährt und wohin und dann benennst du den Raum.
          • Siggi0904
            @haselchen Ah, sehr cool. Funktioniert. 👍
            Sieht jetzt so aus:
            Wenn der noch die maps laden würde, wär das grandios.
            Sieht bei mir so aus:
            haselchen Vandura 2 Replies Last reply Reply Quote 1
            • haselchen
              haselchen Most Active @Siggi0904 last edited by haselchen
              @siggi0904
              Sieht schonmal schön aus.
              Die Map bekommst du über den Command Befehl.
              Das mag heute alles anders sein, meine Konfig ist paar Jahre alt.
              Ich hatte damals get_map_v1 in den Datenpunkt geschrieben
              Siehe Screenshot.
              Dann erschienen in Maps Daten
              Hier unten sind die ganzen Befehle:
              https://github.com/MeisterTR/XiaomiRobotVacuumProtocol
              Siggi0904 1 Reply Last reply Reply Quote 1
              • Siggi0904
                @haselchen ein control gibt es bei mir leider nicht.
                Bei loadMap unter cleanmap passiert nichts.
                • haselchen
                  @siggi0904
                  Mich nicht verschaukeln bitte 😉
                  Dein Screenshot von vorhin
                  • Siggi0904
                    @haselchen sorry, ich meinte command.
                    Ich habe nun nochmal in den Einstellungen vom Adapter geschaut.
                    Hab die Option "enable map from xiaomi cloud" aktiviert und die Option "use new map format with room colors".
                    Dann fliegen bei der Eingabe von 0 oder 1 oder 2 oder 3 die jeweiligen Karten unter map64 und mapURL ein.
                    control sieht hier so aus:
                    • haselchen
                      @siggi0904
                      Na dann kannste jetzt ja loslegen und das Haus sauber machen lassen 🤓
                      Die map64 URL benutzt man für VIS
                      Kannst Dir die Karte dort anzeigen lassen
                      • Siggi0904
                        @haselchen sehr cool, großen Dank. 😁 👍
                        • Vandura
                          Vandura @Siggi0904 last edited by
                          @siggi0904 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                          Sieht jetzt so aus:
                          Ich bekomme die Karte einfach nicht geladen...
                          • Siggi0904
                            Siggi0904 @Vandura last edited by
                            @vandura ich konnte die Karten erst laden nachdem ich die Räume angelegt hab.
                            Dann probiere mal die gleichen ID's wie die Räume für die Map durch.
                            Vandura 1 Reply Last reply Reply Quote 0
                            • Vandura
                              Ich habe das schon alles seit 2 Jahren, die Räume und alles. Ich musste nur den Adapter mal löschen und nach der Neuinstallation ist die Karte verschwunden.
                              Gruß Rick
                              • Vandura
                                Vandura @Vandura last edited by Vandura
                                Hier mal ein paar Pics zur Verdeutlichung...
                                Es lief mal alles......😧
                                Hier noch mein Canvas
                                pi@raspberrypi:~ $ cd /opt/iobroker
                                pi@raspberrypi:/opt/iobroker $ npm ls canvas
                                iobroker.inst@2.0.3 /opt/iobroker
                                ├── canvas@2.11.0
                                ├─┬ iobroker.mihome-vacuum@3.9.5
                                │ └── canvas@2.11.0 deduped
                                └─┬ iobroker.parcel@0.0.25
                                  └─┬ jsdom@20.0.3
                                raspberrypi
                                Plattform
                                linux
                                Betriebssystem
                                linux
                                Architektur
                                arm
                                CPUs
                                Geschwindigkeit
                                1500 MHz
                                Modell
                                unknown
                                RAM
                                7.58 GB
                                System-Betriebszeit
                                6 T. 04:23:42
                                Node.js
                                v18.15.0
                                time
                                1680529047566
                                timeOffset
                                -120
                                Anzahl der Adapter
                                470
                                NPM
                                9.5.0
                                Datenträgergröße
                                457.13 GB
                                freier Festplattenspeicher
                                420.35 GB
                                Betriebszeit
                                6 T. 04:22:43
                                Aktive Instanzen
                                29
                                Weg
                                /opt/iobroker/
                                Hostname
                                raspberrypi
                                • haselchen
                                  haselchen Most Active @Vandura last edited by
                                  @vandura
                                  Hast du es so gemacht wie oben beschrieben?
                                  Command Befehl?
                                  Zum Testen mal einen Raum angelegt?
                                  Adapter neu gestartet?
                                  Gerät neu gestartet?
                                  und und und....
                                  Edit: habs jetzt nicht im Blick, ob er mit Node18 läuft.
                                  Müsstest du mal nachschauen in den Infos oder auf Github.
                                  Ansonsten mal Node16 probieren.
                                  bahnuhr Vandura 2 Replies Last reply Reply Quote 0
                                  • bahnuhr
                                    bahnuhr Forum Testing Most Active @haselchen last edited by
                                    @haselchen sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                                    Läuft mit 18 einwandfrei.
                                    • haselchen
                                      haselchen Most Active @bahnuhr last edited by
                                      @bahnuhr
                                      @Vandura
                                      Okay, können wir das ausschliessen.
                                      • Vandura
                                        Vandura @haselchen last edited by
                                        @vandura
                                        Command Befehl?
                                        und und und....
                                        Jepp, habe ich gemacht mit dem Command Befehl.....passiert gar nichts....
                                        • haselchen
                                          haselchen Most Active @Vandura last edited by haselchen
                                          @vandura
                                          Es muss ja wenigstens eine Antwort kommen.
                                          Entweder im Log oder im DP selber.
                                          Unter x-get Response
                                          • Vandura
                                            Vandura @haselchen last edited by Vandura
                                            @vandura
                                            mihome-vacuum.0
                                            2023-04-03 16:59:23.904	debug	Receive <<< Helo <<< 213100200000000013173ccd642ae9cbffffffffffffffffffffffffffffffff
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.557	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.carpet_mode:{"val":true,"ack":true,"ts":1680533959555,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335414192}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.476	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533959472,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.471	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533959467,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.465	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.sound_volume:{"val":100,"ack":true,"ts":1680533959462,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335413873}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.463	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":111}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.461	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533959456,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.454	debug	Message= {"id":111,"method":"get_carpet_mode"}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.454	debug	Mappointer_updated
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.454	debug	MIIO RECIVE: {"result":["rubyslite%2F320289997%2F0"],"id":110}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.447	debug	Message= {"id":110,"method":"get_map_v1"}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.447	debug	MIIO RECIVE: {"result":[100],"id":109}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.435	debug	Message= {"id":109,"method":"get_sound_volume"}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.434	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.deviceInfo.wifi_signal:{"val":-50,"ack":true,"ts":1680533959431,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680523671786}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.431	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533959427,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.381	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.water_box_mode:{"val":202,"ack":true,"ts":1680533959357,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335413682}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.379	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.water_box:{"val":false,"ack":true,"ts":1680533959357,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335413682}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.376	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.dnd:{"val":false,"ack":true,"ts":1680533959357,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412477}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.368	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.error:{"val":0,"ack":true,"ts":1680533959347,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412477}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.365	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.fan_power:{"val":104,"ack":true,"ts":1680533959347,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412477}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.364	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.cleanedarea:{"val":24.71,"ack":true,"ts":1680533959347,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680431103614}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.362	debug	MIIO RECIVE: {"result":{"ssid":"xxxxxxxxxx","ip":"192.168.178.142","mac":"64:90:c1:01:38:b0","bssid":"1c:ed:6f:bc:e2:7d","rssi":-50},"id":108}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.361	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.cleanedtime:{"val":28,"ack":true,"ts":1680533959346,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680431346926}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.356	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.state:{"val":8,"ack":true,"ts":1680533959342,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680431407729}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.352	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.battery:{"val":100,"ack":true,"ts":1680533959342,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680437091348}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.348	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.mop:{"val":false,"ack":true,"ts":1680533959342,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412343}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.346	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533959340,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.333	debug	Message= {"id":108,"method":"get_network_info"}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.333	debug	setGetStatus {"msg_ver":2,"msg_seq":2407,"state":8,"battery":100,"clean_time":1678,"clean_area":24710000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.332	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":2407,"state":8,"battery":100,"clean_time":1678,"clean_area":24710000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"unsave_map_reason":0,"unsave_map_flag":0}],"id":107}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.320	debug	Message= {"id":107,"method":"get_status"}
                                            mihome-vacuum.0
                                            2023-04-03 16:59:19.320	debug	get params for stock Vacuum
                                            mihome-vacuum.0
                                            2023-04-03 16:59:13.901	debug	Receive <<< Helo <<< 213100200000000013173ccd642ae9c1ffffffffffffffffffffffffffffffff
                                            mihome-vacuum.0
                                            2023-04-03 16:59:03.897	debug	Receive <<< Helo <<< 213100200000000013173ccd642ae9b7ffffffffffffffffffffffffffffffff
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.275	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.carpet_mode:{"val":true,"ack":true,"ts":1680533939272,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335414192}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.270	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533939267,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.221	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533939210,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.219	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.sound_volume:{"val":100,"ack":true,"ts":1680533939210,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335413873}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.217	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":106}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.216	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533939209,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.200	debug	Message= {"id":106,"method":"get_carpet_mode"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.200	debug	Mappointer_updated
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.199	debug	MIIO RECIVE: {"result":["rubyslite%2F320289997%2F0"],"id":105}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.192	debug	Message= {"id":105,"method":"get_map_v1"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.191	debug	MIIO RECIVE: {"result":[100],"id":104}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.183	debug	Message= {"id":104,"method":"get_sound_volume"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.155	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.deviceInfo.wifi_signal:{"val":-50,"ack":true,"ts":1680533939151,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680523671786}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.091	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533939069,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.088	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.water_box_mode:{"val":202,"ack":true,"ts":1680533939069,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335413682}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.086	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.water_box:{"val":false,"ack":true,"ts":1680533939069,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335413682}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.084	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.dnd:{"val":false,"ack":true,"ts":1680533939068,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412477}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.081	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.error:{"val":0,"ack":true,"ts":1680533939067,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412477}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.079	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.fan_power:{"val":104,"ack":true,"ts":1680533939067,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412477}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.077	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.cleanedarea:{"val":24.71,"ack":true,"ts":1680533939067,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680431103614}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.075	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.cleanedtime:{"val":28,"ack":true,"ts":1680533939067,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680431346926}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.073	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.state:{"val":8,"ack":true,"ts":1680533939067,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680431407729}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.070	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.battery:{"val":100,"ack":true,"ts":1680533939066,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680437091348}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.062	debug	MIIO RECIVE: {"result":{"ssid":"XXXXXXX","ip":"192.168.178.142","mac":"64:90:c1:01:38:b0","bssid":"1c:ed:6f:bc:e2:7d","rssi":-50},"id":103}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.052	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.mop:{"val":false,"ack":true,"ts":1680533939046,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412343}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.049	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533939046,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.038	debug	Message= {"id":103,"method":"get_network_info"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.037	debug	setGetStatus {"msg_ver":2,"msg_seq":2406,"state":8,"battery":100,"clean_time":1678,"clean_area":24710000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.036	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":2406,"state":8,"battery":100,"clean_time":1678,"clean_area":24710000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"unsave_map_reason":0,"unsave_map_flag":0}],"id":102}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.028	debug	Message= {"id":102,"method":"get_status"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:59.028	debug	get params for stock Vacuum
                                            mihome-vacuum.0
                                            2023-04-03 16:58:53.894	debug	Receive <<< Helo <<< 213100200000000013173ccd642ae9adffffffffffffffffffffffffffffffff
                                            mihome-vacuum.0
                                            2023-04-03 16:58:43.890	debug	Receive <<< Helo <<< 213100200000000013173ccd642ae9a3ffffffffffffffffffffffffffffffff
                                            mihome-vacuum.0
                                            2023-04-03 16:58:39.025	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.carpet_mode:{"val":true,"ack":true,"ts":1680533919023,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335414192}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.948	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533918943,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.942	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533918935,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.932	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":101}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.926	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.sound_volume:{"val":100,"ack":true,"ts":1680533918917,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335413873}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.925	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533918916,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.920	debug	Message= {"id":101,"method":"get_carpet_mode"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.920	debug	Mappointer_updated
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.919	debug	MIIO RECIVE: {"result":["rubyslite%2F320289997%2F0"],"id":100}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.911	debug	Message= {"id":100,"method":"get_map_v1"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.910	debug	MIIO RECIVE: {"result":[100],"id":99}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.903	debug	Message= {"id":99,"method":"get_sound_volume"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.856	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.deviceInfo.wifi_signal:{"val":-50,"ack":true,"ts":1680533918852,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680523671786}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.851	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533918829,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.822	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.water_box_mode:{"val":202,"ack":true,"ts":1680533918777,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335413682}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.820	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.water_box:{"val":false,"ack":true,"ts":1680533918777,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335413682}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.817	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.dnd:{"val":false,"ack":true,"ts":1680533918777,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412477}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.815	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.error:{"val":0,"ack":true,"ts":1680533918777,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412477}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.812	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.control.fan_power:{"val":104,"ack":true,"ts":1680533918777,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412477}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.809	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.cleanedarea:{"val":24.71,"ack":true,"ts":1680533918776,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680431103614}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.807	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.cleanedtime:{"val":28,"ack":true,"ts":1680533918776,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680431346926}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.799	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.state:{"val":8,"ack":true,"ts":1680533918776,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680431407729}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.796	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.battery:{"val":100,"ack":true,"ts":1680533918776,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680437091348}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.791	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.mop:{"val":false,"ack":true,"ts":1680533918776,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680335412343}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.787	silly	States user redis pmessage mihome-vacuum.0.*/mihome-vacuum.0.info.connection:{"val":true,"ack":true,"ts":1680533918775,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1680533653851}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.774	debug	MIIO RECIVE: {"result":{"ssid":"xxxxxxxxx","ip":"192.168.178.142","mac":"64:90:c1:01:38:b0","bssid":"1c:ed:6f:bc:e2:7d","rssi":-50},"id":98}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.749	debug	Message= {"id":98,"method":"get_network_info"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.749	debug	setGetStatus {"msg_ver":2,"msg_seq":2405,"state":8,"battery":100,"clean_time":1678,"clean_area":24710000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"unsave_map_reason":0,"unsave_map_flag":0,"error_text":"No error"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.748	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":2405,"state":8,"battery":100,"clean_time":1678,"clean_area":24710000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":202,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"unsave_map_reason":0,"unsave_map_flag":0}],"id":97}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.740	debug	Message= {"id":97,"method":"get_status"}
                                            mihome-vacuum.0
                                            2023-04-03 16:58:38.739	debug	get params for stock Vacuum
                                            mihome-vacuum.0
                                            2023-04-03 16:58:33.885	debug	Receive <<< Helo <<< 213100200000000013173ccd642ae999ffffffffffffffffffffffffffffffff
                                            1198
                                            366016
