    4. Alpha Test js-controller 5.0
    • Feuersturm
      Feuersturm @foxriver76 last edited by Feuersturm
      @foxriver76 sagte in Alpha Test js-controller 5.0:
      @feuersturm In der Browserkonsole evtl. etwas was einen Hinweis geben könnte?
      Browser Konsole enthält keine Fehlermeldungen (Protokoll Fenster im Admin geöffnet und mal testweise eine Instanz neu gestartet).
      Werde gleich mal ein issue beim Controller eröffnen.
      https://github.com/ioBroker/ioBroker.js-controller/issues/2191
      Feuer-sturm created this issue in ioBroker/ioBroker.js-controller
      closed No auto update of admin log after updating to js-controller 5.0.1 #2191
        DocGame @apollon77 last edited by
        @apollon77 Bis auf den Yeelight-2 Adapter scheint alles zu laufen. Bei diesem kommt folgende Meldung:
        host.iobroker 2023-04-01 09:21:31.466	info	Restart adapter system.adapter.yeelight-2.0 because enabled
        host.iobroker 2023-04-01 09:21:31.466	error	instance system.adapter.yeelight-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker 2023-04-01 09:21:31.466	error	Caught by controller[1]: at TCP.<anonymous> (node:net:322:12)
        host.iobroker 2023-04-01 09:21:31.466	error	Caught by controller[1]: at Socket.emit (node:domain:489:12)
        host.iobroker 2023-04-01 09:21:31.466	error	Caught by controller[1]: at Socket.emit (node:events:525:35)
        host.iobroker 2023-04-01 09:21:31.466	error	Caught by controller[1]: at Object.onceWrapper (node:events:628:26)
        host.iobroker 2023-04-01 09:21:31.466	error	Caught by controller[1]: at Socket.onClose (node:net:911:10)
        host.iobroker 2023-04-01 09:21:31.466	error	Caught by controller[1]: at new NodeError (node:internal/errors:399:5)
        host.iobroker 2023-04-01 09:21:31.466	error	Caught by controller[1]: Error: Socket closed before the connection was established
        host.iobroker 2023-04-01 09:21:31.466	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        yeelight-2.0 2023-04-01 09:21:31.300	info	terminating
        yeelight-2.0 2023-04-01 09:21:30.801	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        yeelight-2.0 2023-04-01 09:21:30.801	info	terminating
        yeelight-2.0 2023-04-01 09:21:30.800	info	cleaned everything up...
        yeelight-2.0 2023-04-01 09:21:30.795	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
        yeelight-2.0 2023-04-01 09:21:30.795	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:399:5) at Socket.onClose (node:net:911:10) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:525:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:322:12)
        yeelight-2.0 2023-04-01 09:21:30.795	error	unhandled promise rejection: Socket closed before the connection was established
        yeelight-2.0 2023-04-01 09:21:30.795	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        yeelight-2.0 2023-04-01 09:21:27.240	info	starting. Version 1.2.1 (non-npm: iobroker-community-adapters/ioBroker.yeelight-2#2927cdb26f938e958726504bfa2d6dec43049b77) in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230330-e0b409fe
        host.iobroker 2023-04-01 09:21:25.668	info	instance system.adapter.yeelight-2.0 started with pid 701331
        host.iobroker 2023-04-01 09:21:25.216	info	"system.adapter.yeelight-2.0" enabled
        ? apollon77 2 Replies Last reply Reply Quote 0
          A Former User @DocGame last edited by
          @docgame
          hier mit dem Yeelight-Adapter keine Probleme, hab Node 18 installiert, im lxc unter debian bullseye.., alles auf latest:
          ilovegym@iobroker-test:/opt/iobroker$ iob logs --watch | grep yeelight
          2023-04-01 11:21:21.935  - info: host.iobroker-test iobroker add yeelight-2 --host iobroker-test
          2023-04-01 11:21:23.679  - info: host.iobroker-test iobroker  Installing iobroker.yeelight-2@1.2.1... (System call)
          2023-04-01 11:21:30.378  - info: host.iobroker-test iobroker host.iobroker-test install adapter yeelight-2
          2023-04-01 11:21:30.403  - info: host.iobroker-test iobroker upload [20] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/1.png icons/1.png image/png
          2023-04-01 11:21:30.413  - info: host.iobroker-test iobroker upload [19] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/2.png icons/2.png image/png
          2023-04-01 11:21:30.420  - info: host.iobroker-test iobroker upload [18] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/3.png icons/3.png image/png
          2023-04-01 11:21:30.425  - info: host.iobroker-test iobroker upload [17] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/4.png icons/4.png image/png
          2023-04-01 11:21:30.430  - info: host.iobroker-test iobroker upload [16] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/5.png icons/5.png image/png
          2023-04-01 11:21:30.435  - info: host.iobroker-test iobroker upload [15] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/6.png icons/6.png image/png
          2023-04-01 11:21:30.441  - info: host.iobroker-test iobroker upload [14] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/7.png icons/7.png image/png
          2023-04-01 11:21:30.452  - info: host.iobroker-test iobroker upload [13] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/bslamp1.png icons/bslamp1.png image/png
          2023-04-01 11:21:30.462  - info: host.iobroker-test iobroker upload [12] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling1.png icons/ceiling1.png image/png
          2023-04-01 11:21:30.466  - info: host.iobroker-test iobroker upload [11] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling10.png icons/ceiling10.png image/png
          2023-04-01 11:21:30.471  - info: host.iobroker-test iobroker upload [10] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling3.png icons/ceiling3.png image/png
          2023-04-01 11:21:30.476  - info: host.iobroker-test iobroker upload [9] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/ceiling4.png icons/ceiling4.png image/png
          2023-04-01 11:21:30.480  - info: host.iobroker-test iobroker upload [8] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/color.png icons/color.png image/png
          2023-04-01 11:21:30.484  - info: host.iobroker-test iobroker upload [7] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/desklamp.png icons/desklamp.png image/png
          2023-04-01 11:21:30.487  - info: host.iobroker-test iobroker upload [6] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/mono.png icons/mono.png image/png
          2023-04-01 11:21:30.491  - info: host.iobroker-test iobroker upload [5] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/icons/stripe.png icons/stripe.png image/png
          2023-04-01 11:21:30.499  - info: host.iobroker-test iobroker upload [4] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index.html index.html text/html
          2023-04-01 11:21:30.503  - info: host.iobroker-test iobroker upload [3] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/index_m.html index_m.html text/html
          2023-04-01 11:21:30.508  - info: host.iobroker-test iobroker upload [2] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/lan.jpg lan.jpg image/jpeg
          2023-04-01 11:21:30.512  - info: host.iobroker-test iobroker upload [1] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/words.js words.js application/javascript
          2023-04-01 11:21:30.516  - info: host.iobroker-test iobroker upload [0] yeelight-2.admin /opt/iobroker/node_modules/iobroker.yeelight-2/admin/yeelight.png yeelight.png image/png
          2023-04-01 11:21:30.538  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2 created/updated
          2023-04-01 11:21:30.554  - info: host.iobroker-test iobroker host.iobroker-test create instance yeelight-2
          2023-04-01 11:21:30.560  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.alive created
          2023-04-01 11:21:30.565  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.connected created
          2023-04-01 11:21:30.571  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.compactMode created
          2023-04-01 11:21:30.576  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.cpu created
          2023-04-01 11:21:30.581  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.cputime created
          2023-04-01 11:21:30.586  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.memHeapUsed created
          2023-04-01 11:21:30.591  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.memHeapTotal created
          2023-04-01 11:21:30.596  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.memRss created
          2023-04-01 11:21:30.602  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.uptime created
          2023-04-01 11:21:30.612  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.inputCount created
          2023-04-01 11:21:30.620  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.outputCount created
          2023-04-01 11:21:30.626  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.eventLoopLag created
          2023-04-01 11:21:30.631  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.sigKill created
          2023-04-01 11:21:30.635  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0.logLevel created
          2023-04-01 11:21:30.641  - info: host.iobroker-test iobroker host.iobroker-test object system.adapter.yeelight-2.0 created
          2023-04-01 11:21:33.663  - info: host.iobroker-test instance system.adapter.yeelight-2.0 started with pid 4466
          2023-04-01 11:21:34.653  - info: yeelight-2.0 (4466) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230330-e0b409fe
          2023-04-01 11:22:47.259  - info: host.iobroker-test stopInstance system.adapter.yeelight-2.0 (force=false, process=true)
          2023-04-01 11:22:47.261  - info: yeelight-2.0 (4466) Got terminate signal TERMINATE_YOURSELF
          2023-04-01 11:22:47.262  - info: yeelight-2.0 (4466) cleaned everything up...
          2023-04-01 11:22:47.263  - info: yeelight-2.0 (4466) terminating
          2023-04-01 11:22:47.263  - info: yeelight-2.0 (4466) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2023-04-01 11:22:47.304  - info: host.iobroker-test stopInstance system.adapter.yeelight-2.0 send kill signal
          2023-04-01 11:22:47.763  - info: yeelight-2.0 (4466) terminating
          2023-04-01 11:22:47.787  - info: host.iobroker-test instance system.adapter.yeelight-2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2023-04-01 11:22:50.327  - info: host.iobroker-test instance system.adapter.yeelight-2.0 started with pid 4481
          2023-04-01 11:22:51.238  - info: yeelight-2.0 (4481) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230330-e0b409fe
          2023-04-01 11:22:51.348  - info: yeelight-2.0 (4481) State value to set for "yeelight-2.0.bslamp1-0x000000000f2c60fd.info.Port" has to be type "number" but received type "string"
          2023-04-01 11:22:51.355  - info: yeelight-2.0 (4481) State value to set for "yeelight-2.0.stripe-0x000000000361a2e1.info.Port" has to be type "number" but received type "string"
          Welche Node Version hast du installiert?
            seq.0
            2023-04-01 10:17:13.167 warn State "seq.0.system.adapter.seq.0.logging" has no existing object, this might lead to an error in future versions
            seq.0
            2023-04-01 10:17:13.145 info starting. Version 0.2.10 in /opt/iobroker/node_modules/iobroker.seq, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230330-e0b409fe
            host.usv-serverschrank
            2023-04-01 10:17:12.531 info instance system.adapter.seq.0 started with pid 24436
            der ist verkehrt
              DocGame @Guest last edited by DocGame
              @ilovegym Node.js: v18.15.0 wie bei dir....
              Nachtrag; Ich habe die Instanz gelöscht....eine neue gemacht....und jetzt kommen keine Fehler mehr
                apollon77 @arteck last edited by
                @arteck danke. Foxriver hat damit Fehler gefunden.
                  apollon77 @DocGame last edited by
                  @docgame hat nichts mit Controller zu tun.
                  • Feuersturm
                    Feuersturm last edited by
                    @apollon77 Schreibst du hier, wenn es eine neue Version vom js-controller gibt die getestet werden soll?
                      e-i-k-e last edited by
                      Beeindruckend wie schnell das update auf den js-controller 5.0 durchgeführt worden ist.
                      Ich habe auch das bekannte Problem mit dem log und der milight-smart-light Adapter funktioniert nicht wirklich.
                      https://github.com/Steiger04/ioBroker.milight-smart-light/issues/58
                      Ansonsten läuft alles. 👍
                      e-i-k-e created this issue in Steiger04/ioBroker.milight-smart-light
                      open main->::Error: Parameter "enumName" (js-controller 5.0) #58
                        apollon77 @Feuersturm last edited by
                        @feuersturm Na klar,
                          Nach einem erneuten Neustart von ioBroker, will mein Yeelight Adapter plötzlich auch nicht mehr.
                          host.ioBroker-Rock
                          2023-04-02 21:33:58.543	warn	Do not restart adapter system.adapter.yeelight-2.0 because restart loop detected
                          host.ioBroker-Rock
                          2023-04-02 21:33:58.543	info	Restart adapter system.adapter.yeelight-2.0 because enabled
                          host.ioBroker-Rock
                          2023-04-02 21:33:58.543	error	instance system.adapter.yeelight-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          host.ioBroker-Rock
                          2023-04-02 21:33:58.542	error	Caught by controller[0]: at TCP.<anonymous> (node:net:322:12)
                          host.ioBroker-Rock
                          2023-04-02 21:33:58.542	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
                          host.ioBroker-Rock
                          2023-04-02 21:33:58.542	error	Caught by controller[0]: at Socket.emit (node:events:525:35)
                          host.ioBroker-Rock
                          2023-04-02 21:33:58.541	error	Caught by controller[0]: at Object.onceWrapper (node:events:628:26)
                          host.ioBroker-Rock
                          2023-04-02 21:33:58.541	error	Caught by controller[0]: at Socket.onClose (node:net:911:10)
                          host.ioBroker-Rock
                          2023-04-02 21:33:58.541	error	Caught by controller[0]: at new NodeError (node:internal/errors:399:5)
                          host.ioBroker-Rock
                          2023-04-02 21:33:58.540	error	Caught by controller[0]: Error: Socket closed before the connection was established
                          host.ioBroker-Rock
                          2023-04-02 21:33:58.539	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          yeelight-2.0
                          2023-04-02 21:33:58.409	info	terminating
                          yeelight-2.0
                          2023-04-02 21:33:57.906	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          yeelight-2.0
                          2023-04-02 21:33:57.904	info	terminating
                          yeelight-2.0
                          2023-04-02 21:33:57.903	info	cleaned everything up...
                          yeelight-2.0
                          2023-04-02 21:33:57.875	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
                          yeelight-2.0
                          2023-04-02 21:33:57.874	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:399:5) at Socket.onClose (node:net:911:10) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:525:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:322:12)
                          yeelight-2.0
                          2023-04-02 21:33:57.873	error	unhandled promise rejection: Socket closed before the connection was established
                          yeelight-2.0
                          2023-04-02 21:33:57.871	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          yeelight-2.0
                          2023-04-02 21:33:54.669	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230330-e0b409fe
                          host.ioBroker-Rock
                          2023-04-02 21:33:50.899	info	instance system.adapter.yeelight-2.0 started with pid 23551
                          alexa2.0
                          2023-04-02 21:33:50.136	info	Alexa-Push-Connection disconnected - retry: Retry Connection in 60s
                          host.ioBroker-Rock
                          2023-04-02 21:33:20.706	info	Restart adapter system.adapter.yeelight-2.0 because enabled
                          host.ioBroker-Rock
                          2023-04-02 21:33:20.705	error	instance system.adapter.yeelight-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          host.ioBroker-Rock
                          2023-04-02 21:33:20.705	error	Caught by controller[1]: at TCP.<anonymous> (node:net:322:12)
                          host.ioBroker-Rock
                          2023-04-02 21:33:20.704	error	Caught by controller[1]: at Socket.emit (node:domain:489:12)
                          host.ioBroker-Rock
                          2023-04-02 21:33:20.704	error	Caught by controller[1]: at Socket.emit (node:events:525:35)
                          host.ioBroker-Rock
                          2023-04-02 21:33:20.701	error	Caught by controller[1]: at Object.onceWrapper (node:events:628:26)
                          host.ioBroker-Rock
                          2023-04-02 21:33:20.701	error	Caught by controller[1]: at Socket.onClose (node:net:911:10)
                          host.ioBroker-Rock
                          2023-04-02 21:33:20.701	error	Caught by controller[1]: at new NodeError (node:internal/errors:399:5)
                          host.ioBroker-Rock
                          2023-04-02 21:33:20.700	error	Caught by controller[1]: Error: Socket closed before the connection was established
                          host.ioBroker-Rock
                          2023-04-02 21:33:20.699	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          yeelight-2.0
                          2023-04-02 21:33:20.586	info	terminating
                          yeelight-2.0
                          2023-04-02 21:33:20.084	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          yeelight-2.0
                          2023-04-02 21:33:20.082	info	terminating
                          yeelight-2.0
                          2023-04-02 21:33:20.081	info	cleaned everything up...
                          yeelight-2.0
                          2023-04-02 21:33:20.051	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
                          yeelight-2.0
                          2023-04-02 21:33:20.049	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:399:5) at Socket.onClose (node:net:911:10) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:525:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:322:12)
                          yeelight-2.0
                          2023-04-02 21:33:20.048	error	unhandled promise rejection: Socket closed before the connection was established
                          yeelight-2.0
                          2023-04-02 21:33:20.047	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          yeelight-2.0
                          2023-04-02 21:33:16.855	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230330-e0b409fe
                          host.ioBroker-Rock
                          2023-04-02 21:33:13.855	info	instance system.adapter.yeelight-2.0 started with pid 23534
                            Alpha (@next) updated to 5.0.1-alpha.0-20230403-fd495c2e
                            • Fixes missing logging object when logTransporter is used (e.g. Admin)
                            • Fixes other issue with logTransporter (e.g. Admin) - events should now stream again in Admin
                            • Fixed Compact group initialization
                            • Fixes Binary/Text detection in writeFile
                            • Fixes sendToHost (all) command
                            Laut aktuellem stand sind damit alle gemeldete und auf den controller zurückzuführeden Themen behoben. Das Windows Kodi/git-npm-Fehler Thema muss man noch genauer untersuchen denke ich.
                            Gaspode Feuersturm 2 Replies Last reply Reply Quote 0
                            • Gaspode
                              Gaspode @apollon77 last edited by Gaspode
                              @apollon77
                              Die Missing Logging object Warnung tritt hier nicht mehr auf
                              Admin Log wird automatisch aktualisiert (wobei das bei mir ja auch mit der Vorgängerversion ging)
                              Sonst ist mir erst mal nix aufgefallen, nur ein alter bekannter unter Windows ist wieder da (das liegt aber am aktualisierten JavaScript Adapter): Der Font für die Symbole im Suchfenster ist kaputt:
                              Fehlermeldung im Log
                              javascript.0	2023-04-03 12:43:30.883	error	Cannot patch font: Error: Parameter "data" needs to be a Buffer but type "object" has been passed
                              Edit: OK, vergiss es, hat Bluefox bereits (wieder) in GIT gefixt.
                                Danke für das Update.
                                Das Problem mit Yeelight besteht weiterhin.
                                host.ioBroker-Rock
                                2023-04-03 21:29:21.231	info	Restart adapter system.adapter.yeelight-2.0 because enabled
                                host.ioBroker-Rock
                                2023-04-03 21:29:21.230	error	instance system.adapter.yeelight-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                host.ioBroker-Rock
                                2023-04-03 21:29:21.229	error	Caught by controller[1]: at TCP.<anonymous> (node:net:322:12)
                                host.ioBroker-Rock
                                2023-04-03 21:29:21.228	error	Caught by controller[1]: at Socket.emit (node:domain:489:12)
                                host.ioBroker-Rock
                                2023-04-03 21:29:21.227	error	Caught by controller[1]: at Socket.emit (node:events:525:35)
                                host.ioBroker-Rock
                                2023-04-03 21:29:21.227	error	Caught by controller[1]: at Object.onceWrapper (node:events:628:26)
                                host.ioBroker-Rock
                                2023-04-03 21:29:21.226	error	Caught by controller[1]: at Socket.onClose (node:net:911:10)
                                host.ioBroker-Rock
                                2023-04-03 21:29:21.225	error	Caught by controller[1]: at new NodeError (node:internal/errors:399:5)
                                host.ioBroker-Rock
                                2023-04-03 21:29:21.225	error	Caught by controller[1]: Error: Socket closed before the connection was established
                                host.ioBroker-Rock
                                2023-04-03 21:29:21.224	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                yeelight-2.0
                                2023-04-03 21:29:20.592	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                yeelight-2.0
                                2023-04-03 21:29:20.590	info	terminating
                                yeelight-2.0
                                2023-04-03 21:29:20.589	info	cleaned everything up...
                                yeelight-2.0
                                2023-04-03 21:29:20.562	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
                                yeelight-2.0
                                2023-04-03 21:29:20.561	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:399:5) at Socket.onClose (node:net:911:10) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:525:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:322:12)
                                yeelight-2.0
                                2023-04-03 21:29:20.560	error	unhandled promise rejection: Socket closed before the connection was established
                                yeelight-2.0
                                2023-04-03 21:29:20.558	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                host.ioBroker-Rock
                                2023-04-03 21:29:20.372	info	instance system.adapter.alexa2.0 started with pid 33531
                                host.ioBroker-Rock
                                2023-04-03 21:29:18.170	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.ioBroker-Rock
                                2023-04-03 21:29:17.910	info	instance system.adapter.device-watcher.0 started with pid 33520
                                yeelight-2.0
                                2023-04-03 21:29:17.308	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230403-fd495c2e
                                • Feuersturm
                                  Feuersturm @apollon77 last edited by
                                  @apollon77 sagte in Alpha Test js-controller 5.0:
                                  Master Slave System wurde erfolgreich aktualisiert.
                                  Admin Log aktualisiert sich jetzt auch wieder automatisch
                                  Bisher keine weiteren Auffälligkeiten bei mir 🙂
                                  Dankeschön 🌻
                                    apollon77 @e-i-k-e last edited by
                                    @e-i-k-e mach mal loglevel Debug. Vllt sieht man da mehr.
                                      e-i-k-e @apollon77 last edited by
                                      @apollon77
                                      Gerne.
                                      host.ioBroker-Rock
                                      2023-04-03 23:27:06.136	info	Restart adapter system.adapter.yeelight-2.0 because enabled
                                      host.ioBroker-Rock
                                      2023-04-03 23:27:06.135	error	instance system.adapter.yeelight-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      host.ioBroker-Rock
                                      2023-04-03 23:27:06.135	error	Caught by controller[1]: at TCP.<anonymous> (node:net:322:12)
                                      host.ioBroker-Rock
                                      2023-04-03 23:27:06.135	error	Caught by controller[1]: at Socket.emit (node:domain:489:12)
                                      host.ioBroker-Rock
                                      2023-04-03 23:27:06.134	error	Caught by controller[1]: at Socket.emit (node:events:525:35)
                                      host.ioBroker-Rock
                                      2023-04-03 23:27:06.134	error	Caught by controller[1]: at Object.onceWrapper (node:events:628:26)
                                      host.ioBroker-Rock
                                      2023-04-03 23:27:06.134	error	Caught by controller[1]: at Socket.onClose (node:net:911:10)
                                      host.ioBroker-Rock
                                      2023-04-03 23:27:06.134	error	Caught by controller[1]: at new NodeError (node:internal/errors:399:5)
                                      host.ioBroker-Rock
                                      2023-04-03 23:27:06.133	error	Caught by controller[1]: Error: Socket closed before the connection was established
                                      host.ioBroker-Rock
                                      2023-04-03 23:27:06.133	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      yeelight-2.0
                                      2023-04-03 23:27:05.485	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      yeelight-2.0
                                      2023-04-03 23:27:05.484	debug	Plugin sentry destroyed
                                      yeelight-2.0
                                      2023-04-03 23:27:05.483	info	terminating
                                      yeelight-2.0
                                      2023-04-03 23:27:05.482	info	cleaned everything up...
                                      yeelight-2.0
                                      2023-04-03 23:27:05.446	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
                                      yeelight-2.0
                                      2023-04-03 23:27:05.445	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:399:5) at Socket.onClose (node:net:911:10) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:525:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:322:12)
                                      yeelight-2.0
                                      2023-04-03 23:27:05.445	error	unhandled promise rejection: Socket closed before the connection was established
                                      yeelight-2.0
                                      2023-04-03 23:27:05.444	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      yeelight-2.0
                                      2023-04-03 23:27:05.436	debug	ERROR YEELIGHT CONNECTION: 0x000000000000000: Connection 192.168.3.140:55443: Error: connect EHOSTUNREACH 192.168.3.140:55443
                                      yeelight-2.0
                                      2023-04-03 23:27:02.673	debug	DEVICE FOUND IN AND CONFIG: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
                                      yeelight-2.0
                                      2023-04-03 23:27:02.670	debug	INITINAL ID FOUND FOR: color-0x0000000005ed0835
                                      yeelight-2.0
                                      2023-04-03 23:27:02.669	debug	RESPONSE MESSAGE: from: 0x0000000005ed0835, id: 1, result:[off,23,16711680,2,3000,,,0,100,0,,,,,,,,]}
                                      yeelight-2.0
                                      2023-04-03 23:27:02.642	debug	YEELIGHT FOUND: 192.168.3.141:55443 id: 0x0000000005ed0835 model: color
                                      yeelight-2.0
                                      2023-04-03 23:27:02.349	debug	YEELIGHT FOUND: 192.168.3.140:55443 id: 0x000000000000000 model: color
                                      yeelight-2.0
                                      2023-04-03 23:27:02.333	debug	SMARTNAME:
                                      yeelight-2.0
                                      2023-04-03 23:27:02.331	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                      yeelight-2.0
                                      2023-04-03 23:27:02.323	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_groß
                                      yeelight-2.0
                                      2023-04-03 23:27:02.322	debug	SMARTNAME:
                                      yeelight-2.0
                                      2023-04-03 23:27:02.320	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
                                      yeelight-2.0
                                      2023-04-03 23:27:02.308	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_klein
                                      yeelight-2.0
                                      2023-04-03 23:27:02.307	debug	DEVICES IN OBJECTS FOUND: 2
                                      yeelight-2.0
                                      2023-04-03 23:27:02.306	debug	DEVICES IN OBJECTS: {"yeelight-2.0.Stehlampe_Schlafzimmer_klein":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_klein","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629168,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_klein","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},"yeelight-2.0.Stehlampe_Schlafzimmer_groß":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_groß","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629164,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_groß","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}}
                                      yeelight-2.0
                                      2023-04-03 23:27:02.272	debug	DEVICES IN CONFIG: [{"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]},{"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}]
                                      yeelight-2.0
                                      2023-04-03 23:27:02.218	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230403-fd495c2e
                                      yeelight-2.0
                                      2023-04-03 23:27:01.853	debug	Plugin sentry Initialize Plugin (enabled=true)
                                      mqtt.0
                                      2023-04-03 23:27:01.267	info	Client [] connected with secret 1680557221267_3140
                                      mqtt.0
                                      2023-04-03 23:27:01.022	info	Client [] connection closed: disconnected
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:59.134	info	instance system.adapter.yeelight-2.0 started with pid 34722
                                      influxdb.0
                                      2023-04-03 23:26:36.571	info	Store 501 buffered influxDB history points
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:29.001	info	Restart adapter system.adapter.yeelight-2.0 because enabled
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:29.000	error	instance system.adapter.yeelight-2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:29.000	error	Caught by controller[0]: at TCP.<anonymous> (node:net:322:12)
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:29.000	error	Caught by controller[0]: at Socket.emit (node:domain:489:12)
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:28.999	error	Caught by controller[0]: at Socket.emit (node:events:525:35)
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:28.999	error	Caught by controller[0]: at Object.onceWrapper (node:events:628:26)
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:28.999	error	Caught by controller[0]: at Socket.onClose (node:net:911:10)
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:28.999	error	Caught by controller[0]: at new NodeError (node:internal/errors:399:5)
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:28.998	error	Caught by controller[0]: Error: Socket closed before the connection was established
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:28.997	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      yeelight-2.0
                                      2023-04-03 23:26:28.347	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      yeelight-2.0
                                      2023-04-03 23:26:28.346	debug	Plugin sentry destroyed
                                      yeelight-2.0
                                      2023-04-03 23:26:28.345	info	terminating
                                      yeelight-2.0
                                      2023-04-03 23:26:28.344	info	cleaned everything up...
                                      yeelight-2.0
                                      2023-04-03 23:26:28.323	error	Exception-Code: ERR_SOCKET_CLOSED_BEFORE_CONNECTION: Socket closed before the connection was established
                                      yeelight-2.0
                                      2023-04-03 23:26:28.323	error	Error: Socket closed before the connection was established at new NodeError (node:internal/errors:399:5) at Socket.onClose (node:net:911:10) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:525:35) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:322:12)
                                      yeelight-2.0
                                      2023-04-03 23:26:28.322	error	unhandled promise rejection: Socket closed before the connection was established
                                      yeelight-2.0
                                      2023-04-03 23:26:28.322	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      yeelight-2.0
                                      2023-04-03 23:26:28.315	debug	ERROR YEELIGHT CONNECTION: 0x000000000000000: Connection 192.168.3.140:55443: Error: connect EHOSTUNREACH 192.168.3.140:55443
                                      yeelight-2.0
                                      2023-04-03 23:26:26.545	debug	DEVICE FOUND IN AND CONFIG: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
                                      yeelight-2.0
                                      2023-04-03 23:26:26.542	debug	INITINAL ID FOUND FOR: color-0x0000000005ed0835
                                      yeelight-2.0
                                      2023-04-03 23:26:26.542	debug	RESPONSE MESSAGE: from: 0x0000000005ed0835, id: 1, result:[off,23,16711680,2,3000,,,0,100,0,,,,,,,,]}
                                      yeelight-2.0
                                      2023-04-03 23:26:25.547	debug	YEELIGHT FOUND: 192.168.3.141:55443 id: 0x0000000005ed0835 model: color
                                      yeelight-2.0
                                      2023-04-03 23:26:25.254	debug	YEELIGHT FOUND: 192.168.3.140:55443 id: 0x000000000000000 model: color
                                      yeelight-2.0
                                      2023-04-03 23:26:25.238	debug	SMARTNAME:
                                      yeelight-2.0
                                      2023-04-03 23:26:25.236	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]}
                                      yeelight-2.0
                                      2023-04-03 23:26:25.229	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_groß
                                      yeelight-2.0
                                      2023-04-03 23:26:25.228	debug	SMARTNAME:
                                      yeelight-2.0
                                      2023-04-03 23:26:25.226	debug	OLD CONF. FROM OBJ: {"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}
                                      yeelight-2.0
                                      2023-04-03 23:26:25.213	debug	OBJ_ELEMENT: yeelight-2.0.Stehlampe_Schlafzimmer_klein
                                      yeelight-2.0
                                      2023-04-03 23:26:25.212	debug	DEVICES IN OBJECTS FOUND: 2
                                      yeelight-2.0
                                      2023-04-03 23:26:25.211	debug	DEVICES IN OBJECTS: {"yeelight-2.0.Stehlampe_Schlafzimmer_klein":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_klein","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629168,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_klein","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}},"yeelight-2.0.Stehlampe_Schlafzimmer_groß":{"type":"device","common":{"name":"color","icon":"/icons/color.png"},"native":{"sid":"Stehlampe_Schlafzimmer_groß","type":"color"},"from":"system.adapter.yeelight-2.0","user":"system.user.admin","ts":1680464629164,"_id":"yeelight-2.0.Stehlampe_Schlafzimmer_groß","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}}
                                      yeelight-2.0
                                      2023-04-03 23:26:25.181	debug	DEVICES IN CONFIG: [{"name":"Stehlampe_Schlafzimmer_groß","ip":"192.168.3.140","port":"55443","smart_name":"","type":"color","id":"0x000000000000000","supports":["get_prop","set_default","set_power","toggle","set_bright","start_cf","stop_cf","set_scene","cron_add","cron_get","cron_del","set_ct_abx","set_rgb","set_hsv","set_adjust","adjust_bright","adjust_ct","adjust_color","set_music","set_name"]},{"name":"Stehlampe_Schlafzimmer_klein","ip":"192.168.3.141","port":"55443","smart_name":"","type":"color","id":"0x0000000005ed0835"}]
                                      yeelight-2.0
                                      2023-04-03 23:26:25.142	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.yeelight-2, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230403-fd495c2e
                                      yeelight-2.0
                                      2023-04-03 23:26:24.734	debug	Plugin sentry Initialize Plugin (enabled=true)
                                      yeelight-2.0
                                      2023-04-03 23:26:24.629	debug	States connected to redis: 192.168.3.104:6379
                                      yeelight-2.0
                                      2023-04-03 23:26:24.617	debug	States create User PubSub Client
                                      yeelight-2.0
                                      2023-04-03 23:26:24.615	debug	States create System PubSub Client
                                      yeelight-2.0
                                      2023-04-03 23:26:24.608	debug	Redis States: Use Redis connection: 192.168.3.104:6379
                                      yeelight-2.0
                                      2023-04-03 23:26:24.587	debug	Objects connected to redis: 192.168.3.104:6379
                                      yeelight-2.0
                                      2023-04-03 23:26:24.579	debug	Objects client initialize lua scripts
                                      yeelight-2.0
                                      2023-04-03 23:26:23.863	debug	Objects create User PubSub Client
                                      yeelight-2.0
                                      2023-04-03 23:26:23.861	debug	Objects create System PubSub Client
                                      yeelight-2.0
                                      2023-04-03 23:26:23.856	debug	Objects client ready ... initialize now
                                      yeelight-2.0
                                      2023-04-03 23:26:23.793	debug	Redis Objects: Use Redis connection: 192.168.3.104:6379
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:21.996	info	instance system.adapter.yeelight-2.0 started with pid 34705
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:21.680	info	"system.adapter.yeelight-2.0" enabled
                                      host.ioBroker-Rock
                                      2023-04-03 23:26:10.184	info	"system.adapter.yeelight-2.0" disabled
                                        @e-i-k-e sagte in Alpha Test js-controller 5.0:
                                        Also mal abgesehen vom crash tippe ich das eher das dein issue ist ... EHOSTUNREACH heisst das das gerät im Netzwerk nicht da ist ... Ich denke er adapter code schliesst darauf hin das socket was aber nie offen war wegen dem Fehler. Bitte adapter issue anlegen das man das dort fixt ... und schau warum das Geröt nicht online ist
                                          apollon77 last edited by apollon77
                                          Alpha Update
                                          5.0.1-alpha.0-20230406-4552d569
                                          • Fixes compact mode
                                          • Hide warning about "www folder not found" for widgets adapters
                                          Wenn alles so stabil bleibt würde wir überlegen Mitte nächste Woche in den Beta Test im Latest Repo zu gehen ...
                                          Gaspode Thomas Braun Feuersturm 3 Replies Last reply Reply Quote 2
                                          • Gaspode
                                            @apollon77
                                            Keine Auffälligkeiten. Den Compact Mode nutze ich normalerweise nicht. Hab ihn jetzt mal testweise nach langer Suche 🙂 eingeschaltet (Windows) und merke keinen Unterschied zu vorher. Ist wahrscheinlich gut so, aber kann ich irgendwie kontrollieren, dass er auch wirklich aktiv ist? Hinter jeder Instanz wird jedenfalls noch unterschiedliche RAM Nutzung angezeigt.
                                            @apollon77 said in Alpha Test js-controller 5.0:
                                            Dazu kann ich nix sagen, kenne die Warning nicht.
                                            140
                                            20656
