    4. Test ioBroker unter Windows installieren - 2023 Edition
    • David G.
      David G. @Gaspode last edited by
      @gaspode
      Ich wollte eben einen Adapter über git installieren.
      In einem anderem Thread habe ich erfahren, dass folgende Meldung wohl bedeutet, dass kein git vorhanden ist.
      0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
      1 info using npm@9.5.0
      2 info using node@v18.15.0
      3 timing npm:load:whichnode Completed in 3ms
      4 timing config:load:defaults Completed in 3ms
      5 timing config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc Completed in 4ms
      6 timing config:load:builtin Completed in 4ms
      7 timing config:load:cli Completed in 4ms
      8 timing config:load:env Completed in 1ms
      9 timing config:load:file:C:\ioBroker\.npmrc Completed in 0ms
      10 timing config:load:project Completed in 3ms
      11 timing config:load:file:C:\WINDOWS\system32\config\systemprofile\.npmrc Completed in 0ms
      12 timing config:load:user Completed in 0ms
      13 timing config:load:file:C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm\etc\npmrc Completed in 1ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:setEnvs Completed in 2ms
      16 timing config:load Completed in 19ms
      17 timing npm:load:configload Completed in 20ms
      18 timing npm:load:mkdirpcache Completed in 1ms
      19 timing npm:load:mkdirplogs Completed in 0ms
      20 verbose title npm install copystring/ioBroker.roborock#dev
      21 verbose argv "install" "copystring/ioBroker.roborock#dev"
      22 timing npm:load:setTitle Completed in 4ms
      23 timing config:load:flatten Completed in 6ms
      24 timing npm:load:display Completed in 7ms
      25 verbose logfile logs-max:10 dir:C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2023-03-30T08_57_07_607Z-
      26 verbose logfile C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2023-03-30T08_57_07_607Z-debug-0.log
      27 timing npm:load:logFile Completed in 9ms
      28 timing npm:load:timers Completed in 0ms
      29 timing npm:load:configScope Completed in 0ms
      30 timing npm:load Completed in 45ms
      31 timing arborist:ctor Completed in 1ms
      32 silly logfile start cleaning logs, removing 8 files
      33 timing idealTree:init Completed in 565ms
      34 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.js-controller
      35 timing idealTree Completed in 645ms
      36 timing command:install Completed in 659ms
      37 verbose stack Error: An unknown git error occurred
      37 verbose stack     at makeError (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\make-error.js:28:13)
      37 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\git\lib\spawn.js:37:26
      37 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      38 verbose cwd C:\ioBroker
      39 verbose Windows_NT 10.0.22621
      40 verbose node v18.15.0
      41 verbose npm  v9.5.0
      42 error code ENOENT
      43 error syscall spawn git
      44 error path git
      45 error errno -4058
      46 error enoent An unknown git error occurred
      47 error enoent This is related to npm not being able to find a file.
      47 error enoent
      48 verbose exit -4058
      49 timing npm Completed in 750ms
      50 verbose unfinished npm timer reify 1680166627692
      51 verbose unfinished npm timer reify:loadTrees 1680166627699
      52 verbose unfinished npm timer idealTree:userRequests 1680166628267
      53 verbose code -4058
      54 error A complete log of this run can be found in:
      54 error     C:\WINDOWS\system32\config\systemprofile\AppData\Local\npm-cache\_logs\2023-03-30T08_57_07_607Z-debug-0.log
      Ist es möglich, gut fest/optional im Installer zu integrieren?
      Gaspode 1 Reply Last reply Reply Quote 0
      • JB_Sullivan
        JB_Sullivan last edited by
        So, dann werde ich mich heute auch mal ran trauen. Mein Produktiv System läuft ja nach wie vor und bevorzugt auf Windows. Ich habe zwar hin und wieder so einen Anflug, das ich mich unter Proxmox auch auf Linux Basis an ioB ab-arbeite. Da fühle ich mich aber deutlich unsicherer als unter Windows.
        Wenn aber bald der js-controller 5.x Einzug halten wird, werde ich über kurz oder lang mit meiner Node 14.xx nicht mehr weit kommen.
        "Leider" ist meine produktive Installation noch die "Altlast" von @Stabilostick, welche mir aber über die Jahre immer gute Dienste geleistet hat (bis auf die Zeit, wo ein Bug, beim deinstallieren von Adaptern, in der iobroker.json bösen Unfug angerichtet hatte)
        Ich werde berichten, wie die Installation / Migration aus dem alten Produktivsystem heraus mit dem neuen Installer funktioniert hat 🙂
          sigi234 Forum Testing Most Active @JB_Sullivan last edited by sigi234
          @jb_sullivan
          TIP:
          Stoppe iob und sichere den Ordner iobroker-data
          • JB_Sullivan
            JB_Sullivan @sigi234 last edited by
            @sigi234 Danke für den Tip Sigi, aber wir beide sind ja quasi ioB-Windows Urgesteine 😂😂😂
            Ich habe natürlich alle mir bekannten Vorsichtsmaßnahmen bereits getroffen. Die Installation ist schon völlig fehlerfrei durchgelaufen. Aktuell holt er sich scheinbar aus dem GIT die Adapter, so wie das auch unter BackitUp der Fall ist.
            Gibt es im Anschluss auch den Fehler, das der VIS Editor nicht installiert wird - so wie das bei BackItUp der Fall ist?
            • Gaspode
              Gaspode @David G. last edited by
              @david-g said in Test ioBroker unter Windows installieren - 2023 Edition:
              Prinzipiell schon, die Frage ist nur, wo fängt man an und wo hört man auf, ohne, dass der Installer zu überfrachtet wird und auch wartbar bleibt. Spontan fallen mir da nämlich auch noch Python 2, Python 3, MS Visual Studio und/oder MS Build Tools ein, die auch potentiell erforderlich sein können. Im Fall von Git scheint es ja mit der normalen Installation getan zu sein, bei den anderen gibt es evtl. weitere Schritte, die man durchführen muss. Ich selbst hab da bisher keine Erfahrung, da ich noch keinen Adapter nutze, der solche Voraussetzungen benötigt.
              Ich hab den Windows Installer sowieso schon als Thema beim nächsten Entwicklertreffen als Thema angemeldet, evtl. können wir da über dieses Thema sprechen.
              David G. apollon77 2 Replies Last reply Reply Quote 0
                @jb_sullivan sagte in Test ioBroker unter Windows installieren - 2023 Edition:
                • David G.
                  David G. @Gaspode last edited by David G.
                  @gaspode sagte in Test ioBroker unter Windows installieren - 2023 Edition:
                  Hier also einfach diesen https://git-scm.com/download/win installer ausführen und fertig?
                  Auch die 32bit auf einem 64bit System (der 32bit wird ganz oben irgendwie so hervorgehoben...)?
                  Gute Idee.
                  Git finde ich schon sinnig.
                  Wird immerhin für eine (nicht wenig benutze Funktion) vom iobroker benötigt.
                  • Gaspode
                    Nee, schon die passende Version. Ganz oben ist aber doch der Link zur 64 Bit Version?
                    • JB_Sullivan
                      Wann habe ich meinen "Migrationstart" hier verkündet? Vor 29 Minuten.
                      Alles fertig - 71 Adapter. Die VIS läuft wie als wenn nix gewesen wäre. Der ganze Prozess der Installation und Migration der Alt Daten hat 1A funktioniert ..........
                      ..... bis auf RF-Link
                      RF_Link nutzt den Seriell Port, welcher bei jeder Änderung von Node & NPM in der Konsole wieder händisch, ich nenne es mal aktiviert werden muss.
                      Jetzt muss ich mich erstmal auf die Suche machen wie DAS nochmal ging.
                      Nur nochmal eine reine Verständnis Frage, da der ganze Prozess so schnell ging - werden die ganzen Adapter Daten aus der alten Version rüber kopiert oder aus dem GIT neu geladen?
                      Bei BackItUp mit der GIT Neuladung dauert das STUNDEN.
                      Wenn hier "nur" rüber kopiert wird, birgt das aber auch das Risiko das man bei der Migration ggf. die Fehler einer "angeschossene" Installation wie mit übernimmt.
                      host.GLT
                      2023-04-02 10:52:40.959	info	iobroker npm-install: NPM version: 9.5.0Installing iobroker.rflink@2.1.6... (System call)
                      host.GLT
                      2023-04-02 10:52:30.972	info	iobroker install rflink@2.1.6 using installedVersion
                      host.GLT
                      2023-04-02 10:52:30.972	warn	startInstance cannot find adapter "rflink@2.1.6". Try to install it... 3 attempt
                      host.GLT
                      2023-04-02 10:52:29.966	info	iobroker npm-install: exit 25
                      host.GLT
                      2023-04-02 10:52:28.934	error	iobroker npm-install: host.GLT Cannot install iobroker.rflink@2.1.6: 1
                      host.GLT
                      2023-04-02 10:51:45.557	info	iobroker npm-install: Installing iobroker.rflink@2.1.6... (System call)
                      host.GLT
                      2023-04-02 10:51:45.553	info	iobroker npm-install: NPM version: 9.5.0
                      Gaspode sigi234 2 Replies Last reply Reply Quote 1
                      • Gaspode
                        Gaspode @JB_Sullivan last edited by Gaspode
                        @jb_sullivan said in Test ioBroker unter Windows installieren - 2023 Edition:
                        Es wird nur der iobroker-data Ordner kopiert und an die gewählten Einstellungen (Hostname, ports) angepasst. Den Rest macht ioBroker ganz automatisch, das ist also kein Verdienst des Installers. 😉
                        Und ja, die Adapter werden in ihrer jeweils aktuellen Version automatisch neu installiert allerdings aus npm, nicht aus GIT.
                        Da nur die Daten übernommen werden, denke ich das nicht. Evtl. kann "jemand" mit tieferen ioBroker Kenntnissen da was dazu sagen? @apollon77 vielleicht? 🙂
                          Warte ab, die Instanzen werden alle nachinstalliert! Siehst du im tab-logs, dauerte bei mir 20 Minuten.
                          • Gaspode
                            Gaspode @sigi234 last edited by
                            @sigi234 said in Test ioBroker unter Windows installieren - 2023 Edition:
                            Und bei ihm 29, hat er doch oben geschrieben. 😉
                              sigi234 Forum Testing Most Active @Gaspode last edited by
                              Oh Mann . 😀
                                apollon77 @Gaspode last edited by
                                @gaspode Naja die Frage in meinen Augen ist: Wenn wir immer mehr wieder einbauen landen wir da wo Stabilostick aufgehört hat ... sehr komplex. sehr unfangreich ufn irgendwann schwer zu warten falls @Gaspode (wollens nicht hoffen) keine Zeit mehr hat.
                                Was ich mir vllt vorstellen könnte sind das man "checks" einbaut nach solchen Dingen und quasi eine "hey du solltest noch ... machen" seite im installer macht - abert es nicht einzubauen sondern den user danach selbst machen lassen
                                • JB_Sullivan
                                  Es war dieses mal nicht so einfach wie die anderen mal. Ich habe hier im Forum einen ähnlichen Beitrag gefunden, wo ich meine Erfahrung gepostet habe ( https://forum.iobroker.net/topic/60173/rflink-auf-win-rechner-cannot-find-adapter-rflink-2-1-6/6?_=1669338504851 )
                                  Das Hauptproblem, war dieses mal, das die RF-Link INSTANZ zwar vorhanden war, aber der Adapter nicht in der Adapter Liste auftauchte. Möglicher Weise ist der RF-Link Adapter im Rahmen der Migration nicht übernommen oder gelöscht worden.
                                  Zusätzlich zu dem schon bekannten Workaround des serialport, musste ich den RF-Link Adapter händisch über GIT wieder in meine bestehende Installation einbinden. Jetzt geht wieder alles - siehe auch Link oben.
                                  • JB_Sullivan
                                    Wenn alles läuft wie es soll, kann dann eigentlich aus der neuen Installation der angelegte iobroker-data-old Ordner entsorgt werden?
                                    • Gaspode
                                      Jep.
                                      • JB_Sullivan
                                        JB_Sullivan @Gaspode last edited by
                                        @gaspode
                                        .... und Node liegt jetzt im Windows Programme Ordner und nicht mehr im ioBroker Ordner so wie früher.
                                        ..... und wenn ich in Zukunft Node/NPM updaten will, starte ich lediglich den dann aktuellen Installer und der ersetzt die niederen, gegen höheren Node/NPM Versionen?
                                        • Gaspode
                                          Genau.
                                          Genau. Wobei der Installer die aktuell empfohlene Nodes Version ermittelt und herunterlädt. Du brauchst also nicht für jede neue Nodes Version einen neuen Installer. Aus diesem Grund installiert sich der Installer jetzt auch selbst und ist im Statrtmenü unter ioBroker Setup zu finden.
                                          • Gaspode
                                            Neue Version 2.2.1 auf der Download Seite verfügbar.
                                            Die neue Version behebt ein Problem, das durch "&" Zeichen im Pfad bzw. Windows Benutzernamen auftrat. Näheres dazu hier:
                                            https://forum.iobroker.net/post/982680
                                            Dennoch rate ich ausdrücklich von Sonderzeichen und Leerzeichen in Pfaden und Benutzernamen ab! Auch Node.js bzw. npm hatte und hat immer wieder mal Probleme damit.
                                            Außerdem gibt's eine kurze Doku für Einsteiger:
                                            https://github.com/ioBroker/ioBroker.build/blob/master/Windows-Installer.md
                                            31.7k
                                            79.8k
                                            installation iobroker windows windows installation
                                            25
                                            399
                                            60102
