    4. Adapter: SMA SEMP
    Adapter: SMA SEMP
      Webwanze @Rene_HM last edited by
      @rene_hm
      Scheint jetzt zu funkionieren:
      2023-03-11 14:33:46.618 - info: host.ioBroker "system.adapter.semp.0" enabled
      2023-03-11 14:33:46.650 - info: host.ioBroker instance system.adapter.semp.0 started with pid 4472
      2023-03-11 14:33:47.283 - debug: semp.0 (4472) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-03-11 14:33:47.302 - debug: semp.0 (4472) Objects client ready ... initialize now
      2023-03-11 14:33:47.303 - debug: semp.0 (4472) Objects create System PubSub Client
      2023-03-11 14:33:47.304 - debug: semp.0 (4472) Objects create User PubSub Client
      2023-03-11 14:33:47.317 - debug: semp.0 (4472) Objects client initialize lua scripts
      2023-03-11 14:33:47.321 - debug: semp.0 (4472) Objects connected to redis: 127.0.0.1:9001
      2023-03-11 14:33:47.332 - debug: semp.0 (4472) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-03-11 14:33:47.337 - debug: semp.0 (4472) States create System PubSub Client
      2023-03-11 14:33:47.338 - debug: semp.0 (4472) States create User PubSub Client
      2023-03-11 14:33:47.347 - debug: semp.0 (4472) States connected to redis: 127.0.0.1:9000
      2023-03-11 14:33:47.370 - debug: semp.0 (4472) Plugin sentry Initialize Plugin (enabled=true)
      2023-03-11 14:33:47.546 - info: semp.0 (4472) starting. Version 0.3.1 (non-npm: rg-engineering/ioBroker.semp#ba417263657375badc4c456e5859f8b0e308da66) in /opt/iobroker/node_modules/iobroker.semp, node: v16.19.0, js-controller: 4.0.24
      2023-03-11 14:33:47.563 - debug: semp.0 (4472) SSDPServer created: http://192.168.1.2:9765/description.xml 58ee6313-b746-46aa-aae2-954018429865
      2023-03-11 14:33:47.568 - debug: semp.0 (4472) SEMPServer created
      2023-03-11 14:33:47.568 - debug: semp.0 (4472) gateway created...
      2023-03-11 14:33:47.571 - debug: semp.0 (4472) SEMP server listening on 9765
      2023-03-11 14:33:47.574 - debug: semp.0 (4472) SSDPServer started
      2023-03-11 14:33:47.574 - debug: semp.0 (4472) gateway started...
      2023-03-11 14:33:47.574 - debug: semp.0 (4472) Started all!
      2023-03-11 14:33:47.575 - debug: semp.0 (4472) add device {"IsActive":true,"ID":"F-12345678-123456789012-12","Name":"newDevice0","Vendor":"ACME","Type":"Dryer","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}]}
      2023-03-11 14:33:47.575 - debug: semp.0 (4472) add device F-12345678-123456789012-12
      2023-03-11 14:33:47.576 - debug: semp.0 (4472) can use optional energy: false
      2023-03-11 14:33:47.577 - info: semp.0 (4472) device created F-12345678-123456789012-12 newDevice0
      2023-03-11 14:33:47.577 - debug: semp.0 (4472) set device
      2023-03-11 14:33:47.577 - debug: semp.0 (4472) newDevice0 setState On
      2023-03-11 14:33:47.578 - debug: semp.0 (4472) UpdateData
      2023-03-11 14:33:47.579 - debug: semp.0 (4472) device {"IsActive":true,"ID":"F-12345678-123456789012-12","Name":"newDevice0","Vendor":"ACME","Type":"Dryer","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}],"OptionalEnergy":false}
      2023-03-11 14:33:47.579 - debug: semp.0 (4472) result [{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}]
      2023-03-11 14:33:47.579 - debug: semp.0 (4472) result [{"IsActive":true,"ID":"F-12345678-123456789012-12","Name":"newDevice0","Vendor":"ACME","Type":"Dryer","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}],"OptionalEnergy":false}]
      2023-03-11 14:33:47.593 - debug: semp.0 (4472) newDevice0 got {"val":"on","ack":true,"ts":1678541192446,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1678541192446} from Devices.newDevice0.State
      2023-03-11 14:33:47.597 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"recommended state from SHM","type":"boolean","role":"state","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192445,"_id":"semp.0.Devices.newDevice0.RecommendedState","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.RecommendedState
      2023-03-11 14:33:47.649 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"last time recommendation changed","type":"string","role":"value.time","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192499,"_id":"semp.0.Devices.newDevice0.Changed","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.Changed
      2023-03-11 14:33:47.650 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"current State","type":"string","role":"state","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192505,"_id":"semp.0.Devices.newDevice0.State","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.State
      2023-03-11 14:33:47.652 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"Energy used","type":"number","unit":"Wh","role":"value","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192509,"_id":"semp.0.Devices.newDevice0.Energy","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.Energy
      2023-03-11 14:33:47.655 - debug: semp.0 (4472) subscribe OID_Power 0_userdata.0.DEVICES.ECENTRALHEATING_P
      2023-03-11 14:33:47.657 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
      2023-03-11 14:33:47.681 - debug: semp.0 (4472) newDevice0 got {"val":"on","ack":true,"ts":1678541192446,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1678541192446} from Devices.newDevice0.State
      2023-03-11 14:33:50.632 - debug: semp.0 (4472) SHM requested description
      2023-03-11 14:33:50.632 - info: semp.0 (4472) adapter discovered by SHM
      2023-03-11 14:33:56.466 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
      2023-03-11 14:33:56.466 - debug: semp.0 (4472) get all devices
      2023-03-11 14:33:56.467 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
      2023-03-11 14:33:56.469 - debug: semp.0 (4472) response xml
      newDevice0
      Dryer
      1234
      ACME
      1000
      Measurement
      false
      false
      false
      true
      On
      33
      0
      60
      2023-03-11 14:33:56.470 - debug: semp.0 (4472) response sent
      2023-03-11 14:33:56.627 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
      2023-03-11 14:33:56.627 - debug: semp.0 (4472) get all devices
      2023-03-11 14:33:56.627 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
      2023-03-11 14:33:56.628 - debug: semp.0 (4472) response xml
      newDevice0
      Dryer
      1234
      ACME
      1000
      Measurement
      false
      false
      false
      true
      On
      33
      0
      60
      2023-03-11 14:33:56.629 - debug: semp.0 (4472) response sent
      2023-03-11 14:33:56.727 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
      2023-03-11 14:33:56.727 - debug: semp.0 (4472) get all devices
      2023-03-11 14:33:56.727 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
      2023-03-11 14:33:56.728 - debug: semp.0 (4472) response xml
      newDevice0
      Dryer
      1234
      ACME
      1000
      Measurement
      false
      false
      false
      true
      On
      33
      0
      60
      2023-03-11 14:33:56.728 - debug: semp.0 (4472) response sent
      2023-03-11 14:34:00.048 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
      2023-03-11 14:34:00.048 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541627657 = 0.11358416666666667Wh
      2023-03-11 14:34:07.617 - debug: semp.0 (4472) SHM requested description
      2023-03-11 14:34:15.008 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
      2023-03-11 14:34:15.008 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541640048 = 0.2507175Wh
      2023-03-11 14:34:27.620 - debug: semp.0 (4472) SHM requested description
      2023-03-11 14:34:30.026 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
      2023-03-11 14:34:30.027 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541655008 = 0.3883916666666667Wh
      2023-03-11 14:34:41.757 - debug: semp.0 (4472) SHM requested description
      2023-03-11 14:34:41.795 - debug: semp.0 (4472) SHM requested description
      2023-03-11 14:34:45.008 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
      2023-03-11 14:34:45.008 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541670027 = 0.5257175000000001Wh
      2023-03-11 14:34:47.615 - debug: semp.0 (4472) SHM requested description
      2023-03-11 14:34:56.905 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
      2023-03-11 14:34:56.905 - debug: semp.0 (4472) get all devices
      2023-03-11 14:34:56.906 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
      2023-03-11 14:34:56.907 - debug: semp.0 (4472) response xml
      newDevice0
      Dryer
      1234
      ACME
      1000
      Measurement
      false
      false
      false
      true
      On
      33
      0
      60
      2023-03-11 14:34:56.909 - debug: semp.0 (4472) response sent
      2023-03-11 14:34:57.093 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
      2023-03-11 14:34:57.093 - debug: semp.0 (4472) get all devices
      2023-03-11 14:34:57.094 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
      2023-03-11 14:34:57.094 - debug: semp.0 (4472) response xml
      newDevice0
      Dryer
      1234
      ACME
      1000
      Measurement
      false
      false
      false
      true
      On
      33
      0
      60
      2023-03-11 14:34:57.095 - debug: semp.0 (4472) response sent
      2023-03-11 14:34:57.185 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
      2023-03-11 14:34:57.186 - debug: semp.0 (4472) get all devices
      2023-03-11 14:34:57.186 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
      2023-03-11 14:34:57.186 - debug: semp.0 (4472) response xml
      newDevice0
      Dryer
      1234
      ACME
      1000
      Measurement
      false
      false
      false
      true
      On
      33
      0
      60
      2023-03-11 14:34:57.187 - debug: semp.0 (4472) response sent
      2023-03-11 14:35:00.013 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
      2023-03-11 14:35:00.014 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541685008 = 0.6632633333333334Wh
        cb187 @Webwanze last edited by
        Nutzt hier noch keiner die PV Überschussladen Funktion mit automatischer Phasenumschaltung?
          cb187 @cb187 last edited by
          Hab jetzt mal zwei Wallbox hinzugefügt, schade er lässt nicht beide gleichzeitig laden und teilt sich das auf.Schaltet nur zwischen beiden Boxen immer um.
          • Rene_HM
            Rene_HM Developer @cb187 last edited by
            @cb187 reicht PV - Leistung nicht für beide?
              cb187 @Rene_HM last edited by
              @rene_hm für beide hätte es gereicht wenn es aufgeteilt wäre.Aber ka wie sma das handhabt bzw ist die frage ob das bei den überhaupt geht.
                @Rene_HM Was ich nicht verstehe beobachte ich gerade wieder wenn zb die WP eingeplant ist und genügend PV Überschusss da ist bricht immer Wallbox nach kurzer Zeit ab.Wenn die nicht existiert dann funzt das top.Ich glaub wir müssen uns mal über anydesk verbinden.Damit du da mal life siehst und besser interpretieren kannst.
                  Besser machts der Evcc usw auch nicht.
                    beender last edited by
                    ich verstehe das Verhalten von dem Plugin oder SMA nicht, oder ich habe etwas komplett falsch konfiguriert.
                    Aktuell habe ich einen Überschuss von ca. 6000W und die Empfehlung vom Home Manager sind 0 W:
                    Ich versuche damit meine Wallbox zu steuern. Für eine halbe Stunde hat diese auch geladen, dann wurde diese gestoppt.
                    Die Wallbox ist recht minimal konfiguriert:
                    Philipp
                      cb187 @beender last edited by cb187
                      @beender hey stell mal min energy und max energy auf 0 ein.Und dann sollte reiner PV Überschuss direkt gehen.
                      Wenn du ne 11kw Wallbox hast solltest du dann auch bei max power 11020 einstellen.Bildschirm­foto 2023-04-03 um 12.00.18.png Bildschirm­foto 2023-04-03 um 12.00.47.png
                      beim go musste ich noch drei script hinzufügen.
                        beender @cb187 last edited by beender
                        @cb187
                        Ich habe noch eine Vermutung. Ich lese die Daten per Modbus von meiner ABB Terra AC aus, bekomme aber gefühlt nicht den korrekten State für "Plug Connected" raus. Das ist vermutlich auch der Grund für den Abbruch.
                        Die 3800 W sind eher auf mein Hybrid-Auto bezogen, da dieses nur 1-phasig laden kann. Ich habe es trotzdem mal auf die 11kW gesetzt.
                        Ich werde noch probieren den Plug Connected Status konstant auf true zu setzen. Von mir aus kann der SHM die Wallbox dauerhaft überwachen / kontrollieren. Vermutlich geht das meiste eh über die genutzte Charge Power.
                          Ok probier mal aus.ist ja schnell gemacht plug connect zuerstellen.
                          @beender said in Adapter: SMA SEMP:
                          @cb187
                          • Rene_HM
                            Rene_HM Developer last edited by
                            Ich habe die Version 1.2.0 des Adapters released.
                            Folgende Änderungen sind enthalten:
                            • man kann eine URL anstatt eines einfachen Datenpunktes für die Konfiguration der Schnittstelle der wallbox verwenden
                            • bug fix: ein Gerät, welches aufgrund einer Energeianforderung durch den SHM eingeschaltet wird, wird am Ende der maximalen Einschaltdauer oder am Ende des timeframes automatisch ausgeschaltet. Die Optio diesbezüglich wurde entfernt
                              @rene_hm
                              bei mir will der Adapter auch nicht so ganz
                              seh ich aber bekomme keine Geräte geladen auf der Übersicht...
                              der response sieht eigentlich gut aus würde ich sagen..
                              <?xml version="1.0" encoding="utf-8"?> <Device2EM xmlns="http://www.sma.de/communication/schema/SEMP/v1"> <DeviceInfo> <Identification> <DeviceId>F-7.442202-000000000001-00</DeviceId> <DeviceName>Waschmaschiene</DeviceName> <DeviceType>WashingMachine</DeviceType> <DeviceSerial>111111111111</DeviceSerial> <DeviceVendor>Siemens</DeviceVendor> </Identification> <Characteristics> <MaxPowerConsumption>3500</MaxPowerConsumption> </Characteristics> <Capabilities> <CurrentPower> <Method>Measurement</Method> </CurrentPower> <Timestamps> <AbsoluteTimestamps>false</AbsoluteTimestamps> </Timestamps> <Interruptions> <InterruptionsAllowed>false</InterruptionsAllowed> </Interruptions> <Requests> <OptionalEnergy>false</OptionalEnergy> </Requests> </Capabilities> </DeviceInfo> <DeviceInfo> <Identification> <DeviceId>F-7.442202-000000000002-00</DeviceId> <DeviceName>Hundi-Waschmaschiene</DeviceName> <DeviceType>WashingMachine</DeviceType> <DeviceSerial>2222222222</DeviceSerial> <DeviceVendor>Samsung</DeviceVendor> </Identification> <Characteristics> <MaxPowerConsumption>3500</MaxPowerConsumption> </Characteristics> <Capabilities> <CurrentPower> <Method>Measurement</Method> </CurrentPower> <Timestamps> <AbsoluteTimestamps>false</AbsoluteTimestamps> </Timestamps> <Interruptions> <InterruptionsAllowed>false</InterruptionsAllowed> </Interruptions> <Requests> <OptionalEnergy>false</OptionalEnergy> </Requests> </Capabilities> </DeviceInfo> <DeviceStatus> <DeviceId>F-7.442202-000000000001-00</DeviceId> <EMSignalsAccepted>true</EMSignalsAccepted> <Status>On</Status> <PowerConsumption> <PowerInfo> <AveragePower>0</AveragePower> <Timestamp>0</Timestamp> <AveragingInterval>60</AveragingInterval> </PowerInfo> </PowerConsumption> </DeviceStatus> <DeviceStatus> <DeviceId>F-7.442202-000000000002-00</DeviceId> <EMSignalsAccepted>true</EMSignalsAccepted> <Status>On</Status> <PowerConsumption> <PowerInfo> <AveragePower>0</AveragePower> <Timestamp>0</Timestamp> <AveragingInterval>60</AveragingInterval> </PowerInfo> </PowerConsumption> </DeviceStatus> </Device2EM>
                              ausserdem bekomme ich die csv nicht geschrieben..
                              mit welchen rechten versuchst du die zu schreiben
                              master semp.0: exception in WriteCSVLog [Error: ENOENT: no such file or directory, open '']
                              04 Jun 2023 19:47:11.466
                               master semp.0: exception in CreateFilename [Error: ENOENT: no such file or directory, stat 'home/iobroker/semp.csv']
                              egal welchen Ordner ich nehme..
                              04 Jun 2023 19:48:03.482
                              04 Jun 2023 19:48:03.286
                              04 Jun 2023 19:48:03.261
                              master semp.0: exception in CreateFilename [Error: ENOENT: no such file or directory, stat '/home/iobroker/javascript/semp.csv']
                              hier /home/iobroker/javascript darf der iobroker user 100% schreiben da ich eine kopie meiner Script da ablege ..
                              • Rene_HM
                                Rene_HM Developer @arteck last edited by
                                @arteck
                                ich denke, hier fehlt der führende "/" also
                                /home/iobroker/semp.csv
                                und die DeviceID würde ich ohne Punkt versuchen
                                also anstatt
                                besser
                                F-74422020-000000000001-00
                                  arteck Developer Most Active @Rene_HM last edited by arteck
                                  @rene_hm
                                  nene
                                  04 Jun 2023 20:20:35.164
                                   master semp.0: exception in CreateFilename [Error: ENOENT: no such file or directory, stat '/home/iobroker/semp.csv']
                                  und mit dem . oder ohne.. auch nicht
                                  <?xml version="1.0" encoding="utf-8"?> <Device2EM xmlns="http://www.sma.de/communication/schema/SEMP/v1"> <DeviceInfo> <Identification> <DeviceId>F-7442202-000000000001-00</DeviceId> <DeviceName>Waschmaschiene</DeviceName> <DeviceType>WashingMachine</DeviceType> <DeviceSerial>111111111111</DeviceSerial> <DeviceVendor>Siemens</DeviceVendor> </Identification> <Characteristics> <MaxPowerConsumption>3500</MaxPowerConsumption> </Characteristics> <Capabilities> <CurrentPower> <Method>Measurement</Method> </CurrentPower> <Timestamps> <AbsoluteTimestamps>false</AbsoluteTimestamps> </Timestamps> <Interruptions> <InterruptionsAllowed>false</InterruptionsAllowed> </Interruptions> <Requests> <OptionalEnergy>false</OptionalEnergy> </Requests> </Capabilities> </DeviceInfo> <DeviceInfo> <Identification> <DeviceId>F-7442202-000000000002-00</DeviceId> <DeviceName>Hundi_Waschmaschiene</DeviceName> <DeviceType>WashingMachine</DeviceType> <DeviceSerial>2222222222</DeviceSerial> <DeviceVendor>Samsung</DeviceVendor> </Identification> <Characteristics> <MaxPowerConsumption>3500</MaxPowerConsumption> </Characteristics> <Capabilities> <CurrentPower> <Method>Measurement</Method> </CurrentPower> <Timestamps> <AbsoluteTimestamps>false</AbsoluteTimestamps> </Timestamps> <Interruptions> <InterruptionsAllowed>false</InterruptionsAllowed> </Interruptions> <Requests> <OptionalEnergy>false</OptionalEnergy> </Requests> </Capabilities> </DeviceInfo> <DeviceStatus> <DeviceId>F-7442202-000000000001-00</DeviceId> <EMSignalsAccepted>true</EMSignalsAccepted> <Status>On</Status> <PowerConsumption> <PowerInfo> <AveragePower>0</AveragePower> <Timestamp>0</Timestamp> <AveragingInterval>60</AveragingInterval> </PowerInfo> </PowerConsumption> </DeviceStatus> <DeviceStatus> <DeviceId>F-7442202-000000000002-00</DeviceId> <EMSignalsAccepted>true</EMSignalsAccepted> <Status>On</Status> <PowerConsumption> <PowerInfo> <AveragePower>0</AveragePower> <Timestamp>0</Timestamp> <AveragingInterval>60</AveragingInterval> </PowerInfo> </PowerConsumption> </DeviceStatus> </Device2EM>
                                  • Rene_HM
                                    @arteck versuche es mal ohne Angaber der csv-Datei, einfach nur /home/iobroker. Die csv legt der Adapter selbst an.
                                    und bzgl. Device-ID: wenn du den Punkt weglässt, musst du noch ein Zeichen hinzufügen. Dieser Teil der DeviceID muss 8 Zeichen lang sein.
                                    Hat der Adapter die BaseID mit dem Punkt selbst generiert? Wenn ja, muss ich das noch beheben...
                                      @rene_hm sagte in Adapter: SMA SEMP:
                                      jo hat der
                                      ahhh ok dann schau ich mal...
                                      mist hast recht ..muss ich schauen .. ich habs nur gelöscht
                                      mit der Datei check ich auch.. das hab ich nicht gemacht..
                                      NAchtrag : jo gehts.. mit ohne angabe der csv also nur mit /home/iobroker gehts..
                                      und mit den 8 Stelligen kennung ..hab ich die Geräte jetzt auch im sunny Portal
                                      • Stefan Gönczy
                                        Stefan Gönczy last edited by
                                        Moin,
                                        ich habe mal eine Frage : Ich versuche seit einer Woche einen Verbraucher als KANN Verbraucher einzurichten .
                                        Ich möchte eine Pumpe bei Solar-Überschuss vom Home Manager einschalten lassen und wieder aus ...
                                        Ich habe jetzt das Gerät so Konfiguriert :
                                        Min-Leistung : 100 W Max : 5000 W
                                        Energieanfragen : Timer aktiv - Täglich 08:00 - 20:00 - Min-Lauf 00:05 Max-Lauf 02:00
                                        trotz dem schaltet der HomeManager das Gerät dauerhaft von 8-20 Uhr an ( egal ob überschuss oder nicht ) ...
                                        Was habe ich falsch gemacht ?
                                        Gruß Stefan
                                        • Rene_HM
                                          Rene_HM Developer @Stefan Gönczy last edited by
                                          @stefan-gönczy Im SunnyPortal wird die "verbrauchte" Energie auch angezeigt?
                                          wie hier für den Kühlschrank?
                                          Stefan Gönczy 1 Reply Last reply Reply Quote 0
                                          • Stefan Gönczy
                                            Stefan Gönczy @Rene_HM last edited by
                                            @rene_hm nein - da wird nichts angezeigt ...
                                            232
                                            29763
