    3. Einsteigerfragen
    4. Installation
    5. ioBroker Backup wieder einspielen
      federal last edited by
      gehe davon aus, dass auf dem Stick gleiche abgespeichert sind
      F Homoran 2 Replies Last reply Reply Quote 0
        federal @Glasfaser last edited by
        @glasfaser
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
        npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
        npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
        ^C(##################) ⠏ reify:aws-sdk: timing reifyNode:node_modules/iobroker.zigbee/node_module
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
        Qix- created this issue in visionmedia/debug
        closed ReDos Vulnerability Regression Visibility Notice #797
        timemachine3030 created this issue in axios/axios
        closed Hotfix: Prevent SSRF #3410
        • Glasfaser
          Glasfaser @federal last edited by
          @federal
          alles gut ... nur Werbung
            federal @federal last edited by
            pi@raspberrypi:/opt/iobroker $ iobroker status
            Objects type: jsonl
            States  type: jsonl
            pi@raspberrypi:/opt/iobroker $ iobroker start all
            The adapter "admin.0" was started.
            The adapter "tuya.0" was started.
            The adapter "backitup.0" was started.
            The adapter "vis-timeandweather.0" was started.
            The adapter "worx.0" was started.
            • Glasfaser
              @federal sagte in ioBroker Backup wieder einspielen:
              The adapter .... was started.
              Ja ... und was ist jetzt !?
                @glasfaser
                so wie ich es verstehe, wurden nur 5 Adapter gestartet.
                iob läuft weiterhin nicht!
                Wie soll ich weiter vorgehen?
                • Glasfaser
                  Du hast doch ein Backup/Restore eingespielt ... und das dauert
                  Aber :
                  durch den krasch werden die anderen Adapter nicht mehr nachinstalliert .
                  Neues Backup/Restore einspielen .
                    @glasfaser said in ioBroker Backup wieder einspielen:
                    Aber :
                    wie kann ich sicherstellen, dass PuTTY nicht aussteigt? Wenn man nichts eingibt, bricht die Verbindung weg.
                    Soll ich mit der letzten Sicherung probieren? Habe aber Chromecast Adapter v3.0.3 nicht zum laufen gebracht.
                    Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                      Homoran Global Moderator Administrators @federal last edited by
                      hoffentlich!
                      dann könntest du eine Neuinstallation durchführen und ein funktionierendes Backup wieder einspielen.
                      • Glasfaser
                        Glasfaser @federal last edited by Glasfaser
                        Zwei Session mit Putty machen .
                        Dann liegt ein Netzwerkproblem bei dir vor !
                          Homoran Global Moderator Administrators @federal last edited by Homoran
                          was haben wir denn überhaupt als Basis?
                          was kommt bei iob diag?
                          • Glasfaser
                            Glasfaser @Glasfaser last edited by
                            @federal
                            @glasfaser sagte in ioBroker Backup wieder einspielen:
                            Dann passt meine Vermutung ... in einem anderen Thread von dir :
                            https://forum.iobroker.net/post/770163
                              federal @Homoran last edited by Homoran
                              @homoran said in ioBroker Backup wieder einspielen:
                              Skript v.2023-04-02
                              *** BASE SYSTEM ***
                              Model           : Raspberry Pi 4 Model B Rev 1.2
                              Architecture    : armv7l
                              Docker          : false
                              Virtualization  : none
                              Distributor ID: Raspbian
                              Description:    Raspbian GNU/Linux 10 (buster)
                              Release:        10
                              Codename:       buster
                              PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                              NAME="Raspbian GNU/Linux"
                              VERSION_ID="10"
                              VERSION="10 (buster)"
                              VERSION_CODENAME=buster
                              ID=raspbian
                              ID_LIKE=debian
                              HOME_URL="http://www.raspbian.org/"
                              SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                              BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                              Systemuptime and Load:
                               18:54:45 up 41 days,  9:15,  2 users,  load average: 2.40, 2.64, 2.80
                              CPU threads: 4
                              *** Time and Time Zones ***
                                             Local time: Mon 2023-04-03 18:54:45 CEST
                                         Universal time: Mon 2023-04-03 16:54:45 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              *** User and Groups ***
                              pi
                              /home/pi
                              pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:           3.8G        1.6G        167M        190M        2.1G        2.3G
                              Swap:           99M         37M         62M
                              Total:         3.9G        1.6G        230M
                                       3838 M total memory
                                       1571 M used memory
                                        853 M active memory
                                       2584 M inactive memory
                                        167 M free memory
                                        264 M buffer memory
                                       1836 M swap cache
                                         99 M total swap
                                         37 M used swap
                                         62 M free swap
                              *** FILESYSTEM ***
                              /dev/root      ext4       29G  7.8G   21G  28% /
                              devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                              tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
                              tmpfs          tmpfs     1.9G  209M  1.7G  11% /run
                              tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                              /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                              tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                              [Tue Feb 21 08:39:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:B7:67:4E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                              [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                              [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                              [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): recovery complete
                              [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                              [Tue Feb 21 08:39:22 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                              [Tue Feb 21 08:39:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                              Show mounted filesystems (real ones only):
                              TARGET        SOURCE         FSTYPE OPTIONS
                              /             /dev/mmcblk0p2 ext4   rw,noatime
                              |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                              `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              576M    /var/
                              213M    /var/cache
                              200M    /var/cache/apt
                              142M    /var/log
                              141M    /var/cache/apt/archives
                              /opt/iobroker/backups:
                              103M    /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              449M    /opt/iobroker/iobroker-data/
                              311M    /opt/iobroker/iobroker-data/files
                              85M     /opt/iobroker/iobroker-data/backup-objects
                              72M     /opt/iobroker/iobroker-data/files/telegram.admin
                              51M     /opt/iobroker/iobroker-data/files/javascript.admin
                              19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
                              18M     /opt/iobroker/iobroker-data/states.jsonl
                              15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                              12M     /opt/iobroker/iobroker-data/objects.jsonl
                              9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v16.19.1
                              /usr/bin/node           v16.19.1
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
                              nodejs:
                                Installed: 16.19.1-deb-1nodesource1
                                Candidate: 16.19.1-deb-1nodesource1
                                Version table:
                               *** 16.19.1-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                      100 /var/lib/dpkg/status
                                   10.24.0~dfsg-1~deb10u3 500
                              find: '/opt/iobroker/node_modules/.osx-temperature-sensor-hwc16MPv': No such file or directory
                              find: '/opt/iobroker/node_modules/.fsevents-yNYMVUiI': No such file or directory
                              find: '/opt/iobroker/node_modules/.iobroker.history-EyYkjPpJ': No such file or directory
                              Temp directories causing npm8 problem: 891
                              Some problems detected, please run iob fix
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  4.0.24
                              admin:          "admin" not found
                              javascript:     6.1.4
                              Adapters from github:   0
                              Adapter State
                                system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
                                system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                                system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
                                system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                                system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                                system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                                system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
                              + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                              + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
                                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                              + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                              + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                              + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
                              + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
                              + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                              + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
                              + system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
                              + system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
                              + system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
                              + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                              + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.text2command.1           : text2command          : raspberrypi                              -  enabled
                              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                              + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                                system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D8F906-if00
                              + instance is alive
                              ioBroker-Repositories
                              Stable (default): http://download.iobroker.net/sources-dist.json
                              Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                              Active repo(s): Stable (default)
                              Installed ioBroker-Instances
                              Used repository: Stable (default)
                              Adapter    "history"      : 2.2.4    , installed 2.2.4
                              Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                              Adapter    "ical"         : 1.13.2   , installed 1.13.2
                              Adapter    "info"         : 1.9.19   , installed 1.9.19
                              Adapter    "iot"          : 1.14.2   , installed 1.14.2
                              Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                              Controller "js-controller": 4.0.24   , installed 4.0.24
                              Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
                              Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
                              Adapter    "ping"         : 1.5.3    , installed 1.5.3
                              Adapter    "sayit"        : 1.12.3   , installed 1.12.3
                              Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                              Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                              Adapter    "tado"         : 0.4.5    , installed 0.4.5
                              Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                              Adapter    "text2command" : 2.3.0    , installed 2.3.0
                              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                              Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                              Adapter    "vis"          : 1.4.15   , installed 1.4.15
                              Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                              Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                              Adapter    "worx"         : 2.0.3    , installed 2.0.3
                              Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                              Objects and States
                              Objects:        8545
                              States:         8737
                              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17659      556/sshd
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          364555978  8627/cupsd
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       366535826  32518/io.sonoff.0
                              tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          13294      366/python
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       366534662  32324/iobroker.js-c
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       366531583  32324/iobroker.js-c
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       366544012  1601/io.web.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          17661      556/sshd
                              udp        0      0 0.0.0.0:36865           0.0.0.0:*                           108        13851      344/avahi-daemon: r
                              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       366550232  3641/io.tuya.0
                              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       366550233  3641/io.tuya.0
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       366534930  32501/io.shelly.0
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16570      545/dhcpcd
                              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          364552998  8628/cups-browsed
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13849      344/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                108        13850      344/avahi-daemon: r
                              udp6       0      0 :::54050                :::*                                108        13852      344/avahi-daemon: r
                              2023-04-03 18:56:10.723  - warn: shelly.0 (32501) [authEnabled] 192.168.178.61 (shellyswitch25 / shellyswitch25-40F520008D21 / SHSW-25#40F520008D21#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:10.731  - warn: shelly.0 (32501) [authEnabled] 192.168.178.66 (shellyswitch25 / shellyswitch25-40F520001056 / SHSW-25#40F520001056#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:11.031  - warn: shelly.0 (32501) [authEnabled] 192.168.178.88 (shelly1 / shelly1-483FDA8DAE88 / SHSW-1#483FDA8DAE88#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:11.158  - warn: shelly.0 (32501) [authEnabled] 192.168.178.64 (shelly1 / shelly1-E09806963CF8 / SHSW-1#E09806963CF8#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:11.165  - warn: shelly.0 (32501) [authEnabled] 192.168.178.91 (shellyplug-s / shellyplug-s-A4138B / SHPLG-S#A4138B#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:11.207  - warn: shelly.0 (32501) [authEnabled] 192.168.178.76 (shelly1 / shelly1-483FDA822EBC / SHSW-1#483FDA822EBC#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:11.340  - warn: shelly.0 (32501) [authEnabled] 192.168.178.72 (shellyswitch25 / shellyswitch25-40F52000DA81 / SHSW-25#40F52000DA81#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:11.430  - warn: shelly.0 (32501) [authEnabled] 192.168.178.63 (shelly1 / shelly1-40F52000CBB8 / SHSW-1#40F52000CBB8#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:11.592  - warn: shelly.0 (32501) [authEnabled] 192.168.178.94 (shelly1 / shelly1-F4CFA2ED662C / SHSW-1#F4CFA2ED662C#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:11.598  - warn: shelly.0 (32501) [authEnabled] 192.168.178.95 (shelly1 / shelly1-483FDAA23470 / SHSW-1#483FDAA23470#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:11.849  - warn: shelly.0 (32501) [authEnabled] 192.168.178.73 (shelly1 / shelly1-483FDA82B865 / SHSW-1#483FDA82B865#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:12.362  - warn: shelly.0 (32501) [authEnabled] 192.168.178.101 (shelly1 / shelly1-E8DB84D41EDF / SHSW-1#E8DB84D41EDF#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:12.490  - warn: shelly.0 (32501) [authEnabled] 192.168.178.33 (shelly1 / shelly1-C45BBE6B9506 / SHSW-1#C45BBE6B9506#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:12.701  - warn: shelly.0 (32501) [authEnabled] 192.168.178.65 (shelly1 / shelly1-E09806963C5D / SHSW-1#E09806963C5D#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-04-03 18:56:12.440  - info: netatmo.0 (32465) Websocket error: websocket error,  Error: websocket error
                                  at WS.Transport.onError (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:64:13)
                                  at WebSocket.ws.onerror (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:149:10)
                                  at WebSocket.onError (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:452:14)
                                  at WebSocket.emit (node:events:513:28)
                                  at WebSocket.emit (node:domain:489:12)
                                  at ClientRequest.response (/opt/iobroker/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:721:12)
                                  at Object.onceWrapper (node:events:628:26)
                                  at ClientRequest.emit (node:events:525:35)
                                  at ClientRequest.emit (node:domain:489:12)
                                  at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:693:27)
                              iob diag has finished.
                              Press any key for a summary
                                @federal
                                es lag daran, dass iob und Motioneye gemeinsam auf einem pi genutzt wurden. Seit dem ich Motioneye deaktiviert habe, lief alles gut!
                                  Thomas Braun Most Active @federal last edited by
                                  @federal
                                  Solltest du tun. Und du solltest auch den Buster erlösen und durch das aktuelle Release Debian 11 'Bullseye' ersetzen, der Buster ist letztes Jahr im September abgekündigt worden.
                                  Im Zuge dessen dann auch auf nodejs@18 springen.
                                    @federal was ist denn das?
                                    ich denke der ist gerade neu gestartet?
                                    hat auch gut zu rödeln!
                                    Was läuft da sonst noch?
                                    und nur 5 Adapter sähen anders aus.
                                    admin als https konfiguriert?
                                    und deaktiviert
                                      Nee, die Kiste ist am
                                      unsanft 'neugestartet' worden.
                                        Aber :
                                        habe ein Backup eigespielt
                                        System successfully restored!
                                        pi@raspberrypi:/opt/iobroker/backups $ iobroker start all
                                        The adapter "history.0" was started.
                                        The adapter "javascript.0" was started.
                                        The adapter "scenes.0" was started.
                                        The adapter "telegram.0" was started.
                                        The adapter "chromecast.0" was started.
                                        The adapter "hmip.0" was started.
                                        The adapter "ical.0" was started.
                                        The adapter "netatmo.0" was started.
                                        The adapter "ping.0" was started.
                                        The adapter "shelly.0" was started.
                                        The adapter "sonoff.0" was started.
                                        The adapter "weatherunderground.0" was started.
                                        The adapter "zigbee.0" was started.
                                        The adapter "broadlink2.0" was started.
                                        The adapter "cloud.0" was started.
                                        The adapter "discovery.0" was started.
                                        The adapter "echarts.0" was started.
                                        The adapter "fb-checkpresence.0" was started.
                                        The adapter "feiertage.0" was started.
                                        The adapter "fullybrowser.0" was started.
                                        The adapter "harmony.0" was started.
                                        The adapter "info.0" was started.
                                        The adapter "iot.0" was started.
                                        The adapter "panasonic-comfort-cloud.0" was started.
                                        The adapter "sayit.0" was started.
                                        The adapter "sayit.1" was started.
                                        The adapter "sayit.2" was started.
                                        The adapter "sayit.3" was started.
                                        The adapter "tado.0" was started.
                                        The adapter "tankerkoenig.0" was started.
                                        The adapter "text2command.1" was started.
                                        The adapter "trashschedule.0" was started.
                                        The adapter "vis-inventwo.0" was started.
                                        The adapter "vis.0" was started.
                                        The adapter "web.0" was started.
                                        kann aber nach wie vor nicht auf iob zugreifen
                                        • Glasfaser
                                          iob list instances
                                          sagt
                                            iob list instances
                                            pi@raspberrypi:/opt/iobroker/backups $ iob list instances
                                            + instance is alive
                                            Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                                            1.0k
                                            7212
