    3. Einsteigerfragen
    4. Installation
    5. ioBroker Backup wieder einspielen
      Nee, die Kiste ist am
      [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      unsanft 'neugestartet' worden.
        federal @Glasfaser last edited by
        @glasfaser said in ioBroker Backup wieder einspielen:
        @federal sagte in ioBroker Backup wieder einspielen:
        so wie ich es verstehe, wurden nur 5 Adapter gestartet.
        Du hast doch ein Backup/Restore eingespielt ... und das dauert
        Aber :
        durch den krasch werden die anderen Adapter nicht mehr nachinstalliert .
        Wie soll ich weiter vorgehen?
        Neues Backup/Restore einspielen .
        habe ein Backup eigespielt
        System successfully restored!
        pi@raspberrypi:/opt/iobroker/backups $ iobroker start all
        The adapter "history.0" was started.
        The adapter "javascript.0" was started.
        The adapter "scenes.0" was started.
        The adapter "telegram.0" was started.
        The adapter "chromecast.0" was started.
        The adapter "hmip.0" was started.
        The adapter "ical.0" was started.
        The adapter "netatmo.0" was started.
        The adapter "ping.0" was started.
        The adapter "shelly.0" was started.
        The adapter "sonoff.0" was started.
        The adapter "tuya.0" was started.
        The adapter "weatherunderground.0" was started.
        The adapter "zigbee.0" was started.
        The adapter "broadlink2.0" was started.
        The adapter "cloud.0" was started.
        The adapter "discovery.0" was started.
        The adapter "echarts.0" was started.
        The adapter "fb-checkpresence.0" was started.
        The adapter "feiertage.0" was started.
        The adapter "fullybrowser.0" was started.
        The adapter "harmony.0" was started.
        The adapter "info.0" was started.
        The adapter "iot.0" was started.
        The adapter "panasonic-comfort-cloud.0" was started.
        The adapter "sayit.0" was started.
        The adapter "sayit.1" was started.
        The adapter "sayit.2" was started.
        The adapter "sayit.3" was started.
        The adapter "tado.0" was started.
        The adapter "tankerkoenig.0" was started.
        The adapter "text2command.1" was started.
        The adapter "trashschedule.0" was started.
        The adapter "vis-inventwo.0" was started.
        The adapter "vis-timeandweather.0" was started.
        The adapter "vis.0" was started.
        The adapter "web.0" was started.
        The adapter "worx.0" was started.
        kann aber nach wie vor nicht auf iob zugreifen
        Glasfaser Homoran 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @federal last edited by
          iob list instances
          sagt
            iob list instances
            pi@raspberrypi:/opt/iobroker/backups $ iob list instances
              system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
              system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
              system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
              system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
              system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
              system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
              system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
              system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
              system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
              system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
              system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
            + system.adapter.history.0                : history               : raspberrypi                              -  enabled
            + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
              system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
            + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
            + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
            + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
            + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
            + system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
            + system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
            + system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
            + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
            + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
            + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.1           : text2command          : raspberrypi                              -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
            + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
              system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
            + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D8F906-if00
            + instance is alive
            Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
            • Glasfaser
              @federal
              iob start admin
                Thomas Braun Most Active @federal last edited by Thomas Braun
                @federal
                Der admin läuft nicht.
                iob start admin
                Hast du zwischenzeitlich den
                iob fix
                ausgeführt?
                  federal @Thomas Braun last edited by federal
                  @thomas-braun said in ioBroker Backup wieder einspielen:
                  @federal
                  iob start admin
                  iob fix
                  ausgeführt?
                  leider unverändert
                      Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                  pi@raspberrypi:/opt/iobroker/backups $ iob start
                  pi@raspberrypi:/opt/iobroker/backups $ iob start admin
                  The adapter "admin.0" was started.
                    system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                  + system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                  + instance is alive
                  unter iobroker logs --watch läuft was
                  Thomas Braun F 3 Replies Last reply Reply Quote 0
                    läuft was
                    Aha. Was geheimes?
                      @federal
                      iob diag
                      sagt nun?
                        federal @Thomas Braun last edited by Homoran
                        iob diag
                        Skript v.2023-04-02
                        *** BASE SYSTEM ***
                        Model           : Raspberry Pi 4 Model B Rev 1.2
                        Architecture    : armv7l
                        Docker          : false
                        Virtualization  : none
                        Distributor ID: Raspbian
                        Description:    Raspbian GNU/Linux 10 (buster)
                        Release:        10
                        Codename:       buster
                        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                        NAME="Raspbian GNU/Linux"
                        VERSION_ID="10"
                        VERSION="10 (buster)"
                        VERSION_CODENAME=buster
                        ID=raspbian
                        ID_LIKE=debian
                        HOME_URL="http://www.raspbian.org/"
                        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                        Systemuptime and Load:
                         20:09:09 up 41 days, 10:29,  2 users,  load average: 12.11, 9.94, 6.40
                        CPU threads: 4
                        *** Time and Time Zones ***
                                       Local time: Mon 2023-04-03 20:09:23 CEST
                                   Universal time: Mon 2023-04-03 18:09:23 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:           3.8G        2.0G         84M        171M        1.7G        1.8G
                        Swap:           99M         55M         44M
                        Total:         3.9G        2.1G        128M
                                 3838 M total memory
                                 2019 M used memory
                                  487 M active memory
                                 3075 M inactive memory
                                   84 M free memory
                                  196 M buffer memory
                                 1537 M swap cache
                                   99 M total swap
                                   55 M used swap
                                   44 M free swap
                        *** FILESYSTEM ***
                        /dev/root      ext4       29G  8.5G   20G  31% /
                        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                        tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
                        tmpfs          tmpfs     1.9G  209M  1.7G  11% /run
                        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                        [Tue Feb 21 08:39:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:B7:67:4E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                        [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                        [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): recovery complete
                        [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                        [Tue Feb 21 08:39:22 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Tue Feb 21 08:39:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                        Show mounted filesystems (real ones only):
                        TARGET        SOURCE         FSTYPE OPTIONS
                        /             /dev/mmcblk0p2 ext4   rw,noatime
                        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        576M    /var/
                        213M    /var/cache
                        200M    /var/cache/apt
                        142M    /var/log
                        141M    /var/cache/apt/archives
                        /opt/iobroker/backups:
                        103M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        435M    /opt/iobroker/iobroker-data/
                        311M    /opt/iobroker/iobroker-data/files
                        85M     /opt/iobroker/iobroker-data/backup-objects
                        72M     /opt/iobroker/iobroker-data/files/telegram.admin
                        51M     /opt/iobroker/iobroker-data/files/javascript.admin
                        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
                        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                        11M     /opt/iobroker/iobroker-data/objects.jsonl
                        9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
                        9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v16.19.1
                        /usr/bin/node           v16.19.1
                        /usr/bin/npm            8.19.3
                        /usr/bin/npx            8.19.3
                        nodejs:
                          Installed: 16.19.1-deb-1nodesource1
                          Candidate: 16.19.1-deb-1nodesource1
                          Version table:
                         *** 16.19.1-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                100 /var/lib/dpkg/status
                             10.24.0~dfsg-1~deb10u3 500
                        Temp directories causing npm8 problem: 894
                        Some problems detected, please run iob fix
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  4.0.24
                        admin:          6.3.5
                        javascript:     6.1.4
                        Adapters from github:   0
                        Adapter State
                        + instance is alive
                        ioBroker-Repositories
                        Stable (default): http://download.iobroker.net/sources-dist.json
                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                        Active repo(s): Stable (default)
                        Installed ioBroker-Instances
                        Used repository: Stable (default)
                        Adapter    "admin"        : 6.3.5    , installed 6.3.5
                        Adapter    "history"      : 2.2.4    , installed 2.2.4
                        Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                        Adapter    "ical"         : 1.13.2   , installed 1.13.2
                        Adapter    "info"         : 1.9.19   , installed 1.9.19
                        Adapter    "iot"          : 1.14.2   , installed 1.14.2
                        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                        Controller "js-controller": 4.0.24   , installed 4.0.24
                        Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
                        Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
                        Adapter    "ping"         : 1.5.3    , installed 1.5.3
                        Adapter    "sayit"        : 1.12.3   , installed 1.12.3
                        Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                        Adapter    "tado"         : 0.4.5    , installed 0.4.5
                        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                        Adapter    "text2command" : 2.3.0    , installed 2.3.0
                        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                        Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                        Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
                        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                        Adapter    "worx"         : 2.0.3    , installed 2.0.3
                        Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                        Objects and States
                        Objects:        8552
                        States:         8771
                        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                        Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
                        Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17659      556/sshd
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          364555978  8627/cupsd
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       366918206  619/io.sonoff.0
                        tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          13294      366/python
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       366917975  403/iobroker.js-con
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       366917968  403/iobroker.js-con
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          17661      556/sshd
                        udp        0      0 0.0.0.0:36865           0.0.0.0:*                           108        13851      344/avahi-daemon: r
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       366918219  634/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       366918220  634/io.tuya.0
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       366919119  602/io.shelly.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16570      545/dhcpcd
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          364552998  8628/cups-browsed
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13849      344/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                108        13850      344/avahi-daemon: r
                        udp6       0      0 :::54050                :::*                                108        13852      344/avahi-daemon: r
                        2023-04-03 20:12:04.327  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:8:5)
                        2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                        2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                        2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                        2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
                        2023-04-03 20:12:04.329  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Zählerstand" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                        2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
                        2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:9:5)
                        2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                        2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                        2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                        2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
                        2023-04-03 20:12:04.360  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
                        2023-04-03 20:12:04.370  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
                        2023-04-03 20:12:04.377  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
                        2023-04-03 20:12:04.479  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                        2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
                        2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:5:5)
                        2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                        2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                        2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                        2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
                        2023-04-03 20:12:04.507  - warn: shelly.0 (602) [authEnabled] 192.168.178.64 (shelly1 / shelly1-E09806963CF8 / SHSW-1#E09806963CF8#1): This device is not protected via restricted login (see adapter documentation for details)
                        2023-04-03 20:12:04.515  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
                        2023-04-03 20:12:04.671  - warn: shelly.0 (602) [authEnabled] 192.168.178.95 (shelly1 / shelly1-483FDAA23470 / SHSW-1#483FDAA23470#1): This device is not protected via restricted login (see adapter documentation for details)
                        iob diag has finished.
                        Press any key for a summary
                        führe gleich iob fix aus
                          Hast du da mal als root herumgehampelt?
                          Das sollte der iob fix nämlich eigentlich bereinigen.
                          find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \;
                          bringt?
                            Homoran Global Moderator Administrators @federal last edited by
                            @homoran sagte in ioBroker Backup wieder einspielen:
                            admin als https konfiguriert?
                            und deaktiviert
                              wenn, dann unbewusst
                                @federal
                                Was ist denn da los? Bei 4 ist die Kiste eigentlich dicht.
                                Homoran F 2 Replies Last reply Reply Quote 0
                                  federal @Homoran last edited by
                                  @homoran said in ioBroker Backup wieder einspielen:
                                  und deaktiviert
                                  https war eingerichtet. Wie kann ich es deaktivieren?
                                    load average: 2.40, 2.64, 2.80
                                    hat auch gut zu rödeln!
                                    ich werde anscheinend ignoriert
                                      <4 ist doch i.O.
                                        Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                                        @thomas-braun aber nicht, wenn angeblich nichts läuft
                                          federal @federal last edited by
                                          @federal said in ioBroker Backup wieder einspielen:
                                          @federal
                                          iob start admin
                                          iob fix
                                          habe mal ein Ausschnitt gemacht
                                          2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25    )
                                          2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_hand    ler.js:151:20)
                                          2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Object.onceWrapper (node:events:628:26)
                                          2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:events:513:28)
                                          2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:domain:489:12)
                                          2023-04-03 20:15:16.041  - error: host.raspberrypi Caught by controller[0]:         at TCP.<anonymous> (node:net:301:12)
                                          2023-04-03 20:15:16.041  - warn: host.raspberrypi instance system.adapter.shelly    .0 terminated due to SIGTERM
                                          2023-04-03 20:15:16.042  - info: host.raspberrypi instance system.adapter.shelly    .0 terminated with code null ()
                                          2023-04-03 20:15:16.107  - warn: host.raspberrypi instance system.adapter.sonoff    .0 terminated due to SIGTERM
                                          2023-04-03 20:15:16.108  - info: host.raspberrypi instance system.adapter.sonoff    .0 terminated with code null ()
                                          2023-04-03 20:15:16.201  - info: host.raspberrypi instance system.adapter.histor    y.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2023-04-03 20:15:16.209  - info: tuya.0 (634) Terminated (START_IMMEDIATELY_AFTE    R_STOP): Without reason
                                          2023-04-03 20:15:16.889  - info: host.raspberrypi instance system.adapter.tuya.0     terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                          2023-04-03 20:15:16.891  - info: host.raspberrypi All instances are stopped.
                                          2023-04-03 20:15:19.754  - error: host.raspberrypi Cannot find view "system" for     search "instance" : Connection is closed.
                                          2023-04-03 20:15:19.756  - warn: host.raspberrypi instance system.adapter.zigbee    .0 terminated due to SIGTERM
                                          2023-04-03 20:15:19.756  - info: host.raspberrypi instance system.adapter.zigbee    .0 terminated with code null ()
                                          2023-04-03 20:15:19.757  - info: host.raspberrypi All instances are stopped.
                                          2023-04-03 20:15:25.061  - info: host.raspberrypi terminated
                                            @federal
                                            Starte die Kiste mal durch...
                                            Sauber!
                                            sudo reboot
                                            7205
