    3. Einsteigerfragen
    4. Installation
    5. ioBroker Backup wieder einspielen
    • Glasfaser
      Glasfaser @federal last edited by
      @federal
      iob start admin
        Thomas Braun Most Active @federal last edited by Thomas Braun
        @federal
        Der admin läuft nicht.
        iob start admin
        Hast du zwischenzeitlich den
        iob fix
        ausgeführt?
          federal @Thomas Braun last edited by federal
          @thomas-braun said in ioBroker Backup wieder einspielen:
          @federal
          iob start admin
          iob fix
          ausgeführt?
          leider unverändert
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          pi@raspberrypi:/opt/iobroker/backups $ iob start
          pi@raspberrypi:/opt/iobroker/backups $ iob start admin
          The adapter "admin.0" was started.
          pi@raspberrypi:/opt/iobroker/backups $ iob list instances
            system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
            system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
            system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
          + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
            system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
            system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
            system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
            system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
            system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
            system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
            system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
            system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
            system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
            system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
            system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
          + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
            system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
          + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.text2command.1           : text2command          : raspberrypi                              -  enabled
            system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          + system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
            system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D8F906-if00
          + instance is alive
          unter iobroker logs --watch läuft was
          Thomas Braun F 3 Replies Last reply Reply Quote 0
            @federal sagte in ioBroker Backup wieder einspielen:
            läuft was
            Aha. Was geheimes?
              @federal
              iob diag
              sagt nun?
                federal @Thomas Braun last edited by Homoran
                iob diag
                Skript v.2023-04-02
                *** BASE SYSTEM ***
                Model           : Raspberry Pi 4 Model B Rev 1.2
                Architecture    : armv7l
                Docker          : false
                Virtualization  : none
                Distributor ID: Raspbian
                Description:    Raspbian GNU/Linux 10 (buster)
                Release:        10
                Codename:       buster
                PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                NAME="Raspbian GNU/Linux"
                VERSION_ID="10"
                VERSION="10 (buster)"
                VERSION_CODENAME=buster
                ID=raspbian
                ID_LIKE=debian
                HOME_URL="http://www.raspbian.org/"
                SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                Systemuptime and Load:
                 20:09:09 up 41 days, 10:29,  2 users,  load average: 12.11, 9.94, 6.40
                CPU threads: 4
                *** Time and Time Zones ***
                               Local time: Mon 2023-04-03 20:09:23 CEST
                           Universal time: Mon 2023-04-03 18:09:23 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:           3.8G        2.0G         84M        171M        1.7G        1.8G
                Swap:           99M         55M         44M
                Total:         3.9G        2.1G        128M
                         3838 M total memory
                         2019 M used memory
                          487 M active memory
                         3075 M inactive memory
                           84 M free memory
                          196 M buffer memory
                         1537 M swap cache
                           99 M total swap
                           55 M used swap
                           44 M free swap
                *** FILESYSTEM ***
                /dev/root      ext4       29G  8.5G   20G  31% /
                devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
                tmpfs          tmpfs     1.9G  209M  1.7G  11% /run
                tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                [Tue Feb 21 08:39:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:B7:67:4E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): recovery complete
                [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                [Tue Feb 21 08:39:22 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Tue Feb 21 08:39:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                Show mounted filesystems (real ones only):
                TARGET        SOURCE         FSTYPE OPTIONS
                /             /dev/mmcblk0p2 ext4   rw,noatime
                |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                576M    /var/
                213M    /var/cache
                200M    /var/cache/apt
                142M    /var/log
                141M    /var/cache/apt/archives
                /opt/iobroker/backups:
                103M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                435M    /opt/iobroker/iobroker-data/
                311M    /opt/iobroker/iobroker-data/files
                85M     /opt/iobroker/iobroker-data/backup-objects
                72M     /opt/iobroker/iobroker-data/files/telegram.admin
                51M     /opt/iobroker/iobroker-data/files/javascript.admin
                19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
                15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                11M     /opt/iobroker/iobroker-data/objects.jsonl
                9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
                9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v16.19.1
                /usr/bin/node           v16.19.1
                /usr/bin/npm            8.19.3
                /usr/bin/npx            8.19.3
                nodejs:
                  Installed: 16.19.1-deb-1nodesource1
                  Candidate: 16.19.1-deb-1nodesource1
                  Version table:
                 *** 16.19.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                        100 /var/lib/dpkg/status
                     10.24.0~dfsg-1~deb10u3 500
                Temp directories causing npm8 problem: 894
                Some problems detected, please run iob fix
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  4.0.24
                admin:          6.3.5
                javascript:     6.1.4
                Adapters from github:   0
                Adapter State
                + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
                + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
                + system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
                + system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
                + system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
                + instance is alive
                ioBroker-Repositories
                Stable (default): http://download.iobroker.net/sources-dist.json
                Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                Active repo(s): Stable (default)
                Installed ioBroker-Instances
                Used repository: Stable (default)
                Adapter    "admin"        : 6.3.5    , installed 6.3.5
                Adapter    "history"      : 2.2.4    , installed 2.2.4
                Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                Adapter    "ical"         : 1.13.2   , installed 1.13.2
                Adapter    "info"         : 1.9.19   , installed 1.9.19
                Adapter    "iot"          : 1.14.2   , installed 1.14.2
                Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                Controller "js-controller": 4.0.24   , installed 4.0.24
                Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
                Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
                Adapter    "ping"         : 1.5.3    , installed 1.5.3
                Adapter    "sayit"        : 1.12.3   , installed 1.12.3
                Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                Adapter    "tado"         : 0.4.5    , installed 0.4.5
                Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                Adapter    "text2command" : 2.3.0    , installed 2.3.0
                Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
                Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                Adapter    "worx"         : 2.0.3    , installed 2.0.3
                Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                Objects and States
                Objects:        8552
                States:         8771
                Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
                Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17659      556/sshd
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          364555978  8627/cupsd
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       366918206  619/io.sonoff.0
                tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          13294      366/python
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       366917975  403/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       366917968  403/iobroker.js-con
                tcp6       0      0 :::22                   :::*                    LISTEN      0          17661      556/sshd
                udp        0      0 0.0.0.0:36865           0.0.0.0:*                           108        13851      344/avahi-daemon: r
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       366918219  634/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       366918220  634/io.tuya.0
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       366919119  602/io.shelly.0
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16570      545/dhcpcd
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          364552998  8628/cups-browsed
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13849      344/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        13850      344/avahi-daemon: r
                udp6       0      0 :::54050                :::*                                108        13852      344/avahi-daemon: r
                2023-04-03 20:12:04.327  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:8:5)
                2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
                2023-04-03 20:12:04.329  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Zählerstand" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
                2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:9:5)
                2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
                2023-04-03 20:12:04.360  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
                2023-04-03 20:12:04.370  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
                2023-04-03 20:12:04.377  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
                2023-04-03 20:12:04.479  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
                2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
                2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:5:5)
                2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
                2023-04-03 20:12:04.507  - warn: shelly.0 (602) [authEnabled] 192.168.178.64 (shelly1 / shelly1-E09806963CF8 / SHSW-1#E09806963CF8#1): This device is not protected via restricted login (see adapter documentation for details)
                2023-04-03 20:12:04.515  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
                2023-04-03 20:12:04.671  - warn: shelly.0 (602) [authEnabled] 192.168.178.95 (shelly1 / shelly1-483FDAA23470 / SHSW-1#483FDAA23470#1): This device is not protected via restricted login (see adapter documentation for details)
                iob diag has finished.
                Press any key for a summary
                führe gleich iob fix aus
                  Hast du da mal als root herumgehampelt?
                  Das sollte der iob fix nämlich eigentlich bereinigen.
                  find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \;
                  bringt?
                    Homoran Global Moderator Administrators @federal last edited by
                    kann aber nach wie vor nicht auf iob zugreifen
                    @homoran sagte in ioBroker Backup wieder einspielen:
                    admin als https konfiguriert?
                    und deaktiviert
                      wenn, dann unbewusst
                        @federal
                        Was ist denn da los? Bei 4 ist die Kiste eigentlich dicht.
                        Homoran F 2 Replies Last reply Reply Quote 0
                          federal @Homoran last edited by
                          @homoran said in ioBroker Backup wieder einspielen:
                          und deaktiviert
                          https war eingerichtet. Wie kann ich es deaktivieren?
                            load average: 2.40, 2.64, 2.80
                            hat auch gut zu rödeln!
                            ich werde anscheinend ignoriert
                              <4 ist doch i.O.
                                Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                                @thomas-braun aber nicht, wenn angeblich nichts läuft
                                  federal @federal last edited by
                                  @federal said in ioBroker Backup wieder einspielen:
                                  @federal
                                  iob start admin
                                  iob fix
                                  habe mal ein Ausschnitt gemacht
                                  2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25    )
                                  2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_hand    ler.js:151:20)
                                  2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Object.onceWrapper (node:events:628:26)
                                  2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:events:513:28)
                                  2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:domain:489:12)
                                  2023-04-03 20:15:16.041  - error: host.raspberrypi Caught by controller[0]:         at TCP.<anonymous> (node:net:301:12)
                                  2023-04-03 20:15:16.041  - warn: host.raspberrypi instance system.adapter.shelly    .0 terminated due to SIGTERM
                                  2023-04-03 20:15:16.042  - info: host.raspberrypi instance system.adapter.shelly    .0 terminated with code null ()
                                  2023-04-03 20:15:16.107  - warn: host.raspberrypi instance system.adapter.sonoff    .0 terminated due to SIGTERM
                                  2023-04-03 20:15:16.108  - info: host.raspberrypi instance system.adapter.sonoff    .0 terminated with code null ()
                                  2023-04-03 20:15:16.201  - info: host.raspberrypi instance system.adapter.histor    y.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2023-04-03 20:15:16.209  - info: tuya.0 (634) Terminated (START_IMMEDIATELY_AFTE    R_STOP): Without reason
                                  2023-04-03 20:15:16.889  - info: host.raspberrypi instance system.adapter.tuya.0     terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  2023-04-03 20:15:16.891  - info: host.raspberrypi All instances are stopped.
                                  2023-04-03 20:15:19.754  - error: host.raspberrypi Cannot find view "system" for     search "instance" : Connection is closed.
                                  2023-04-03 20:15:19.756  - warn: host.raspberrypi instance system.adapter.zigbee    .0 terminated due to SIGTERM
                                  2023-04-03 20:15:19.756  - info: host.raspberrypi instance system.adapter.zigbee    .0 terminated with code null ()
                                  2023-04-03 20:15:19.757  - info: host.raspberrypi All instances are stopped.
                                  2023-04-03 20:15:25.061  - info: host.raspberrypi terminated
                                    @federal
                                    Starte die Kiste mal durch...
                                    Sauber!
                                    sudo reboot
                                      @federal
                                      Sauber!
                                      sudo reboot
                                      jetzt bin ich wieder am Anfang von heute
                                      pi@raspberrypi:~ $ iobroker status
                                      node:internal/modules/cjs/loader:1024
                                        throw err;
                                      Error: Cannot find module 'buffer-equal-constant-time'
                                      Require stack:
                                      - /opt/iobroker/node_modules/jwa/index.js
                                      - /opt/iobroker/node_modules/jws/lib/sign-stream.js
                                      - /opt/iobroker/node_modules/jws/index.js
                                      - /opt/iobroker/node_modules/jsonwebtoken/decode.js
                                      - /opt/iobroker/node_modules/jsonwebtoken/index.js
                                      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                                      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                                      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
                                          at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                                          at Module.require (node:internal/modules/cjs/loader:1093:19)
                                          at require (node:internal/modules/cjs/helpers:108:18)
                                          at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
                                          at Module._compile (node:internal/modules/cjs/loader:1191:14)
                                          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                                          at Module.load (node:internal/modules/cjs/loader:1069:32)
                                          at Function.Module._load (node:internal/modules/cjs/loader:904:12)
                                          at Module.require (node:internal/modules/cjs/loader:1093:19) {
                                        code: 'MODULE_NOT_FOUND',
                                        requireStack: [
                                          '/opt/iobroker/node_modules/jwa/index.js',
                                          '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
                                          '/opt/iobroker/node_modules/jws/index.js',
                                          '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
                                          '/opt/iobroker/node_modules/jsonwebtoken/index.js',
                                          '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                                          '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        @federal
                                        ich verstehe es leider nicht
                                          Thomas Braun Most Active last edited by Thomas Braun
                                          Ich auch nicht.
                                          Die drei Zahlen sind die Auslastung der CPU im Moment, der letzten 5 und der letzten 15 Minuten. 1 ist dabei ein Kern, da dein RPI derer 4 hat ist 4 halt = 100%.
                                          Irgendwas zieht da bei dir massiv Ressourcen, insbesondere da da vom iobroker her eigentlich nicht viel läuft macht das stutzig.
                                          Mit
                                          top
                                          schauen was da los ist.
                                          Edit: Mal zum Vergleich mein Rpi 4 / 8 GB:
                                          echad@chet:~ $ uptime
                                           20:42:40 up 8 days, 20:36,  2 users,  load average: 0.42, 0.37, 0.35
                                            Ich auch nicht.
                                            Mit
                                            top
                                            7210
