    3. Einsteigerfragen
    4. Installation
    5. ioBroker Backup wieder einspielen
      federal @Thomas Braun last edited by federal
      @thomas-braun said in ioBroker Backup wieder einspielen:
      @federal
      Der admin läuft nicht.
      iob start admin
      Hast du zwischenzeitlich den
      iob fix
      ausgeführt?
      leider unverändert
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi:/opt/iobroker/backups $ iob start
      pi@raspberrypi:/opt/iobroker/backups $ iob start admin
      The adapter "admin.0" was started.
      pi@raspberrypi:/opt/iobroker/backups $ iob list instances
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
        system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
        system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
        system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
        system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
        system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
        system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
        system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
        system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.1           : text2command          : raspberrypi                              -  enabled
        system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014D8F906-if00
      + instance is alive
      unter iobroker logs --watch läuft was
      Thomas Braun F 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @federal last edited by
        @federal sagte in ioBroker Backup wieder einspielen:
        läuft was
        Aha. Was geheimes?
          @federal
          iob diag
          sagt nun?
            federal @Thomas Braun last edited by Homoran
            iob diag
            Skript v.2023-04-02
            *** BASE SYSTEM ***
            Model           : Raspberry Pi 4 Model B Rev 1.2
            Architecture    : armv7l
            Docker          : false
            Virtualization  : none
            Distributor ID: Raspbian
            Description:    Raspbian GNU/Linux 10 (buster)
            Release:        10
            Codename:       buster
            PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="10"
            VERSION="10 (buster)"
            VERSION_CODENAME=buster
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            Systemuptime and Load:
             20:09:09 up 41 days, 10:29,  2 users,  load average: 12.11, 9.94, 6.40
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Mon 2023-04-03 20:09:23 CEST
                       Universal time: Mon 2023-04-03 18:09:23 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           3.8G        2.0G         84M        171M        1.7G        1.8G
            Swap:           99M         55M         44M
            Total:         3.9G        2.1G        128M
                     3838 M total memory
                     2019 M used memory
                      487 M active memory
                     3075 M inactive memory
                       84 M free memory
                      196 M buffer memory
                     1537 M swap cache
                       99 M total swap
                       55 M used swap
                       44 M free swap
            *** FILESYSTEM ***
            /dev/root      ext4       29G  8.5G   20G  31% /
            devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
            tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
            tmpfs          tmpfs     1.9G  209M  1.7G  11% /run
            tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
            /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
            tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
            [Tue Feb 21 08:39:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:B7:67:4E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
            [Tue Feb 21 08:39:21 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
            [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): recovery complete
            [Tue Feb 21 08:39:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            [Tue Feb 21 08:39:22 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Tue Feb 21 08:39:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            Show mounted filesystems (real ones only):
            TARGET        SOURCE         FSTYPE OPTIONS
            /             /dev/mmcblk0p2 ext4   rw,noatime
            |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
            `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            576M    /var/
            213M    /var/cache
            200M    /var/cache/apt
            142M    /var/log
            141M    /var/cache/apt/archives
            /opt/iobroker/backups:
            103M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            435M    /opt/iobroker/iobroker-data/
            311M    /opt/iobroker/iobroker-data/files
            85M     /opt/iobroker/iobroker-data/backup-objects
            72M     /opt/iobroker/iobroker-data/files/telegram.admin
            51M     /opt/iobroker/iobroker-data/files/javascript.admin
            19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
            15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
            11M     /opt/iobroker/iobroker-data/objects.jsonl
            9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
            9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v16.19.1
            /usr/bin/node           v16.19.1
            /usr/bin/npm            8.19.3
            /usr/bin/npx            8.19.3
            nodejs:
              Installed: 16.19.1-deb-1nodesource1
              Candidate: 16.19.1-deb-1nodesource1
              Version table:
             *** 16.19.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u3 500
            Temp directories causing npm8 problem: 894
            Some problems detected, please run iob fix
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  4.0.24
            admin:          6.3.5
            javascript:     6.1.4
            Adapters from github:   0
            Adapter State
            + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
            + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: raspberrypi                              -  enabled
            + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
            + system.adapter.sayit.1                  : sayit                 : raspberrypi                              -  enabled, port: 0
            + system.adapter.sayit.2                  : sayit                 : raspberrypi                              -  enabled, port: 0
            + system.adapter.sayit.3                  : sayit                 : raspberrypi                              -  enabled, port: 0
            + instance is alive
            ioBroker-Repositories
            Stable (default): http://download.iobroker.net/sources-dist.json
            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
            Active repo(s): Stable (default)
            Installed ioBroker-Instances
            Used repository: Stable (default)
            Adapter    "admin"        : 6.3.5    , installed 6.3.5
            Adapter    "history"      : 2.2.4    , installed 2.2.4
            Adapter    "hmip"         : 1.20.0   , installed 1.20.0
            Adapter    "ical"         : 1.13.2   , installed 1.13.2
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "iot"          : 1.14.2   , installed 1.14.2
            Adapter    "javascript"   : 6.1.4    , installed 6.1.4
            Controller "js-controller": 4.0.24   , installed 4.0.24
            Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
            Adapter    "panasonic-comfort-cloud": 2.1.0, installed 2.1.0
            Adapter    "ping"         : 1.5.3    , installed 1.5.3
            Adapter    "sayit"        : 1.12.3   , installed 1.12.3
            Adapter    "shelly"       : 6.3.1    , installed 6.3.1
            Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
            Adapter    "tado"         : 0.4.5    , installed 0.4.5
            Adapter    "telegram"     : 1.15.2   , installed 1.15.2
            Adapter    "text2command" : 2.3.0    , installed 2.3.0
            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
            Adapter    "tuya"         : 3.13.1   , installed 3.13.1
            Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
            Adapter    "worx"         : 2.0.3    , installed 2.0.3
            Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
            Objects and States
            Objects:        8552
            States:         8771
            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
            Hit:2 https://deb.nodesource.com/node_16.x buster InRelease
            Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17659      556/sshd
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          364555978  8627/cupsd
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       366918206  619/io.sonoff.0
            tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          13294      366/python
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       366917975  403/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       366917968  403/iobroker.js-con
            tcp6       0      0 :::22                   :::*                    LISTEN      0          17661      556/sshd
            udp        0      0 0.0.0.0:36865           0.0.0.0:*                           108        13851      344/avahi-daemon: r
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       366918219  634/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       366918220  634/io.tuya.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       366919119  602/io.shelly.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16570      545/dhcpcd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          364552998  8628/cups-browsed
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13849      344/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        13850      344/avahi-daemon: r
            udp6       0      0 :::54050                :::*                                108        13852      344/avahi-daemon: r
            2023-04-03 20:12:04.327  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:8:5)
            2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
            2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
            2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
            2023-04-03 20:12:04.328  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
            2023-04-03 20:12:04.329  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Zählerstand" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
            2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
            2023-04-03 20:12:04.330  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:9:5)
            2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
            2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
            2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
            2023-04-03 20:12:04.331  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
            2023-04-03 20:12:04.360  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
            2023-04-03 20:12:04.370  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
            2023-04-03 20:12:04.377  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Zählerstand" has to be type "string" but received type "number"
            2023-04-03 20:12:04.479  - warn: javascript.0 (471) You are assigning a number to the state "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
            2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
            2023-04-03 20:12:04.490  - warn: javascript.0 (471)     at Object.<anonymous> (script.js.Zähler.Gas.Umdrehungen_Gas:5:5)
            2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
            2023-04-03 20:12:04.491  - warn: javascript.0 (471)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
            2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
            2023-04-03 20:12:04.492  - warn: javascript.0 (471)     at processImmediate (node:internal/timers:466:21)
            2023-04-03 20:12:04.507  - warn: shelly.0 (602) [authEnabled] 192.168.178.64 (shelly1 / shelly1-E09806963CF8 / SHSW-1#E09806963CF8#1): This device is not protected via restricted login (see adapter documentation for details)
            2023-04-03 20:12:04.515  - info: javascript.0 (471) State value to set for "0_userdata.0.Zöhlerstände.Gas.Arbeitsvariable" has to be type "string" but received type "number"
            2023-04-03 20:12:04.671  - warn: shelly.0 (602) [authEnabled] 192.168.178.95 (shelly1 / shelly1-483FDAA23470 / SHSW-1#483FDAA23470#1): This device is not protected via restricted login (see adapter documentation for details)
            iob diag has finished.
            Press any key for a summary
            führe gleich iob fix aus
              Thomas Braun Most Active @federal last edited by Thomas Braun
              Hast du da mal als root herumgehampelt?
              Das sollte der iob fix nämlich eigentlich bereinigen.
              find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \;
              bringt?
                Homoran Global Moderator Administrators @federal last edited by
                kann aber nach wie vor nicht auf iob zugreifen
                @homoran sagte in ioBroker Backup wieder einspielen:
                admin als https konfiguriert?
                und deaktiviert
                  wenn, dann unbewusst
                    @federal
                    Was ist denn da los? Bei 4 ist die Kiste eigentlich dicht.
                    Homoran F 2 Replies Last reply Reply Quote 0
                      federal @Homoran last edited by
                      @homoran said in ioBroker Backup wieder einspielen:
                      und deaktiviert
                      https war eingerichtet. Wie kann ich es deaktivieren?
                        load average: 2.40, 2.64, 2.80
                        hat auch gut zu rödeln!
                        ich werde anscheinend ignoriert
                          <4 ist doch i.O.
                            Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                            @thomas-braun aber nicht, wenn angeblich nichts läuft
                              federal @federal last edited by
                              @federal said in ioBroker Backup wieder einspielen:
                              @federal
                              iob start admin
                              iob fix
                              habe mal ein Ausschnitt gemacht
                              2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25    )
                              2023-04-03 20:15:16.039  - error: host.raspberrypi Caught by controller[0]:         at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_hand    ler.js:151:20)
                              2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Object.onceWrapper (node:events:628:26)
                              2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:events:513:28)
                              2023-04-03 20:15:16.040  - error: host.raspberrypi Caught by controller[0]:         at Socket.emit (node:domain:489:12)
                              2023-04-03 20:15:16.041  - error: host.raspberrypi Caught by controller[0]:         at TCP.<anonymous> (node:net:301:12)
                              2023-04-03 20:15:16.041  - warn: host.raspberrypi instance system.adapter.shelly    .0 terminated due to SIGTERM
                              2023-04-03 20:15:16.042  - info: host.raspberrypi instance system.adapter.shelly    .0 terminated with code null ()
                              2023-04-03 20:15:16.107  - warn: host.raspberrypi instance system.adapter.sonoff    .0 terminated due to SIGTERM
                              2023-04-03 20:15:16.108  - info: host.raspberrypi instance system.adapter.sonoff    .0 terminated with code null ()
                              2023-04-03 20:15:16.201  - info: host.raspberrypi instance system.adapter.histor    y.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2023-04-03 20:15:16.209  - info: tuya.0 (634) Terminated (START_IMMEDIATELY_AFTE    R_STOP): Without reason
                              2023-04-03 20:15:16.889  - info: host.raspberrypi instance system.adapter.tuya.0     terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                              2023-04-03 20:15:16.891  - info: host.raspberrypi All instances are stopped.
                              2023-04-03 20:15:19.754  - error: host.raspberrypi Cannot find view "system" for     search "instance" : Connection is closed.
                              2023-04-03 20:15:19.756  - warn: host.raspberrypi instance system.adapter.zigbee    .0 terminated due to SIGTERM
                              2023-04-03 20:15:19.756  - info: host.raspberrypi instance system.adapter.zigbee    .0 terminated with code null ()
                              2023-04-03 20:15:19.757  - info: host.raspberrypi All instances are stopped.
                              2023-04-03 20:15:25.061  - info: host.raspberrypi terminated
                                @federal
                                Starte die Kiste mal durch...
                                Sauber!
                                sudo reboot
                                  @federal
                                  Sauber!
                                  sudo reboot
                                  jetzt bin ich wieder am Anfang von heute
                                  pi@raspberrypi:~ $ iobroker status
                                  node:internal/modules/cjs/loader:1024
                                    throw err;
                                  Error: Cannot find module 'buffer-equal-constant-time'
                                  Require stack:
                                  - /opt/iobroker/node_modules/jwa/index.js
                                  - /opt/iobroker/node_modules/jws/lib/sign-stream.js
                                  - /opt/iobroker/node_modules/jws/index.js
                                  - /opt/iobroker/node_modules/jsonwebtoken/decode.js
                                  - /opt/iobroker/node_modules/jsonwebtoken/index.js
                                  - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                                  - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                                  - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                                  - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
                                      at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                                      at Module.require (node:internal/modules/cjs/loader:1093:19)
                                      at require (node:internal/modules/cjs/helpers:108:18)
                                      at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
                                      at Module._compile (node:internal/modules/cjs/loader:1191:14)
                                      at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                                      at Module.load (node:internal/modules/cjs/loader:1069:32)
                                      at Function.Module._load (node:internal/modules/cjs/loader:904:12)
                                      at Module.require (node:internal/modules/cjs/loader:1093:19) {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: [
                                      '/opt/iobroker/node_modules/jwa/index.js',
                                      '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
                                      '/opt/iobroker/node_modules/jws/index.js',
                                      '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
                                      '/opt/iobroker/node_modules/jsonwebtoken/index.js',
                                      '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                                      '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                      '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                      '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                    @federal
                                    ich verstehe es leider nicht
                                      Thomas Braun Most Active last edited by Thomas Braun
                                      Ich auch nicht.
                                      Die drei Zahlen sind die Auslastung der CPU im Moment, der letzten 5 und der letzten 15 Minuten. 1 ist dabei ein Kern, da dein RPI derer 4 hat ist 4 halt = 100%.
                                      Irgendwas zieht da bei dir massiv Ressourcen, insbesondere da da vom iobroker her eigentlich nicht viel läuft macht das stutzig.
                                      Mit
                                      top
                                      schauen was da los ist.
                                      Edit: Mal zum Vergleich mein Rpi 4 / 8 GB:
                                      echad@chet:~ $ uptime
                                       20:42:40 up 8 days, 20:36,  2 users,  load average: 0.42, 0.37, 0.35
                                        Ich auch nicht.
                                        Mit
                                        top
                                          @federal
                                          Nach dem reboot schaut es gesünder aus.
                                            @federal
                                            iob ist immer noch nicht erreichbar.
                                            Ich muss mich ausklinken. Danke an alle.
                                            1.2k
                                            7206
