    3. Einsteigerfragen
    4. Installation
    5. ioBroker Backup wieder einspielen
      Thomas Braun Most Active @federal last edited by
      @federal
      Last login: Tue Apr  4 15:43:58 2023 from 100.75.198.95
      echad@chet:~ $ cd /opt/iobroker/
      echad@chet:/opt/iobroker $ npm ls buffer-equal-constant-time
      iobroker.inst@3.0.0 /opt/iobroker
      ├─┬ iobroker.backitup@2.6.16
      │ └─┬ google-auth-library@8.7.0
      │   └─┬ jws@4.0.0
      │     └─┬ jwa@2.0.0
      │       └── buffer-equal-constant-time@1.0.1
      └─┬ iobroker.js-controller@5.0.1-alpha.0-20230403-fd495c2e
        └─┬ jsonwebtoken@9.0.0
          └─┬ jws@3.2.2
            └─┬ jwa@1.4.1
              └── buffer-equal-constant-time@1.0.1 deduped
      Ich würde den js-controller nochmal installieren.
        federal @Thomas Braun last edited by
        @thomas-braun said in ioBroker Backup wieder einspielen:
        @federal
        │   └─┬ jws@4.0.0
        │     └─┬ jwa@2.0.0
            └─┬ jws@3.2.2
              └─┬ jwa@1.4.1
        wie mache ich das?
        Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @federal last edited by
          @federal sagte in ioBroker Backup wieder einspielen:
          wie mache ich das?
          https://forum.iobroker.net/post/972634
            Thomas Braun Most Active @federal last edited by Thomas Braun
            @federal
            iob stop
            iob fix
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
            iob start
              federal @Thomas Braun last edited by federal
              @federal
              iob stop
              iob fix
              cd /opt/iobroker
              iob start
              Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                @federal
                Wie immer bei Linux:
                Warten bis wieder eine Eingabezeile erscheint, erst dann ist der Task erledigt.
                  @federal
                    Your installation was fixed successfully
                      Run iobroker start to start ioBroker again!
                  pi@raspberrypi:~ $ cd /opt/iobroker
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-contr                     oller
                  npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now                      a built-in Node module. If you've depended on crypto, you should switch to the o                     ne that's built-in.
                  npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide                     s its own type definitions, so you do not need this installed.
                  npm WARN deprecated request-promise-native@1.0.9: request-promise-native has bee                     n deprecated because it extends the now deprecated request package, see https://                     github.com/request/request/issues/3142
                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b                     ecause it extends the now deprecated request package, see https://github.com/req                     uest/request/issues/3142
                  npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS                     ON 3
                  npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and                      does not need to be installed separately. It is now unmaintained.
                  npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav                     e a low-severity ReDos regression when used in a Node.js environment. It is reco                     mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss                     ues/797)
                  npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy.                      new code should use the URLSearchParams API instead.
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v                     ersions may use Math.random() in certain circumstances, which is known to be pro                     blematic.  See https://v8.dev/blog/math-random for details.
                  npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older v                     ersions may use Math.random() in certain circumstances, which is known to be pro                     blematic.  See https://v8.dev/blog/math-random for details.
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                     hub.com/request/request/issues/3142
                  npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21                     .1. For more information, see https://github.com/axios/axios/pull/3410
                  (##################) ⠸ reify:aws-sdk: timing reifyNode:node_modules/typescript
                  (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                  npm ERR! command failed
                  npm ERR! signal SIGINT
                  npm ERR! command sh -c -- node ./install/installTypings.js
                  npm ERR! Installing NodeJS typings...
                  npm ERR! latest @types: 18, installed node: 16
                  npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T16_30_22_609Z-debug-0.log
                  pi@raspberrypi:/opt/iobroker $ iob start
                  pi@raspberrypi:/opt/iobroker $ iob protokol
                  node:internal/modules/cjs/loader:1024
                    throw err;
                  Error: Cannot find module 'buffer-equal-constant-time'
                  Require stack:
                  - /opt/iobroker/node_modules/jwa/index.js
                  - /opt/iobroker/node_modules/jws/lib/sign-stream.js
                  - /opt/iobroker/node_modules/jws/index.js
                  - /opt/iobroker/node_modules/jsonwebtoken/decode.js
                  - /opt/iobroker/node_modules/jsonwebtoken/index.js
                  - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                  - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                  - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                  - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
                      at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                      at Module.require (node:internal/modules/cjs/loader:1093:19)
                      at require (node:internal/modules/cjs/helpers:108:18)
                      at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
                      at Module._compile (node:internal/modules/cjs/loader:1191:14)
                      at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                      at Module.load (node:internal/modules/cjs/loader:1069:32)
                      at Function.Module._load (node:internal/modules/cjs/loader:904:12)
                      at Module.require (node:internal/modules/cjs/loader:1093:19) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [
                      '/opt/iobroker/node_modules/jwa/index.js',
                      '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
                      '/opt/iobroker/node_modules/jws/index.js',
                      '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
                      '/opt/iobroker/node_modules/jsonwebtoken/index.js',
                      '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                      '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                      '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                      '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                  timemachine3030 created this issue in axios/axios
                  closed Hotfix: Prevent SSRF #3410
                  • Glasfaser
                    Glasfaser @federal last edited by Glasfaser
                    @federal
                    Bitte dein Beitrag nicht Editieren ... das bringt alle durcheinander !!!
                      Geh mal auf nodejs 18.
                        kann ich die Eingabe dazu haben?
                        • Glasfaser
                          wo hast du denn diesen Befehl her !?
                            federal @Glasfaser last edited by
                            @glasfaser said in ioBroker Backup wieder einspielen:
                            sorry. Habe mit iobroker status verwechselt
                            • Glasfaser
                                Schau in meiner Signatur.
                                  Super! Danke.
                                  V18 hat leider nichts gebracht
                                  pi@raspberrypi:/opt/iobroker $ iobroker status
                                  node:internal/modules/cjs/loader:1078
                                    throw err;
                                  Require stack:
                                      at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                                      at Module._load (node:internal/modules/cjs/loader:920:27)
                                      at Module.require (node:internal/modules/cjs/loader:1141:19)
                                      at require (node:internal/modules/cjs/helpers:110:18)
                                      at Module._compile (node:internal/modules/cjs/loader:1254:14)
                                      at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                                      at Module.load (node:internal/modules/cjs/loader:1117:32)
                                      at Module._load (node:internal/modules/cjs/loader:958:12)
                                      at Module.require (node:internal/modules/cjs/loader:1141:19) {
                                    requireStack: [
                                  Node.js v18.15.0
                                  • Glasfaser
                                    @federal
                                    mache mal ein
                                    npm prune
                                      @federal
                                      Was spuckt
                                      sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                      uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      aus?
                                        @federal
                                        mache mal ein
                                        npm prune
                                        pi@raspberrypi:/opt/iobroker $ npm prune
                                        npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in odule. If you've depended on crypto, you should switch to the one that's built-in.
                                        npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own tfinitions, so you do not need this installed.
                                        npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecateuse it extends the now deprecated request package, see https://github.com/request/request/i3142
                                        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it e the now deprecated request package, see https://github.com/request/request/issues/3142
                                        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not nebe installed separately. It is now unmaintained.
                                        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-sevReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.73.1. (https://github.com/visionmedia/debug/issues/797)
                                        npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code suse the URLSearchParams API instead.
                                        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
                                        npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
                                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/reqequest/issues/3142
                                        npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For morrmation, see https://github.com/axios/axios/pull/3410
                                        (##################) ⠴ reify:aws-sdk: timing reifyNode:node_modules/typescript Completed in
                                        added 16 packages, removed 936 packages, and changed 1238 packages in 17m
                                        175 packages are looking for funding
                                          run `npm fund` for details
                                        habe plötzlich bei Telegram die Buttons angezeigt bekommen?
                                        mikeal created this issue in request/request
                                        open Request’s Past, Present and Future #3142
                                        Qix- created this issue in visionmedia/debug
                                        closed ReDos Vulnerability Regression Visibility Notice #797
                                        • Glasfaser
                                          Bitte das noch zeigen !!! :
                                          @thomas-braun sagte in ioBroker Backup wieder einspielen:
                                          @federal
                                          Was spuckt
                                          aus?
                                            pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                            pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node        -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE &        & pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                            armv7l
                                            /usr/bin/nodejs
                                            /usr/bin/node
                                            /usr/bin/npm
                                            /usr/bin/npx
                                            v18.15.0
                                            v18.15.0
                                            9.5.0
                                            9.5.0
                                            4.0.24
                                            pi
                                            pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
                                            tty
                                            /home/pi
                                            OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                            OK:3 https://deb.nodesource.com/node_18.x buster InRelease
                                            Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u        m sie anzuzeigen.
                                            nodejs:
                                              Installiert:           18.15.0-deb-1nodesource1
                                              Installationskandidat: 18.15.0-deb-1nodesource1
                                              Versionstabelle:
                                             *** 18.15.0-deb-1nodesource1 500
                                                    500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                                                    100 /var/lib/dpkg/status
                                                 10.24.0~dfsg-1~deb10u3 500
                                            pi@raspberrypi:~ $
                                            pi@raspberrypi:~ $
                                            1.2k
                                            7206
