    3. Einsteigerfragen
    4. Installation
    5. ioBroker Backup wieder einspielen
      federal @Thomas Braun last edited by
      @thomas-braun said in ioBroker Backup wieder einspielen:
      @federal
      Last login: Tue Apr  4 15:43:58 2023 from 100.75.198.95
      echad@chet:~ $ cd /opt/iobroker/
      echad@chet:/opt/iobroker $ npm ls buffer-equal-constant-time
      iobroker.inst@3.0.0 /opt/iobroker
      ├─┬ iobroker.backitup@2.6.16
      │ └─┬ google-auth-library@8.7.0
      │   └─┬ jws@4.0.0
      │     └─┬ jwa@2.0.0
      │       └── buffer-equal-constant-time@1.0.1
      └─┬ iobroker.js-controller@5.0.1-alpha.0-20230403-fd495c2e
        └─┬ jsonwebtoken@9.0.0
          └─┬ jws@3.2.2
            └─┬ jwa@1.4.1
              └── buffer-equal-constant-time@1.0.1 deduped
      Ich würde den js-controller nochmal installieren.
      wie mache ich das?
      Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @federal last edited by
        @federal sagte in ioBroker Backup wieder einspielen:
        wie mache ich das?
        https://forum.iobroker.net/post/972634
          Thomas Braun Most Active @federal last edited by Thomas Braun
          @federal
          iob stop
          iob fix
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
          iob start
            federal @Thomas Braun last edited by federal
            @federal
            iob stop
            iob fix
            cd /opt/iobroker
            iob start
            Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
              @federal
              Wie immer bei Linux:
              Warten bis wieder eine Eingabezeile erscheint, erst dann ist der Task erledigt.
                @federal
                  Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                pi@raspberrypi:~ $ cd /opt/iobroker
                pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-contr                     oller
                npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now                      a built-in Node module. If you've depended on crypto, you should switch to the o                     ne that's built-in.
                npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide                     s its own type definitions, so you do not need this installed.
                npm WARN deprecated request-promise-native@1.0.9: request-promise-native has bee                     n deprecated because it extends the now deprecated request package, see https://                     github.com/request/request/issues/3142
                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b                     ecause it extends the now deprecated request package, see https://github.com/req                     uest/request/issues/3142
                npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS                     ON 3
                npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and                      does not need to be installed separately. It is now unmaintained.
                npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav                     e a low-severity ReDos regression when used in a Node.js environment. It is reco                     mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss                     ues/797)
                npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy.                      new code should use the URLSearchParams API instead.
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v                     ersions may use Math.random() in certain circumstances, which is known to be pro                     blematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older v                     ersions may use Math.random() in certain circumstances, which is known to be pro                     blematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                     hub.com/request/request/issues/3142
                npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21                     .1. For more information, see https://github.com/axios/axios/pull/3410
                (##################) ⠸ reify:aws-sdk: timing reifyNode:node_modules/typescript
                (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                npm ERR! command failed
                npm ERR! signal SIGINT
                npm ERR! command sh -c -- node ./install/installTypings.js
                npm ERR! Installing NodeJS typings...
                npm ERR! latest @types: 18, installed node: 16
                npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T16_30_22_609Z-debug-0.log
                pi@raspberrypi:/opt/iobroker $ iob start
                pi@raspberrypi:/opt/iobroker $ iob protokol
                node:internal/modules/cjs/loader:1024
                  throw err;
                Error: Cannot find module 'buffer-equal-constant-time'
                Require stack:
                - /opt/iobroker/node_modules/jwa/index.js
                - /opt/iobroker/node_modules/jws/lib/sign-stream.js
                - /opt/iobroker/node_modules/jws/index.js
                - /opt/iobroker/node_modules/jsonwebtoken/decode.js
                - /opt/iobroker/node_modules/jsonwebtoken/index.js
                - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
                    at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                    at Module.require (node:internal/modules/cjs/loader:1093:19)
                    at require (node:internal/modules/cjs/helpers:108:18)
                    at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
                    at Module._compile (node:internal/modules/cjs/loader:1191:14)
                    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                    at Module.load (node:internal/modules/cjs/loader:1069:32)
                    at Function.Module._load (node:internal/modules/cjs/loader:904:12)
                    at Module.require (node:internal/modules/cjs/loader:1093:19) {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: [
                    '/opt/iobroker/node_modules/jwa/index.js',
                    '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
                    '/opt/iobroker/node_modules/jws/index.js',
                    '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
                    '/opt/iobroker/node_modules/jsonwebtoken/index.js',
                    '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                    '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                    '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                    '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                timemachine3030 created this issue in axios/axios
                closed Hotfix: Prevent SSRF #3410
                • Glasfaser
                  Glasfaser @federal last edited by Glasfaser
                  @federal
                  Bitte dein Beitrag nicht Editieren ... das bringt alle durcheinander !!!
                    Geh mal auf nodejs 18.
                      kann ich die Eingabe dazu haben?
                      • Glasfaser
                        wo hast du denn diesen Befehl her !?
                          federal @Glasfaser last edited by
                          @glasfaser said in ioBroker Backup wieder einspielen:
                          sorry. Habe mit iobroker status verwechselt
                          • Glasfaser
                              Schau in meiner Signatur.
                                Super! Danke.
                                V18 hat leider nichts gebracht
                                pi@raspberrypi:/opt/iobroker $ iobroker status
                                node:internal/modules/cjs/loader:1078
                                  throw err;
                                Require stack:
                                    at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                                    at Module._load (node:internal/modules/cjs/loader:920:27)
                                    at Module.require (node:internal/modules/cjs/loader:1141:19)
                                    at require (node:internal/modules/cjs/helpers:110:18)
                                    at Module._compile (node:internal/modules/cjs/loader:1254:14)
                                    at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                                    at Module.load (node:internal/modules/cjs/loader:1117:32)
                                    at Module._load (node:internal/modules/cjs/loader:958:12)
                                    at Module.require (node:internal/modules/cjs/loader:1141:19) {
                                  requireStack: [
                                Node.js v18.15.0
                                • Glasfaser
                                  @federal
                                  mache mal ein
                                  npm prune
                                    @federal
                                    Was spuckt
                                    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                    uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    aus?
                                      @federal
                                      mache mal ein
                                      npm prune
                                      pi@raspberrypi:/opt/iobroker $ npm prune
                                      npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in odule. If you've depended on crypto, you should switch to the one that's built-in.
                                      npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own tfinitions, so you do not need this installed.
                                      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecateuse it extends the now deprecated request package, see https://github.com/request/request/i3142
                                      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it e the now deprecated request package, see https://github.com/request/request/issues/3142
                                      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not nebe installed separately. It is now unmaintained.
                                      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-sevReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.73.1. (https://github.com/visionmedia/debug/issues/797)
                                      npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code suse the URLSearchParams API instead.
                                      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
                                      npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
                                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/reqequest/issues/3142
                                      npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For morrmation, see https://github.com/axios/axios/pull/3410
                                      (##################) ⠴ reify:aws-sdk: timing reifyNode:node_modules/typescript Completed in
                                      added 16 packages, removed 936 packages, and changed 1238 packages in 17m
                                      175 packages are looking for funding
                                        run `npm fund` for details
                                      habe plötzlich bei Telegram die Buttons angezeigt bekommen?
                                      mikeal created this issue in request/request
                                      open Request’s Past, Present and Future #3142
                                      Qix- created this issue in visionmedia/debug
                                      closed ReDos Vulnerability Regression Visibility Notice #797
                                      • Glasfaser
                                        Bitte das noch zeigen !!! :
                                        @thomas-braun sagte in ioBroker Backup wieder einspielen:
                                        @federal
                                        Was spuckt
                                        aus?
                                          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                          pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node        -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE &        & pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                          armv7l
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          /usr/bin/npx
                                          v18.15.0
                                          v18.15.0
                                          9.5.0
                                          9.5.0
                                          4.0.24
                                          pi
                                          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
                                          tty
                                          /home/pi
                                          OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                          OK:3 https://deb.nodesource.com/node_18.x buster InRelease
                                          Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u        m sie anzuzeigen.
                                          nodejs:
                                            Installiert:           18.15.0-deb-1nodesource1
                                            Installationskandidat: 18.15.0-deb-1nodesource1
                                            Versionstabelle:
                                           *** 18.15.0-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                                                  100 /var/lib/dpkg/status
                                               10.24.0~dfsg-1~deb10u3 500
                                          pi@raspberrypi:~ $
                                          pi@raspberrypi:~ $
                                            buster
                                            Ist kürzlich dahingeschieden und muss duch 'bullseye' ersetzt werden.
                                            1.2k
                                            7206
