    3. Einsteigerfragen
    4. Installation
    5. ioBroker Backup wieder einspielen
    • Glasfaser
      Glasfaser @federal last edited by
      @federal sagte in ioBroker Backup wieder einspielen:
      wie mache ich das?
      https://forum.iobroker.net/post/972634
        Thomas Braun Most Active @federal last edited by Thomas Braun
        @federal
        iob stop
        iob fix
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        iob start
          federal @Thomas Braun last edited by federal
          @thomas-braun said in ioBroker Backup wieder einspielen:
          @federal
          iob stop
          iob fix
          cd /opt/iobroker
          iob start
          Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
            @federal
            Wie immer bei Linux:
            Warten bis wieder eine Eingabezeile erscheint, erst dann ist der Task erledigt.
              @federal
                Your installation was fixed successfully
                  Run iobroker start to start ioBroker again!
              pi@raspberrypi:~ $ cd /opt/iobroker
              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-contr                     oller
              npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now                      a built-in Node module. If you've depended on crypto, you should switch to the o                     ne that's built-in.
              npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide                     s its own type definitions, so you do not need this installed.
              npm WARN deprecated request-promise-native@1.0.9: request-promise-native has bee                     n deprecated because it extends the now deprecated request package, see https://                     github.com/request/request/issues/3142
              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
              npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b                     ecause it extends the now deprecated request package, see https://github.com/req                     uest/request/issues/3142
              npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS                     ON 3
              npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and                      does not need to be installed separately. It is now unmaintained.
              npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav                     e a low-severity ReDos regression when used in a Node.js environment. It is reco                     mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss                     ues/797)
              npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy.                      new code should use the URLSearchParams API instead.
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v                     ersions may use Math.random() in certain circumstances, which is known to be pro                     blematic.  See https://v8.dev/blog/math-random for details.
              npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older v                     ersions may use Math.random() in certain circumstances, which is known to be pro                     blematic.  See https://v8.dev/blog/math-random for details.
              npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                     hub.com/request/request/issues/3142
              npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21                     .1. For more information, see https://github.com/axios/axios/pull/3410
              (##################) ⠸ reify:aws-sdk: timing reifyNode:node_modules/typescript
              (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     (##################) ⠼ reify:aws-sdk: timing reifyNode:node_modules/typescript C                     npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
              npm ERR! command failed
              npm ERR! signal SIGINT
              npm ERR! command sh -c -- node ./install/installTypings.js
              npm ERR! Installing NodeJS typings...
              npm ERR! latest @types: 18, installed node: 16
              npm ERR!     /home/iobroker/.npm/_logs/2023-04-04T16_30_22_609Z-debug-0.log
              pi@raspberrypi:/opt/iobroker $ iob start
              pi@raspberrypi:/opt/iobroker $ iob protokol
              node:internal/modules/cjs/loader:1024
                throw err;
              Error: Cannot find module 'buffer-equal-constant-time'
              Require stack:
              - /opt/iobroker/node_modules/jwa/index.js
              - /opt/iobroker/node_modules/jws/lib/sign-stream.js
              - /opt/iobroker/node_modules/jws/index.js
              - /opt/iobroker/node_modules/jsonwebtoken/decode.js
              - /opt/iobroker/node_modules/jsonwebtoken/index.js
              - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
              - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
              - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
              - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
                  at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                  at Module.require (node:internal/modules/cjs/loader:1093:19)
                  at require (node:internal/modules/cjs/helpers:108:18)
                  at Object.<anonymous> (/opt/iobroker/node_modules/jwa/index.js:1:19)
                  at Module._compile (node:internal/modules/cjs/loader:1191:14)
                  at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                  at Module.load (node:internal/modules/cjs/loader:1069:32)
                  at Function.Module._load (node:internal/modules/cjs/loader:904:12)
                  at Module.require (node:internal/modules/cjs/loader:1093:19) {
                code: 'MODULE_NOT_FOUND',
                requireStack: [
                  '/opt/iobroker/node_modules/jwa/index.js',
                  '/opt/iobroker/node_modules/jws/lib/sign-stream.js',
                  '/opt/iobroker/node_modules/jws/index.js',
                  '/opt/iobroker/node_modules/jsonwebtoken/decode.js',
                  '/opt/iobroker/node_modules/jsonwebtoken/index.js',
                  '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                  '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                  '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                  '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              timemachine3030 created this issue in axios/axios
              closed Hotfix: Prevent SSRF #3410
              • Glasfaser
                Glasfaser @federal last edited by Glasfaser
                @federal
                Bitte dein Beitrag nicht Editieren ... das bringt alle durcheinander !!!
                  Geh mal auf nodejs 18.
                    kann ich die Eingabe dazu haben?
                    Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                    • Glasfaser
                      wo hast du denn diesen Befehl her !?
                        federal @Glasfaser last edited by
                        @glasfaser said in ioBroker Backup wieder einspielen:
                        sorry. Habe mit iobroker status verwechselt
                        • Glasfaser
                            Schau in meiner Signatur.
                              Super! Danke.
                              V18 hat leider nichts gebracht
                              pi@raspberrypi:/opt/iobroker $ iobroker status
                              node:internal/modules/cjs/loader:1078
                                throw err;
                              Require stack:
                                  at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                                  at Module._load (node:internal/modules/cjs/loader:920:27)
                                  at Module.require (node:internal/modules/cjs/loader:1141:19)
                                  at require (node:internal/modules/cjs/helpers:110:18)
                                  at Module._compile (node:internal/modules/cjs/loader:1254:14)
                                  at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                                  at Module.load (node:internal/modules/cjs/loader:1117:32)
                                  at Module._load (node:internal/modules/cjs/loader:958:12)
                                  at Module.require (node:internal/modules/cjs/loader:1141:19) {
                                requireStack: [
                              Node.js v18.15.0
                              • Glasfaser
                                @federal
                                mache mal ein
                                npm prune
                                  @federal
                                  Was spuckt
                                  sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                  uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  aus?
                                    @federal
                                    mache mal ein
                                    npm prune
                                    pi@raspberrypi:/opt/iobroker $ npm prune
                                    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in odule. If you've depended on crypto, you should switch to the one that's built-in.
                                    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own tfinitions, so you do not need this installed.
                                    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecateuse it extends the now deprecated request package, see https://github.com/request/request/i3142
                                    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it e the now deprecated request package, see https://github.com/request/request/issues/3142
                                    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not nebe installed separately. It is now unmaintained.
                                    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-sevReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.73.1. (https://github.com/visionmedia/debug/issues/797)
                                    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code suse the URLSearchParams API instead.
                                    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
                                    npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
                                    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/reqequest/issues/3142
                                    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For morrmation, see https://github.com/axios/axios/pull/3410
                                    (##################) ⠴ reify:aws-sdk: timing reifyNode:node_modules/typescript Completed in
                                    added 16 packages, removed 936 packages, and changed 1238 packages in 17m
                                    175 packages are looking for funding
                                      run `npm fund` for details
                                    habe plötzlich bei Telegram die Buttons angezeigt bekommen?
                                    mikeal created this issue in request/request
                                    open Request’s Past, Present and Future #3142
                                    Qix- created this issue in visionmedia/debug
                                    closed ReDos Vulnerability Regression Visibility Notice #797
                                    • Glasfaser
                                      Bitte das noch zeigen !!! :
                                      @thomas-braun sagte in ioBroker Backup wieder einspielen:
                                      @federal
                                      Was spuckt
                                      aus?
                                        pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node        -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE &        & pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        armv7l
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        /usr/bin/npx
                                        v18.15.0
                                        v18.15.0
                                        9.5.0
                                        9.5.0
                                        4.0.24
                                        pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
                                        tty
                                        /home/pi
                                        OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                        OK:3 https://deb.nodesource.com/node_18.x buster InRelease
                                        Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u        m sie anzuzeigen.
                                        nodejs:
                                          Installiert:           18.15.0-deb-1nodesource1
                                          Installationskandidat: 18.15.0-deb-1nodesource1
                                          Versionstabelle:
                                         *** 18.15.0-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                                                100 /var/lib/dpkg/status
                                             10.24.0~dfsg-1~deb10u3 500
                                        pi@raspberrypi:~ $
                                        pi@raspberrypi:~ $
                                          buster
                                          Ist kürzlich dahingeschieden und muss duch 'bullseye' ersetzt werden.
                                            buster
                                            und wie mach ich das?
                                            1.2k
                                            7206
