    4. iob diag - Skript
    iob diag - Skript
    • Glasfaser
      Glasfaser @Thomas Braun last edited by Glasfaser
      @thomas-braun sagte in iob diag - Skript:
      Kannst nochmal nach dem journalctl schauen? Sollte jetzt raus sein.
      Upps
      /var:
      sudo: unable to resolve host iobrokerv6: Name or service not known
      32M     /var/
      30M     /var/lib
      18M     /var/lib/apt/lists
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      ./iob_diag: line 303: syntax error: unexpected end of file
      root@iobrokerv6:/opt/iobroker#
      Negalein Thomas Braun 2 Replies Last reply Reply Quote 0
        emil70 @Thomas Braun last edited by
        Habe bei mir auch noch mal genau geguckt
        Diese Fehlermeldungen gibt es
        *** Time and Time Zones ***
        ./iob_diag: line 76: timedatectl: command not found
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        ./iob_diag: line 93: systemctl: command not found
        ./iob_diag: line 118: journalctl: command not found
        • Negalein
          Negalein Global Moderator @Glasfaser last edited by
          @glasfaser sagte in iob diag - Skript:
          Upps
          auch gerade gehabt
          *** FILESYSTEM ***
          Filesystem                       Type      Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--100--disk--0 ext4       20G   15G  4.0G  79% /
          10.0.1.21:/volume1/Backups       nfs4       14T  9.5T  4.6T  68% /opt/iobroker/backups
          none                             tmpfs     492K  4.0K  488K   1% /dev
          udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
          tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
          tmpfs                            tmpfs     1.6G  136K  1.6G   1% /run
          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1001
          dmesg: read kernel buffer failed: Operation not permitted
          Show mounted filesystems (real ones only):
          TARGET                           SOURCE                                FSTYPE     OPTIONS
          /                                /dev/mapper/pve-vm--100--disk--0      ext4       rw,relatime,stripe=16
          |-/opt/iobroker/backups          10.0.1.21:/volume1/Backups            nfs4       rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.1.201,local_lock=none,addr=10.0.1.21
          |-/proc/cpuinfo                  lxcfs[/proc/cpuinfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/diskstats                lxcfs[/proc/diskstats]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/loadavg                  lxcfs[/proc/loadavg]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/meminfo                  lxcfs[/proc/meminfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/stat                     lxcfs[/proc/stat]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/swaps                    lxcfs[/proc/swaps]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          |-/proc/uptime                   lxcfs[/proc/uptime]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          `-/sys/devices/system/cpu/online lxcfs[/sys/devices/system/cpu/online] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
          /var:
          2.5G    /var/
          2.0G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
          2.0G    /var/log
          307M    /var/lib
          • Glasfaser
            Geht :
            /var:
            32M     /var/
            30M     /var/lib
            18M     /var/lib/apt
            13M     /var/lib/dpkg
            Orrrrrrrrrr... Docker doesn't read journals!
            /opt/iobroker/backups:
            582M    /opt/iobroker/backups/
              Thomas Braun Most Active @Glasfaser last edited by
              @glasfaser
              Jaja, wenn man seinen eigenen Code nicht mal laufen lässt... 😉
              Probier jetzt nochmal.
              • Glasfaser
                siehe oben
                  @glasfaser
                  Okay, dann blanke ich die Meldung jetzt.
                    Thomas Braun Most Active @Thomas Braun last edited by
                    Also bei der Zeit und beim Terminaltype tickt der Docker anders, stimmt's?
                    • Glasfaser
                      Ja , die Befehle gibt es nicht
                      z.b:
                      root@iobrokerv6:/opt/iobroker# timedatectl
                      bash: timedatectl: command not found
                        Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
                        @glasfaser
                        Klar, das sind alles systemd-Kommandos.
                        Muss ich wohl leider den Code splitten und 'Sonderstrick' machen.
                        (Und/oder den root-Verboten-Code scharf schalten!)
                        • Glasfaser
                          Jein . kann gut gehen ...
                          , bzw.
                          Das Thema wurde schon mehrmals durchgekaut .. beim Thema " Docker "
                          bzw. auch hier Zusammengefasst :
                          https://forum.iobroker.net/topic/53193/root-user-im-container-docker-ja-nein-warum
                            @glasfaser
                            Jaja, ich weiß...
                              @glasfaser
                              Ziehst du nochmal?
                              • Glasfaser
                                Tue Apr  4 17:56:58 UTC 2023
                                Tue Apr  4 19:56:58 CEST 2023
                                CEST +0200
                                Etc/UTC
                                X-Server:       false
                                Desktop:
                                Terminal:
                                Run Level:
                                EDIT :
                                sieht auch gut aus
                                /var:
                                33M     /var/
                                30M     /var/lib
                                18M     /var/lib/apt
                                13M     /var/lib/dpkg
                                /opt/iobroker/iobroker-data:
                                  @glasfaser
                                  Okay, zumindest die Fehlermeldungen sind weg. RunLevel gibt es im Docker halt auch nicht im klassischen Sinne.
                                  Ich seh gerade, im SUMMARY muss ich das auch umstellen.
                                    @glasfaser
                                    Ziehst du das nochmal?
                                    Und kannst du auch mal die Langfassung wie auch die Summary posten?
                                    • Glasfaser
                                      Glasfaser last edited by Glasfaser
                                      EDIT
                                      EDIT
                                        @glasfaser
                                        Passt also.
                                        Was ich aber immer noch nicht verstanden habe: Wenn es einen user mit der uid=1000 gibt (wird der 'iobroker' sein), warum kann es keinen user 'glasfaser' mit uid=1001 im docker geben?
                                        • Glasfaser
                                          ist doch schon ein non-root-user
                                          https://medium.com/redbubble/running-a-docker-container-as-a-non-root-user-7d2e00f8ee15
                                            @glasfaser
                                            Ja mir wird immer erzählt das ginge nicht mit einem standard user und man müsse da immer als root herumgeistern.
                                            738
                                            154718
