    4. iob diag - Skript
    iob diag - Skript
      emil70 @Thomas Braun last edited by
      Habe bei mir auch noch mal genau geguckt
      Diese Fehlermeldungen gibt es
      *** Time and Time Zones ***
      ./iob_diag: line 76: timedatectl: command not found
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      ./iob_diag: line 93: systemctl: command not found
      ./iob_diag: line 118: journalctl: command not found
      • Negalein
        Negalein Global Moderator @Glasfaser last edited by
        @glasfaser sagte in iob diag - Skript:
        Upps
        auch gerade gehabt
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--100--disk--0 ext4       20G   15G  4.0G  79% /
        10.0.1.21:/volume1/Backups       nfs4       14T  9.5T  4.6T  68% /opt/iobroker/backups
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
        tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
        tmpfs                            tmpfs     1.6G  136K  1.6G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1001
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems (real ones only):
        TARGET                           SOURCE                                FSTYPE     OPTIONS
        /                                /dev/mapper/pve-vm--100--disk--0      ext4       rw,relatime,stripe=16
        |-/opt/iobroker/backups          10.0.1.21:/volume1/Backups            nfs4       rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.1.201,local_lock=none,addr=10.0.1.21
        |-/proc/cpuinfo                  lxcfs[/proc/cpuinfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/diskstats                lxcfs[/proc/diskstats]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/loadavg                  lxcfs[/proc/loadavg]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/meminfo                  lxcfs[/proc/meminfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/stat                     lxcfs[/proc/stat]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/swaps                    lxcfs[/proc/swaps]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        |-/proc/uptime                   lxcfs[/proc/uptime]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        `-/sys/devices/system/cpu/online lxcfs[/sys/devices/system/cpu/online] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        /var:
        2.5G    /var/
        2.0G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
        2.0G    /var/log
        307M    /var/lib
        ./iob_diag: line 303: syntax error: unexpected end of file
        • Glasfaser
          Glasfaser @Thomas Braun last edited by Glasfaser
          Geht :
          /var:
          sudo: unable to resolve host iobrokerv6: Name or service not known
          32M     /var/
          30M     /var/lib
          18M     /var/lib/apt/lists
          18M     /var/lib/apt
          13M     /var/lib/dpkg
          Orrrrrrrrrr... Docker doesn't read journals!
          /opt/iobroker/backups:
          582M    /opt/iobroker/backups/
            Thomas Braun Most Active @Glasfaser last edited by
            @glasfaser
            Jaja, wenn man seinen eigenen Code nicht mal laufen lässt... 😉
            Probier jetzt nochmal.
            • Glasfaser
              @thomas-braun sagte in iob diag - Skript:
              siehe oben
                @glasfaser
                Okay, dann blanke ich die Meldung jetzt.
                  Thomas Braun Most Active @Thomas Braun last edited by
                  Also bei der Zeit und beim Terminaltype tickt der Docker anders, stimmt's?
                  • Glasfaser
                    Ja , die Befehle gibt es nicht
                    z.b:
                    root@iobrokerv6:/opt/iobroker# timedatectl
                    bash: timedatectl: command not found
                      Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
                      @glasfaser
                      Klar, das sind alles systemd-Kommandos.
                      Muss ich wohl leider den Code splitten und 'Sonderstrick' machen.
                      (Und/oder den root-Verboten-Code scharf schalten!)
                      • Glasfaser
                        Jein . kann gut gehen ...
                        , bzw.
                        Das Thema wurde schon mehrmals durchgekaut .. beim Thema " Docker "
                        bzw. auch hier Zusammengefasst :
                        https://forum.iobroker.net/topic/53193/root-user-im-container-docker-ja-nein-warum
                          @glasfaser
                          Jaja, ich weiß...
                            @glasfaser
                            Ziehst du nochmal?
                            • Glasfaser
                              Tue Apr  4 17:56:58 UTC 2023
                              Tue Apr  4 19:56:58 CEST 2023
                              CEST +0200
                              Etc/UTC
                              X-Server:       false
                              Desktop:
                              Terminal:
                              Run Level:
                              EDIT :
                              sieht auch gut aus
                              /var:
                              33M     /var/
                              30M     /var/lib
                              18M     /var/lib/apt
                              13M     /var/lib/dpkg
                              /opt/iobroker/iobroker-data:
                                @glasfaser
                                Okay, zumindest die Fehlermeldungen sind weg. RunLevel gibt es im Docker halt auch nicht im klassischen Sinne.
                                Ich seh gerade, im SUMMARY muss ich das auch umstellen.
                                  @glasfaser
                                  Ziehst du das nochmal?
                                  Und kannst du auch mal die Langfassung wie auch die Summary posten?
                                  • Glasfaser
                                    Glasfaser last edited by Glasfaser
                                    EDIT
                                    EDIT
                                      @glasfaser
                                      Passt also.
                                      Was ich aber immer noch nicht verstanden habe: Wenn es einen user mit der uid=1000 gibt (wird der 'iobroker' sein), warum kann es keinen user 'glasfaser' mit uid=1001 im docker geben?
                                      • Glasfaser
                                        ist doch schon ein non-root-user
                                        https://medium.com/redbubble/running-a-docker-container-as-a-non-root-user-7d2e00f8ee15
                                          @glasfaser
                                          Ja mir wird immer erzählt das ginge nicht mit einem standard user und man müsse da immer als root herumgeistern.
                                          • Glasfaser
                                            Das Docker Image ist im Default auf 1000 SETGID und SETUID
                                            siehe auch hier :
                                            https://hub.docker.com/r/buanet/iobroker/dockerfile
                                            738
                                            154705
