    4. iob diag - Skript
    iob diag - Skript
    • Negalein
      Negalein Global Moderator @Glasfaser last edited by
      @glasfaser sagte in iob diag - Skript:
      Upps
      auch gerade gehabt
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0 ext4       20G   15G  4.0G  79% /
      10.0.1.21:/volume1/Backups       nfs4       14T  9.5T  4.6T  68% /opt/iobroker/backups
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
      tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs     1.6G  136K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1001
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems (real ones only):
      TARGET                           SOURCE                                FSTYPE     OPTIONS
      /                                /dev/mapper/pve-vm--100--disk--0      ext4       rw,relatime,stripe=16
      |-/opt/iobroker/backups          10.0.1.21:/volume1/Backups            nfs4       rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.1.201,local_lock=none,addr=10.0.1.21
      |-/proc/cpuinfo                  lxcfs[/proc/cpuinfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/diskstats                lxcfs[/proc/diskstats]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/loadavg                  lxcfs[/proc/loadavg]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/meminfo                  lxcfs[/proc/meminfo]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/stat                     lxcfs[/proc/stat]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/swaps                    lxcfs[/proc/swaps]                    fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/uptime                   lxcfs[/proc/uptime]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys/devices/system/cpu/online lxcfs[/sys/devices/system/cpu/online] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      2.5G    /var/
      2.0G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
      2.0G    /var/log
      307M    /var/lib
      ./iob_diag: line 303: syntax error: unexpected end of file
      • Glasfaser
        Glasfaser @Thomas Braun last edited by Glasfaser
        Geht :
        /var:
        sudo: unable to resolve host iobrokerv6: Name or service not known
        32M     /var/
        30M     /var/lib
        18M     /var/lib/apt/lists
        18M     /var/lib/apt
        13M     /var/lib/dpkg
        Orrrrrrrrrr... Docker doesn't read journals!
        /opt/iobroker/backups:
        582M    /opt/iobroker/backups/
          Thomas Braun Most Active @Glasfaser last edited by
          @glasfaser
          Jaja, wenn man seinen eigenen Code nicht mal laufen lässt... 😉
          Probier jetzt nochmal.
          • Glasfaser
            @thomas-braun sagte in iob diag - Skript:
            siehe oben
              @glasfaser
              Okay, dann blanke ich die Meldung jetzt.
                Thomas Braun Most Active @Thomas Braun last edited by
                Also bei der Zeit und beim Terminaltype tickt der Docker anders, stimmt's?
                • Glasfaser
                  Ja , die Befehle gibt es nicht
                  z.b:
                  root@iobrokerv6:/opt/iobroker# timedatectl
                  bash: timedatectl: command not found
                    Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
                    @glasfaser
                    Klar, das sind alles systemd-Kommandos.
                    Muss ich wohl leider den Code splitten und 'Sonderstrick' machen.
                    (Und/oder den root-Verboten-Code scharf schalten!)
                    • Glasfaser
                      Jein . kann gut gehen ...
                      , bzw.
                      Das Thema wurde schon mehrmals durchgekaut .. beim Thema " Docker "
                      bzw. auch hier Zusammengefasst :
                      https://forum.iobroker.net/topic/53193/root-user-im-container-docker-ja-nein-warum
                        @glasfaser
                        Jaja, ich weiß...
                          @glasfaser
                          Ziehst du nochmal?
                          • Glasfaser
                            *** Time and Time Zones ***
                            Tue Apr  4 17:56:58 UTC 2023
                            Tue Apr  4 19:56:58 CEST 2023
                            CEST +0200
                            Etc/UTC
                            *** X-Server-Setup ***
                            X-Server:       false
                            Desktop:
                            Terminal:
                            Run Level:
                            EDIT :
                            sieht auch gut aus
                            /var:
                            33M     /var/
                            30M     /var/lib
                            18M     /var/lib/apt
                            13M     /var/lib/dpkg
                            /opt/iobroker/iobroker-data:
                              @glasfaser
                              Okay, zumindest die Fehlermeldungen sind weg. RunLevel gibt es im Docker halt auch nicht im klassischen Sinne.
                              Ich seh gerade, im SUMMARY muss ich das auch umstellen.
                                @glasfaser
                                Ziehst du das nochmal?
                                Und kannst du auch mal die Langfassung wie auch die Summary posten?
                                • Glasfaser
                                  Glasfaser last edited by Glasfaser
                                  EDIT
                                  EDIT
                                    @glasfaser
                                    Passt also.
                                    Was ich aber immer noch nicht verstanden habe: Wenn es einen user mit der uid=1000 gibt (wird der 'iobroker' sein), warum kann es keinen user 'glasfaser' mit uid=1001 im docker geben?
                                    • Glasfaser
                                      ist doch schon ein non-root-user
                                      https://medium.com/redbubble/running-a-docker-container-as-a-non-root-user-7d2e00f8ee15
                                        @glasfaser
                                        Ja mir wird immer erzählt das ginge nicht mit einem standard user und man müsse da immer als root herumgeistern.
                                        • Glasfaser
                                          Das Docker Image ist im Default auf 1000 SETGID und SETUID
                                          siehe auch hier :
                                          https://hub.docker.com/r/buanet/iobroker/dockerfile
                                            @glasfaser
                                            Und einen weiteren user gibt der host nicht her?
                                            738
                                            154718
