    4. Test Adapter OpenDTU
      Thomas Braun Most Active @IdleBit last edited by
      @idlebit
      Okay, dachte ich mir.
        crunchip Forum Testing Most Active last edited by crunchip
        @IdleBit hab vorgestern mal die neuste Version eingespielt
        SDK-Version	v4.4.3
        Konfigurationsversion	0.1.24
        Firmwareversion / git Hash	7e28336
        seit dem kommt allerdings sporadisch immer mal
        opendtu.0
        2023-04-03 12:05:41.731	info	Connect to OpenDTU over websocket connection.
        opendtu.0
        2023-04-03 12:05:26.781	info	Connect to OpenDTU over websocket connection.
        opendtu.0
        2023-04-03 12:05:11.163	info	Connect to OpenDTU over websocket connection.
        opendtu.0
        2023-04-03 12:04:56.742	info	Connect to OpenDTU over websocket connection.
        opendtu.0
        2023-04-03 12:04:42.132	info	Connect to OpenDTU over websocket connection.
        opendtu.0
        2023-04-03 12:00:55.626	info	Connect to OpenDTU over websocket connection.
        ist da was bekannt, oder liegt das an meiner Verbindung?
        bei einem Neustart der Instanz kommt es auch mal dazu
        2023-04-03 09:54:44.776 - info: host.IoBroker stopInstance system.adapter.opendtu.0 (force=false, process=true)
        2023-04-03 09:54:44.839 - info: opendtu.0 (2626) Got terminate signal TERMINATE_YOURSELF
        2023-04-03 09:54:44.854 - info: opendtu.0 (2626) terminating
        2023-04-03 09:54:44.857 - info: opendtu.0 (2626) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-04-03 09:54:45.090 - info: host.IoBroker stopInstance system.adapter.opendtu.0 send kill signal
        2023-04-03 09:54:45.893 - error: opendtu.0 (2626) Cannot find view "system" for search "device" : Connection is closed.
        2023-04-03 09:54:45.895 - warn: opendtu.0 (2626) Cannot get view: Connection is closed.
        2023-04-03 09:54:45.897 - error: opendtu.0 (2626) Cannot find view "system" for search "channel" : Connection is closed.
        2023-04-03 09:54:45.898 - error: opendtu.0 (2626) Cannot find view "system" for search "state" : Connection is closed.
        2023-04-03 09:54:45.900 - error: opendtu.0 (2626) Cannot find view "system" for search "state" : Connection is closed.
        2023-04-03 09:54:45.928 - warn: opendtu.0 (2626) redis get opendtu.0.dtu.rssi, error - Connection is closed.
        2023-04-03 09:54:45.929 - warn: opendtu.0 (2626) redis get opendtu.0.dtu.ip, error - Connection is closed.
        2023-04-03 09:54:45.931 - warn: opendtu.0 (2626) redis get opendtu.0.dtu.uptime, error - Connection is closed.
        2023-04-03 09:54:45.932 - warn: opendtu.0 (2626) redis get opendtu.0.dtu.available, error - Connection is closed.
        2023-04-03 09:54:45.937 - warn: opendtu.0 (2626) Could not perform strict object check of state opendtu.0.dtu.rssi: DB closed
        2023-04-03 09:54:45.938 - warn: opendtu.0 (2626) get state error: Connection is closed.
        2023-04-03 09:54:45.939 - warn: opendtu.0 (2626) Could not perform strict object check of state opendtu.0.dtu.ip: DB closed
        2023-04-03 09:54:45.940 - warn: opendtu.0 (2626) get state error: Connection is closed.
        2023-04-03 09:54:45.940 - warn: opendtu.0 (2626) Could not perform strict object check of state opendtu.0.dtu.uptime: DB closed
        2023-04-03 09:54:45.941 - warn: opendtu.0 (2626) get state error: Connection is closed.
        2023-04-03 09:54:45.942 - warn: opendtu.0 (2626) Could not perform strict object check of state opendtu.0.dtu.available: DB closed
        2023-04-03 09:54:45.943 - warn: opendtu.0 (2626) get state error: Connection is closed.
        2023-04-03 09:54:46.118 - info: host.IoBroker stopInstance system.adapter.opendtu.0 killing pid 2626
        2023-04-03 09:54:46.595 - info: host.IoBroker instance system.adapter.opendtu.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-04-03 09:54:48.655 - info: host.IoBroker instance system.adapter.opendtu.0 started with pid 1560201
        2023-04-03 09:54:52.362 - info: opendtu.0 (1560201) starting. Version 0.1.1 (non-npm: o0shojo0o/ioBroker.opendtu) in /opt/iobroker/node_modules/iobroker.opendtu, node: v18.14.2, js-controller: 4.0.24
        2023-04-03 09:54:54.413 - info: opendtu.0 (1560201) Connect to OpenDTU over websocket connection.
        2023-04-03 12:20:57.915 - info: opendtu.0 (1560201) Connect to OpenDTU over websocket connection.
        2023-04-03 12:23:02.522 - info: host.IoBroker stopInstance system.adapter.opendtu.0 (force=false, process=true)
        2023-04-03 12:23:02.583 - info: opendtu.0 (1560201) Got terminate signal TERMINATE_YOURSELF
        2023-04-03 12:23:02.587 - info: opendtu.0 (1560201) terminating
        2023-04-03 12:23:02.588 - info: opendtu.0 (1560201) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-04-03 12:23:02.837 - info: host.IoBroker stopInstance system.adapter.opendtu.0 send kill signal
        2023-04-03 12:23:03.444 - error: opendtu.0 (1560201) Cannot find view "system" for search "state" : Connection is closed.
        2023-04-03 12:23:03.445 - warn: opendtu.0 (1560201) Cannot get view: Connection is closed.
        2023-04-03 12:23:03.766 - info: host.IoBroker instance system.adapter.opendtu.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-04-03 12:23:06.126 - info: host.IoBroker instance system.adapter.opendtu.0 started with pid 1629028
        2023-04-03 12:23:11.023 - info: opendtu.0 (1629028) starting. Version 0.1.1 (non-npm: o0shojo0o/ioBroker.opendtu) in /opt/iobroker/node_modules/iobroker.opendtu, node: v18.14.2, js-controller: 4.0.24
        2023-04-03 12:23:11.713 - info: opendtu.0 (1629028) Connect to OpenDTU over websocket connection.
        Z IdleBit 2 Replies Last reply Reply Quote 0
        • Z
          zolpetol @crunchip last edited by
          Danke für den Adapter!
          Eine Sache ist mir gerade aufgefallen: Unter dem Browser Chrome passiert nichts, bzw. wird nichts angezeigt, wenn ich auf den Tab openDTU klicke. Habe das auch unter dem Browser Edge probiert, da gibt es diese Probleme nicht - die openDTU-Oberfläche wird angezeigt.
          crunchip IdleBit 2 Replies Last reply Reply Quote 0
            crunchip Forum Testing Most Active @zolpetol last edited by
            @zolpetol hab ich auch, allerdings noch nicht herausgefunden warum es in chrome nicht angezeigt wird
            https://forum.iobroker.net/post/954741
              Thomas Braun Most Active @crunchip last edited by Thomas Braun
              @crunchip @zolpetol
              Liegt aber nicht generell am Chrome, hier läuft es mittlerweile. Hab an den Einstellungen des VPN weitere Hosts geroutet.
              Intern ging es eh immer.
                crunchip Forum Testing Most Active @Thomas Braun last edited by
                @thomas-braun sagte in Test Adapter OpenDTU:
                bei mir eben nicht, anfangs dachte ich es liegt am VPN, weil ich von aussen drauf zugreifen wollte, bis ich dann zu hause getestet hatte, jeder Browser funktioniert bei mir, nur eben chrome nicht
                  Laser last edited by
                  @crunchip
                  Ist es normal, daß auf der Seriellen Ausgabe kaum noch etwas erscheint? MQTT ist nicht genutzt, nur der OpenDTU Adapter.
                  15:32:36.652 > Interrupt received
                  15:32:36.751 > Interrupt received
                  15:32:42.063 > Interrupt received
                  15:32:42.175 > Interrupt received
                  15:32:47.404 > Interrupt received
                  15:32:52.716 > Interrupt received
                  15:32:52.819 > Interrupt received
                  15:32:58.148 > Interrupt received
                    @laser kommen den Daten an?
                      Laser @crunchip last edited by Laser
                      @crunchip ja, aber gaanz selten. Etwa alle 4 Minuten.
                      16:28:14.323 > Interrupt received
                      16:28:14.323 > TX RealTimeRunData Channel: 3 --> 15 83 81 83 46 80 11 12 60 80 0B 00 64 2E D7 16 00 00 00 00 00 00 00 00 BE 1C 93
                      16:28:20.332 > Interrupt received
                      16:28:26.684 > Interrupt received
                      16:28:32.412 > Interrupt received
                      16:28:32.507 > Interrupt received
                      16:28:38.344 > Interrupt received
                      16:28:38.432 > Interrupt received
                      16:28:44.284 > Interrupt received
                      16:28:44.359 > Fetch inverter: 112183818346
                      16:28:44.359 > Request SystemConfigPara
                      16:28:50.324 > Interrupt received
                      16:28:56.655 > Interrupt received
                      16:29:02.283 > Interrupt received
                        crunchip Forum Testing Most Active @Laser last edited by
                        @laser sagte in Test Adapter OpenDTU:
                        und welches Intervall hast du eingestellt?
                          @crunchip 5 Sekunden
                            crunchip Forum Testing Most Active @Laser last edited by crunchip
                            @laser hmm, bei mir steht es auf 10 sec, läuft unauffällig und in der Konsole werden die Daten entsprechend angezeigt
                            hast du möglicherweise eine schlechte Verbindung
                              @crunchip Bisher (bevor ich einen neuen DTU- Adapter zusammengebaut und geflasht hatte,) liefen pausenlos Werte ein. Werde die DTU mal umpositionieren.
                              EDIT: das gleiche Verhalten.
                                Laser @Laser last edited by
                                @crunchip Ansonsten, wenn ich Steuerbefehle absende, reagieren die Hoymiles in angemessener Zeit ( 10... 20 Sek- geschätzt).
                                • IdleBit
                                  IdleBit @crunchip last edited by
                                  @crunchip said in Test Adapter OpenDTU:
                                  SDK-Version v4.4.3
                                  Nein ist nichts bekannt, da wird deine Verbindung flöten gehen bzw. der DTU Neustarten / oder die Verbindung verlieren.
                                  Die Meldungen beim Neustart sind Timing Probleme die auftreten wenn der Adapter zu langsam stoppt, das kann passieren wenn das System zB. Ausgelastet war.
                                  • IdleBit
                                    IdleBit @zolpetol last edited by
                                    @zolpetol said in Test Adapter OpenDTU:
                                    UIch nutze auch Chrome ohne Probleme, kann es sein das dein IoBroker über https erreicht wird?
                                    Denn sperrt Chrome iFrames die kein https haben so wie die Seite von openDTU.
                                    • IdleBit
                                      @Laser Wenn du Probleme mit der Hardware hast würde ich in deiner stelle eher mal im OpenDTU Discord vorbeischauen weil da sitzen die Devs und Menschen die Support geben für das guten Stück.
                                      Das ist deren Server: https://discord.gg/WzhxEY62mB
                                      • N
                                        nettworker @Laser last edited by
                                        @laser said in Test Adapter OpenDTU:
                                        @peterredl
                                        Bei mir sehen die Objekte so aus:
                                        Ausschalten soll so gehen (??)
                                        setState('mqtt.1.solar.112183818346.cmd.power',0);
                                        Limit ändern so:
                                        var Zielwert;
                                        Zielwert = 300;
                                        //setState("mqtt.1.solar.112183227304.cmd.limit_nonpersistent_relative", Zielwert);
                                        setState("mqtt.1.solar.112183225956.cmd.limit_nonpersistent_relative", Zielwert);
                                        egal, ob relativ oder absolut, mal geht es, mal nicht
                                        Wie sind denn die cmd Datenpunkte bei dir "entstanden"?
                                        Von der openDTU wurden sie nicht angelegt, ich habe sie von Hand angelegt und die werden überhaupt nicht beachtet bzw. abgerufen.
                                          crunchip Forum Testing Most Active @nettworker last edited by
                                          @nettworker so nebenbei, wenn du doch eh den Adapter nutzt, sind die Datenpunkte unter powercontrol zu finden
                                          • IdleBit
                                            IdleBit @nettworker last edited by
                                            @nettworker hier geht es um den Adapter für die OpenDTU und nicht um die MQTT Einbindung.
                                            Bitte bleibt bei Thema oder macht einen neuen Thread auf, ich bekomme non stop hier Mails weil andauernd im meinen Thread Offtopic geschrieben wird..
                                            L Duffy 2 Replies Last reply Reply Quote 0
                                            dtu hoymiles opendtu solar
                                            47
                                            457
                                            121514
