    3. Einsteigerfragen
    4. Installation
    5. ioBroker Backup wieder einspielen
    • Glasfaser
      Glasfaser @federal last edited by
      @federal
      mache mal ein
      npm prune
        Thomas Braun Most Active @federal last edited by
        @federal
        Was spuckt
        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        aus?
          federal @Glasfaser last edited by
          @glasfaser said in ioBroker Backup wieder einspielen:
          @federal
          mache mal ein
          npm prune
          pi@raspberrypi:/opt/iobroker $ npm prune
          npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in odule. If you've depended on crypto, you should switch to the one that's built-in.
          npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own tfinitions, so you do not need this installed.
          npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecateuse it extends the now deprecated request package, see https://github.com/request/request/i3142
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it e the now deprecated request package, see https://github.com/request/request/issues/3142
          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
          npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not nebe installed separately. It is now unmaintained.
          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-sevReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.73.1. (https://github.com/visionmedia/debug/issues/797)
          npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code suse the URLSearchParams API instead.
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
          npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/reqequest/issues/3142
          npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For morrmation, see https://github.com/axios/axios/pull/3410
          (##################) ⠴ reify:aws-sdk: timing reifyNode:node_modules/typescript Completed in
          added 16 packages, removed 936 packages, and changed 1238 packages in 17m
          175 packages are looking for funding
            run `npm fund` for details
          habe plötzlich bei Telegram die Buttons angezeigt bekommen?
          mikeal created this issue in request/request
          open Request’s Past, Present and Future #3142
          Qix- created this issue in visionmedia/debug
          closed ReDos Vulnerability Regression Visibility Notice #797
          timemachine3030 created this issue in axios/axios
          closed Hotfix: Prevent SSRF #3410
          • Glasfaser
            @federal sagte in ioBroker Backup wieder einspielen:
            Bitte das noch zeigen !!! :
            @thomas-braun sagte in ioBroker Backup wieder einspielen:
            @federal
            Was spuckt
            aus?
              pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
              pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node        -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE &        & pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              armv7l
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              /usr/bin/npx
              v18.15.0
              v18.15.0
              9.5.0
              9.5.0
              4.0.24
              pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
              tty
              /home/pi
              OK:1 http://archive.raspberrypi.org/debian buster InRelease
              OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              OK:3 https://deb.nodesource.com/node_18.x buster InRelease
              Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u        m sie anzuzeigen.
              nodejs:
                Installiert:           18.15.0-deb-1nodesource1
                Installationskandidat: 18.15.0-deb-1nodesource1
                Versionstabelle:
               *** 18.15.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                      100 /var/lib/dpkg/status
                   10.24.0~dfsg-1~deb10u3 500
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $
                buster
                Ist kürzlich dahingeschieden und muss duch 'bullseye' ersetzt werden.
                  federal @Thomas Braun last edited by
                  @thomas-braun said in ioBroker Backup wieder einspielen:
                  buster
                  und wie mach ich das?
                  Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                    @federal
                    Hier hat das 'Abenteuer' mal einer protokoliert:
                    https://forum.iobroker.net/topic/47214/upgrade-von-debian-10-buster-auf-11-bullseye
                    • Glasfaser
                      Gegenfrage , läuft jetzt ioBroker !?
                      denn :
                      Mehr kam nicht bei der letzten Antwort !
                        denn :
                        ich habe danach iob fix ausgeführt
                        jetzt habe ich folgendes
                        pi@raspberrypi:~ $ iobroker status
                        iobroker is not running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                        • Glasfaser
                          Glasfaser @federal last edited by Glasfaser
                          Ja ... und kommst du jetzt auf den Admin
                          iobroker start
                            nein. Buttons gehen auch nicht mehr.
                              iobroker start
                              habe ich mehrmals probiert. Ohne Erfolg.
                              • Glasfaser
                                Jetzt sind wir schon bei >65 Beiträge ...
                                @federal
                                Setzte deine Kiste neu auf mit bullseye , ioBroker installieren ... dann eine Restore !
                                  Hallo Leute. Ich habe die Kiste doch ohne zurücksetzen zum laufen gebracht. Habe erneut mit dem Tool von Elzershark repariert und es hat auf einmal funktioniert. Vor euren Verschlägen/Befehlen ging es nicht! Alles läuft auf dem aktuellen Stand. Vielen Danke für eure Unterstützung.
                                  Homoran Glasfaser 2 Replies Last reply Reply Quote 0
                                    Homoran Global Moderator Administrators @federal last edited by
                                    hattest du das "Tool" vorher schon genutzt?
                                    dann wundert mich nichts mehr.
                                    dann bleibt nur
                                    @glasfaser sagte in ioBroker Backup wieder einspielen:
                                    Glasfaser 1 Reply Last reply Reply Quote 2
                                    • Glasfaser
                                      Erneut ... davon hast du nie was geschrieben ...
                                      Eher kaputt gemacht !!
                                      • Glasfaser
                                        Glasfaser @Homoran last edited by Glasfaser
                                        @federal
                                        @homoran sagte in ioBroker Backup wieder einspielen:
                                        Dito ...
                                        wenn du ein ioBroker System vernünftig laufen haben möchtest , dann installiere alles neu und nicht mit einem Dosenöffner-Werkzeug es instand setzen
                                        Edit :
                                        und zu :
                                        wenn du es von Anfang an uns geschrieben hättest , wären " wir " an deinem Problem ganz anders vorgegangen !
                                          @federal
                                          Dito ...
                                          wenn man sich nicht auskennt und auf externe Unterstützung angewiesen ist, ist es nicht so einfach. Ich bin mir nicht sicher, ob meine Sicherungen vollständig und i. O. sind. Möchte nicht alles neu machen. Werde mir zweiten Pi anschaffen und an dem die Versuche vornehmen. Sonnst ist es mir zu heiß, alles zu verlieren.
                                            @federal
                                            Dito ...
                                            Edit :
                                            und zu :
                                            habe nicht daran gedacht. Sorry. Wie kann man prüfen, ob was fehlerhaft ist?
                                            1.0k
                                            7203
