ioBroker Backup wieder einspielen
@federal
Was spucktsudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejsaus?
@glasfaser said in ioBroker Backup wieder einspielen:
mache mal ein
npm prunepi@raspberrypi:/opt/iobroker $ npm prune npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in odule. If you've depended on crypto, you should switch to the one that's built-in. npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own tfinitions, so you do not need this installed. npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecateuse it extends the now deprecated request package, see https://github.com/request/request/i3142 npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it e the now deprecated request package, see https://github.com/request/request/issues/3142 npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3 npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not nebe installed separately. It is now unmaintained. npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-sevReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.73.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-sevReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.73.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-sevReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.73.1. (https://github.com/visionmedia/debug/issues/797) npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code suse the URLSearchParams API instead. npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions mayath.random() in certain circumstances, which is known to be problematic. See https://v8.de/math-random for details. npm WARN deprecated uuid@3.3.2: Please upgrade to version 7 or higher. Older versions mayath.random() in certain circumstances, which is known to be problematic. See https://v8.de/math-random for details. npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/reqequest/issues/3142 npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For morrmation, see https://github.com/axios/axios/pull/3410 (##################) ⠴ reify:aws-sdk: timing reifyNode:node_modules/typescript Completed in added 16 packages, removed 936 packages, and changed 1238 packages in 17m 175 packages are looking for funding run `npm fund` for details pi@raspberrypi:/opt/iobroker $habe plötzlich bei Telegram die Buttons angezeigt bekommen?
@federal sagte in ioBroker Backup wieder einspielen:
Bitte das noch zeigen !!! :
@thomas-braun sagte in ioBroker Backup wieder einspielen:
@federal
pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE & & pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm /usr/bin/npx v18.15.0 v18.15.0 9.5.0 9.5.0 4.0.24 pi pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g pio i2c spi iobroker tty /home/pi OK:1 http://archive.raspberrypi.org/debian buster InRelease OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease OK:3 https://deb.nodesource.com/node_18.x buster InRelease Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u m sie anzuzeigen. nodejs: Installiert: 18.15.0-deb-1nodesource1 Installationskandidat: 18.15.0-deb-1nodesource1 Versionstabelle: *** 18.15.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_18.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u3 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages pi@raspberrypi:~ $ pi@raspberrypi:~ $ -
buster
Ist kürzlich dahingeschieden und muss duch 'bullseye' ersetzt werden.
@thomas-braun said in ioBroker Backup wieder einspielen:
buster
und wie mach ich das?
Hier hat das 'Abenteuer' mal einer protokoliert:
https://forum.iobroker.net/topic/47214/upgrade-von-debian-10-buster-auf-11-bullseye
Gegenfrage , läuft jetzt ioBroker !?
denn :
Mehr kam nicht bei der letzten Antwort !
denn :
ich habe danach iob fix ausgeführt
jetzt habe ich folgendespi@raspberrypi:~ $ iobroker status iobroker is not running on this host. Objects type: jsonl States type: jsonl -
Ja ... und kommst du jetzt auf den Adminiobroker start -
nein. Buttons gehen auch nicht mehr.
iobroker start
habe ich mehrmals probiert. Ohne Erfolg.
Jetzt sind wir schon bei >65 Beiträge ...
@federalHier hat das 'Abenteuer' mal einer protokoliert:
Setzte deine Kiste neu auf mit bullseye , ioBroker installieren ... dann eine Restore !
Hallo Leute. Ich habe die Kiste doch ohne zurücksetzen zum laufen gebracht. Habe erneut mit dem Tool von Elzershark repariert und es hat auf einmal funktioniert. Vor euren Verschlägen/Befehlen ging es nicht! Alles läuft auf dem aktuellen Stand. Vielen Danke für eure Unterstützung.
hattest du das "Tool" vorher schon genutzt?
dann wundert mich nichts mehr.dann bleibt nur
@glasfaser sagte in ioBroker Backup wieder einspielen:
Erneut ... davon hast du nie was geschrieben ...
Eher kaputt gemacht !!
@homoran sagte in ioBroker Backup wieder einspielen:
Dito ...
wenn du ein ioBroker System vernünftig laufen haben möchtest , dann installiere alles neu und nicht mit einem Dosenöffner-Werkzeug es instand setzen
Edit :
und zu :
wenn du es von Anfang an uns geschrieben hättest , wären " wir " an deinem Problem ganz anders vorgegangen !
Dito ...
wenn man sich nicht auskennt und auf externe Unterstützung angewiesen ist, ist es nicht so einfach. Ich bin mir nicht sicher, ob meine Sicherungen vollständig und i. O. sind. Möchte nicht alles neu machen. Werde mir zweiten Pi anschaffen und an dem die Versuche vornehmen. Sonnst ist es mir zu heiß, alles zu verlieren.
Dito ...
Edit :
und zu :
habe nicht daran gedacht. Sorry. Wie kann man prüfen, ob was fehlerhaft ist?
ich hoffe mit Backitup und nicht ein SD Clone
Das sogenannte Tool ( Dosenöffner-Werkzeug ) macht mehr kaputt ... das heißt du machst da was unkontrolliertes-- Automatik Tool ---
hier im Forum kann man dir in einzelnen Schritten mehr helfen ., deshalb sind alle Infos für uns wichtig !
und dafür ist das :
https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
