    3. Einsteigerfragen
    4. Installation
    5. ioBroker Backup wieder einspielen
      federal @Glasfaser last edited by
      @glasfaser said in ioBroker Backup wieder einspielen:
      @federal
      mache mal ein
      npm prune
      pi@raspberrypi:/opt/iobroker $ npm prune
      npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in odule. If you've depended on crypto, you should switch to the one that's built-in.
      npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own tfinitions, so you do not need this installed.
      npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecateuse it extends the now deprecated request package, see https://github.com/request/request/i3142
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it e the now deprecated request package, see https://github.com/request/request/issues/3142
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not nebe installed separately. It is now unmaintained.
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-sevReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.73.1. (https://github.com/visionmedia/debug/issues/797)
      npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code suse the URLSearchParams API instead.
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
      npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions mayath.random() in certain circumstances, which is known to be problematic.  See https://v8.de/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/reqequest/issues/3142
      npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For morrmation, see https://github.com/axios/axios/pull/3410
      (##################) ⠴ reify:aws-sdk: timing reifyNode:node_modules/typescript Completed in
      added 16 packages, removed 936 packages, and changed 1238 packages in 17m
      175 packages are looking for funding
        run `npm fund` for details
      habe plötzlich bei Telegram die Buttons angezeigt bekommen?
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      Qix- created this issue in visionmedia/debug
      closed ReDos Vulnerability Regression Visibility Notice #797
      timemachine3030 created this issue in axios/axios
      closed Hotfix: Prevent SSRF #3410
      • Glasfaser
        @federal sagte in ioBroker Backup wieder einspielen:
        Bitte das noch zeigen !!! :
        @thomas-braun sagte in ioBroker Backup wieder einspielen:
        @federal
        Was spuckt
        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        aus?
          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
          pi@raspberrypi:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node        -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE &        & pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          /usr/bin/npx
          v18.15.0
          v18.15.0
          9.5.0
          9.5.0
          4.0.24
          pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
          tty
          /home/pi
          OK:1 http://archive.raspberrypi.org/debian buster InRelease
          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          OK:3 https://deb.nodesource.com/node_18.x buster InRelease
          Aktualisierung für 3 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, u        m sie anzuzeigen.
          nodejs:
            Installiert:           18.15.0-deb-1nodesource1
            Installationskandidat: 18.15.0-deb-1nodesource1
            Versionstabelle:
           *** 18.15.0-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u3 500
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $
            Thomas Braun Most Active @federal last edited by
            buster
            Ist kürzlich dahingeschieden und muss duch 'bullseye' ersetzt werden.
              federal @Thomas Braun last edited by
              @thomas-braun said in ioBroker Backup wieder einspielen:
              buster
              und wie mach ich das?
              Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                @federal
                Hier hat das 'Abenteuer' mal einer protokoliert:
                https://forum.iobroker.net/topic/47214/upgrade-von-debian-10-buster-auf-11-bullseye
                • Glasfaser
                  Glasfaser @federal last edited by
                  Gegenfrage , läuft jetzt ioBroker !?
                  denn :
                  Mehr kam nicht bei der letzten Antwort !
                    denn :
                    ich habe danach iob fix ausgeführt
                    jetzt habe ich folgendes
                    pi@raspberrypi:~ $ iobroker status
                    iobroker is not running on this host.
                    Objects type: jsonl
                    States  type: jsonl
                    • Glasfaser
                      Glasfaser @federal last edited by Glasfaser
                      Ja ... und kommst du jetzt auf den Admin
                      iobroker start
                        nein. Buttons gehen auch nicht mehr.
                          iobroker start
                          habe ich mehrmals probiert. Ohne Erfolg.
                          • Glasfaser
                            Jetzt sind wir schon bei >65 Beiträge ...
                            @federal
                            Setzte deine Kiste neu auf mit bullseye , ioBroker installieren ... dann eine Restore !
                              Hallo Leute. Ich habe die Kiste doch ohne zurücksetzen zum laufen gebracht. Habe erneut mit dem Tool von Elzershark repariert und es hat auf einmal funktioniert. Vor euren Verschlägen/Befehlen ging es nicht! Alles läuft auf dem aktuellen Stand. Vielen Danke für eure Unterstützung.
                              Homoran Glasfaser 2 Replies Last reply Reply Quote 0
                                Homoran Global Moderator Administrators @federal last edited by
                                hattest du das "Tool" vorher schon genutzt?
                                dann wundert mich nichts mehr.
                                dann bleibt nur
                                @glasfaser sagte in ioBroker Backup wieder einspielen:
                                Glasfaser 1 Reply Last reply Reply Quote 2
                                • Glasfaser
                                  Erneut ... davon hast du nie was geschrieben ...
                                  Eher kaputt gemacht !!
                                  • Glasfaser
                                    Glasfaser @Homoran last edited by Glasfaser
                                    @federal
                                    @homoran sagte in ioBroker Backup wieder einspielen:
                                    Dito ...
                                    wenn du ein ioBroker System vernünftig laufen haben möchtest , dann installiere alles neu und nicht mit einem Dosenöffner-Werkzeug es instand setzen
                                    Edit :
                                    und zu :
                                    wenn du es von Anfang an uns geschrieben hättest , wären " wir " an deinem Problem ganz anders vorgegangen !
                                      @federal
                                      Dito ...
                                      wenn man sich nicht auskennt und auf externe Unterstützung angewiesen ist, ist es nicht so einfach. Ich bin mir nicht sicher, ob meine Sicherungen vollständig und i. O. sind. Möchte nicht alles neu machen. Werde mir zweiten Pi anschaffen und an dem die Versuche vornehmen. Sonnst ist es mir zu heiß, alles zu verlieren.
                                        @federal
                                        Dito ...
                                        Edit :
                                        und zu :
                                        habe nicht daran gedacht. Sorry. Wie kann man prüfen, ob was fehlerhaft ist?
                                        • Glasfaser
                                          ich hoffe mit Backitup und nicht ein SD Clone
                                          Das sogenannte Tool ( Dosenöffner-Werkzeug ) macht mehr kaputt ... das heißt du machst da was unkontrolliertes-- Automatik Tool ---
                                          hier im Forum kann man dir in einzelnen Schritten mehr helfen ., deshalb sind alle Infos für uns wichtig !
                                          und dafür ist das :
                                          https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
                                            das haben wir bisher versucht.
                                            Da wir aber nichts von der Nutzung des "Tools" wussten, fielen uns nur die verbogenen Rechte auf.
                                            So was macht das "Tool", und einiges mehr.
                                            1.0k
                                            7203
