    4. jarvis v3.1.x - just another remarkable vis
    • gelberlemmy
      gelberlemmy @MCU last edited by
      @mcu sagte in jarvis v3.1.x - just another remarkable vis:
      @gelberlemmy Bei mir läuft der auch sehr lange, habe allerdings auch alle selektiert.
      Es kommt auch eine Fehlermeldung im Browser-LOG (F12).
      Bei dir auch?
      Läuft quasi voll das LOG
        MCU @gelberlemmy last edited by
        @gelberlemmy
        Dann bitte ein Issue in github eröffnen.
        https://github.com/Zefau/ioBroker.jarvis/issues
        gelberlemmy 1 Reply Last reply Reply Quote 0
        • gelberlemmy
          @mcu da kamen noch andere Dinge. Ja ich werde Morgen ein Issue aufmachen. Danke für den Support
            @gelberlemmy Immer wieder gerne.
              dering last edited by
              Seit heute stürzt jarvis ab und ich erhalte folgende Fehlermeldung:
              jarvis.0
              2023-04-07 14:33:10.818	info	State value to set for "jarvis.0.settings.breakpoint-md" has to be type "number" but received type "string"
              jarvis.0
              2023-04-07 14:33:10.818	info	State value to set for "jarvis.0.settings.breakpoint-sm" has to be type "number" but received type "string"
              jarvis.0
              2023-04-07 14:33:10.817	info	State value to set for "jarvis.0.settings.pageHomeReturn" has to be type "number" but received type "string"
              jarvis.0
              2023-04-07 14:33:10.794	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              jarvis.0
              2023-04-07 14:33:10.793	info	terminating
              jarvis.0
              2023-04-07 14:33:10.793	info	Adapter stopped und unloaded.
              jarvis.0
              2023-04-07 14:33:10.773	info	Found Backups for devices.
              jarvis.0
              2023-04-07 14:33:10.764	info	Found Backups for layout.
              jarvis.0
              2023-04-07 14:33:10.761	error	Cannot read properties of null (reading 'native')
              jarvis.0
              2023-04-07 14:33:10.761	error	TypeError: Cannot read properties of null (reading 'native') at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/jarvis.js:136:66) at processImmediate (node:internal/timers:468:21)
              jarvis.0
              2023-04-07 14:33:10.760	error	uncaught exception: Cannot read properties of null (reading 'native')
              jarvis.0
              2023-04-07 14:33:10.759	info	Found Backups for styles.
              jarvis.0
              2023-04-07 14:33:10.758	info	Found Backups for widgets.
              jarvis.0
              2023-04-07 14:33:10.758	info	Found Backups for settings.
              jarvis.0
              2023-04-07 14:33:10.731	info	starting. Version 3.1.3 in /opt/iobroker/node_modules/iobroker.jarvis, node: v16.19.1, js-controller: 4.0.24
              Ich wüsste nicht, was ich in den letzten Tagen geändert haben sollte, was dafür verantwortlich sein könnte.
              Ist dieser Fehler bekannt? Wäre es unbedenklich auf die neueste Version aus github zu aktualisieren?
                MCU @dering last edited by MCU
                @dering
                Was steht in den DPs drin?
                Mach mal ein Upload.
                iob upload jarvis
                Wann stürzt jarvis ab, direkt nach dem Start?
                Browser-Log F12?
                Werden dort Fehler angezeigt?
                Aktualisieren, ja, wenn du die Apps nicht nutzt.
                Trotzdem immer erst eine Sicherung der DPs machen, als txt oder mit backitup >2.6.0.
                D 3 Replies Last reply Reply Quote 0
                  dering @MCU last edited by
                  @mcu
                  Ich kann den Datenpunkt native nicht finden.
                  iob upload jarvis hat nicht geholfen. jarvis stürzt direkt nach dem Start ab. Per Browser komm ich gar nicht drauf.
                  Mit App meinst du die App fürs Smartphone/Tablet? Die nutze ich nicht.
                  Ich hab ein Backup über backitup, dann aktualisiere ich mal auf die neueste Version.
                    @mcu
                    Ich hab jetzt 3.1.4-beta.6 installiert, jedoch gleicher Fehler:
                    host.iobroker
                    2023-04-07 15:51:32.001	error	instance system.adapter.jarvis.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    jarvis.0
                    2023-04-07 15:51:31.498	info	State value to set for "jarvis.0.settings.breakpoint-md" has to be type "number" but received type "string"
                    jarvis.0
                    2023-04-07 15:51:31.497	info	State value to set for "jarvis.0.settings.breakpoint-sm" has to be type "number" but received type "string"
                    jarvis.0
                    2023-04-07 15:51:31.496	info	State value to set for "jarvis.0.settings.pageHomeReturn" has to be type "number" but received type "string"
                    jarvis.0
                    2023-04-07 15:51:31.457	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    jarvis.0
                    2023-04-07 15:51:31.456	info	terminating
                    jarvis.0
                    2023-04-07 15:51:31.456	info	Adapter stopped und unloaded.
                    jarvis.0
                    2023-04-07 15:51:31.436	info	Found Backups for layout.
                    jarvis.0
                    2023-04-07 15:51:31.426	info	Found Backups for devices.
                    jarvis.0
                    2023-04-07 15:51:31.423	error	Cannot read properties of null (reading 'native')
                    jarvis.0
                    2023-04-07 15:51:31.423	error	TypeError: Cannot read properties of null (reading 'native') at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/jarvis.js:136:66) at processImmediate (node:internal/timers:468:21)
                    jarvis.0
                    2023-04-07 15:51:31.422	error	uncaught exception: Cannot read properties of null (reading 'native')
                    jarvis.0
                    2023-04-07 15:51:31.421	info	Found Backups for styles.
                    jarvis.0
                    2023-04-07 15:51:31.421	info	Found Backups for settings.
                    jarvis.0
                    2023-04-07 15:51:31.420	info	Found Backups for widgets.
                    jarvis.0
                    2023-04-07 15:51:31.396	info	starting. Version 3.1.4-beta.6 (non-npm: Zefau/ioBroker.jarvis) in /opt/iobroker/node_modules/iobroker.jarvis, node: v16.19.1, js-controller: 4.0.24
                      @dering Web-Adapter mit Instanz 0 vorhanden?
                        @mcu
                        Hast du eine Idee wo man 'native' finden sollte?
                          @dering Er findet keine Web Instanz 0
                            @mcu
                            Tatsächlich nicht. Hatte ich aber schon vor einigen Tagen gelöscht. Ich habe nur noch web.1.
                              @dering Jarvis braucht Web.0
                                @mcu
                                Joa und schon funktioniert es wieder 🙂
                                Ich danke dir für die schnelle Hilfe!
                                  MCU last edited by MCU
                                  Bis zu 9 boolean-DPs über ein HomeKitTile steuern.
                                  HomeKitTile mal anders (NUR mit PRO)
                                    marsmännchen @MCU last edited by
                                    Guten Abend mal wieder!
                                    Folgendes:
                                    Wenn ich als IFrame einen MJPEG Stream verwende (welcher stabil und sauber dargestellt wird) habe ich bei der Skalierung entweder den unerwünschten Balken:
                                    Im Layout:
                                    Oder einen Scrollbalken:
                                    Im Layout:
                                    Lässt sich so etwas irgendwie vermeiden? Da es von der breite her im Layout nur so zugelassen wird.
                                    MfG
                                    Patrick
                                      MCU @marsmännchen last edited by
                                      @marsmännchen
                                      Versuch es mal mit dem displayImage. Dort kann man das Verhältnis (Größe / Anpassung) einstellen.
                                        @mcu
                                        Kann nur sagen : Perfekt wie immer!!
                                        Danke sehr!
                                          marsmännchen @marsmännchen last edited by
                                          kann man bei der Notification die Dauer des Popup irgendwie auf unendlich stellen?
                                          jarvisNotify.timeout = 15000;  //5000ms -> 5 Sekunden
                                          0 funktioniert leider nicht.
                                          stephan1827 1 Reply Last reply Reply Quote 0
                                          • stephan1827
                                            stephan1827 @marsmännchen last edited by
                                            Hat hier schon jemand erfolgreich eine RTSP Stream eingebunden. Ich habe eine Reolink E1 Outdoor Kamera. RTSP läuft aber den string in einen iFrame eintragen reicht anscheinend nicht. Ich habe auf dieser Seite geguckt, aber da finde ich leider keine Lösung.
                                            https://mcuiobroker.gitbook.io/jarvis-infos/tipps/allgemein/kameras#reolink
                                            92
                                            1825
                                            690376
