      Thomas Braun Most Active @oFbEQnpoLKKl6mbY5e13 last edited by
      @ofbeqnpolkkl6mby5e13 sagte in Test Adapter ioBroker.backitup v2.6.x:
      dass der Pfad /opt/iobroker/backups sein muss, wäre der Pfad nicht konfigurierbar.
      Der Pfad ist relativ zu /opt/iobroker/backups wenn das Verzeichnis als Mountpunkt verwendet wird. Hängt halt vom Setup ab, zu dem aber noch nichts verwertbares gesagt wurde.
      • David G.
        habe eben auf die 2.6.16 geupdated.
        Seit dem laufen die Backups nicht mehr durch.
        Das planmäßige Backup heute morgen um 11 lief noch.
        backitup.0
        2023-04-07 12:47:52.125	debug	[iobroker] exec: done
        backitup.0
        2023-04-07 12:47:51.823	debug	[iobroker/historyJSON] done
        backitup.0
        2023-04-07 12:47:51.822	debug	[iobroker/historyJSON] new history json values created
        backitup.0
        2023-04-07 12:47:51.650	debug	[iobroker/historyHTML] done
        backitup.0
        2023-04-07 12:47:51.591	debug	[iobroker/historyHTML] new history html values created
        backitup.0
        2023-04-07 12:47:51.280	debug	[iobroker/telegram] done
        backitup.0
        2023-04-07 12:47:50.482	debug	[iobroker/clean] done
        backitup.0
        2023-04-07 12:47:50.481	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
        backitup.0
        2023-04-07 12:47:50.329	debug	[iobroker/googledrive] done
        backitup.0
        2023-04-07 12:47:48.525	debug	[iobroker/googledrive] Google Drive: Copy javascripts_2023_04_07-12_47_29_backupiobroker.tar.gz...
        backitup.0
        2023-04-07 12:47:46.728	debug	[iobroker/googledrive] Google Drive: Copy zigbee.0_2023_04_07-12_47_28_backupiobroker.tar.gz...
        backitup.0
        2023-04-07 12:47:42.186	debug	[iobroker/googledrive] Google Drive: Copy mysql_2023_04_07-12_47_08_backupiobroker.tar.gz...
        backitup.0
        2023-04-07 12:47:42.035	error	[iobroker/googledrive] Google Drive: File "/opt/iobroker/backups/iobroker_2023_04_07-12_46_05_backupiobroker.tar.gz" not found
        backitup.0
        2023-04-07 12:47:41.881	debug	[iobroker/dropbox] done
        backitup.0
        2023-04-07 12:47:40.852	debug	[iobroker/dropbox] Dropbox: Copy javascripts_2023_04_07-12_47_29_backupiobroker.tar.gz...
        backitup.0
        2023-04-07 12:47:40.070	debug	[iobroker/dropbox] Dropbox: Copy zigbee.0_2023_04_07-12_47_28_backupiobroker.tar.gz...
        backitup.0
        2023-04-07 12:47:35.400	debug	[iobroker/dropbox] Dropbox: Copy mysql_2023_04_07-12_47_08_backupiobroker.tar.gz...
        backitup.0
        2023-04-07 12:47:35.398	error	[iobroker/dropbox] Dropbox: File "/opt/iobroker/backups/iobroker_2023_04_07-12_46_05_backupiobroker.tar.gz" not found
        backitup.0
        2023-04-07 12:47:34.793	debug	[iobroker/ftp] done
        backitup.0
        2023-04-07 12:47:34.496	debug	[iobroker/ftp] Send javascripts_2023_04_07-12_47_29_backupiobroker.tar.gz
        backitup.0
        2023-04-07 12:47:34.421	debug	[iobroker/ftp] Send zigbee.0_2023_04_07-12_47_28_backupiobroker.tar.gz
        backitup.0
        2023-04-07 12:47:31.601	debug	[iobroker/ftp] Send mysql_2023_04_07-12_47_08_backupiobroker.tar.gz
        backitup.0
        2023-04-07 12:47:31.597	error	[iobroker/ftp] File "/opt/iobroker/backups/iobroker_2023_04_07-12_46_05_backupiobroker.tar.gz" not found
        backitup.0
        2023-04-07 12:47:31.595	debug	[iobroker/ftp] Send iobroker_2023_04_07-12_46_05_backupiobroker.tar.gz
        backitup.0
        2023-04-07 12:47:31.593	debug	[iobroker/ftp] FTP connected.
        backitup.0
        2023-04-07 12:47:30.992	debug	[iobroker/javascripts] done
        backitup.0
        2023-04-07 12:47:30.991	debug	[iobroker/javascripts] Backup created: /opt/iobroker/backups/javascripts_2023_04_07-12_47_29_backupiobroker.tar.gz
        backitup.0
        2023-04-07 12:47:30.991	debug	[iobroker/javascripts] Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
        backitup.0
        2023-04-07 12:47:30.981	debug	[iobroker/javascripts] Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
        backitup.0
        2023-04-07 12:47:30.174	debug	[iobroker/javascripts] found Script: 4_fach_Schalter_og
        backitup.0
        2023-04-07 12:47:30.173	debug	[iobroker/javascripts] found Script: aedvcfaedv
        backitup.0
        2023-04-07 12:47:30.172	debug	[iobroker/javascripts] found Script: VIS
        backitup.0
        2023-04-07 12:47:30.171	debug	[iobroker/javascripts] found Script: Dwtest
        backitup.0
        2023-04-07 12:47:30.171	debug	[iobroker/javascripts] found Script: Aaaaa
        backitup.0
        2023-04-07 12:47:30.170	debug	[iobroker/javascripts] found Script: Tebelle_Device_Watcher
        backitup.0
        2023-04-07 12:47:30.169	debug	[iobroker/javascripts] found Script: Reminder_Zeiterfassung_Frank
        backitup.0
        2023-04-07 12:47:30.168	debug	[iobroker/javascripts] found Script: To_SQL
        backitup.0
        2023-04-07 12:47:30.167	debug	[iobroker/javascripts] found Script: Reboot_bei_absturz
        backitup.0
        2023-04-07 12:47:30.166	debug	[iobroker/javascripts] found Script: Tabelle_ai_on_the_edge
        backitup.0
        2023-04-07 12:47:30.166	debug	[iobroker/javascripts] found Script: Sparen_David
        backitup.0
        2023-04-07 12:47:30.164	debug	[iobroker/javascripts] found Script: berechnungen
        backitup.0
        2023-04-07 12:47:30.164	debug	[iobroker/javascripts] found Script: Tabelle_Wireguard
        backitup.0
        2023-04-07 12:47:30.162	debug	[iobroker/javascripts] found Script: Test_
        backitup.0
        2023-04-07 12:47:30.162	debug	[iobroker/javascripts] found Script: Letzte_des_Monats
        backitup.0
        2023-04-07 12:47:30.161	debug	[iobroker/javascripts] found Script: Steckdose_Balkon
        backitup.0
        2023-04-07 12:47:30.161	debug	[iobroker/javascripts] found Script: Tabelle_anrufe
        backitup.0
        2023-04-07 12:47:30.160	debug	[iobroker/javascripts] found Script: Erreichbarkeit
        backitup.0
        2023-04-07 12:47:30.159	debug	[iobroker/javascripts] found Script: medikamente
        backitup.0
        2023-04-07 12:47:30.159	debug	[iobroker/javascripts] found Script: Profilwechsel_Urlaub_Feiertag
        backitup.0
        2023-04-07 12:47:30.158	debug	[iobroker/javascripts] found Script: Ueberwachung_Kuehltruhe
        backitup.0
        2023-04-07 12:47:30.158	debug	[iobroker/javascripts] found Script: Speedtest2
        backitup.0
        2023-04-07 12:47:30.157	debug	[iobroker/javascripts] found Script: Ueberwachte_Geraete
        backitup.0
        2023-04-07 12:47:30.156	debug	[iobroker/javascripts] found Script: Historie
        backitup.0
        2023-04-07 12:47:30.156	debug	[iobroker/javascripts] found Script: Alarmanlage_mit_Settings
        backitup.0
        2023-04-07 12:47:30.155	debug	[iobroker/javascripts] found Script: Settings
        backitup.0
        2023-04-07 12:47:30.129	debug	[iobroker/javascripts] found Script: altertest
        backitup.0
        2023-04-07 12:47:30.128	debug	[iobroker/javascripts] found Script: shedule
        backitup.0
        2023-04-07 12:47:30.127	debug	[iobroker/javascripts] found Script: waschundtrocknerzaehlen
        backitup.0
        2023-04-07 12:47:30.127	debug	[iobroker/javascripts] found Script: Gefrierschrank
        backitup.0
        2023-04-07 12:47:30.126	debug	[iobroker/javascripts] found Script: test
        backitup.0
        2023-04-07 12:47:30.125	debug	[iobroker/javascripts] found Script: Tebelle_Ping
        backitup.0
        2023-04-07 12:47:30.124	debug	[iobroker/javascripts] found Script: Tabelle_Tracking
        backitup.0
        2023-04-07 12:47:30.124	debug	[iobroker/javascripts] found Script: Tabelle_Tankstellen
        backitup.0
        2023-04-07 12:47:30.122	debug	[iobroker/javascripts] found Script: Tabelle_Tankerkoenig
        backitup.0
        2023-04-07 12:47:30.122	debug	[iobroker/javascripts] found Script: Tabelle_Kalender
        backitup.0
        2023-04-07 12:47:30.121	debug	[iobroker/javascripts] found Script: Tabelle_Erreichbarkeit_Zigbee
        backitup.0
        2023-04-07 12:47:30.120	debug	[iobroker/javascripts] found Script: Tabelle_Erreichbarkeit_SONOFF
        backitup.0
        2023-04-07 12:47:30.119	debug	[iobroker/javascripts] found Script: Tabelle_Erreibarkeit_Shelly
        backitup.0
        2023-04-07 12:47:30.119	debug	[iobroker/javascripts] found Script: Tabelle_Briefe
        backitup.0
        2023-04-07 12:47:30.118	debug	[iobroker/javascripts] found Script: Tabelle_Batterie_HmIP
        backitup.0
        2023-04-07 12:47:30.117	debug	[iobroker/javascripts] found Script: Tabelle_Backup
        backitup.0
        2023-04-07 12:47:30.116	debug	[iobroker/javascripts] found Script: Tabelle_Adapter
        backitup.0
        2023-04-07 12:47:30.115	debug	[iobroker/javascripts] found Script: TV
        backitup.0
        2023-04-07 12:47:30.114	debug	[iobroker/javascripts] found Script: Geburtstage
        backitup.0
        2023-04-07 12:47:30.113	debug	[iobroker/javascripts] found Script: Zeit_letzter_Stromausfall
        backitup.0
        2023-04-07 12:47:30.112	debug	[iobroker/javascripts] found Script: Usv_Service_Starten_
        backitup.0
        2023-04-07 12:47:30.112	debug	[iobroker/javascripts] found Script: Telegram_Akkuladung
        backitup.0
        2023-04-07 12:47:30.112	debug	[iobroker/javascripts] found Script: Shutdown
        backitup.0
        2023-04-07 12:47:30.111	debug	[iobroker/javascripts] found Script: zaehtest
        backitup.0
        2023-04-07 12:47:30.111	debug	[iobroker/javascripts] found Script: uhrtest
        backitup.0
        2023-04-07 12:47:30.110	debug	[iobroker/javascripts] found Script: test
        backitup.0
        2023-04-07 12:47:30.109	debug	[iobroker/javascripts] found Script: loeschen
        backitup.0
        2023-04-07 12:47:30.109	debug	[iobroker/javascripts] found Script: json_von_hdd_lesen
        backitup.0
        2023-04-07 12:47:30.108	debug	[iobroker/javascripts] found Script: hping3
        backitup.0
        2023-04-07 12:47:30.107	debug	[iobroker/javascripts] found Script: forumhilfe
        backitup.0
        2023-04-07 12:47:30.106	debug	[iobroker/javascripts] found Script: forum
        backitup.0
        2023-04-07 12:47:30.106	debug	[iobroker/javascripts] found Script: farbtest
        backitup.0
        2023-04-07 12:47:30.105	debug	[iobroker/javascripts] found Script: echartbild
        backitup.0
        2023-04-07 12:47:30.104	debug	[iobroker/javascripts] found Script: cptest
        backitup.0
        2023-04-07 12:47:30.103	debug	[iobroker/javascripts] found Script: Zufall
        backitup.0
        2023-04-07 12:47:30.103	debug	[iobroker/javascripts] found Script: Zeittest
        backitup.0
        2023-04-07 12:47:30.102	debug	[iobroker/javascripts] found Script: Woche_Kopie_
        backitup.0
        2023-04-07 12:47:30.102	debug	[iobroker/javascripts] found Script: Testanruf
        backitup.0
        2023-04-07 12:47:30.101	debug	[iobroker/javascripts] found Script: Termine_morgen_
        backitup.0
        2023-04-07 12:47:30.101	debug	[iobroker/javascripts] found Script: Telegramtest
        backitup.0
        2023-04-07 12:47:30.100	debug	[iobroker/javascripts] found Script: Tatei_schreiben
        backitup.0
        2023-04-07 12:47:30.100	debug	[iobroker/javascripts] found Script: Tasmota_Update
        backitup.0
        2023-04-07 12:47:30.099	debug	[iobroker/javascripts] found Script: Skript_1
        backitup.0
        2023-04-07 12:47:30.099	debug	[iobroker/javascripts] found Script: Sichtweite
        backitup.0
        2023-04-07 12:47:30.098	debug	[iobroker/javascripts] found Script: Owntracks_test_
        backitup.0
        2023-04-07 12:47:30.098	debug	[iobroker/javascripts] found Script: Mail2
        backitup.0
        2023-04-07 12:47:30.097	debug	[iobroker/javascripts] found Script: Mail
        backitup.0
        2023-04-07 12:47:30.097	debug	[iobroker/javascripts] found Script: Löschen
        backitup.0
        2023-04-07 12:47:30.096	debug	[iobroker/javascripts] found Script: Locationtest
        backitup.0
        2023-04-07 12:47:30.096	debug	[iobroker/javascripts] found Script: Inzidenz_Si
        backitup.0
        2023-04-07 12:47:30.095	debug	[iobroker/javascripts] found Script: Gps_abstand
        backitup.0
        2023-04-07 12:47:30.094	debug	[iobroker/javascripts] found Script: Geraete_zu_hause
        backitup.0
        2023-04-07 12:47:30.094	debug	[iobroker/javascripts] found Script: Funktionen_triggern_test_
        backitup.0
        2023-04-07 12:47:30.093	debug	[iobroker/javascripts] found Script: Beschreibung_
        backitup.0
        2023-04-07 12:47:30.092	debug	[iobroker/javascripts] found Script: Adalterlistetest
        backitup.0
        2023-04-07 12:47:30.091	debug	[iobroker/javascripts] found Script: Info_Garage
        backitup.0
        2023-04-07 12:47:30.090	debug	[iobroker/javascripts] found Script: Bild_BH_emfangen
        backitup.0
        2023-04-07 12:47:30.089	debug	[iobroker/javascripts] found Script: Ansage_Haustuer_geschlossen
        backitup.0
        2023-04-07 12:47:30.089	debug	[iobroker/javascripts] found Script: Tanken_2
        backitup.0
        2023-04-07 12:47:30.088	debug	[iobroker/javascripts] found Script: tv_backup
        backitup.0
        2023-04-07 12:47:30.087	debug	[iobroker/javascripts] found Script: alter_berechnen
        backitup.0
        2023-04-07 12:47:30.086	debug	[iobroker/javascripts] found Script: Tv
        backitup.0
        2023-04-07 12:47:30.086	debug	[iobroker/javascripts] found Script: Sql_test_
        backitup.0
        2023-04-07 12:47:30.085	debug	[iobroker/javascripts] found Script: Sql_test
        backitup.0
        2023-04-07 12:47:30.084	debug	[iobroker/javascripts] found Script: Garage_schließen
        backitup.0
        2023-04-07 12:47:30.084	debug	[iobroker/javascripts] found Script: Garage_mit_Lichtschalter_oeffnen
        backitup.0
        2023-04-07 12:47:30.083	debug	[iobroker/javascripts] found Script: Garage_iob
        backitup.0
        2023-04-07 12:47:30.082	debug	[iobroker/javascripts] found Script: Garage_1sek
        backitup.0
        2023-04-07 12:47:30.081	debug	[iobroker/javascripts] found Script: Ping_Verzögerung_ABwesendb
        backitup.0
        2023-04-07 12:47:30.081	debug	[iobroker/javascripts] found Script: Personen_Zaehlen
        backitup.0
        2023-04-07 12:47:30.080	debug	[iobroker/javascripts] found Script: Umrechnung_Ping_Google
        backitup.0
        2023-04-07 12:47:30.079	debug	[iobroker/javascripts] found Script: Popup
        backitup.0
        2023-04-07 12:47:30.079	debug	[iobroker/javascripts] found Script: Fernbedienung
        backitup.0
        2023-04-07 12:47:30.078	debug	[iobroker/javascripts] found Script: Ansagen
        backitup.0
        2023-04-07 12:47:30.077	debug	[iobroker/javascripts] found Script: Ansage_Anrufer
        backitup.0
        2023-04-07 12:47:30.076	debug	[iobroker/javascripts] found Script: PRESETS
        backitup.0
        2023-04-07 12:47:30.076	debug	[iobroker/javascripts] found Script: Texte_vis
        backitup.0
        2023-04-07 12:47:30.075	debug	[iobroker/javascripts] found Script: iob_alle_aus
        backitup.0
        2023-04-07 12:47:30.075	debug	[iobroker/javascripts] found Script: Morgens_treppenlicht_unten_aus
        backitup.0
        2023-04-07 12:47:30.075	debug	[iobroker/javascripts] found Script: Schlafzimmer_seitliche_Spots
        backitup.0
        2023-04-07 12:47:30.074	debug	[iobroker/javascripts] found Script: Flurlicht_UG
        backitup.0
        2023-04-07 12:47:30.074	debug	[iobroker/javascripts] found Script: Dimmer_Esszimmerdeckenlamoe
        backitup.0
        2023-04-07 12:47:30.073	debug	[iobroker/javascripts] found Script: Licht_wenn_nachts_nach_Hause
        backitup.0
        2023-04-07 12:47:30.073	debug	[iobroker/javascripts] found Script: Licht_Kuechenzeile
        backitup.0
        2023-04-07 12:47:30.072	debug	[iobroker/javascripts] found Script: Flurschlaflicht
        backitup.0
        2023-04-07 12:47:30.071	debug	[iobroker/javascripts] found Script: Licht_Anwesenheitssteuerung
        backitup.0
        2023-04-07 12:47:30.071	debug	[iobroker/javascripts] found Script: Erinnerung
        backitup.0
        2023-04-07 12:47:30.070	debug	[iobroker/javascripts] found Script: BH_Kindergarten_abholen
        backitup.0
        2023-04-07 12:47:30.069	debug	[iobroker/javascripts] found Script: Upluad_Hannah
        backitup.0
        2023-04-07 12:47:30.069	debug	[iobroker/javascripts] found Script: guten_morgen
        backitup.0
        2023-04-07 12:47:30.068	debug	[iobroker/javascripts] found Script: doy
        backitup.0
        2023-04-07 12:47:30.067	debug	[iobroker/javascripts] found Script: Wochenübersicht_System
        backitup.0
        2023-04-07 12:47:30.066	debug	[iobroker/javascripts] found Script: Taegliches_Wetter
        backitup.0
        2023-04-07 12:47:30.065	debug	[iobroker/javascripts] found Script: RPI_LEDs_aus
        backitup.0
        2023-04-07 12:47:30.064	debug	[iobroker/javascripts] found Script: Muellmeldung
        backitup.0
        2023-04-07 12:47:30.063	debug	[iobroker/javascripts] found Script: Kommende_Woche
        backitup.0
        2023-04-07 12:47:30.062	debug	[iobroker/javascripts] found Script: Inzidenz
        backitup.0
        2023-04-07 12:47:30.061	debug	[iobroker/javascripts] found Script: Geraetestatus
        backitup.0
        2023-04-07 12:47:30.061	debug	[iobroker/javascripts] found Script: Gaestelan_Passwort_mit_QR
        backitup.0
        2023-04-07 12:47:30.060	debug	[iobroker/javascripts] found Script: Eiskratzen
        backitup.0
        2023-04-07 12:47:30.059	debug	[iobroker/javascripts] found Script: Auto_gute_nacht_
        backitup.0
        2023-04-07 12:47:30.058	debug	[iobroker/javascripts] found Script: Anzahl_Geräte
        backitup.0
        2023-04-07 12:47:30.057	debug	[iobroker/javascripts] found Script: Verlauf_Fenster
        backitup.0
        2023-04-07 12:47:30.056	debug	[iobroker/javascripts] found Script: Mittelwert_Heizung_KZ1
        backitup.0
        2023-04-07 12:47:30.055	debug	[iobroker/javascripts] found Script: Heizung_Party
        backitup.0
        2023-04-07 12:47:30.055	debug	[iobroker/javascripts] found Script: tasker_http
        backitup.0
        2023-04-07 12:47:30.054	debug	[iobroker/javascripts] found Script: owntracks_http
        backitup.0
        2023-04-07 12:47:30.053	debug	[iobroker/javascripts] found Script: Seat_to_places
        backitup.0
        2023-04-07 12:47:30.052	debug	[iobroker/javascripts] found Script: Owntracks_zu_Places
        backitup.0
        2023-04-07 12:47:30.051	debug	[iobroker/javascripts] found Script: Google_maps_link
        backitup.0
        2023-04-07 12:47:30.050	debug	[iobroker/javascripts] found Script: Adresse_Tin
        backitup.0
        2023-04-07 12:47:30.049	debug	[iobroker/javascripts] found Script: Adresse_David
        backitup.0
        2023-04-07 12:47:30.048	debug	[iobroker/javascripts] found Script: Forum_Gerae_auslesen_
        backitup.0
        2023-04-07 12:47:30.048	debug	[iobroker/javascripts] found Script: Wassermelder_Garage
        backitup.0
        2023-04-07 12:47:30.047	debug	[iobroker/javascripts] found Script: Auslage_pfi_blade
        backitup.0
        2023-04-07 12:47:30.046	debug	[iobroker/javascripts] found Script: CCU_Zeilenumbruch_und_Nachrichten_generieren
        backitup.0
        2023-04-07 12:47:30.044	debug	[iobroker/javascripts] found Script: CCU_Statusmeldungen
        backitup.0
        2023-04-07 12:47:30.042	debug	[iobroker/javascripts] found Script: CCU_Hardware_auslesen
        backitup.0
        2023-04-07 12:47:30.041	debug	[iobroker/javascripts] found Script: RAM
        backitup.0
        2023-04-07 12:47:30.040	debug	[iobroker/javascripts] found Script: CPU_Kopieren
        backitup.0
        2023-04-07 12:47:30.039	debug	[iobroker/javascripts] found Script: Haustür_Willkommen
        backitup.0
        2023-04-07 12:47:30.036	debug	[iobroker/javascripts] found Script: Meldung_offene_Fenster_beim_abschliessen
        backitup.0
        2023-04-07 12:47:30.034	debug	[iobroker/javascripts] found Script: Licht_an_bei_Alarm
        backitup.0
        2023-04-07 12:47:30.033	debug	[iobroker/javascripts] found Script: Alarmanlage_Telegram
        backitup.0
        2023-04-07 12:47:30.029	debug	[iobroker/javascripts] found Script: Alarmanlage
        backitup.0
        2023-04-07 12:47:29.127	debug	[iobroker/javascripts] Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
        backitup.0
        2023-04-07 12:47:28.369	debug	[iobroker/zigbee] done
        backitup.0
        2023-04-07 12:47:28.368	debug	[iobroker/zigbee] found zigbee database: zigbee.0
        backitup.0
        2023-04-07 12:47:27.607	debug	[iobroker/mysql] done
        backitup.0
        2023-04-07 12:47:27.606	debug	[iobroker/mysql] MySql-Backup for is finish
        backitup.0
        2023-04-07 12:47:27.597	debug	[iobroker/mysql] MySql File deleted!
        backitup.0
        2023-04-07 12:47:26.602	debug	[iobroker/mysql] Packed 9MB so far...
        backitup.0
        2023-04-07 12:47:08.959	debug	[iobroker/mysql] MySql-Backup started ...
        backitup.0
        2023-04-07 12:47:08.649	debug	[iobroker/iobroker] done
        backitup.0
        2023-04-07 12:46:22.998	debug	[iobroker/iobroker] host.pi 26536 objects saved
        backitup.0
        2023-04-07 12:46:15.380	debug	[iobroker/iobroker] host.pi 24256 states saved
        backitup.0
        2023-04-07 12:46:05.014	debug	Backup has started
        Er mag irgendwie keinen Clouddienst mehr...
        • simatec
          simatec Developer Most Active @David G. last edited by
          @david-g sagte in Test Adapter ioBroker.backitup v2.6.x:
          Dein iobroker Backup wurde nicht gefunden... Prüfe mal deine Rechte
          ls -lah /opt/iobroker/backups
          iob fix
          • David G.
            David G. @simatec last edited by
            @simatec
            Nach dem fixer ist er durchgelaufen.
            Kann es sein, dass das Update die Rechte verbogen hat?
            Zur Vollständigkeit mal die rechte vor dem fixer:
            pi@pi:~ $ ls -lah /opt/iobroker/backups
            total 2.1G
            drwxrwxr-x+ 2 iobroker iobroker  20K Apr  7 12:47 .
            drwxrwxr-x+ 9 iobroker iobroker 4.0K Mar 20 11:19 ..
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Feb 11 11:02 homematic_2023_02_11-11_02_15_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Feb 12 11:00 homematic_2023_02_12-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Feb 13 11:00 homematic_2023_02_13-11_00_12_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Feb 14 11:01 homematic_2023_02_14-11_01_45_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Mar 13 11:00 homematic_2023_03_13-11_00_12_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Mar 14 11:00 homematic_2023_03_14-11_00_12_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Mar 15 11:00 homematic_2023_03_15-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Mar 16 11:00 homematic_2023_03_16-11_00_12_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Mar 17 11:00 homematic_2023_03_17-11_00_12_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Mar 18 11:00 homematic_2023_03_18-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Mar 19 11:03 homematic_2023_03_19-11_02_52_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker 1.8M Mar 20 11:00 homematic_2023_03_20-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Mar 21 11:00 homematic_2023_03_21-11_00_12_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Mar 22 11:00 homematic_2023_03_22-11_00_12_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Mar 23 11:00 homematic_2023_03_23-11_00_12_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Mar 24 11:00 homematic_2023_03_24-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Mar 25 11:00 homematic_2023_03_25-11_00_12_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Mar 26 11:00 homematic_2023_03_26-11_00_12_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Mar 27 11:00 homematic_2023_03_27-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Mar 28 11:00 homematic_2023_03_28-11_00_12_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Mar 29 11:00 homematic_2023_03_29-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Mar 30 11:00 homematic_2023_03_30-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Mar 31 11:00 homematic_2023_03_31-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Apr  1 11:00 homematic_2023_04_01-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Apr  2 11:00 homematic_2023_04_02-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Apr  3 11:00 homematic_2023_04_03-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Apr  4 11:00 homematic_2023_04_04-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Apr  5 11:00 homematic_2023_04_05-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Apr  6 11:00 homematic_2023_04_06-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rw-r--+ 1 iobroker iobroker 1.8M Apr  7 11:00 homematic_2023_04_07-11_00_11_3.67.10_backupiobroker.tar.sbk
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan  5 11:01 iobroker_2023_01_05-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan  7 11:01 iobroker_2023_01_07-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan 10 11:01 iobroker_2023_01_10-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan 13 11:01 iobroker_2023_01_13-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan 14 11:01 iobroker_2023_01_14-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan 15 11:01 iobroker_2023_01_15-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan 16 11:01 iobroker_2023_01_16-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan 19 11:01 iobroker_2023_01_19-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan 25 11:01 iobroker_2023_01_25-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan 27 11:01 iobroker_2023_01_27-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan 28 11:01 iobroker_2023_01_28-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan 29 11:01 iobroker_2023_01_29-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Jan 31 11:01 iobroker_2023_01_31-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Feb  3 11:01 iobroker_2023_02_03-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Feb  5 11:03 iobroker_2023_02_05-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  31M Feb  8 11:01 iobroker_2023_02_08-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  32M Feb 16 11:01 iobroker_2023_02_16-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  32M Feb 18 11:01 iobroker_2023_02_18-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  32M Feb 20 11:07 iobroker_2023_02_20-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  32M Feb 22 11:01 iobroker_2023_02_22-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  33M Feb 25 11:01 iobroker_2023_02_25-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  33M Mar  1 11:01 iobroker_2023_03_01-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  33M Mar  3 11:01 iobroker_2023_03_03-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  33M Mar  4 11:01 iobroker_2023_03_04-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  33M Mar  5 11:01 iobroker_2023_03_05-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  33M Mar 14 11:01 iobroker_2023_03_14-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  33M Mar 16 11:01 iobroker_2023_03_16-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  33M Mar 18 11:01 iobroker_2023_03_18-11_00_40_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  33M Mar 19 11:01 iobroker_2023_03_19-11_00_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker  33M Mar 20 11:01 iobroker_2023_03_20-11_00_40_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker  33M Apr  7 12:43 iobroker_2023_04_07-12_42_53_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 766K Feb 10 11:01 javascripts_2023_02_10-11_01_20_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 783K Feb 11 11:01 javascripts_2023_02_11-11_01_39_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 790K Feb 12 11:02 javascripts_2023_02_12-11_02_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 805K Feb 13 11:01 javascripts_2023_02_13-11_01_18_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 830K Feb 14 11:01 javascripts_2023_02_14-11_01_08_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 831K Feb 15 11:01 javascripts_2023_02_15-11_01_24_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 833K Feb 16 11:01 javascripts_2023_02_16-11_01_18_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 833K Feb 17 11:01 javascripts_2023_02_17-11_01_25_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 833K Feb 18 11:01 javascripts_2023_02_18-11_01_19_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 833K Feb 19 11:01 javascripts_2023_02_19-11_01_17_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 834K Feb 20 11:08 javascripts_2023_02_20-11_08_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 816K Feb 21 11:01 javascripts_2023_02_21-11_01_24_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 816K Feb 22 11:01 javascripts_2023_02_22-11_01_29_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 823K Feb 23 11:03 javascripts_2023_02_23-11_03_04_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 823K Feb 24 11:02 javascripts_2023_02_24-11_02_34_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 826K Feb 25 11:01 javascripts_2023_02_25-11_01_50_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 829K Feb 26 11:03 javascripts_2023_02_26-11_03_57_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 832K Feb 27 11:01 javascripts_2023_02_27-11_01_21_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 832K Feb 28 11:01 javascripts_2023_02_28-11_01_48_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 838K Mar 13 11:01 javascripts_2023_03_13-11_01_28_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 838K Mar 14 11:01 javascripts_2023_03_14-11_01_48_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 838K Mar 15 11:01 javascripts_2023_03_15-11_01_29_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 838K Mar 16 11:01 javascripts_2023_03_16-11_01_45_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 838K Mar 17 11:01 javascripts_2023_03_17-11_01_51_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 839K Mar 18 11:01 javascripts_2023_03_18-11_01_44_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 839K Mar 19 11:01 javascripts_2023_03_19-11_01_43_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 839K Mar 20 07:30 javascripts_2023_03_20-07_30_35_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 839K Mar 20 11:01 javascripts_2023_03_20-11_01_45_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 839K Mar 21 11:01 javascripts_2023_03_21-11_01_33_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 843K Mar 30 11:01 javascripts_2023_03_30-11_01_17_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 844K Apr  2 13:01 javascripts_2023_04_02-13_01_02_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 846K Apr  7 12:30 javascripts_2023_04_07-12_30_46_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 846K Apr  7 12:39 javascripts_2023_04_07-12_39_21_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 846K Apr  7 12:44 javascripts_2023_04_07-12_44_00_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 846K Apr  7 12:47 javascripts_2023_04_07-12_47_29_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.2M Feb 11 11:01 mysql_2023_02_11-11_01_24_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.2M Feb 12 11:02 mysql_2023_02_12-11_01_54_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.2M Feb 13 11:01 mysql_2023_02_13-11_01_04_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.3M Feb 14 11:01 mysql_2023_02_14-11_00_54_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.3M Feb 15 11:01 mysql_2023_02_15-11_01_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.3M Feb 16 11:01 mysql_2023_02_16-11_01_04_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.4M Feb 17 11:01 mysql_2023_02_17-11_01_12_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.4M Feb 18 11:01 mysql_2023_02_18-11_01_06_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.5M Feb 19 11:01 mysql_2023_02_19-11_01_03_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.5M Feb 20 11:08 mysql_2023_02_20-11_07_51_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.6M Feb 21 11:01 mysql_2023_02_21-11_01_09_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 9.6M Mar 13 11:01 mysql_2023_03_13-11_01_11_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 9.6M Mar 14 11:01 mysql_2023_03_14-11_01_30_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 9.7M Mar 15 11:01 mysql_2023_03_15-11_01_13_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 9.7M Mar 16 11:01 mysql_2023_03_16-11_01_28_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 9.8M Mar 17 11:01 mysql_2023_03_17-11_01_32_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 9.8M Mar 18 11:01 mysql_2023_03_18-11_01_28_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 9.9M Mar 19 11:01 mysql_2023_03_19-11_01_28_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 9.9M Mar 20 07:30 mysql_2023_03_20-07_30_18_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 9.9M Mar 20 11:01 mysql_2023_03_20-11_01_29_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker  10M Mar 21 11:01 mysql_2023_03_21-11_01_16_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker  52M Mar 22 11:17 mysql_2023_03_22-11_17_05_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  52M Mar 24 11:01 mysql_2023_03_24-11_01_18_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  52M Mar 25 11:01 mysql_2023_03_25-11_01_07_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  53M Mar 26 11:01 mysql_2023_03_26-11_01_21_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  53M Mar 27 11:01 mysql_2023_03_27-11_01_05_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  53M Mar 28 11:01 mysql_2023_03_28-11_01_17_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  53M Mar 29 11:01 mysql_2023_03_29-11_00_59_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker    0 Mar 29 11:01 mysql_2023_03_29-11_00_59_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker  11M Mar 30 11:01 mysql_2023_03_30-11_00_57_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker  54M Mar 31 11:01 mysql_2023_03_31-11_01_04_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  54M Apr  1 11:01 mysql_2023_04_01-11_01_07_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  54M Apr  2 11:01 mysql_2023_04_02-11_01_06_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  11M Apr  2 13:01 mysql_2023_04_02-13_00_41_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker  55M Apr  3 11:01 mysql_2023_04_03-11_01_11_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  55M Apr  4 11:01 mysql_2023_04_04-11_01_05_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  55M Apr  5 11:01 mysql_2023_04_05-11_01_11_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  55M Apr  6 11:01 mysql_2023_04_06-11_00_58_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker 916K Apr  6 11:01 mysql_2023_04_06-11_00_58_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker  56M Apr  7 11:01 mysql_2023_04_07-11_01_04_backupiobroker.sql
            -rw-rw-r--+ 1 iobroker iobroker  11M Apr  7 12:30 mysql_2023_04_07-12_30_25_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker  11M Apr  7 12:39 mysql_2023_04_07-12_39_02_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker  11M Apr  7 12:43 mysql_2023_04_07-12_43_44_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker  11M Apr  7 12:47 mysql_2023_04_07-12_47_08_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 10 11:01 zigbee.0_2023_02_10-11_01_20_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 11 11:01 zigbee.0_2023_02_11-11_01_39_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 12 11:02 zigbee.0_2023_02_12-11_02_09_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 13 11:01 zigbee.0_2023_02_13-11_01_17_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 14 11:01 zigbee.0_2023_02_14-11_01_08_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 15 11:01 zigbee.0_2023_02_15-11_01_23_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 16 11:01 zigbee.0_2023_02_16-11_01_17_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 17 11:01 zigbee.0_2023_02_17-11_01_25_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 18 11:01 zigbee.0_2023_02_18-11_01_19_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 19 11:01 zigbee.0_2023_02_19-11_01_17_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 20 11:08 zigbee.0_2023_02_20-11_08_09_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 21 11:01 zigbee.0_2023_02_21-11_01_23_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 22 11:01 zigbee.0_2023_02_22-11_01_29_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 23 11:03 zigbee.0_2023_02_23-11_03_03_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 24 11:02 zigbee.0_2023_02_24-11_02_33_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 25 11:01 zigbee.0_2023_02_25-11_01_49_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 26 11:03 zigbee.0_2023_02_26-11_03_57_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 27 11:01 zigbee.0_2023_02_27-11_01_20_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Feb 28 11:01 zigbee.0_2023_02_28-11_01_47_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Mar 13 11:01 zigbee.0_2023_03_13-11_01_27_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Mar 14 11:01 zigbee.0_2023_03_14-11_01_47_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Mar 15 11:01 zigbee.0_2023_03_15-11_01_29_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Mar 16 11:01 zigbee.0_2023_03_16-11_01_45_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2K Mar 17 11:01 zigbee.0_2023_03_17-11_01_50_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.4K Mar 18 11:01 zigbee.0_2023_03_18-11_01_43_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.5K Mar 19 11:01 zigbee.0_2023_03_19-11_01_43_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.5K Mar 20 07:30 zigbee.0_2023_03_20-07_30_34_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.5K Mar 20 11:01 zigbee.0_2023_03_20-11_01_45_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Mar 21 11:01 zigbee.0_2023_03_21-11_01_32_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Mar 30 11:01 zigbee.0_2023_03_30-11_01_16_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.4K Apr  2 13:01 zigbee.0_2023_04_02-13_01_01_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Apr  7 12:30 zigbee.0_2023_04_07-12_30_45_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Apr  7 12:39 zigbee.0_2023_04_07-12_39_21_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Apr  7 12:44 zigbee.0_2023_04_07-12_44_00_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Apr  7 12:47 zigbee.0_2023_04_07-12_47_28_backupiobroker.tar.gz
            pi@pi:~ $
            • simatec
              simatec Developer Most Active @David G. last edited by simatec
              @david-g nein das Update ändert keine Rechte
              Es fehlt auch nur das iobroker backup.
              Erstelle es mal über cli „iob backup“ und poste die Ausgabe.
              • David G.
                David G. @simatec last edited by David G.
                @simatec sagte in Test Adapter ioBroker.backitup v2.6.x:
                Hier die Ausgabe, aber wie gesagt läuft es ja wieder nach dem fix.
                pi@pi:~ $ iob backup
                host.pi 24257 states saved
                host.pi 26537 objects saved
                /usr/bin/iob: line 10: 26203 Killed                  sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                pi@pi:~ $
                Auf einem anderen System habe ich das Update auch heute eingespielt. Dort gab es diese Erscheinung nicht.
                  Thomas Braun Most Active @David G. last edited by
                  Dürfte aber auch keine reguläre Rückmeldung sein. Hast du den Prozess abgeschossen?
                  • David G.
                    David G. @Thomas Braun last edited by
                    Gestartet und gewartet. War das "reguläre" Ende.
                      @david-g
                      So sollte das eigentlich ausschauen:
                      echad@chet:~ $ iob backup
                      host.chet 7232 states saved
                      host.chet 9065 objects saved
                      Backup created: /opt/iobroker/backups/2023_04_07-20_06_05_backupiobroker.tar.gz
                      This backup can only be restored with js-controller version up from 4.1
                      echad@chet:~ $
                      • David G.
                        Hab es gtad nochmal getestet. Selbes Ergebnis.
                        Wurde auch kein Backup angelegt.
                        Die backups über die gui sind zu sehen.
                        Das nächste automatische läuft morgen.
                          @david-g
                          Hast du den
                          iob fix
                          mal drübergejagt?
                          • David G.
                            Kommando zurück.
                            Über die gui läuft auch nicht mehr...
                            Ja, habe ich heute morgen. Danach lief einmal ein Backup.
                            Lasse den jetzt nochmal laufen....
                              @david-g
                              Wie schaut deine Umgebung aus?
                              iob diag
                              mal anschauen.
                              David G. 2 Replies Last reply Reply Quote 0
                              • David G.
                                Fixer grad nochmal laufen lassen.
                                Jetzt geht es wieder......
                                Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)           Kernel:                 6.1.21-v8+
                                Installation:           Native                                     Timezone:               Europe/Berlin (CEST, +0200)
                                User-ID:                1000                                       X-Server:               false
                                Boot Target:            multi-user.target
                                Pending OS-Updates:     0                                          Pending iob updates:    0
                                Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                                                        /usr/bin/node           v18.15.0
                                                        /usr/bin/npm            9.5.0
                                                        /usr/bin/npx            9.5.0
                                Recommended versions are nodejs 18.x.y and npm 9.x.y
                                MEMORY:
                                Mem:            3.8G        2.6G        623M        0.0K        587M        1.1G
                                Swap:            99M          0B         99M
                                Total:          3.9G        2.6G        723M
                                Active iob-Instances:   55
                                Active repo(s): Stable (default)
                                ioBroker Core:          js-controller           4.0.24
                                                        admin                   6.3.7
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                + system.adapter.admin.1                  : admin                 : pi                                       -  enabled, port: 777, bind: 0.0.0.0, run as: admin
                                + system.adapter.admin.2                  : admin                 : pi                                       -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                                + system.adapter.web.1                    : web                   : pi                                       -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                Objects:                26530
                                States:                 24360
                                Size of iob-Database:
                                39M     /opt/iobroker/iobroker-data/objects.jsonl
                                22M     /opt/iobroker/iobroker-data/states.jsonl
                                Skript v.2023-04-02
                                *** BASE SYSTEM ***                                                Model           : Raspberry Pi 4 Model B Rev 1.2
                                Architecture    : aarch64
                                Docker          : false
                                Virtualization  : none
                                Distributor ID: Raspbian                                           Description:    Raspbian GNU/Linux 11 (bullseye)
                                Release:        11
                                Codename:       bullseye
                                PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                                NAME="Raspbian GNU/Linux"
                                VERSION_ID="11"
                                VERSION="11 (bullseye)"
                                VERSION_CODENAME=bullseye
                                ID=raspbian
                                ID_LIKE=debian
                                HOME_URL="http://www.raspbian.org/"
                                SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                Systemuptime and Load:
                                 21:17:25 up 7 min,  2 users,  load average: 4.58, 3.51, 1.76
                                CPU threads: 4
                                *** Time and Time Zones ***
                                               Local time: Fri 2023-04-07 21:17:25 CEST
                                           Universal time: Fri 2023-04-07 19:17:25 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                *** User and Groups ***
                                pi
                                /home/pi
                                pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                *** X-Server-Setup ***
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.8G        2.6G        862M        0.0K        324M        1.1G
                                Swap:            99M          0B         99M
                                Total:          3.9G        2.6G        962M
                                         3793 M total memory
                                         2607 M used memory
                                         2665 M active memory
                                           85 M inactive memory
                                          861 M free memory
                                            3 M buffer memory
                                          320 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                *** FILESYSTEM ***
                                /dev/root      ext4      229G   18G  203G   8% /
                                devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                tmpfs          tmpfs     759M  880K  758M   1% /run
                                /dev/sda1      vfat      253M   51M  202M  20% /boot
                                tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                [Fri Apr  7 21:09:51 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:AC:7B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=7faabd4d-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Fri Apr  7 21:09:53 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Fri Apr  7 21:09:53 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                [Fri Apr  7 21:09:55 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                Show mounted filesystems (real ones only):
                                TARGET  SOURCE    FSTYPE OPTIONS
                                /       /dev/sda2 ext4   rw,noatime
                                `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                /var:
                                8.4G    /var/
                                7.9G    /var/log
                                3.0G    /var/log/journal/bd463378997f44f088b185e90db76a13
                                406M    /var/lib
                                /opt/iobroker/backups:
                                2.3G    /opt/iobroker/backups/
                                /opt/iobroker/iobroker-data:
                                715M    /opt/iobroker/iobroker-data/
                                528M    /opt/iobroker/iobroker-data/files
                                131M    /opt/iobroker/iobroker-data/backup-objects
                                111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup
                                111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup/sql.sql
                                37M     /opt/iobroker/iobroker-data/objects.jsonl
                                33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                                22M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.b7f9d93f.js.map
                                22M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.fd5c95e4.js.map
                                *** NodeJS-Installation ***
                                /usr/bin/npm            9.5.0
                                /usr/bin/npx            9.5.0
                                nodejs:
                                  Installed: 18.15.0-deb-1nodesource1
                                  Candidate: 18.15.0-deb-1nodesource1
                                  Version table:
                                 *** 18.15.0-deb-1nodesource1 500
                                        500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                                        100 /var/lib/dpkg/status
                                     12.22.12~dfsg-1~deb11u3 500
                                        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                                No problems detected
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Core adapters versions
                                js-controller:  4.0.24
                                admin:          6.3.7
                                javascript:     6.1.4
                                Adapters from github:   10
                                Adapter State
                                + system.adapter.accuweather.0            : accuweather           : pi                                       -  enabled
                                + system.adapter.adb.0                    : adb                   : pi                                       -  enabled
                                + system.adapter.alexa2.0                 : alexa2                : pi                                       -  enabled
                                  system.adapter.alias-manager.0          : alias-manager         : pi                                       - disabled
                                + system.adapter.backitup.0               : backitup              : pi                                       -  enabled
                                  system.adapter.birthdays.0              : birthdays             : pi                                       -  enabled
                                + system.adapter.bosesoundtouch.0         : bosesoundtouch        : pi                                       -  enabled
                                + system.adapter.cloud.0                  : cloud                 : pi                                       -  enabled
                                  system.adapter.daswetter.0              : daswetter             : pi                                       -  enabled
                                  system.adapter.daswetter.1              : daswetter             : pi                                       -  enabled
                                  system.adapter.device-reminder.0        : device-reminder       : pi                                       - disabled
                                + system.adapter.device-watcher.0         : device-watcher        : pi                                       -  enabled
                                  system.adapter.devices.0                : devices               : pi                                       - disabled
                                  system.adapter.discovery.0              : discovery             : pi                                       - disabled
                                + system.adapter.echarts.0                : echarts               : pi                                       -  enabled
                                + system.adapter.email.0                  : email                 : pi                                       -  enabled
                                  system.adapter.feiertage.0              : feiertage             : pi                                       -  enabled
                                  system.adapter.flot.0                   : flot                  : pi                                       -  enabled
                                  system.adapter.fullybrowser.0           : fullybrowser          : pi                                       - disabled
                                + system.adapter.google-sharedlocations.0 : google-sharedlocations: pi                                       -  enabled
                                + system.adapter.hm-rega.0                : hm-rega               : pi                                       -  enabled
                                + system.adapter.hm-rpc.0                 : hm-rpc                : pi                                       -  enabled, port: 0
                                + system.adapter.hm-rpc.1                 : hm-rpc                : pi                                       -  enabled, port: 0
                                + system.adapter.hmip.0                   : hmip                  : pi                                       -  enabled
                                  system.adapter.ical.0                   : ical                  : pi                                       -  enabled
                                  system.adapter.ical.1                   : ical                  : pi                                       -  enabled
                                  system.adapter.iceroad.0                : iceroad               : pi                                       -  enabled
                                + system.adapter.imap.0                   : imap                  : pi                                       -  enabled
                                + system.adapter.info.0                   : info                  : pi                                       -  enabled
                                + system.adapter.iot.0                    : iot                   : pi                                       -  enabled
                                + system.adapter.javascript.0             : javascript            : pi                                       -  enabled
                                + system.adapter.linux-control.0          : linux-control         : pi                                       -  enabled
                                + system.adapter.logparser.0              : logparser             : pi                                       -  enabled
                                + system.adapter.lovelace.0               : lovelace              : pi                                       -  enabled, port: 8091, bind: 0.0.0.0 (SSL), run as: admin
                                + system.adapter.lovelace.1               : lovelace              : pi                                       -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
                                + system.adapter.mqtt.0                   : mqtt                  : pi                                       -  enabled, port: 1884, bind: 0.0.0.0
                                  system.adapter.nctalk.0                 : nctalk                : pi                                       - disabled, port: 443
                                  system.adapter.net-tools.0              : net-tools             : pi                                       - disabled
                                + system.adapter.nina.0                   : nina                  : pi                                       -  enabled
                                + system.adapter.nut.0                    : nut                   : pi                                       -  enabled
                                + system.adapter.parcel.0                 : parcel                : pi                                       -  enabled
                                + system.adapter.parcel.1                 : parcel                : pi                                       -  enabled
                                  system.adapter.parser.0                 : parser                : pi                                       - disabled
                                + system.adapter.ping.0                   : ping                  : pi                                       -  enabled
                                + system.adapter.places.0                 : places                : pi                                       -  enabled
                                  system.adapter.proxy.0                  : proxy                 : pi                                       -  enabled
                                + system.adapter.pushover.0               : pushover              : pi                                       -  enabled
                                + system.adapter.rest-api.0               : rest-api              : pi                                       -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                                + system.adapter.roborock.0               : roborock              : pi                                       -  enabled
                                + system.adapter.rpi2.0                   : rpi2                  : pi                                       -  enabled
                                + system.adapter.sayit.0                  : sayit                 : pi                                       -  enabled, port: 0
                                + system.adapter.shelly.0                 : shelly                : pi                                       -  enabled, port: 1888, bind: 192.168.99.33
                                + system.adapter.simple-api.0             : simple-api            : pi                                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                + system.adapter.sonoff.0                 : sonoff                : pi                                       -  enabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.sony-bravia.0            : sony-bravia           : pi                                       -  enabled
                                + system.adapter.sourceanalytix.0         : sourceanalytix        : pi                                       -  enabled
                                + system.adapter.sql.0                    : sql                   : pi                                       -  enabled, port: 0
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : pi                                       -  enabled
                                + system.adapter.telegram.0               : telegram              : pi                                       -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.telegram.1               : telegram              : pi                                       -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.tr-064.0                 : tr-064                : pi                                       -  enabled
                                + system.adapter.trashschedule.0          : trashschedule         : pi                                       -  enabled
                                  system.adapter.tvspielfilm.0            : tvspielfilm           : pi                                       -  enabled
                                + system.adapter.upnp.0                   : upnp                  : pi                                       -  enabled
                                  system.adapter.vis.0                    : vis                   : pi                                       -  enabled
                                + system.adapter.vw-connect.0             : vw-connect            : pi                                       -  enabled
                                  system.adapter.windows-control.0        : windows-control       : pi                                       - disabled
                                + system.adapter.wireguard.0              : wireguard             : pi                                       -  enabled
                                + system.adapter.zigbee.0                 : zigbee                : pi                                       -  enabled, port: /dev/ttyUSB0
                                + instance is alive
                                ioBroker-Repositories
                                Stable (default): http://download.iobroker.net/sources-dist.json
                                Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                Installed ioBroker-Instances
                                Used repository: Stable (default)
                                Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
                                Adapter    "adb"          : 0.0.7    , installed 0.0.7
                                Adapter    "admin"        : 6.3.5    , installed 6.3.7
                                Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                                Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                                Adapter    "backitup"     : 2.6.16   , installed 2.6.16
                                Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
                                Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
                                Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                                Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                                Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                                Adapter    "device-watcher": 2.6.1   , installed 2.6.1
                                Adapter    "devices"      : 1.1.2    , installed 1.1.2
                                Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                Adapter    "echarts"      : 1.0.12   , installed 1.4.13
                                Adapter    "email"        : 1.1.4    , installed 1.1.4
                                Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                                Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
                                Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
                                Adapter    "hmip"         : 1.20.0   , installed 1.20.0
                                Adapter    "ical"         : 1.13.2   , installed 1.13.2
                                Adapter    "iceroad"      : 1.2.0    , installed 1.2.0
                                Adapter    "info"         : 1.9.19   , installed 1.9.19
                                Adapter    "iot"          : 1.14.2   , installed 1.14.2
                                Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                                Controller "js-controller": 4.0.24   , installed 4.0.24
                                Adapter    "linux-control": 1.1.3    , installed 1.1.5
                                Adapter    "logparser"    : 2.1.1    , installed 2.1.1
                                Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                                Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                Adapter    "operating-hours": 0.0.19 , installed 0.0.19
                                Adapter    "parcel"       : 0.0.25   , installed 0.0.25
                                Adapter    "parser"       : 1.1.8    , installed 1.1.8
                                Adapter    "ping"         : 1.5.3    , installed 1.5.3
                                Adapter    "places"       : 1.1.2    , installed 1.1.2
                                Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                                Adapter    "puppeteer"    : 0.2.7    , installed 0.2.7
                                Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                                Adapter    "rest-api"     : 1.0.4    , installed 1.0.4
                                Adapter    "sayit"        : 1.12.3   , installed 1.12.6
                                Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                                Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                                Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
                                Adapter    "sql"          : 2.2.0    , installed 2.2.0
                                Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                                Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
                                Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                                Adapter    "vw-connect"   : 0.0.62   , installed 0.0.62
                                Adapter    "windows-control": 0.1.5  , installed 0.1.5
                                Adapter    "wireguard"    : 1.3.1    , installed 1.4.1
                                Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                                Objects and States
                                Objects:        26530
                                States:         24360
                                Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                                Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                                Reading package lists...
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17709      1244/io.sonoff.0
                                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       20589      1395/io.mqtt.0
                                tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1001       17072      1085/io.hm-rpc.0
                                tcp        0      0 192.168.99.33:3493      0.0.0.0:*               LISTEN      0          14167      983/upsd
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15793      538/iobroker.js-con
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12884      538/iobroker.js-con
                                tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       20670      1536/adb
                                tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1001       18827      1201/io.shelly.0
                                tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          14168      983/upsd
                                tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1001       17099      1092/io.hm-rpc.1
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15680      567/sshd: /usr/sbin
                                tcp6       0      0 :::8000                 :::*                    LISTEN      1001       33520      2391/io.upnp.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16110      839/io.admin.0
                                tcp6       0      0 :::8083                 :::*                    LISTEN      1001       27071      2271/io.web.1
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28873      2239/io.web.0
                                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       22160      2065/io.simple-api.
                                tcp6       0      0 :::8091                 :::*                    LISTEN      1001       23882      1710/io.lovelace.0
                                tcp6       0      0 :::8093                 :::*                    LISTEN      1001       22177      1998/io.rest-api.0
                                tcp6       0      0 :::8092                 :::*                    LISTEN      1001       21989      1737/io.lovelace.1
                                tcp6       0      0 :::1984                 :::*                    LISTEN      1001       33013      3092/go2rtc_linux_a
                                tcp6       0      0 :::7777                 :::*                    LISTEN      1001       13231      911/io.admin.2
                                tcp6       0      0 :::3306                 :::*                    LISTEN      109        11930      632/mariadbd
                                tcp6       0      0 :::777                  :::*                    LISTEN      1001       14182      851/io.admin.1
                                tcp6       0      0 :::8555                 :::*                    LISTEN      1001       33018      3092/go2rtc_linux_a
                                tcp6       0      0 :::8554                 :::*                    LISTEN      1001       33016      3092/go2rtc_linux_a
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          15682      567/sshd: /usr/sbin
                                udp        0      0 0.0.0.0:35270           0.0.0.0:*                           1001       28902      2391/io.upnp.0
                                udp        0      0 0.0.0.0:39367           0.0.0.0:*                           108        13590      400/avahi-daemon: r
                                udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          12955      -
                                udp        0      0 10.137.192.1:5353       0.0.0.0:*                           1001       20545      1314/io.tr-064.0
                                udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1001       20544      1314/io.tr-064.0
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13588      400/avahi-daemon: r
                                udp        0      0 0.0.0.0:50934           0.0.0.0:*                           1001       28903      2391/io.upnp.0
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       28147      2391/io.upnp.0
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       28146      2391/io.upnp.0
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15788      802/dhcpcd
                                udp6       0      0 :::8443                 :::*                                1001       33017      3092/go2rtc_linux_a
                                udp6       0      0 :::51820                :::*                                0          12956      -
                                udp6       0      0 :::5353                 :::*                                108        13589      400/avahi-daemon: r
                                udp6       0      0 :::56911                :::*                                108        13591      400/avahi-daemon: r
                                2023-04-07 21:17:58.539  - info: sourceanalytix.0 (2073) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Sonstige.Sonstige_h successfully
                                2023-04-07 21:17:58.540  - info: sourceanalytix.0 (2073) Initialising (9 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.TOGGO.Toggo_h"
                                2023-04-07 21:17:58.721  - info: javascript.0 (961) script.js.Eigene_Scripte.Multimedia.Tv.Fernbedienung: Ghostbusters
                                2023-04-07 21:17:58.723  - info: javascript.0 (961) script.js.Eigene_Scripte.Multimedia.Tv.Fernbedienung: Fri Apr 07 2023 20:15:00 GMT+0200 (Central European Summer Time)
                                2023-04-07 21:17:58.723  - info: javascript.0 (961) script.js.Eigene_Scripte.Multimedia.Tv.Fernbedienung: Fri Apr 07 2023 22:30:00 GMT+0200 (Central European Summer Time)
                                2023-04-07 21:17:58.724  - info: javascript.0 (961) script.js.Eigene_Scripte.Multimedia.Tv.Fernbedienung: Vox
                                2023-04-07 21:17:58.813  - error: telegram.0 (1023) Cannot send message [chatId - 353434894]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                                2023-04-07 21:18:06.351  - info: linux-control.0 (1685) getting data from CP_Trift (192.168.22.207:22)
                                2023-04-07 21:18:09.451  - info: linux-control.0 (1685) [getConnection] Host 'CP_Trift' (192.168.22.207:22) seems not to be online
                                2023-04-07 21:18:10.395  - info: sourceanalytix.0 (2073) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.TOGGO.Toggo_h successfully
                                2023-04-07 21:18:10.396  - info: sourceanalytix.0 (2073) Initialising (10 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.TV.TV_h"
                                2023-04-07 21:18:11.895  - error: cloud.0 (1479) Cannot activate admin.0 for cloud, because authentication is enabled. Please create extra instance for cloud
                                2023-04-07 21:18:11.939  - error: cloud.0 (1479) Cannot activate lovelace.0 for cloud, because HTTPs is enabled. Please create extra instance for cloud
                                2023-04-07 21:18:11.942  - info: cloud.0 (1479) Trying to connect as system.user.admin to cloud
                                2023-04-07 21:18:11.995  - info: cloud.0 (1479) Connection changed: connect
                                2023-04-07 21:18:22.540  - info: sourceanalytix.0 (2073) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.TV.TV_h successfully
                                2023-04-07 21:18:22.541  - info: sourceanalytix.0 (2073) InitialisiCopy text starting h
                                • David G.
                                  David G. @Thomas Braun last edited by David G.
                                  @simatec
                                  Das planmäßige Backup heute ist wieder mit den selben Meldungen abgebrochen.
                                  Am 20ten Mrz hat er zum letzten Mal erfolgreich das ioborker Backup hochgeladen.
                                  In der json oder per Telegramm wurde mir nicht vom Fehler berichtet. Das macht er erst seit dem Update gestern.
                                  Wüsste nicht, dass ich zwischenzeitlich was am System gemacht habe was das Fehlerbild begünstigt.
                                  EDIT
                                  Unter opt/ioborker/backups liegt auch kein ioborker Backup. Nur JavaScript, zigbee, SQL und ccu.
                                  EDIT 2
                                  Habe auch grad gesehen, dass ich Backups mit 2 verschiedenen Namensgebung habe.
                                  Ist das der Unterschied zwischen Console und gui oder ein Fehler?
                                  iobroker_2023_04_07-21_29_25_backupiobroker.tar.gz
                                  2023_04_07-21_08_10_backupiobroker.tar.gz
                                    Thomas Braun Most Active @David G. last edited by Thomas Braun
                                    @david-g
                                    Legst du die alle nur lokal ab oder ist das z. B. ein gemountetes NAS?
                                    Was sagt ein
                                    vcgencmd mem_oom
                                    • David G.
                                      pi@pi:~ $ vcgencmd mem_oom
                                      oom events: 0
                                      pi@pi:~ $
                                      Hast du meinen Edit mit den Dateinamen im Beitrag vor diesem gesehen?
                                      Das sind meine Settings
                                      Screenshot_20230408_113655_Chrome.jpg Screenshot_20230408_113701_Chrome.jpg Screenshot_20230408_113639_Chrome.jpg
                                      Glaube der Ordner ist so groß, da bei ftp die Backups dort liegen bleiben.
                                        FTP ist ja auch nur eine Krücke. Ich würde das nach Möglichkeit auf was 'smarteres' wie NFS oder CIFS/SMB umstellen.
                                        • simatec
                                          CLI vergibt automatisch den Namen
                                          • David G.
                                            @thomas-braun sagte in Test Adapter ioBroker.backitup v2.6.x:
                                            Auf den Speicher komme ich leider nur so.....
                                            Okay, dann liegt da kein Problem.
                                            Komische Sache.....
                                            Bei vielen Dingen bin ich ja entspannt, aber kein Backup ist schon hart....
                                            170
                                            2780
                                            2379831
