    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    • Vandura
      Vandura @haselchen last edited by Vandura
      @haselchen
      pi@raspberrypi:~ $ sudo apt install libpixman-1-dev libpango1.0-dev libjpeg62-turbo-dev libgif-dev
      Reading package lists... Done
      Building dependency tree... Done
      libgif-dev is already the newest version (5.1.9-2).
      libjpeg62-turbo-dev is already the newest version (1:2.0.6-4).
      libpango1.0-dev is already the newest version (1.46.2-3).
      libpixman-1-dev is already the newest version (0.40.0-1.1~deb11u1+rpt1).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ npm rebuild canvas
      rebuilt dependencies successfully
      pi@raspberrypi:/opt/iobroker $ npm install canvas
      changed 1 package in 3m
      156 packages are looking for funding
        run `npm fund` for details
      up to date in 14s
      pi@raspberrypi:/opt/iobroker $ npm fund
      iobroker.inst@2.0.3
      ├── https://github.com/sponsors/sindresorhus
      │   └── make-dir@3.1.0, mimic-response@2.1.0, ora@4.0.5, cli-spinners@2.7.0, onetime@5.1.2, defaults@1.0.4, boxen@4.2.0, term-size@2.2.0, is-installed-globally@0.3.2, get-stream@5.2.0, macos-release@2.5.0, windows-release@3.3.3, is-plain-obj@3.0.0, get-stream@6.0.1, open@8.4.0, is-docker@2.1.1, p-map@4.0.0, decompress-response@6.0.0, mimic-response@3.1.0, normalize-url@6.1.0, quick-lru@5.1.1, sort-keys@4.2.0, p-limit@2.3.0, p-queue@6.6.2, any-observable@0.5.1, del@6.0.0, globby@11.0.1, escape-goat@3.0.0, escape-string-regexp@4.0.0, meow@8.0.0, camelcase-keys@6.2.2, type-fest@0.18.1, npm-name@6.0.1, p-event@4.2.0, type-fest@0.10.0, is-url-superb@4.0.0, open@7.3.0, ow@0.18.0, type-fest@0.17.0, read-pkg-up@7.0.1, terminal-link@2.1.1, is-npm@5.0.0, parse-json@5.1.0, ansi-escapes@4.3.1, type-fest@0.11.0, figures@3.2.0, find-up@5.0.0, locate-path@6.0.0, p-locate@5.0.0, p-limit@3.1.0, yocto-queue@0.1.0
      ├── https://github.com/sponsors/isaacs
      │   └── rimraf@3.0.2, glob@7.1.6
      ├── https://github.com/sponsors/feross
      │   └── simple-concat@1.0.1, safe-buffer@5.2.1, buffer@6.0.3, ieee754@1.2.1, run-parallel@1.1.10
      ├── https://github.com/yeoman/update-notifier?sponsor=1
      │   └── update-notifier@4.0.0, update-notifier@5.0.1
      ├── https://github.com/sponsors/epoberezkin
      │   └── ajv@6.12.4
      ├── https://github.com/sponsors/jaredhanson
      │   └── passport@0.5.2
      ├── https://github.com/sponsors/RubenVerborgh
      │   └── follow-redirects@1.15.2
      ├── https://github.com/sponsors/ljharb
      │   └── qs@6.10.3, deep-equal@2.2.0, es-get-iterator@1.1.3, is-map@2.0.2, is-set@2.0.2, is-string@1.0.7, has-tostringtag@1.0.0, is-arguments@1.1.1, is-array-buffer@3.0.2, is-typed-array@1.1.10, available-typed-arrays@1.0.5, gopd@1.0.1, is-callable@1.2.4, is-date-object@1.0.5, is-regex@1.1.4, is-shared-array-buffer@1.0.2, object-is@1.1.5, define-properties@1.2.0, has-property-descriptors@1.0.0, object.assign@4.1.4, regexp.prototype.flags@1.4.3, functions-have-names@1.2.3, which-boxed-primitive@1.0.2, is-bigint@1.0.4, has-bigints@1.0.2, is-boolean-object@1.1.2, is-number-object@1.0.7, is-symbol@1.0.4, which-collection@1.0.1, is-weakmap@2.0.1, is-weakset@2.0.2, which-typed-array@1.1.9, is-nan@1.3.2, es-aggregate-error@1.0.9, es-abstract@1.20.5, es-to-primitive@1.2.1, function.prototype.name@1.1.5, es-abstract@1.20.1, string.prototype.trimend@1.0.5, string.prototype.trimstart@1.0.5, get-symbol-description@1.0.0, is-callable@1.2.7, is-negative-zero@2.0.2, is-weakref@1.0.2, object-inspect@1.12.2, safe-regex-test@1.0.0, string.prototype.trimend@1.0.6, string.prototype.trimstart@1.0.6, unbox-primitive@1.0.2, globalthis@1.0.3, resolve@1.17.0
      ├── https://github.com/sponsors/jonschlinkert
      │   └── picomatch@2.3.1, picomatch@2.2.2, set-value@4.1.0
      ├── https://paypal.me/naturalintelligence
      │   └── fast-xml-parser@3.21.1
      ├── https://opencollective.com/serialport/donate
      │   └── serialport@10.5.0, @serialport/bindings-cpp@10.8.0, @serialport/parser-byte-length@10.5.0, @serialport/parser-cctalk@10.5.0, @serialport/parser-delimiter@10.5.0, @serialport/parser-inter-byte-timeout@10.5.0, @serialport/parser-readline@10.5.0, @serialport/parser-ready@10.5.0, @serialport/parser-regex@10.5.0, @serialport/parser-slip-encoder@10.5.0, @serialport/parser-spacepacket@10.5.0, @serialport/stream@10.5.0
      ├── https://tidelift.com/funding/github/npm/loglevel
      │   └── loglevel@1.8.0
      ├── https://www.buymeacoffee.com/systeminfo
      │   └── systeminformation@5.11.15
      ├── https://opencollective.com/ioredis
      │   └── ioredis@4.28.5
      ├── https://github.com/sindresorhus/execa?sponsor=1
      │   └── execa@5.1.1, execa@4.1.0
      ├── https://paulmillr.com/funding/
      │   └── chokidar@3.5.3
      ├── https://github.com/chalk/wrap-ansi?sponsor=1
      │   └── wrap-ansi@7.0.0
      ├── https://github.com/sponsors/3846masa
      │   └── http-cookie-agent@5.0.2
      ├─┬ https://github.com/inikulin/parse5?sponsor=1
      │ │ └── parse5@7.1.2
      │ └── https://github.com/fb55/entities?sponsor=1
      │     └── entities@4.4.0
      ├─┬ https://github.com/sindresorhus/got?sponsor=1
      │ │ └── got@11.8.6, got@10.7.0
      │ └── https://github.com/sindresorhus/is?sponsor=1
      │     └── @sindresorhus/is@4.6.0, @sindresorhus/is@2.1.1
      └─┬ https://github.com/sindresorhus/np?sponsor=1
        │ └── np@7.0.0
        ├── https://github.com/chalk/chalk?sponsor=1
        │   └── chalk@4.1.0
        └─┬ https://github.com/sindresorhus/p-memoize?sponsor=1
          │ └── p-memoize@4.0.1
          └── https://github.com/sindresorhus/mem?sponsor=1
              └── mem@6.1.1
      alles gemacht.......Erfolg....0
      pi@raspberrypi:/opt/iobroker $ sudo ls canvas
      ls: cannot access 'canvas': No such file or directory
      pi@raspberrypi:/opt/iobroker $ npm ls canvas
      iobroker.inst@2.0.3 /opt/iobroker
      ├── canvas@2.11.2
      ├─┬ iobroker.mihome-vacuum@3.9.5
      │ └── canvas@2.11.2 deduped
      └─┬ iobroker.parcel@0.0.25
        └─┬ jsdom@20.0.3
      gleiches wie vorher
        Thomas Braun Most Active @Vandura last edited by
        @vandura
        cd /opt/iobroker
        npm uninstall canvas
        cd ~
        iob upgrade mihome-vacuum@3.9.5
          @vandura
          Und ich hoffe
          sudo ls canvas
          war nur ein Versehen. sudo wird im iobrober/nodejs-Umfeld eigentlich nie eingesetzt.
          Vandura 1 Reply Last reply Reply Quote 0
          • Vandura
            Vandura @Thomas Braun last edited by
            @thomas-braun sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
            @vandura
            Und ich hoffe
            sudo ls canvas
            jepp
            • Christian Wöhrle
              Christian Wöhrle last edited by
              Vielleicht kann mir hier auch jemand helfen.
              Ich habe einen roborock.vacuum.m1s, Verbindung ist aktiv und grün. 5003971e-5e04-4b74-8fbc-1ca7f24d979e-image.png
              Seit Februar reagiert der Sauger aber nicht mehr, es wird auch kein Log weggeschrieben.
              Bis dahin hatte ich hin und wieder Probleme aber mit Restart des Adapters liefs dann wieder.
              Mein Broker läuft auf einem Raspberry pi 4 mit
              Node.js: v16.19.0 und
              NPM: 8.19.3
              Lt. der Readme müsste der m1s ja nach wie vor voll unterstützt werden.
              • haselchen
                haselchen Most Active @Christian Wöhrle last edited by
                @christian-wöhrle
                Und wie sieht das Log beim Adapterstart aus ?
                Christian Wöhrle 1 Reply Last reply Reply Quote 0
                • Christian Wöhrle
                  Christian Wöhrle @haselchen last edited by Christian Wöhrle
                  @haselchen said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                  @christian-wöhrle
                  2023-04-07 23:01:41.796 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                  2023-04-07 23:01:41.796 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                  2023-04-07 23:01:41.797 - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
                  2023-04-07 23:01:48.245 - info: host.raspberrypi "system.adapter.mihome-vacuum.0" disabled
                  2023-04-07 23:01:52.053 - info: host.raspberrypi "system.adapter.mihome-vacuum.0" enabled
                  2023-04-07 23:01:52.555 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2400
                  2023-04-07 23:01:55.365 - info: mihome-vacuum.0 (2400) starting. Version 3.9.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.19.0, js-controller: 4.0.24
                  2023-04-07 23:01:55.503 - info: mihome-vacuum.0 (2400) IOT enabled, create state
                  2023-04-07 23:01:55.627 - info: mihome-vacuum.0 (2400) select standard vacuum protocol....
                  2023-04-07 23:01:56.219 - info: mihome-vacuum.0 (2400) settest next timer: not available
                  2023-04-07 23:01:56.443 - info: mihome-vacuum.0 (2400) change states from State control.fan_power
                  2023-04-07 23:01:56.531 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120053.roomFanPower
                  2023-04-07 23:01:56.532 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120054.roomFanPower
                  2023-04-07 23:01:56.533 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120055.roomFanPower
                  2023-04-07 23:01:56.533 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120417.roomFanPower
                  2023-04-07 23:01:56.534 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001392968.roomFanPower
                  2023-04-07 23:01:56.535 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001392970.roomFanPower
                  2023-04-07 23:01:56.536 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001398141.roomFanPower
                  2023-04-07 23:01:57.434 - info: mihome-vacuum.0 (2400) create state for carpet_mode
                  2023-04-07 23:01:59.336 - error: host.raspberrypi Caught by controller[0]: free(): invalid pointer
                  2023-04-07 23:01:59.336 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                  2023-04-07 23:01:59.336 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                  2023-04-07 23:01:59.336 - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
                  2023-04-07 23:02:29.560 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2849
                  2023-04-07 23:02:32.478 - info: mihome-vacuum.0 (2849) starting. Version 3.9.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.19.0, js-controller: 4.0.24
                  2023-04-07 23:02:32.661 - info: mihome-vacuum.0 (2849) IOT enabled, create state
                  2023-04-07 23:02:42.763 - error: mihome-vacuum.0 (2849) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
                  2023-04-07 23:02:42.764 - warn: mihome-vacuum.0 (2849) No Answer for DeviceModel use old one
                  2023-04-07 23:02:42.765 - warn: mihome-vacuum.0 (2849) No Answer for DeviceModel use model from Config
                  2023-04-07 23:02:42.829 - info: mihome-vacuum.0 (2849) select standard vacuum protocol....
                  2023-04-07 23:02:43.458 - info: mihome-vacuum.0 (2849) settest next timer: not available
                  2023-04-07 23:04:50.220 - info: mihome-vacuum.0 (2849) change states from State control.fan_power
                  2023-04-07 23:04:50.342 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120053.roomFanPower
                  2023-04-07 23:04:50.344 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120054.roomFanPower
                  2023-04-07 23:04:50.344 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120055.roomFanPower
                  2023-04-07 23:04:50.346 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120417.roomFanPower
                  2023-04-07 23:04:50.347 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001392968.roomFanPower
                  2023-04-07 23:04:50.348 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001392970.roomFanPower
                  2023-04-07 23:04:50.350 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001398141.roomFanPower
                  2023-04-07 23:04:51.326 - info: mihome-vacuum.0 (2849) create state for carpet_mode
                  haselchen D 2 Replies Last reply Reply Quote 0
                  • haselchen
                    @christian-wöhrle
                    Und jetzt noch die Adaptereinstellungen
                    • Christian Wöhrle
                      @haselchen
                      • haselchen
                        haselchen Most Active @Christian Wöhrle last edited by haselchen
                        @christian-wöhrle
                        Ich würde den Server mal auf Deutschland umstellen.
                        Und dann nochmal auf get Device im Adapter, eventuell bekommste einen neuen Token.
                        Ansonsten , wenn ich das so sehe, werden doch Datenpunkte angelegt?!
                        Und im Log steht, dass du 10min warten sollst, nach Adapterstart, bis es losgehen kann.
                        Aber ich würde trotzdem erstmal den Server auf Deutschland umstellen.
                        Vermutlich musste das in der App das zuerst machen.
                        Damrak2022 Christian Wöhrle 2 Replies Last reply Reply Quote 0
                        • Damrak2022
                          Damrak2022 last edited by
                          @wildbill Das gleiche Problem habe ich momentan auch mit meinem S7 Habe ihn via App in die Küche geschickt, allerdings sind im Datenpunkt goto keine Koordinaten zu finden:
                          Der Datenpunkt sieht so aus:
                            "_id": "mihome-vacuum.0.control.goTo",
                            "type": "state",
                            "common": {
                              "name": "Go to point",
                              "type": "string",
                              "read": true,
                              "write": true,
                              "desc": "let the vacuum go to a point on the map"
                            "native": {},
                            "from": "system.adapter.mihome-vacuum.0",
                            "user": "system.user.admin",
                            "ts": 1680642958482,
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                              "owner": "system.user.admin",
                          Oder wird das garnicht mehr unterstützt, was ich schade finden würde?
                          • Damrak2022
                            Damrak2022 @haselchen last edited by Damrak2022
                            @haselchen Guten Morgen,
                            ich habe nochmal eine Frage an Dich, da Du mir ja erklärt hast was ich bei der VIS für die Anzeige der Karte eingeben muss. Das Ganze lief bis heute gut. Eben habe ich den Sauger gestartet und jetzt ist wieder das Problem vorhanden, das sich der Staubsauger nicht in Echtzeit auf derKarte bewegt, sondern stur an seinem Ladeplatz angezeigt wird. Habe auch extra mal die Vis geöffnet und im Browser angezeigt - hilft aber nichts. Passiert das bei Dir auch und hast Du eine Idee, woran es liegen könnte?
                            Und wenn ich gerade dabei bin: Wofür ist denn der Datenpunkt: dustCollect und kann man den eventuell noch sinnvoll einbinden?
                            • Christian Wöhrle
                              Der Sauger ist über die Deutschland-Server nicht verfügbar. Habe trotzdem natürlich versucht umzustellen. Jetzt muss ich schauen dass ich ihn wieder in den Instanzen aktivieren kann 😉
                              Datenpunkte sind alle vorhanden.
                                dirkhe Developer @Christian Wöhrle last edited by
                                @christian-wöhrle mach nal bitte die karte aus, kb er dann immer noch abstürzt, dann könnte es auch am canvas liegen, das läuft nicht so gut bis gar nicht auf einem raspi, da canvas 32 bit nicht mehr unterstützt
                                • haselchen
                                  @christian-wöhrle
                                  Heisst das jetzt, dass es geht oder nicht?!
                                  Aus deinem Post kann man das nicht so herauslesen.
                                  • haselchen
                                    haselchen Most Active @Damrak2022 last edited by
                                    @damrak2022
                                    Diese "nicht bewegen Probleme" hab ich nicht.
                                    Sauger ist sauber eingebunden und ebenso in der VIS mit dem entsprechenden Widget und Datenpunkt.
                                    Ich hab das nicht mehr auf dem Schirm.
                                    Zeig mal bitte deine Datenpunkte (erstmal die Maps Datenpunkte) und den Ausschnitt aus der VIS wie du es eingebunden hast.
                                    • Damrak2022
                                      @haselchen So sehen die Datenpunkte aus:
                                      Map64
                                        "_id": "mihome-vacuum.0.cleanmap.map64",
                                        "type": "state",
                                        "common": {
                                          "name": "Map64",
                                          "type": "string",
                                          "role": "vacuum.map.base64",
                                          "read": true,
                                          "write": false,
                                          "desc": "Map in a decoded Base64 PNG"
                                        "native": {},
                                        "ts": 1680642959378,
                                        "acl": {
                                          "object": 1636,
                                          "state": 1636,
                                      So die VIS
                                      haselchen 2 Replies Last reply Reply Quote 0
                                      • Christian Wöhrle
                                        Christian Wöhrle @dirkhe last edited by
                                        @dirkhe said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                                        @christian-wöhrle
                                        Habe die Instanz mal komplett gelöscht, wieder installiert, Karte deaktiviert. Leider wird jetzt garnichts mehr gefunden.
                                        Damrak2022 haselchen 2 Replies Last reply Reply Quote 0
                                        • Damrak2022
                                          Damrak2022 @Christian Wöhrle last edited by Damrak2022
                                          @christian-wöhrle sorry falsch gepostet
                                          • haselchen
                                            @christian-wöhrle
                                            Gleiche Spiel von vorne .
                                            Bekommst du im Adapter einen Token , sprich , wird dein Gerät gefunden ?
                                            Was sagt das Debug Log beim Adapterstart.
                                            1198
                                            366029
