    4. Shellys ("Alt und Plus") über MQTT Adapter
    • mickym
      mickym Most Active @dos1973 last edited by
      @dos1973 Ja
        dos1973 @mickym last edited by dos1973
        @mickym
        0_userdata.0.Wohnung.Status.Shellys.node-red.Rolladen.control
        0_userdata.0.Wohnung.Status.Shellys.node-red.Rolladen.status
        der status ist nicht schreibbar
        kann den Rolladen aus kurz anschliessen...
        • mickym
          mickym Most Active @dos1973 last edited by mickym
          @dos1973 sagte in Shellys ("Alt und Plus") über MQTT Adapter:
        0_userdata.0.Wohnung.Status.Shellys.node-red.Rolladen.control        0_userdata.0.Wohnung.Status.Shellys.node-red.Rolladen.status
          So dann müsste dieser Flow funktionieren:
                 "id": "6d49413af6de6a69",
                 "type": "group",
                 "z": "2e7d4cac81c671e3",
                 "style": {
                     "stroke": "#999999",
                     "stroke-opacity": "1",
                     "fill": "none",
                     "fill-opacity": "1",
                     "label": true,
                     "label-position": "nw",
                     "color": "#a4a4a4"
                 "nodes": [
                     "2687ef51e182ae3e",
                     "8c2f0aa73a8f9642",
                     "4f4d7ebeab8af33c",
                     "582dd65ed0823483",
                     "c2e2efbc11b4b072",
                     "59af2f2b6ec08346",
                     "ce2e90a37a7ef5e7"
                 "x": 54,
                 "y": 2819,
                 "w": 1092,
                 "h": 222
                 "id": "2687ef51e182ae3e",
                 "type": "mqtt in",
                 "g": "6d49413af6de6a69",
                 "name": "",
                 "topic": "shellies/Rolladen/Wohnen/status/cover:0",
                 "qos": "2",
                 "datatype": "auto-detect",
                 "broker": "",
                 "nl": false,
                 "rap": true,
                 "rh": 0,
                 "inputs": 0,
                 "x": 240,
                 "y": 2900,
                 "wires": [
                         "8c2f0aa73a8f9642"
                 "id": "8c2f0aa73a8f9642",
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "payload.state",
                         "tot": "msg"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 530,
                 "y": 2900,
                 "wires": [
                         "4f4d7ebeab8af33c"
                 "id": "4f4d7ebeab8af33c",
                 "type": "ioBroker out",
                 "name": "",
                 "topic": "0_userdata.0.Wohnung.Status.Shellys.node-red.Rolladen.status",
                 "ack": "true",
                 "autoCreate": "true",
                 "stateName": "",
                 "role": "",
                 "payloadType": "boolean",
                 "readonly": "false",
                 "stateUnit": "",
                 "stateMin": "",
                 "stateMax": "",
                 "x": 890,
                 "y": 2900,
                 "wires": []
                 "id": "582dd65ed0823483",
                 "type": "comment",
                 "name": "Status",
                 "info": "",
                 "x": 130,
                 "y": 2860,
                 "wires": []
                 "id": "c2e2efbc11b4b072",
                 "type": "comment",
                 "name": "Schalten",
                 "info": "",
                 "x": 140,
                 "y": 2960,
                 "wires": []
                 "id": "59af2f2b6ec08346",
                 "type": "ioBroker in",
                 "name": "",
                 "topic": "0_userdata.0.Wohnung.Status.Shellys.node-red.Rolladen.control",
                 "payloadType": "value",
                 "onlyack": "command",
                 "func": "all",
                 "gap": "",
                 "fireOnStart": "false",
                 "outFormat": "MQTT",
                 "x": 310,
                 "y": 3000,
                 "wires": [
                         "ce2e90a37a7ef5e7"
                 "id": "ce2e90a37a7ef5e7",
                 "type": "mqtt out",
                 "name": "",
                 "topic": "shellies/Rolladen/Wohnen/command/cover:0",
                 "qos": "",
                 "retain": "",
                 "respTopic": "",
                 "contentType": "",
                 "userProps": "",
                 "correl": "",
                 "expiry": "",
                 "broker": "",
                 "x": 770,
                 "y": 3000,
                 "wires": []
          Die Kommandos siehst ja unten im Screenshot.
          D mickym 2 Replies Last reply Reply Quote 0
            @mickym
            status stimmt: steht opening /closing/stopped
            aber unter control passiert nichts, wenn ich da etwas engebe
            • mickym
              mickym Most Active @mickym last edited by mickym
              @mickym was gibst Du denn ein? 😉 😁 Hast Du auch die mqtt-Out richtig konfiguriert?
                @mickym
                opening /closing ...?
                ok: habs open /close /stop
                in der zwischenzeit habe ich den angeschlossen und calibriert.
                current_pos":19
                {"id":0, "source":"timeout", "state":"stopped","apower":0.0,"voltage":235.5,"current":0.000,"pf":0.00,"aenergy":{"total":4.544,"by_minute":[35.876,0.000,315.490],"minute_ts":1680905190},"temperature":{"tC":54.1, "tF":129.4},"pos_control":true,"current_pos":19}
                • mickym
                  @dos1973 NEIN - das darfst Du nicht eingeben - opening, closing sind Statusbeschreibungen, während das Rollo in Bewegung ist. Ich hab Dir doch die Kommandos gepostet
                  es müsste also auch pos,40 gehen
                    @mickym
                    Ja, oh mann bist du gut
                    ich könnt dich grad knutschen 🙂
                      dos1973 @dos1973 last edited by dos1973
                      @mickym
                      ich möchte mich herzlichst für deine Zeit und deine unerschütterliche Mühe und Geduld bedanken!!! läuft 1A
                      Ich habe 10 Stück im Schrank liegen und habe mich jetzt Wochenlang gescheut das in Angriff zu nehmen.
                      • mickym
                        @mickym
                        Na freut mich - für die aktuelle Position machst dann noch einen eigenen Datenpunkt - ich hab ihn mal pos genannt. Musst Du nicht anlegen
                               "id": "45f9fe0c07a645aa",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "payload.current_pos",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 550,
                               "y": 2960,
                               "wires": [
                                       "2dd3d3c5a66bbe2e"
                               "id": "2dd3d3c5a66bbe2e",
                               "name": "",
                               "topic": "0_userdata.0.Wohnung.Status.Shellys.node-red.Rolladen.pos",
                               "ack": "true",
                               "stateName": "",
                               "role": "",
                               "payloadType": "number",
                               "stateUnit": "",
                               "stateMin": "",
                               "stateMax": "",
                               "x": 900,
                               "y": 2960,
                               "wires": []
                        Als einfach hinter die mqtt-IN Node anschließen. Dann siehst immer den aktuellen Zustand als Zahl.
                          @mickym
                          wäre eine steuerung über Pos möglich - nur mit der Zahl?
                          • mickym
                            @dos1973 Ja - dann musst Du halt den control Datenpunkt immer eine Zahl reinschreiben, dann gehen wir immer davon aus, dass Du die position meinst und stellen das Kommando selbst zusammen.
                            Dann machst halt nur noch eine Zahl da rein und wir setzen über die abgebildete Change Node das Postitionskommando selbst zusammen.
                            Dann funktionieren halt die anderen Kommandos nicht. Oder Du machst noch einen eigenen Datenpunkt - indem Du nur Zahlen schreibst. Eigentlich sollte das ja nun fast alles selbst erklärend sein. 😉
                              @mickym
                              control soll bleiben
                              nur pos soll eben nur mit der zahl fahren:
                              • mickym
                                @dos1973 Achso Du meinst pos gleichzeitig zum Steuern und für den Status ja können wir machen.
                                Such Dir raus, was Du brauchst:
                                       "type": "group",
                                       "style": {
                                           "fill": "none",
                                           "label": true,
                                           "color": "#a4a4a4"
                                       "nodes": [
                                           "2687ef51e182ae3e",
                                           "8c2f0aa73a8f9642",
                                           "4f4d7ebeab8af33c",
                                           "582dd65ed0823483",
                                           "c2e2efbc11b4b072",
                                           "59af2f2b6ec08346",
                                           "ce2e90a37a7ef5e7",
                                           "45f9fe0c07a645aa",
                                           "2dd3d3c5a66bbe2e",
                                           "6047acf1eb80bc34",
                                           "885595c1b312e5de"
                                       "x": 54,
                                       "y": 2799,
                                       "w": 1112,
                                       "h": 362
                                       "type": "mqtt in",
                                       "d": true,
                                       "name": "",
                                       "qos": "2",
                                       "broker": "",
                                       "nl": false,
                                       "rap": true,
                                       "rh": 0,
                                       "inputs": 0,
                                       "x": 240,
                                       "y": 2880,
                                       "wires": [
                                               "8c2f0aa73a8f9642",
                                               "45f9fe0c07a645aa"
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "msg"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 530,
                                       "y": 2880,
                                       "wires": [
                                               "4f4d7ebeab8af33c"
                                       "name": "",
                                       "ack": "true",
                                       "stateName": "",
                                       "role": "",
                                       "payloadType": "string",
                                       "readonly": "true",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 890,
                                       "y": 2880,
                                       "wires": []
                                       "type": "comment",
                                       "name": "Status",
                                       "info": "",
                                       "x": 130,
                                       "y": 2840,
                                       "wires": []
                                       "type": "comment",
                                       "name": "Schalten",
                                       "info": "",
                                       "x": 140,
                                       "y": 3020,
                                       "wires": []
                                       "name": "",
                                       "func": "all",
                                       "gap": "",
                                       "x": 310,
                                       "y": 3060,
                                       "wires": [
                                               "ce2e90a37a7ef5e7"
                                       "type": "mqtt out",
                                       "d": true,
                                       "name": "",
                                       "qos": "",
                                       "retain": "",
                                       "respTopic": "",
                                       "contentType": "",
                                       "userProps": "",
                                       "correl": "",
                                       "expiry": "",
                                       "broker": "",
                                       "x": 970,
                                       "y": 3060,
                                       "wires": []
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "tot": "msg"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 550,
                                       "y": 2940,
                                       "wires": [
                                               "2dd3d3c5a66bbe2e"
                                       "name": "",
                                       "ack": "true",
                                       "stateName": "",
                                       "role": "",
                                       "readonly": "true",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 900,
                                       "y": 2940,
                                       "wires": []
                                       "id": "6047acf1eb80bc34",
                                       "name": "",
                                       "func": "all",
                                       "gap": "",
                                       "x": 300,
                                       "y": 3120,
                                       "wires": [
                                               "885595c1b312e5de"
                                       "id": "885595c1b312e5de",
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "\"pos,\" & payload",
                                               "tot": "jsonata"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 650,
                                       "y": 3120,
                                       "wires": [
                                               "ce2e90a37a7ef5e7"
                                  @mickym
                                  jetzt ist es PERFEKT!
                                  • mickym
                                    @mickym
                                    Na freut mich. 😉 - So ich hoffe auch Du hast alles verstanden, damit Du das nächste Mal Dich selbst dran wagst. 😉
                                      @mickym
                                      nachbauen schaffe ich wahrscheinlich,
                                      verstanden... so lala, da bin ich ehrlich.
                                      muss mir das morgen nochmals ansehen.
                                      • mickym
                                        @dos1973 Sind doch nur ganz wenige Nodes. 😉 - Und wie gesagt mir ist lieber Du fragst lieber öfter bevor Du dann rumprobierst und die armen Geräte auf dem Schrott landen. 🙂 - Dann schlaf mal gut - und träume wie sich Deine Rollläden dann in Zukunft wie von Geisterhand öffnen und schließen. Ich geh mal davon aus, dass Du diese Flows irgendwann auch noch intelligent machen möchtest. 😉
                                          @mickym sagte in Shellys ("Alt und Plus") über MQTT Adapter:
                                          Du klickst auf die 3 Punkte um den JSONATA Editor zu öffnen:
                                          @mickym
                                          wo finde ich dass denn im meinem Flow?
                                          • mickym
                                            @dos1973 Wenn Du bei Deinen Schaltern auf die Change Node klickst, bevor in die mqtt-out Node geschrieben wird, dann sind in der JSONATA Zeile (also das mit dem GROSSEN J) - 3 Punkte und darauf klicken. Die payload ist die Nachrichteneigenschaft aus der eingehenden Nachricht.
                                            80355
