    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    • haselchen
      haselchen Most Active @Christian Wöhrle last edited by
      @christian-wöhrle
      Und wie sieht das Log beim Adapterstart aus ?
      Christian Wöhrle 1 Reply Last reply Reply Quote 0
      • Christian Wöhrle
        Christian Wöhrle @haselchen last edited by Christian Wöhrle
        @haselchen said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
        @christian-wöhrle
        2023-04-07 23:01:41.796 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
        2023-04-07 23:01:41.796 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
        2023-04-07 23:01:41.797 - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
        2023-04-07 23:01:48.245 - info: host.raspberrypi "system.adapter.mihome-vacuum.0" disabled
        2023-04-07 23:01:52.053 - info: host.raspberrypi "system.adapter.mihome-vacuum.0" enabled
        2023-04-07 23:01:52.555 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2400
        2023-04-07 23:01:55.365 - info: mihome-vacuum.0 (2400) starting. Version 3.9.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.19.0, js-controller: 4.0.24
        2023-04-07 23:01:55.503 - info: mihome-vacuum.0 (2400) IOT enabled, create state
        2023-04-07 23:01:55.627 - info: mihome-vacuum.0 (2400) select standard vacuum protocol....
        2023-04-07 23:01:56.219 - info: mihome-vacuum.0 (2400) settest next timer: not available
        2023-04-07 23:01:56.443 - info: mihome-vacuum.0 (2400) change states from State control.fan_power
        2023-04-07 23:01:56.531 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120053.roomFanPower
        2023-04-07 23:01:56.532 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120054.roomFanPower
        2023-04-07 23:01:56.533 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120055.roomFanPower
        2023-04-07 23:01:56.533 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001120417.roomFanPower
        2023-04-07 23:01:56.534 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001392968.roomFanPower
        2023-04-07 23:01:56.535 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001392970.roomFanPower
        2023-04-07 23:01:56.536 - info: mihome-vacuum.0 (2400) change states from State control.fan_power mihome-vacuum.0.rooms.355001398141.roomFanPower
        2023-04-07 23:01:57.434 - info: mihome-vacuum.0 (2400) create state for carpet_mode
        2023-04-07 23:01:59.336 - error: host.raspberrypi Caught by controller[0]: free(): invalid pointer
        2023-04-07 23:01:59.336 - warn: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
        2023-04-07 23:01:59.336 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
        2023-04-07 23:01:59.336 - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
        2023-04-07 23:02:29.560 - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 2849
        2023-04-07 23:02:32.478 - info: mihome-vacuum.0 (2849) starting. Version 3.9.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v16.19.0, js-controller: 4.0.24
        2023-04-07 23:02:32.661 - info: mihome-vacuum.0 (2849) IOT enabled, create state
        2023-04-07 23:02:42.763 - error: mihome-vacuum.0 (2849) YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
        2023-04-07 23:02:42.764 - warn: mihome-vacuum.0 (2849) No Answer for DeviceModel use old one
        2023-04-07 23:02:42.765 - warn: mihome-vacuum.0 (2849) No Answer for DeviceModel use model from Config
        2023-04-07 23:02:42.829 - info: mihome-vacuum.0 (2849) select standard vacuum protocol....
        2023-04-07 23:02:43.458 - info: mihome-vacuum.0 (2849) settest next timer: not available
        2023-04-07 23:04:50.220 - info: mihome-vacuum.0 (2849) change states from State control.fan_power
        2023-04-07 23:04:50.342 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120053.roomFanPower
        2023-04-07 23:04:50.344 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120054.roomFanPower
        2023-04-07 23:04:50.344 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120055.roomFanPower
        2023-04-07 23:04:50.346 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001120417.roomFanPower
        2023-04-07 23:04:50.347 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001392968.roomFanPower
        2023-04-07 23:04:50.348 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001392970.roomFanPower
        2023-04-07 23:04:50.350 - info: mihome-vacuum.0 (2849) change states from State control.fan_power mihome-vacuum.0.rooms.355001398141.roomFanPower
        2023-04-07 23:04:51.326 - info: mihome-vacuum.0 (2849) create state for carpet_mode
        haselchen D 2 Replies Last reply Reply Quote 0
        • haselchen
          @christian-wöhrle
          Und jetzt noch die Adaptereinstellungen
          • Christian Wöhrle
            @haselchen
            • haselchen
              haselchen Most Active @Christian Wöhrle last edited by haselchen
              @christian-wöhrle
              Ich würde den Server mal auf Deutschland umstellen.
              Und dann nochmal auf get Device im Adapter, eventuell bekommste einen neuen Token.
              Ansonsten , wenn ich das so sehe, werden doch Datenpunkte angelegt?!
              Und im Log steht, dass du 10min warten sollst, nach Adapterstart, bis es losgehen kann.
              Aber ich würde trotzdem erstmal den Server auf Deutschland umstellen.
              Vermutlich musste das in der App das zuerst machen.
              Damrak2022 Christian Wöhrle 2 Replies Last reply Reply Quote 0
              • Damrak2022
                Damrak2022 last edited by
                @wildbill Das gleiche Problem habe ich momentan auch mit meinem S7 Habe ihn via App in die Küche geschickt, allerdings sind im Datenpunkt goto keine Koordinaten zu finden:
                Der Datenpunkt sieht so aus:
                  "_id": "mihome-vacuum.0.control.goTo",
                  "type": "state",
                  "common": {
                    "name": "Go to point",
                    "type": "string",
                    "read": true,
                    "write": true,
                    "desc": "let the vacuum go to a point on the map"
                  "native": {},
                  "from": "system.adapter.mihome-vacuum.0",
                  "user": "system.user.admin",
                  "ts": 1680642958482,
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                    "owner": "system.user.admin",
                Oder wird das garnicht mehr unterstützt, was ich schade finden würde?
                • Damrak2022
                  Damrak2022 @haselchen last edited by Damrak2022
                  @haselchen Guten Morgen,
                  ich habe nochmal eine Frage an Dich, da Du mir ja erklärt hast was ich bei der VIS für die Anzeige der Karte eingeben muss. Das Ganze lief bis heute gut. Eben habe ich den Sauger gestartet und jetzt ist wieder das Problem vorhanden, das sich der Staubsauger nicht in Echtzeit auf derKarte bewegt, sondern stur an seinem Ladeplatz angezeigt wird. Habe auch extra mal die Vis geöffnet und im Browser angezeigt - hilft aber nichts. Passiert das bei Dir auch und hast Du eine Idee, woran es liegen könnte?
                  Und wenn ich gerade dabei bin: Wofür ist denn der Datenpunkt: dustCollect und kann man den eventuell noch sinnvoll einbinden?
                  • Christian Wöhrle
                    Der Sauger ist über die Deutschland-Server nicht verfügbar. Habe trotzdem natürlich versucht umzustellen. Jetzt muss ich schauen dass ich ihn wieder in den Instanzen aktivieren kann 😉
                    Datenpunkte sind alle vorhanden.
                      dirkhe Developer @Christian Wöhrle last edited by
                      @christian-wöhrle mach nal bitte die karte aus, kb er dann immer noch abstürzt, dann könnte es auch am canvas liegen, das läuft nicht so gut bis gar nicht auf einem raspi, da canvas 32 bit nicht mehr unterstützt
                      • haselchen
                        @christian-wöhrle
                        Heisst das jetzt, dass es geht oder nicht?!
                        Aus deinem Post kann man das nicht so herauslesen.
                        • haselchen
                          haselchen Most Active @Damrak2022 last edited by
                          @damrak2022
                          Diese "nicht bewegen Probleme" hab ich nicht.
                          Sauger ist sauber eingebunden und ebenso in der VIS mit dem entsprechenden Widget und Datenpunkt.
                          Ich hab das nicht mehr auf dem Schirm.
                          Zeig mal bitte deine Datenpunkte (erstmal die Maps Datenpunkte) und den Ausschnitt aus der VIS wie du es eingebunden hast.
                          • Damrak2022
                            @haselchen So sehen die Datenpunkte aus:
                            Map64
                              "_id": "mihome-vacuum.0.cleanmap.map64",
                              "type": "state",
                              "common": {
                                "name": "Map64",
                                "type": "string",
                                "role": "vacuum.map.base64",
                                "read": true,
                                "write": false,
                                "desc": "Map in a decoded Base64 PNG"
                              "native": {},
                              "ts": 1680642959378,
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                            So die VIS
                            haselchen 2 Replies Last reply Reply Quote 0
                            • Christian Wöhrle
                              Christian Wöhrle @dirkhe last edited by
                              @dirkhe said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                              @christian-wöhrle
                              Habe die Instanz mal komplett gelöscht, wieder installiert, Karte deaktiviert. Leider wird jetzt garnichts mehr gefunden.
                              Damrak2022 haselchen 2 Replies Last reply Reply Quote 0
                              • Damrak2022
                                Damrak2022 @Christian Wöhrle last edited by Damrak2022
                                @christian-wöhrle sorry falsch gepostet
                                • haselchen
                                  @christian-wöhrle
                                  Gleiche Spiel von vorne .
                                  Bekommst du im Adapter einen Token , sprich , wird dein Gerät gefunden ?
                                  Was sagt das Debug Log beim Adapterstart.
                                  • haselchen
                                    @damrak2022
                                    Gucke ich mir gleich an …..
                                    • Damrak2022
                                      @haselchen Okay, danke
                                      • D3ltoroxp
                                        D3ltoroxp last edited by
                                        Hallo zusammen, ich habe grad mal mein System wieder auf den neusten Stand gebracht. Nach Upgrade auf nodejs 18.x kommt nun folgendes.
                                        mihome-vacuum.0
                                        2023-04-09 10:46:14.741	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
                                        unter dem Link gibts nichts. Wie installiere ich denn dieses Canvas Package ? Und wurde das beim Upgrade nach Anleitung gelöscht ?
                                        Thomas Braun T 2 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @D3ltoroxp last edited by
                                          @d3ltoroxp
                                          Den Fixer mal ausgeführt?
                                          Um was für ein System geht es? 32bit? 64bit?
                                            tritor @D3ltoroxp last edited by
                                            hi,
                                            habe auch die waterbox Level error message in der Version 3.10.0
                                            	State value to set for "mihome-vacuum.0.control.water_box_level" has value "42" greater than max "30"
                                            Gerät: Roborock S5 Max
                                            Denke der Issue ist ja schon auf GitHub erfasst.
                                            1198
                                            366161
