    • David G.
      David G. @simatec last edited by David G.
      @simatec
      Ja, der fix ist gestern 2x durch.
      Dadurch ging es ja immer auch kurz.
      Auch mehrere Neustarts ob zu prüfen ob es mit zu tun hat.
      Hier nochmal ein aktuelles iob diag:
      Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
      Kernel:                 6.1.21-v8+                                 Installation:           Native                                     Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000                                       X-Server:               false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0                                          Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.15.0
                              /usr/bin/node           v18.15.0
                              /usr/bin/npm            9.5.0
                              /usr/bin/npx            9.5.0
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            3.8G        2.4G        912M        0.0K        519M        1.3G
      Swap:            99M         12M         87M
      Total:          3.9G        2.4G        999M
      Active iob-Instances:   52
      Active repo(s): Stable (default)
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.7
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.0                    : web                   : pi                                       -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.1                    : web                   : pi                                       -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      Objects:                26473
      States:                 24308
      Size of iob-Database:
      55M     /opt/iobroker/iobroker-data/objects.jsonl
      67M     /opt/iobroker/iobroker-data/states.jsonl
      Und komplett
      *** BASE SYSTEM ***                                                Model           : Raspberry Pi 4 Model B Rev 1.2
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian                                           Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       12:40:42 up 15:30,  2 users,  load average: 3.80, 3.15, 2.18
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Sat 2023-04-08 12:40:42 CEST
                 Universal time: Sat 2023-04-08 10:40:42 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        2.8G        716M        0.0K        266M        876M
      Swap:            99M         12M         87M
      Total:          3.9G        2.8G        804M
               3793 M total memory
               2809 M used memory
               2744 M active memory
                155 M inactive memory
                716 M free memory
                  9 M buffer memory
                256 M swap cache
                 99 M total swap
                 12 M used swap
                 87 M free swap
      *** FILESYSTEM ***
      /dev/root      ext4      229G   18G  202G   9% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  880K  758M   1% /run
      /dev/sda1      vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Fri Apr  7 21:09:51 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:AC:7B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=7faabd4d-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Apr  7 21:09:53 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Apr  7 21:09:53 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Fri Apr  7 21:09:55 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      8.5G    /var/
      7.9G    /var/log
      3.0G    /var/log/journal/bd463378997f44f088b185e90db76a13
      406M    /var/lib
      /opt/iobroker/backups:
      2.4G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      776M    /opt/iobroker/iobroker-data/
      528M    /opt/iobroker/iobroker-data/files
      132M    /opt/iobroker/iobroker-data/backup-objects
      111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup
      111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup/sql.sql
      64M     /opt/iobroker/iobroker-data/states.jsonl
      53M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      22M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.b7f9d93f.js.map
      *** NodeJS-Installation ***
      /usr/bin/npm            9.5.0
      /usr/bin/npx            9.5.0
      nodejs:
        Installed: 18.15.0-deb-1nodesource1
        Candidate: 18.15.0-deb-1nodesource1
        Version table:
       *** 18.15.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u3 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.7
      javascript:     6.1.4
      Adapters from github:   10
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : pi                                       -  enabled
      + system.adapter.adb.0                    : adb                   : pi                                       -  enabled
        system.adapter.alexa2.0                 : alexa2                : pi                                       - disabled
        system.adapter.alias-manager.0          : alias-manager         : pi                                       - disabled
      + system.adapter.backitup.0               : backitup              : pi                                       -  enabled
        system.adapter.birthdays.0              : birthdays             : pi                                       -  enabled
      + system.adapter.bosesoundtouch.0         : bosesoundtouch        : pi                                       -  enabled
      + system.adapter.cloud.0                  : cloud                 : pi                                       -  enabled
        system.adapter.daswetter.0              : daswetter             : pi                                       -  enabled
        system.adapter.daswetter.1              : daswetter             : pi                                       -  enabled
        system.adapter.device-reminder.0        : device-reminder       : pi                                       - disabled
      + system.adapter.device-watcher.0         : device-watcher        : pi                                       -  enabled
        system.adapter.devices.0                : devices               : pi                                       - disabled
        system.adapter.discovery.0              : discovery             : pi                                       - disabled
      + system.adapter.echarts.0                : echarts               : pi                                       -  enabled
      + system.adapter.email.0                  : email                 : pi                                       -  enabled
        system.adapter.feiertage.0              : feiertage             : pi                                       -  enabled
        system.adapter.flot.0                   : flot                  : pi                                       -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : pi                                       - disabled
      + system.adapter.google-sharedlocations.0 : google-sharedlocations: pi                                       -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : pi                                       -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : pi                                       -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : pi                                       -  enabled, port: 0
      + system.adapter.hmip.0                   : hmip                  : pi                                       -  enabled
        system.adapter.ical.0                   : ical                  : pi                                       -  enabled
        system.adapter.ical.1                   : ical                  : pi                                       -  enabled
        system.adapter.iceroad.0                : iceroad               : pi                                       -  enabled
      + system.adapter.imap.0                   : imap                  : pi                                       -  enabled
      + system.adapter.info.0                   : info                  : pi                                       -  enabled
      + system.adapter.iot.0                    : iot                   : pi                                       -  enabled
      + system.adapter.javascript.0             : javascript            : pi                                       -  enabled
      + system.adapter.linux-control.0          : linux-control         : pi                                       -  enabled
      + system.adapter.logparser.0              : logparser             : pi                                       -  enabled
      + system.adapter.lovelace.0               : lovelace              : pi                                       -  enabled, port: 8091, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.lovelace.1               : lovelace              : pi                                       -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
      + system.adapter.mqtt.0                   : mqtt                  : pi                                       -  enabled, port: 1884, bind: 0.0.0.0
        system.adapter.nctalk.0                 : nctalk                : pi                                       - disabled, port: 443
        system.adapter.net-tools.0              : net-tools             : pi                                       - disabled
      + system.adapter.nina.0                   : nina                  : pi                                       -  enabled
      + system.adapter.nut.0                    : nut                   : pi                                       -  enabled
      + system.adapter.parcel.0                 : parcel                : pi                                       -  enabled
      + system.adapter.parcel.1                 : parcel                : pi                                       -  enabled
        system.adapter.parser.0                 : parser                : pi                                       - disabled
      + system.adapter.ping.0                   : ping                  : pi                                       -  enabled
      + system.adapter.places.0                 : places                : pi                                       -  enabled
        system.adapter.proxy.0                  : proxy                 : pi                                       -  enabled
      + system.adapter.pushover.0               : pushover              : pi                                       -  enabled
      + system.adapter.rest-api.0               : rest-api              : pi                                       -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
      + system.adapter.roborock.0               : roborock              : pi                                       -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : pi                                       -  enabled
      + system.adapter.sayit.0                  : sayit                 : pi                                       -  enabled, port: 0
      + system.adapter.shelly.0                 : shelly                : pi                                       -  enabled, port: 1888, bind: 192.168.99.33
      + system.adapter.simple-api.0             : simple-api            : pi                                       -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : pi                                       -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sony-bravia.0            : sony-bravia           : pi                                       -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : pi                                       -  enabled
      + system.adapter.sql.0                    : sql                   : pi                                       -  enabled, port: 0
      + system.adapter.tankerkoenig.0           : tankerkoenig          : pi                                       -  enabled
      + system.adapter.telegram.0               : telegram              : pi                                       -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : pi                                       -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : pi                                       -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : pi                                       -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : pi                                       -  enabled
      + system.adapter.upnp.0                   : upnp                  : pi                                       -  enabled
        system.adapter.vis.0                    : vis                   : pi                                       -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : pi                                       -  enabled
        system.adapter.windows-control.0        : windows-control       : pi                                       - disabled
      + system.adapter.wireguard.0              : wireguard             : pi                                       -  enabled
      + system.adapter.zigbee.0                 : zigbee                : pi                                       -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
      Adapter    "adb"          : 0.0.7    , installed 0.0.7
      Adapter    "admin"        : 6.3.5    , installed 6.3.7
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.6.16   , installed 2.6.16
      Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
      Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
      Adapter    "cloud"        : 4.3.0    , installed 4.3.0
      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
      Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "device-watcher": 2.6.1   , installed 2.6.1
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "echarts"      : 1.0.12   , installed 1.4.13
      Adapter    "email"        : 1.1.4    , installed 1.1.4
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
      Adapter    "hmip"         : 1.20.0   , installed 1.20.0
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "iceroad"      : 1.2.0    , installed 1.2.0
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.14.2   , installed 1.14.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "linux-control": 1.1.3    , installed 1.1.5
      Adapter    "logparser"    : 2.1.1    , installed 2.1.1
      Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "operating-hours": 0.0.19 , installed 0.0.19
      Adapter    "parcel"       : 0.0.25   , installed 0.0.25
      Adapter    "parser"       : 1.1.8    , installed 1.1.8
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "places"       : 1.1.2    , installed 1.1.2
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "puppeteer"    : 0.2.7    , installed 0.2.7
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "rest-api"     : 1.0.4    , installed 1.0.4
      Adapter    "sayit"        : 1.12.3   , installed 1.12.6
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vw-connect"   : 0.0.62   , installed 0.0.62
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "wireguard"    : 1.3.1    , installed 1.4.1
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects:        26473
      States:         24308
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
      Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       2475127    32245/io.sonoff.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       2477175    32333/io.mqtt.0
      tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1001       2473036    31798/io.hm-rpc.0
      tcp        0      0 192.168.99.33:3493      0.0.0.0:*               LISTEN      0          14167      983/upsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2470210    31410/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2470203    31410/iobroker.js-c
      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       2476081    462/adb
      tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1001       2476128    32239/io.shelly.0
      tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          14168      983/upsd
      tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1001       2470901    31819/io.hm-rpc.1
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15680      567/sshd: /usr/sbin
      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       2483547    867/io.upnp.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2470368    31528/io.admin.0
      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       2479099    659/io.web.1
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2479409    650/io.web.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       2476485    477/io.simple-api.0
      tcp6       0      0 :::8091                 :::*                    LISTEN      1001       2476487    32596/io.lovelace.0
      tcp6       0      0 :::8093                 :::*                    LISTEN      1001       2480184    491/io.rest-api.0
      tcp6       0      0 :::8092                 :::*                    LISTEN      1001       2478080    32706/io.lovelace.1
      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       2484408    1283/go2rtc_linux_a
      tcp6       0      0 :::3306                 :::*                    LISTEN      109        11930      632/mariadbd
      tcp6       0      0 :::8555                 :::*                    LISTEN      1001       2484415    1283/go2rtc_linux_a
      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       2484412    1283/go2rtc_linux_a
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15682      567/sshd: /usr/sbin
      udp        0      0 0.0.0.0:33186           0.0.0.0:*                           1001       2479097    867/io.upnp.0
      udp        0      0 0.0.0.0:39367           0.0.0.0:*                           108        13590      400/avahi-daemon: r
      udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          12955      -
      udp        0      0 0.0.0.0:49986           0.0.0.0:*                           1001       2479098    867/io.upnp.0
      udp        0      0 10.137.192.1:5353       0.0.0.0:*                           1001       2473955    32259/io.tr-064.0
      udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1001       2473954    32259/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13588      400/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2480413    867/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2480412    867/io.upnp.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15788      802/dhcpcd
      udp6       0      0 :::8443                 :::*                                1001       2484413    1283/go2rtc_linux_a
      udp6       0      0 :::51820                :::*                                0          12956      -
      udp6       0      0 :::5353                 :::*                                108        13589      400/avahi-daemon: r
      udp6       0      0 :::56911                :::*                                108        13591      400/avahi-daemon: r
      2023-04-08 12:40:41.377  - info: hm-rega.0 (31775) deleted 0 variables
      2023-04-08 12:40:41.434  - info: hm-rega.0 (31775) update functions to enum.functions
      2023-04-08 12:40:45.213  - info: tankerkoenig.0 (524) Start first request
      2023-04-08 12:40:47.156  - info: info.0 (1149) Reading network data every 60 seconds.
      2023-04-08 12:40:48.307  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Amazon.Amazon_h successfully
      2023-04-08 12:40:48.308  - info: sourceanalytix.0 (513) Initialising (4 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Disney.Disney_h"
      2023-04-08 12:41:00.689  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Disney.Disney_h successfully
      2023-04-08 12:41:00.690  - info: sourceanalytix.0 (513) Initialising (5 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Gesamt.Gesamt_h"
      2023-04-08 12:41:08.804  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Gesamt.Gesamt_h successfully
      2023-04-08 12:41:08.805  - info: sourceanalytix.0 (513) Initialising (6 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Homescreen.Homescreen_h"
      2023-04-08 12:41:17.667  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Homescreen.Homescreen_h successfully
      2023-04-08 12:41:17.668  - info: sourceanalytix.0 (513) Initialising (7 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Netflix.Netflix_h"
      2023-04-08 12:41:26.616  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Netflix.Netflix_h successfully
      2023-04-08 12:41:26.617  - info: sourceanalytix.0 (513) Initialising (8 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Sonstige.Sonstige_h"
      2023-04-08 12:41:36.931  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.Sonstige.Sonstige_h successfully
      2023-04-08 12:41:36.932  - info: sourceanalytix.0 (513) Initialising (9 of 18) "0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.TOGGO.Toggo_h"
      2023-04-08 12:41:45.231  - info: sourceanalytix.0 (513) Initialization of 0_userdata.0.Multimedia.TV_Wohnzimmer.Verlauf_Apps.TOGGO.Toggo_h successfully
      2023-04-08 12:41:45.232  - info: sourceanalytix.0 (513) InitialisinCopy text starting here:
      • simatec
        @Thomas-Braun Kannst mal drüberschauen, ob dir etwas auffällt?
        • simatec
          simatec Developer Most Active @David G. last edited by
          @david-g Was kommt jetzt in der Ausgabe über CLI
          iob backup
          • simatec
            simatec Developer Most Active @maximal1981 last edited by
            @maximal1981 Bitte poste den Debuglog vom Backupprozess und zusätzlich auch noch die Ausgabe, wenn du ein Backup über die CLI erstellst
            iob backup
            maximal1981 1 Reply Last reply Reply Quote 0
              Thomas Braun Most Active @simatec last edited by
              @simatec
              Nein, ist fast mustergültig aufgesetzt.
              Ich vermute da 'irgendwas' mit den entfernten Dateisystemen. Wie ist der FTP-Server angebunden?
              • maximal1981
                maximal1981 @simatec last edited by
                @simatec said in Test Adapter ioBroker.backitup v2.6.x:
                iob backup
                lokal habe ich ein erstelltes Backup gefunden, google fehlt es, und im log war keine Fehlermeldung am 2023-04-05 zu finden.
                C:\iobroker>iob backup
                host.iobroker 19416 states saved
                host.iobroker 22426 objects saved
                Backup created: C:\iobroker\backups\2023_04_08-13_12_07_backupiobroker.tar.gz
                C:\iobroker>
                das manuell erstellte hat eine andere Formatierung im Dateinamen.
                Wo finde ich das debug, aktiviert habe ich es, oder muss ich jetzt auf den nächsten automatischen Lauf warten?
                • David G.
                  @simatec
                  Hatte beim ersten Ablauf von iob diag als er die states auflisten wollte den inmem 9009 Fehler. Vermutlich weil der ioborker noch nicht ganz hochgefahren war. Versuche das irgendwie zu reproduzieren wann es kommt. Beim zweiten Anlauf ist das diag dann durchgelaufen.
                  Jetzt ist das Backup über die gui und cli durchgelaufen.
                  Es scheint nach dem fixer oder einem reboot des iobroker immer eine Zeit zu klappen.
                  Poster nachher nochmal das cli eines fehlerhaften Backups. Stoße jetzt mal regelmäßig eins an.
                  • simatec
                    simatec Developer Most Active @maximal1981 last edited by simatec
                    @maximal1981 Die Instanz von Backitup auf Debug stellen.
                    Sollte dies bereits so sein, kannst du dir die Logs der letzten Tage im Tab "Protokolle" über den Button oben "Logs herunterladen" ansehen
                    • maximal1981
                      @simatec
                      manuell geht es, wie oben geschrieben.
                      Backitup
                      System sichern…
                      Backup Informationen
                      info
                      Letzte ioBroker Sicherung:
                      08. April 2023 um 13:34 Uhr
                      Nächste ioBroker Sicherung:
                      09. April 2023 um 02:40 Uhr
                      storage
                      aktive Speicher-Optionen
                      Google Drive
                      backup
                      aktive Backup-Optionen
                      Javascript
                      Systemsicherung
                      Wiederherstellen
                      Lokal
                      Sicherungsquelle
                      Alle Sicherungs Einstellungen können in der Adapterkonfiguration von Backitup geändert werden.
                      Backitup-Ausführung:
                      Started iobroker ...
                      [DEBUG] [iobroker] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups"}
                      [DEBUG] [iobroker] - host.iobroker 19416 states saved
                      [DEBUG] [iobroker] - host.iobroker 22426 objects saved
                      [DEBUG] [iobroker] - Backup created: C:\ioBroker\backups\iobroker_2023_04_08-13_33_34_backupiobroker.tar.gz
                      [DEBUG] [iobroker] - done
                      [DEBUG] [javascripts] - Created javascript_tmp directory: "C:/ioBroker/backups/tmpScripts"
                      [DEBUG] [javascripts] - found Script: Weihnachten
                      [DEBUG] [javascripts] - found Script: Sonos_Esszimmer
                      [DEBUG] [javascripts] - found Script: Halbkeller
                      [DEBUG] [javascripts] - found Script: Ansagen
                      [DEBUG] [javascripts] - found Script: Shelly_update
                      [DEBUG] [javascripts] - found Script: Strom
                      [DEBUG] [javascripts] - found Script: Sonos_Kinderzimmer
                      [DEBUG] [javascripts] - found Script: Fenster-Schlafzimmer
                      [DEBUG] [javascripts] - found Script: Spritpreis_mit_Logo
                      [DEBUG] [javascripts] - found Script: Spritpreisrechner
                      [DEBUG] [javascripts] - found Script: Test
                      [DEBUG] [javascripts] - found Script: Objekte_anlegen_Mäx
                      [DEBUG] [javascripts] - found Script: UWZ
                      [DEBUG] [javascripts] - found Script: adapter_infos
                      [DEBUG] [javascripts] - found Script: adapter_vis
                      [DEBUG] [javascripts] - found Script: adapter_widget
                      [DEBUG] [javascripts] - found Script: hm_meldungen
                      [DEBUG] [javascripts] - found Script: alexa_log_skript
                      [DEBUG] [javascripts] - found Script: receiver_aufnahmen
                      [DEBUG] [javascripts] - found Script: receiver_timer
                      [DEBUG] [javascripts] - found Script: sonoff_infos
                      [DEBUG] [javascripts] - found Script: objekte_erstellen
                      [DEBUG] [javascripts] - found Script: reboot_qnap-b
                      [DEBUG] [javascripts] - found Script: shutdown_esxp01
                      [DEBUG] [javascripts] - found Script: shutdown_esxp02
                      [DEBUG] [javascripts] - found Script: shutdown_qnap-archiv_v0_1
                      [DEBUG] [javascripts] - found Script: shutdown_synology_v0_1
                      [DEBUG] [javascripts] - found Script: alias_erzeugen
                      [DEBUG] [javascripts] - found Script: kodi_fanart
                      [DEBUG] [javascripts] - found Script: onlinezeit
                      [DEBUG] [javascripts] - found Script: regenradar
                      [DEBUG] [javascripts] - found Script: abfall_tage
                      [DEBUG] [javascripts] - found Script: staumeldung
                      [DEBUG] [javascripts] - found Script: test
                      [DEBUG] [javascripts] - found Script: wol_daniel
                      [DEBUG] [javascripts] - found Script: wol_esxp01
                      [DEBUG] [javascripts] - found Script: wol_esxp02
                      [DEBUG] [javascripts] - found Script: wol_qnap_archiv
                      [DEBUG] [javascripts] - found Script: wol_synology
                      [DEBUG] [javascripts] - found Script: wol_winnas
                      [DEBUG] [javascripts] - found Script: wol_xmg
                      [DEBUG] [javascripts] - found Script: Heizungsanforderung
                      [DEBUG] [javascripts] - found Script: wohnzimmer_v0_3
                      [DEBUG] [javascripts] - found Script: pv_ost_west
                      [DEBUG] [javascripts] - found Script: #no-need_temperaturen
                      [DEBUG] [javascripts] - found Script: bewegungsmelder
                      [DEBUG] [javascripts] - found Script: iobroker-pi_api_sync
                      [DEBUG] [javascripts] - found Script: DPs_kopieren
                      [DEBUG] [javascripts] - found Script: Sternzeichen
                      [DEBUG] [javascripts] - found Script: unifi_auto_alive
                      [DEBUG] [javascripts] - found Script: Beleuchtung
                      [DEBUG] [javascripts] - found Script: PC-Steckdose
                      [DEBUG] [javascripts] - found Script: 3D_Drucker
                      [DEBUG] [javascripts] - found Script: Geschirrspueler
                      [DEBUG] [javascripts] - found Script: Geraeteueberwachung
                      [DEBUG] [javascripts] - found Script: Fernseher
                      [DEBUG] [javascripts] - found Script: Lichtueberwachung
                      [DEBUG] [javascripts] - found Script: ankleide_v0_1
                      [DEBUG] [javascripts] - found Script: kueche_v0_1
                      [DEBUG] [javascripts] - found Script: schlafzimmer_v0_1
                      [DEBUG] [javascripts] - found Script: aussenbeleuchtung
                      [DEBUG] [javascripts] - found Script: kueche_v0_2
                      [DEBUG] [javascripts] - found Script: schlafzimmer_v0_3
                      [DEBUG] [javascripts] - found Script: weckzeit_jenny
                      [DEBUG] [javascripts] - found Script: weihnachten
                      [DEBUG] [javascripts] - found Script: #no-need_lueftung_rolladen_v0_2
                      [DEBUG] [javascripts] - found Script: #test_Wecker
                      [DEBUG] [javascripts] - found Script: aussentemperatur
                      [DEBUG] [javascripts] - found Script: kalender
                      [DEBUG] [javascripts] - found Script: kamera_auf_TV
                      [DEBUG] [javascripts] - found Script: tuerklingel
                      [DEBUG] [javascripts] - found Script: weckradio
                      [DEBUG] [javascripts] - found Script: buero_monitore_v0_1
                      [DEBUG] [javascripts] - found Script: trockner_v0_1
                      [DEBUG] [javascripts] - found Script: waschmaschine_v0_1
                      [DEBUG] [javascripts] - found Script: kodi_steckdose_v0_3
                      [DEBUG] [javascripts] - found Script: ps4_lueftung_v0_2
                      [DEBUG] [javascripts] - found Script: schlafzimmer_tv_v0_1
                      [DEBUG] [javascripts] - found Script: vu_receiver
                      [DEBUG] [javascripts] - found Script: backup_erstellen
                      [DEBUG] [javascripts] - found Script: fritzbox
                      [DEBUG] [javascripts] - found Script: ressourcen_berechnungen
                      [DEBUG] [javascripts] - found Script: iobroker_instanz
                      [DEBUG] [javascripts] - found Script: iobroker_pi_instanz
                      [DEBUG] [javascripts] - found Script: qnap_archiv
                      [DEBUG] [javascripts] - found Script: qnap_b
                      [DEBUG] [javascripts] - found Script: sonoff_bewaesserung
                      [DEBUG] [javascripts] - found Script: synology
                      [DEBUG] [javascripts] - found Script: unifi_ap_eg
                      [DEBUG] [javascripts] - found Script: unifi_ap_og
                      [DEBUG] [javascripts] - found Script: unifi_ap_pavillon
                      [DEBUG] [javascripts] - found Script: unifi_controller
                      [DEBUG] [javascripts] - found Script: unifi_switch_rack
                      [DEBUG] [javascripts] - found Script: unifi_switch_wohnzimmer
                      [DEBUG] [javascripts] - found Script: win10
                      [DEBUG] [javascripts] - found Script: winnas
                      [DEBUG] [javascripts] - found Script: wlan_failover
                      [DEBUG] [javascripts] - found Script: Kuddel_vis_var
                      [DEBUG] [javascripts] - found Script: WebSpeedy
                      [DEBUG] [javascripts] - found Script: indirektes_Licht
                      [DEBUG] [javascripts] - found Script: Nachlegen
                      [DEBUG] [javascripts] - found Script: Klima-Kinderzimmer
                      [DEBUG] [javascripts] - found Script: Klima-Schlafzimmer
                      [DEBUG] [javascripts] - found Script: Mini_Clubman
                      [DEBUG] [javascripts] - found Script: objekte_anlegen_v0_1
                      [DEBUG] [javascripts] - found Script: kodi_licht_v0_1
                      [DEBUG] [javascripts] - found Script: schriftleuchte_v0_2
                      [DEBUG] [javascripts] - found Script: weckzeit_daniel
                      [DEBUG] [javascripts] - found Script: kamera_ueberwachung
                      [DEBUG] [javascripts] - found Script: reboot_skript
                      [DEBUG] [javascripts] - found Script: system_ctr_vis
                      [DEBUG] [javascripts] - found Script: esx_nuc
                      [DEBUG] [javascripts] - found Script: PV
                      [DEBUG] [javascripts] - found Script: PV_new
                      [DEBUG] [javascripts] - found Script: #no-need_rolladen_beamer_v0_3
                      [DEBUG] [javascripts] - found Script: rolladen_verdunkelung_v0_1
                      [DEBUG] [javascripts] - found Script: briefkasten_tuerklingel_v0_1
                      [DEBUG] [javascripts] - found Script: echo_stati
                      [DEBUG] [javascripts] - found Script: ccu
                      [DEBUG] [javascripts] - found Script: motioneye
                      [DEBUG] [javascripts] - found Script: nut-server
                      [DEBUG] [javascripts] - found Script: omv
                      [DEBUG] [javascripts] - found Script: pihole
                      [DEBUG] [javascripts] - found Script: raspberry-matic
                      [DEBUG] [javascripts] - found Script: sophos
                      [DEBUG] [javascripts] - found Script: vu_wohnzimmer
                      [DEBUG] [javascripts] - found Script: Klima-Wohnzimmer
                      [DEBUG] [javascripts] - found Script: RGB
                      [DEBUG] [javascripts] - found Script: shutdown_WinNAS_v01
                      [DEBUG] [javascripts] - found Script: lichterkette_flur_v0_3
                      [DEBUG] [javascripts] - found Script: lichtkugeln_v0_2
                      [DEBUG] [javascripts] - found Script: usv_shutdown
                      [DEBUG] [javascripts] - found Script: hm_meldungen_neu
                      [DEBUG] [javascripts] - found Script: logs_vis_neu
                      [DEBUG] [javascripts] - found Script: sonoff_tabelle_6_spalten
                      [DEBUG] [javascripts] - found Script: sonoff_tabelle_8_spalten
                      [DEBUG] [javascripts] - found Script: bahn_verspaetungen
                      [DEBUG] [javascripts] - found Script: anwesenheit
                      [DEBUG] [javascripts] - found Script: remote_abfragen
                      [DEBUG] [javascripts] - found Script: Rolladen
                      [DEBUG] [javascripts] - found Script: harmony_schaltung_v0_4
                      [DEBUG] [javascripts] - found Script: vis_status
                      [DEBUG] [javascripts] - found Script: alexa_benachrichtigungen
                      [DEBUG] [javascripts] - found Script: #zeiten_v01
                      [DEBUG] [javascripts] - found Script: solarweb_abfrage
                      [DEBUG] [javascripts] - found Script: adapter_starten_stoppen
                      [DEBUG] [javascripts] - found Script: staubsauger_v0_3
                      [DEBUG] [javascripts] - found Script: benachrichtigungen_v0_2
                      [DEBUG] [javascripts] - found Script: bewasserung_sonoff
                      [DEBUG] [javascripts] - found Script: bewaesserung
                      [DEBUG] [javascripts] - found Script: rolladen_tag_nacht
                      [DEBUG] [javascripts] - found Script: bewaesserung_neu_1
                      [DEBUG] [javascripts] - found Script: battery
                      [DEBUG] [javascripts] - found Script: userdata_wrong
                      [DEBUG] [javascripts] - found Script: DWD-UWZ-NINA-Pushwarnungen
                      [DEBUG] [javascripts] - found Script: tablet
                      [DEBUG] [javascripts] - found Script: wer_schaltet_DP
                      [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "C:/ioBroker/backups/tmpScripts"
                      [DEBUG] [javascripts] - Javascript tmp directory "C:/ioBroker/backups/tmpScripts" successfully deleted
                      [DEBUG] [javascripts] - Backup created: C:\ioBroker\backups\javascripts_2023_04_08-13_33_46_backupiobroker.tar.gz
                      [DEBUG] [javascripts] - done
                      [DEBUG] [googledrive] - Google Drive: Copy iobroker_2023_04_08-13_33_34_backupiobroker.tar.gz...
                      [DEBUG] [drive] start with {"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"deleteBackupAfter":0}
                      [DEBUG] [googledrive] - Google Drive: Copy javascripts_2023_04_08-13_33_46_backupiobroker.tar.gz...
                      [DEBUG] [googledrive] - done
                      [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
                      [DEBUG] [clean] - done
                      [DEBUG] [email] - [iobroker] used E-Mail-Instance: email.0
                      [DEBUG] [email] - done
                      [DEBUG] [email] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de","time":"08. April 2023 um 13:34 Uhr"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                      [DEBUG] [historyHTML] - new history html values created
                      [DEBUG] [historyHTML] - done
                      [DEBUG] [historyJSON] - new history json values created
                      [DEBUG] [historyJSON] - done
                      [DEBUG] [historyHTML] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"08. April 2023 um 13:34 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                      [DEBUG] [historyJSON] start with {"type":"creator","workDir":"C:\\ioBroker\\node_modules\\iobroker.js-controller\\iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"ignoreErrors":false,"dir":"C:/ioBroker","javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"C:/ioBroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","newToken":true,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"08. April 2023 um 13:34 Uhr"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"meins","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"C:/ioBroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                      [EXIT] 0
                      simatec 2 Replies Last reply Reply Quote 0
                      • simatec
                        @maximal1981 sagte in Test Adapter ioBroker.backitup v2.6.x:
                        Nächste ioBroker Sicherung: 09. April 2023 um 02:40 Uhr
                        Ändere die Zeit auf was krummes wie 2:17 Uhr.
                        Google ist immer zu den Standardzeit gut ausgelastet, was zu Problemen führen kann
                        • simatec
                          @maximal1981 Alternativ nimm ne andere Cloud wie Dropbox oder Onedrive
                            cbrocker last edited by
                            ich bin gerade auch mit einem Problem bei Backup bzw. Restore auf ein neues System beschäftigt.
                            Darf ich mich hier anhängen oder soll ich einen neuen Thread aufmachen?
                              Thomas Braun Most Active @cbrocker last edited by
                              @cbrocker sagte in Test Adapter ioBroker.backitup v2.6.x:
                              Vermutlich die ubersichtlichere Variante.
                              C 1 Reply Last reply Reply Quote 1
                                cbrocker @Thomas Braun last edited by
                                @thomas-braun ja, wenn ich sehe, hier schon 2345 Einträge...
                                mache ich. danke
                                • maximal1981
                                  @simatec
                                  habe Zeit abgeändert, zusätzlich mal onedrive aktiviert und werde es weiter verfolgen.
                                  aber trotzdem dürfte das backup nicht anhalten/einfrieren oder was auch immer, sondern einen Fehler bringen, da bei mir nach dem nicht abgelegten backup 05. April nicht mehr lief, jedoch nächste Sicherung immer korrekt angezeigt wird.
                                  • simatec
                                    @maximal1981 Das Backup wurde erstellt und konnte halt nicht in Google Drive abgelegt werden, da Google nicht erreichbar war
                                    • maximal1981
                                      @simatec aber die nächsten Tage nicht mehr.
                                      wenn zumindest lokale Sicherungen erstellt worden wären die nächsten Tage, und Fehler im Log vorhanden wären.
                                      Kann es sein, dass das backup dann mit dem Upload auf "ewig" hochladet und kein neues gestartet wird?
                                      • simatec
                                        @maximal1981 Dafür benötige ich den vollständigen debuglog vom Backupprozess.
                                        Ansonsten ist es in die Glaskugel schauen
                                        • David G.
                                          @simatec sagte in Test Adapter ioBroker.backitup v2.6.x:
                                          iob backup
                                          Jetzt läuft er wieder nicht
                                          pi@pi:~ $ iob backup
                                          host.pi 24211 states saved
                                          host.pi 26491 objects saved
                                          /usr/bin/iob: line 10: 10346 Killed                  sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                                          pi@pi:~ $
                                          Die "10346" ändert sich bei jeden Versuch. Aber immer etwas nach oben.
                                          Mache jetzt grade erstmal nichts. Kein fix, reboot etc.
                                          • simatec
                                            @david-g So jetzt gehen wir mal in eine andere Richtung.
                                            So wie ich vermute, könnte dir beim Backup der RAM ausgehen.
                                            Wie groß sind deine iobroker Backups?
                                            170
                                            2780
                                            2335378
