    3. Einsteigerfragen
    4. Performance im Multihostbetrieb
    • MarkusSR1984
      MarkusSR1984 @Thomas Braun last edited by
      Skript v.2023-04-02
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : lxc
      Distributor ID: Ubuntu
      Description:    Ubuntu 22.10
      Release:        22.10
      Codename:       kinetic
      PRETTY_NAME="Ubuntu 22.10"
      NAME="Ubuntu"
      VERSION_ID="22.10"
      VERSION="22.10 (Kinetic Kudu)"
      VERSION_CODENAME=kinetic
      ID=ubuntu
      ID_LIKE=debian
      HOME_URL="https://www.ubuntu.com/"
      SUPPORT_URL="https://help.ubuntu.com/"
      BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
      UBUNTU_CODENAME=kinetic
      LOGO=ubuntu-logo
      Systemuptime and Load:
       20:06:19 up 1 day, 21:59,  1 user,  load average: 0.95, 0.91, 0.77
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Sat 2023-04-08 20:06:20 UTC
                 Universal time: Sat 2023-04-08 20:06:20 UTC
                       RTC time: n/a
                      Time zone: Etc/UTC (UTC, +0000)
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             10G        962M        8.8G        0.0K        490M        9.3G
      Swap:            16G          0B         16G
      Total:           26G        962M         25G
              10240 M total memory
                962 M used memory
                200 M active memory
               1171 M inactive memory
               8786 M free memory
                  0 M buffer memory
                490 M swap cache
              16383 M total swap
                  0 M used swap
              16383 M free swap
      *** FILESYSTEM ***
      Filesystem                       Type   Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0 ext4   7.8G  1.6G  5.9G  21% /
      /dev/mapper/pve-vm--100--disk--1 ext4   7.8G  350M  7.1G   5% /opt/iobroker
      none                             tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                            tmpfs  5.8G     0  5.8G   0% /dev/shm
      tmpfs                            tmpfs  2.4G  112K  2.4G   1% /run
      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems (real ones only):
      TARGET          SOURCE                           FSTYPE OPTIONS
      /               /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
      `-/opt/iobroker /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
      /var:
      451M    /var/
      219M    /var/cache
      214M    /var/lib
      213M    /var/cache/apt
      132M    /var/cache/apt/archives
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
      *** NodeJS-Installation ***
      /bin/nodejs     v18.7.0
      /bin/node               v18.7.0
      /bin/npm                8.18.0
      /bin/npx                8.18.0
      nodejs:
        Installed: 18.7.0+dfsg-5ubuntu1
        Candidate: 18.7.0+dfsg-5ubuntu1
        Version table:
       *** 18.7.0+dfsg-5ubuntu1 500
              500 http://archive.ubuntu.com/ubuntu kinetic/universe amd64 Packages
              100 /var/lib/dpkg/status
           16.19.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x kinetic/main amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     "javascript" not found
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker-shuttle                         -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.admin.1                  : admin                 : iobroker-rpi-n                           -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.admin.2                  : admin                 : iobroker-pve                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobroker-shuttle                         -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker-shuttle                         -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker-shuttle                         -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker-shuttle                         -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : iobroker-pve                             -  enabled
        system.adapter.devices.0                : devices               : iobroker-shuttle                         -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-shuttle                         -  enabled
      + system.adapter.ds18b20.0                : ds18b20               : Heizungsregler                           -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker-shuttle                         -  enabled
        system.adapter.flot.0                   : flot                  : iobroker-shuttle                         -  enabled
      + system.adapter.fullcalendar.0           : fullcalendar          : iobroker-shuttle                         -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker-shuttle                         -  enabled
      + system.adapter.history.0                : history               : Heizungsregler                           -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker-pve                             -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-pve                             -  enabled, port: 12001
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-pve                             -  enabled, port: 12010
      + system.adapter.hue-extended.0           : hue-extended          : iobroker-pve                             -  enabled
      + system.adapter.i2c.0                    : i2c                   : Heizungsregler                           -  enabled
        system.adapter.ical.1                   : ical                  : iobroker-shuttle                         -  enabled
        system.adapter.ical.2                   : ical                  : iobroker-shuttle                         -  enabled
        system.adapter.ical.3                   : ical                  : iobroker-shuttle                         - disabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-shuttle                         -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker-shuttle                         -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker-shuttle                         -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker-shuttle                         -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-shuttle                         -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-shuttle                         -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-shuttle                         -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-shuttle                         -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-shuttle                         -  enabled
      + system.adapter.info.0                   : info                  : iobroker-shuttle                         -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker-shuttle                         -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker-shuttle                         -  enabled
      + system.adapter.javascript.1             : javascript            : iobroker-shuttle                         -  enabled
        system.adapter.javascript.10            : javascript            : iobroker-shuttle                         - disabled
        system.adapter.javascript.100           : javascript            : iobroker-rpi-n                           - disabled
        system.adapter.javascript.20            : javascript            : iobroker-rpi-n                           - disabled
        system.adapter.javascript.30            : javascript            : Heizungsregler                           -  enabled
      + system.adapter.logparser.0              : logparser             : Heizungsregler                           -  enabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker-shuttle                         - disabled, port: 54321
      + system.adapter.moma.0                   : moma                  : iobroker-pve                             -  enabled
        system.adapter.mqtt.1                   : mqtt                  : iobroker-shuttle                         - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : iobroker-pve                             -  enabled
        system.adapter.proxy.0                  : proxy                 : iobroker-shuttle                         - disabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker-rpi-n                           -  enabled
        system.adapter.roborock.0               : roborock              : iobroker-rpi-n                           - disabled
      + system.adapter.rpi2.0                   : rpi2                  : iobroker-rpi-n                           -  enabled
      + system.adapter.rpi2.1                   : rpi2                  : Heizungsregler                           -  enabled
      + system.adapter.rpi2.3                   : rpi2                  : iob-rpi-kueche                           -  enabled
      + system.adapter.sayit.0                  : sayit                 : iobroker-rpi-n                           -  enabled, port: 0
      + system.adapter.simple-api.0             : simple-api            : iobroker-shuttle                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : iobroker-shuttle                         -  enabled
      + system.adapter.smartmeter.1             : smartmeter            : iobroker-shuttle                         -  enabled
      + system.adapter.smartmeter.2             : smartmeter            : iobroker-shuttle                         -  enabled
      + system.adapter.socketio.0               : socketio              : iobroker-shuttle                         -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker-rpi-n                           -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-pve                             -  enabled
      + system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker-pve                             -  enabled
      + system.adapter.sql.0                    : sql                   : iobroker-pve                             -  enabled, port: 3306
      + system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iobroker-rpi-n                           -  enabled, port: 9000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-shuttle                         -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker-shuttle                         -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : iobroker-shuttle                         -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker-pve                             -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker-pve                             -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-pve                             -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-pve                             -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-pve                             -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker-pve                             -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pve                             -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-pve                             -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker-pve                             -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker-shuttle                         -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker-shuttle                         -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-shuttle                         -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-shuttle                         -  enabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker-shuttle                         -  enabled
        system.adapter.vis.0                    : vis                   : iobroker-pve                             -  enabled
      + system.adapter.web.0                    : web                   : iobroker-shuttle                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : iobroker-pve                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.worx.0                   : worx                  : iobroker-shuttle                         -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.16   , installed 2.6.16
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "moma"         : 1.2.9    , installed 1.2.9
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Objects and States
      Objects:        16974
      States:         14941
      Hit:1 http://archive.ubuntu.com/ubuntu kinetic InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu kinetic-updates InRelease
      Hit:3 https://deb.nodesource.com/node_16.x kinetic InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu kinetic-security InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          2041957    284/master
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2038482    1/init
      tcp        0      0 0.0.0.0:12010           0.0.0.0:*               LISTEN      1000       5587724    99273/io.hm-rpc.1
      tcp        0      0 0.0.0.0:12001           0.0.0.0:*               LISTEN      1000       5586552    99272/io.hm-rpc.0
      tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      103        2039796    98/systemd-resolved
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      103        2039794    98/systemd-resolved
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2043199    301/io.admin.2
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       5442190    96245/io.web.1
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          2041958    284/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          2038484    1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          2041276    1/init
      udp        0      0 127.0.0.54:53           0.0.0.0:*                           103        2039795    98/systemd-resolved
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           103        2039793    98/systemd-resolved
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2038483    1/init
      udp6       0      0 :::111                  :::*                                0          2038485    1/init
      2023-04-08 19:19:06.561  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
      2023-04-08 19:24:06.561  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
      2023-04-08 19:24:06.562  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
      2023-04-08 19:29:06.555  - info: sql.0 (113036) Do not store value "NULL" for sonoff.0.RegenSensor.BH1750_Illuminance because no number
      2023-04-08 19:29:06.563  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
      2023-04-08 19:29:06.564  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
      2023-04-08 19:34:06.564  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
      2023-04-08 19:34:06.565  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
      2023-04-08 19:39:06.556  - info: sql.0 (113036) Do not store value "NULL" for sonoff.0.RegenSensor.BH1750_Illuminance because no number
      2023-04-08 19:39:06.564  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
      2023-04-08 19:39:06.567  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
      2023-04-08 19:44:06.565  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
      2023-04-08 19:44:06.567  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
      2023-04-08 19:49:06.558  - info: sql.0 (113036) Do not store value "NULL" for sonoff.0.RegenSensor.BH1750_Illuminance because no number
      2023-04-08 19:49:06.566  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
      2023-04-08 19:49:06.568  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
      2023-04-08 19:54:06.567  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
      2023-04-08 19:54:06.570  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
      2023-04-08 19:59:06.558  - info: sql.0 (113036) Do not store value "NULL" for sonoff.0.RegenSensor.BH1750_Illuminance because no number
      2023-04-08 19:59:06.568  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
      2023-04-08 19:59:06.570  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
      2023-04-08 20:03:54.516  - info: admin.2 (301) ==> Connected system.user.admin from ::ffff:192.168.1.50
      2023-04-08 20:04:02.418  - info: admin.2 (301) <== Disconnect system.user.admin from ::ffff:192.168.1.50 devices
      2023-04-08 20:04:06.570  - info: sql.0 (113036) Do not store value "NULL" for Regensensor because no number
      2023-04-08 20:04:06.572  - info: sql.0 (113036) Do not store value "NULL" for AkkuSensor because no number
      • Jey Cee
        Wie sieht den die Netzwerk Topologie aus?
          Thomas Braun Most Active @MarkusSR1984 last edited by Thomas Braun
          @markussr1984
          Zeitzone setzen und nicht als root herumhampeln.
          Und nodejs möchtest du von nodesource beziehen.
          MarkusSR1984 1 Reply Last reply Reply Quote 0
          • MarkusSR1984
            MarkusSR1984 @Thomas Braun last edited by MarkusSR1984
            @thomas-braun said in Performance im Multihostbetrieb:
            @markussr1984
            Wenn ich ehrlich bin, der host ist noch recht frisch und wurde mit dem Empfohlenen install script aufgesetzt. Ich ziehe im moment einige Adapter etc. auf diesen Host um weil er von CPU und RAM den Raspis haushoch überlegen ist und ich so hoffe das Gesammtsystem wieder etwas flotter zu bekommen. Aus diesem Grund wollte/will ich die diag ausgabe eben machen wenn diese Schritte abgeschlossen sind weil sie dann auch aussagekräftig sind.
            Das die instanz als root läuft ist nicht weiter schlimm da es in einem unpreviligierten container unter proxmox läuft. wer in der lage ist da auszubrechen den stört das auch nicht weiter wenn er im container keine root rechte hat aber grundsätzlich stimme ich dir da zu.
            Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
              @markussr1984 sagte in Performance im Multihostbetrieb:
              Da ist eine Interimsversion von Ubuntu eh das falsche Pferd. Die ist in wenigen Wochen wieder anabgekündigt. Wenn es unbedingt Ubuntu sein muss, nimm die aktuelle LTS Variante.
                Das ist nicht der (Haupt)-Grund, warum man nicht als root herumeimert. Du verbiegst dir Ratzfatz die Rechte am iobroker und das Ding läuft nicht so wie es soll.
                Ist nicht zufällig 'best practice ' nur mit den notwendigsten Rechten durch das System zu stolpern.
                • MarkusSR1984
                  Da ist eine Interimsversion von Ubuntu eh das falsche Pferd. Die ist in wenigen Wochen wieder angekündigt. Wenn es unbedingt Ubuntu sein muss, nimm die aktuelle LTS Variante.
                  Ne, das werd ich bei gelegenheit wieder auf debian umstellen, wollte mir die version nur mal anschauen. Ich hab aber aus weiser Vorraussicht eine eigene storage für den IOB verwendet damit sowas leicht zu bewerkstelligen ist, aber das hast du sicher schon bemerkt in der ausgabe 😉
                    Natürlich.
                    • MarkusSR1984
                      Natürlich.
                      Also hab ich dich richtig eingeschätzt 😉 😀
                      Aktuell kämpfe ich aber mit nem Every Update Fehler, Nach jedem JS Adapter update meint der IOB ständig das ich was an den Globalen TS Scripts geändert hätte und startet mir somit im Minutentakt alle JS Instanzen neu 😬
                      Das hat erstmal höhere Priorität da bei mir auch die Zentralheizung über den IOB läuft und es noch zu kalt ist die paar stunden abzuschalten
                        nodejs jetzt in der Version von nodesource installiert oder noch die 'kaputte' dfsg-Version?
                        • MarkusSR1984
                          aktuell noch die aus dem installer script, aber ich änder das mal eben auf dem host wo meine globelen scripte laufen ob er sich dann beruhigt, danke für den Denkansatz
                            @markussr1984
                            Warum fragst du eigentlich nach Hilfe, wenn du die erkannten Fehler im Setup dann nicht änderst?
                            • MarkusSR1984
                              @markussr1984
                              Ich hab ehrlich gesagt nicht mit so einer schnellen Reaktion gerechnet und war da schon im Updateprozess. Wie du sicher weist macht man bei sowas ungern mehrere Fässer auf weil man sonst bei Fehlern schlecht zurückverfolgen kann was passiert ist.
                                @markussr1984
                                nodejs als Laufzeitumgebung ist nur so wesentlich für den iobroker, das muss sitzen. Genauso wie die Zeitzone (und die root shell).
                                Das sind die drei Dinge, die du als erstes angehen musst. Und wenn das richtig ist kannst du auf dieser Basis weiter machen.
                                Alles andere ist wenig bis gar nicht sinnvoll.
                                • MarkusSR1984
                                  @markussr1984
                                  Hab mir grad meine anderen hosts angeschaut, die 3 von 4 laufen auf dem iobroker docker image von buanet:
                                  iob läuft auf user iobroker
                                  nodejs kommt von der source: https://deb.nodesource.com/node_16.x bullseye main
                                  und auch die zeitzone ist da überall richtig gesetzt.
                                  leider kann er da mit dem iob diag command nichts anfangen, das muss ich mir noch anschauen woran das liegt da es ja eigentlich die gleiche version sein sollte.
                                    @markussr1984
                                    Ein
                                    iob fix
                                    zieht iob diag auf das System. Jedenfalls auf Nicht-Dockern.
                                    • MarkusSR1984
                                      @markussr1984
                                      Ein
                                      iob fix
                                      Hat geholfen, danke. Die anderen Hosts folgen noch, aber dafür währ ich hald gern in einem Stable Zustand. Wenn ich da angekommen bin pack ich die diad logs von allen host nochmal hier rein, dann ist das ganze wie schon gesagt auch aussagekräftig.
                                      Hier das log meines "IOB Masters"
                                      Skript v.2023-04-02
                                      *** BASE SYSTEM ***
                                      Docker          : v8.0.0
                                      Virtualization  : Unknown (buanet/Synology?)
                                      Distributor ID: Debian
                                      Description:    Debian GNU/Linux 11 (bullseye)
                                      Release:        11
                                      Codename:       bullseye
                                      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                      NAME="Debian GNU/Linux"
                                      VERSION_ID="11"
                                      VERSION="11 (bullseye)"
                                      VERSION_CODENAME=bullseye
                                      ID=debian
                                      HOME_URL="https://www.debian.org/"
                                      SUPPORT_URL="https://www.debian.org/support"
                                      BUG_REPORT_URL="https://bugs.debian.org/"
                                       00:56:56 up 46 days, 25 min,  0 users,  load average: 13.38, 6.90, 5.71
                                      CPU threads: 4
                                      /home/iobroker/.diag.sh: line 76: timedatectl: command not found
                                      root
                                      /root
                                      root
                                      X-Server:       false
                                      Desktop:
                                      Terminal:
                                      /home/iobroker/.diag.sh: line 93: systemctl: command not found
                                      Boot Target:
                                      *** MEMORY ***
                                      Mem:            3.9G        3.2G        104M        5.0M        588M        412M
                                      Swap:           3.9G        2.0G        2.0G
                                      Total:          7.8G        5.2G        2.1G
                                               3911 M total memory
                                               3219 M used memory
                                                780 M active memory
                                               2622 M inactive memory
                                                103 M free memory
                                                 56 M buffer memory
                                                533 M swap cache
                                               3912 M total swap
                                               1960 M used swap
                                               1952 M free swap
                                      *** FILESYSTEM ***
                                      overlay                           overlay  915G  227G  650G  26% /
                                      tmpfs                             tmpfs     64M     0   64M   0% /dev
                                      shm                               tmpfs     64M     0   64M   0% /dev/shm
                                      /dev/mapper/ubuntu--vg-ubuntu--lv ext4     915G  227G  650G  26% /opt/vc
                                      tmpfs                             tmpfs    2.0G     0  2.0G   0% /proc/asound
                                      tmpfs                             tmpfs    2.0G     0  2.0G   0% /proc/acpi
                                      tmpfs                             tmpfs    2.0G     0  2.0G   0% /proc/scsi
                                      tmpfs                             tmpfs    2.0G     0  2.0G   0% /sys/firmware
                                      /opt/iobroker               /dev/mapper/ubuntu--vg-ubuntu--lv[/opt/docker-share/iobroker/data]        ext4   rw,relatime
                                      /opt/vc                     /dev/mapper/ubuntu--vg-ubuntu--lv[/opt/docker-share/iobroker/vc]        ext4   rw,relatime
                                      /usr/share/zoneinfo/Etc/UTC /dev/mapper/ubuntu--vg-ubuntu--lv[/usr/share/zoneinfo/Europe/Berlin]        ext4   rw,relatime
                                      /etc/resolv.conf            /dev/mapper/ubuntu--vg-ubuntu--lv[/var/lib/docker/containers/19e2d4c8dd001d95f8e77200bef0659fc5d334c1adaf173934df1ecea1abb911/resolv.conf] ext4   rw,relatime
                                      /etc/hostname               /dev/mapper/ubuntu--vg-ubuntu--lv[/var/lib/docker/containers/19e2d4c8dd001d95f8e77200bef0659fc5d334c1adaf173934df1ecea1abb911/hostname]    ext4   rw,relatime
                                      /etc/hosts                  /dev/mapper/ubuntu--vg-ubuntu--lv[/var/lib/docker/containers/19e2d4c8dd001d95f8e77200bef0659fc5d334c1adaf173934df1ecea1abb911/hosts]       ext4   rw,relatime
                                      /var:
                                      33M     /var/
                                      31M     /var/lib
                                      18M     /var/lib/apt/lists
                                      18M     /var/lib/apt
                                      13M     /var/lib/dpkg
                                      1.7G    /opt/iobroker/backups/
                                      14M     /opt/iobroker/iobroker-data/files
                                      /usr/bin/nodejs         v18.15.0
                                      /usr/bin/node           v18.15.0
                                      /usr/bin/npm            9.5.0
                                      /usr/bin/npx            9.5.0
                                      nodejs:
                                        Installed: 18.15.0-deb-1nodesource1
                                        Candidate: 18.15.0-deb-1nodesource1
                                        Version table:
                                       *** 18.15.0-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                                           12.22.12~dfsg-1~deb11u3 500
                                              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                                           12.22.5~dfsg-2~11u1 500
                                              500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                      ioBroker Status
                                      Objects type: redis
                                      States  type: redis
                                      admin:          6.3.5
                                      javascript:     6.1.4
                                      Adapter State
                                      + system.adapter.alexa2.0                 : alexa2                : iobroker-shuttle                         -  enabled
                                        system.adapter.sql.0                    : sql                   : iobroker-pve                             - disabled, port: 3306
                                      + instance is alive
                                      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                                      Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                                      Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                                      Adapter    "devices"      : 1.1.2    , installed 1.1.2
                                      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                      Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                      Adapter    "fullcalendar" : 1.2.0    , installed 1.2.0
                                      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                                      Adapter    "ical"         : 1.13.2   , installed 1.13.2
                                      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                                      Adapter    "info"         : 1.9.19   , installed 1.9.19
                                      Adapter    "iot"          : 1.14.2   , installed 1.14.2
                                      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                                      Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
                                      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                                      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                                      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                                      Adapter    "text2command" : 2.3.0    , installed 2.3.0
                                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                      Adapter    "worx"         : 2.0.3    , installed 2.0.3
                                      Objects and States
                                      Objects:        16947
                                      States:         14918
                                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                                      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                                      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                                      Pending Updates: 0
                                      tcp        0      0 127.0.0.11:40499        0.0.0.0:*               LISTEN      0          108627423  -
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       108634491  -
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       108627636  -
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       108631223  -
                                      tcp6       0      0 :::8084                 :::*                    LISTEN      1000       108632658  -
                                      udp        0      0 127.0.0.11:49741        0.0.0.0:*                           0          108627422  -
                                      2023-04-09 00:59:01.287  - info: javascript.1 (1199) received all objects
                                      2023-04-09 00:59:02.552  - info: javascript.1 (1199) script.js.global.Global_Variables: compiling TypeScript source...
                                      2023-04-09 00:59:02.871  - info: javascript.1 (1199) script.js.global.Global_Variables: source code did not change, using cached compilation result...
                                      2023-04-09 00:59:02.874  - info: javascript.1 (1199) script.js.global.Global_Functions: compiling TypeScript source...
                                      2023-04-09 00:59:03.156  - info: javascript.1 (1199) script.js.global.Global_Functions: source code did not change, using cached compilation result...
                                      2023-04-09 00:59:03.459  - info: javascript.1 (1199) Start javascript script.js.Smart_Home.Steuerung_Beleuchtung
                                      2023-04-09 00:59:03.690  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Beleuchtung: Register Event for hm-rpc.1.0008DBE98F4607.1.PRESS_SHORT
                                      2023-04-09 00:59:03.695  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Beleuchtung: Register Event for hm-rpc.1.0008DD89A2BC10.1.PRESS_SHORT
                                      2023-04-09 00:59:03.699  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Beleuchtung: registered 12 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2023-04-09 00:59:03.699  - info: javascript.1 (1199) Start javascript script.js.Smart_Home.Steuerung_Beleuchtung_Bad
                                      2023-04-09 00:59:03.726  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Beleuchtung_Bad: Aktueller Lichtstatus im Bad ist: false
                                      2023-04-09 00:59:03.729  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Beleuchtung_Bad: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2023-04-09 00:59:03.732  - info: javascript.1 (1199) Start javascript script.js.Smart_Home.Steuerung_Jalousie_OG
                                      2023-04-09 00:59:03.763  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                      2023-04-09 00:59:03.767  - info: javascript.1 (1199) Start javascript script.js.Smart_Home.SommerWinter_Automatik
                                      2023-04-09 00:59:03.963  - info: javascript.1 (1199) script.js.Smart_Home.SommerWinter_Automatik: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                      2023-04-09 00:59:05.273  - info: smartmeter.0 (290) Received 10 values, 3 updated
                                      2023-04-09 00:59:11.066  - info: smartmeter.1 (264) Received 9 values, 0 updated
                                      2023-04-09 00:59:13.766  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Current Brightness ==> 46.25
                                      2023-04-09 00:59:13.768  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Current Brightness ==> 46.25
                                      2023-04-09 00:59:13.789  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Current Brightness ==> 46.25
                                      2023-04-09 00:59:13.792  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Current Brightness ==> 46.25
                                      2023-04-09 00:59:14.032  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Jalousie Gästezimmer ==> Current Pos: -1 Target Level: 100 Send Allowed: true
                                      2023-04-09 00:59:14.110  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Jalousie Wohnzimmer ==> Current Pos: 100 Target Level: 100 Send Allowed: false
                                      2023-04-09 00:59:14.215  - info: javascript.1 (1199) script.js.Smart_Home.Steuerung_Jalousie_OG: Jalousie Schlafzimmer ==> Current Pos: 59 Target Level: 60 Send Allowed: false
                                        Homoran Global Moderator Administrators @MarkusSR1984 last edited by
                                        nicht ganz!
                                        nodejs wird von den Skript korrekt installiert, wenn vorher keine andere Version von nodejs vorhanden ist.
                                        Dein Ubuntu bringt aber eine eigene Version aus einer anderen Quelle mit.
                                        Die wird bei der Installation nicht angefasst und bleibt auch später so drin.
                                        Dass es nicht gut ist siehst du ja daran, dass nach Anwendung des Fixers, der die Rechte geradebiegt, doch einiges funktioniert, was vorher nicht klappte.
                                        • MarkusSR1984
                                          MarkusSR1984 @Homoran last edited by
                                          @homoran said in Performance im Multihostbetrieb:
                                          nicht ganz!
                                          Gut zu wissen. Ich hab aber inzwischen wieder ein Debian installiert und mir das Installerscript genauer angeschaut. Laut diesem sollte es ihn nicht sonderlich interressieren ob nun debian oder ubuntu und es müsste den user iobroker eigentlich bei der installation erstellen. Warum das unter Ubuntu nicht geht ? KP.
                                          unter Debian macht es das alles sauber. Also richtiger User, richtige nodesource etc. Das einzige was mir aufgefallen ist, das er noch nodejs v16.19.1 verwendet obwohl die v18 Empfohlen wird.
                                          Da wo ich das eingesetzt habe waren diese Sachen alles Korrect, da ging nur der "iob diag" command nicht.
                                          Aber ich glaube, das heist ich bin mir nicht zu 100% sicher, das ich durch die Updateprobleme die ich gestern hatte evtl, die Ursache für das träge Verhalten gefunden habe. Im JS Adapter auf meinem Heizungsregler hatte ich einige NPM Packages eingetragen und er wollte sich auf biegen und brechen nicht auf die aktuelle Version updaten lassen, Dies hat dann komischerweise auch dazu geführt das IOB andauernd meinte das sich etwas an den Globalen Scripts geändert hätte. Die ligen zwar auf einem anderen Host aber naja...
                                          Als ich dann die Schnauze voll hatte das mir die Kiste ständig abgeschmiert/eingefrohren ist beim versuch den Adapter zu updaten habe ich den aus den node_modules gelöscht und hab mir das paket von einem anderen Raspi geschnappt und rüberkopiert. Er hat zwar dann trotzdem angefangen ein paar sachen zu kompliieren aber nun läuft die mühle wieder, und das gefühlt auch wieder flotter. Ich beobachte das aber nun mal einige Zeit.
                                          Bei Interesse oder falls wiedererwarten immernoch Performanceprobleme auftreten pack ich die DIAG ausgaben aller hosts in dieses Thema.
                                          Herzlichen Dank nochmal für die Denkanstöße und Diagnose 😘
                                            Globalen Scripts
                                            sind auch mit außerster Vorsicht zu genießen. Du weißt, dass die Dinger vor jedem anderen Skript auch herangezogen werden?
                                            1189
