    3. Einsteigerfragen
    4. Backup Zugriffsproblem influxDB2.5
    • keksn
      keksn last edited by
      Hallo, leider funktioniert mein Influxdb2(7) Backup nicht mehr. Bin aber mit dem beschrieben Punkten zu keiner Lösung gekommen.
      backitup.0
      Zeit
      debug
      Nachricht
      backitup.0
      2023-04-09 08:00:28.312	error	[iobroker] Error: Command failed: "/usr/bin/influx" backup --bucket iobroker -t 866nCegDJG1u4sfO6TvfiIit-aQOZ1Wq1ukvR5SIl9ldn5stgoK33pGF3bQq_aNKc0TMbc9Pe3EQ-ZbAwzvCug== "/opt/iobroker/backups/influxDB_2023_04_09-08_00_28_backupiobroker" 2023/04/09 08:00:28 INFO: Downloading metadata snapshot Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
      backitup.0
      2023-04-09 08:00:28.312	error	[iobroker/influxDB] Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
      backitup.0
      2023-04-09 08:00:28.312	error	[iobroker/influxDB] 2023/04/09 08:00:28 INFO: Downloading metadata snapshot
      backitup.0
      2023-04-09 08:00:28.312	error	[iobroker/influxDB] Error: Command failed: "/usr/bin/influx" backup --bucket iobroker -t 866nCegDJG1u4sfO6TvfiIit-aQOZ1Wq1ukvR5SIl9ldn5stgoK33pGF3bQq_aNKc0TMbc9Pe3EQ-ZbAwzvCug== "/opt/iobroker/backups/influxDB_2023_04_09-08_00_28_backupiobroker"
      backitup.0
      2023-04-09 08:00:28.310	debug	[iobroker/influxDB] InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2023_04_09-08_00_28_backupiobroker" successfully deleted
      backitup.0
      2023-04-09 08:00:28.309	debug	[iobroker/influxDB] Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2023_04_09-08_00_28_backupiobroker"
      backitup.0
      2023-04-09 08:00:28.292	debug	[iobroker/influxDB] InfluxDB Backup tmp directory created
      backitup.0
      2023-04-09 08:00:28.291	debug	[iobroker/influxDB] Start InfluxDB Backup ...
      backitup.0
      2023-04-09 08:00:28.290	debug	[iobroker/influxDB] InfluxDB-Backup started ...
      backitup.0
      2023-04-09 08:00:28.140	debug	[iobroker/iobroker] done
      backitup.0
      2023-04-09 08:00:27.082	debug	[iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_04_09-08_00_21_backupiobroker.tar.gz
      backitup.0
      2023-04-09 08:00:23.895	debug	[iobroker/iobroker] host.iobroker 26002 objects saved
      backitup.0
      2023-04-09 08:00:23.541	debug	[iobroker/iobroker] host.iobroker 20366 states saved
      backitup.0
      2023-04-09 08:00:21.018	debug	[iobroker/mount] done
      backitup.0
      2023-04-09 08:00:21.017	debug	[iobroker/mount] mount successfully completed
      backitup.0
      2023-04-09 08:00:20.968	debug	[iobroker/mount] nfs-mount command: "sudo mount Hometank:/volume1/Backup/iobroker /opt/iobroker/backups"
      backitup.0
      2023-04-09 08:00:11.037	debug	[iobroker/mount] umount successfully completed
      backitup.0
      2023-04-09 08:00:10.971	debug	[iobroker/mount] mount activ... umount is started before mount!!
      backitup.0
      2023-04-09 08:00:10.967	debug	Backup has started ...
      backitup.0
      2023-04-09 08:00:10.957	debug	The local storage check was completed successfully. On the host "iobroker" are currently 47416 MB free space available!
      backitup.0
      2023-04-09 08:00:08.571	debug	The local storage check was completed successfully. On the host "iobroker" are currently 47416 MB free space available!
      keksn simatec 2 Replies Last reply Reply Quote 0
      • keksn
        keksn @keksn last edited by Homoran
        @keksn
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Sun Apr  9 07:56:27 CEST 2023 on tty1
        keksn@iobroker:~$ which influx
        /usr/bin/influx
        keksn@iobroker:~$ cd ~
        apt policy influx*
        influxdb2-cli:
          Installed: 2.7.1-2
          Candidate: 2.7.1-2
          Version table:
         *** 2.7.1-2 500
                500 https://repos.influxdata.com/debian stable/main amd64 Packages
                100 /var/lib/dpkg/status
             2.6.1 500
             2.6.0 500
             2.5.0 500
             2.4.0 500
             2.3.0 500
        influxdb-client:
          Installed: (none)
          Candidate: 1.6.7~rc0-1+b5
          Version table:
             1.6.7~rc0-1+b5 500
                500 http://ftp.debian.org/debian bullseye/main amd64 Packages
        influxdb-dev:
          Installed: (none)
          Candidate: (none)
          Version table:
        influxdb2-client:
          Installed: (none)
          Candidate: 2.7.1-1
          Version table:
             2.7.1-1 500
        influxdb:
          Installed: (none)
          Candidate: 1.8.10-1
          Version table:
             1.8.10-1 500
             1.6.7~rc0-1+b5 500
        influxdb2:
          Installed: 2.7.0-1
          Candidate: 2.7.0-1
          Version table:
         *** 2.7.0-1 500
             2.6.1-1 500
             2.6.0-1 500
             2.5.1-1 500
             2.4.0-1 500
             2.3.0-1 500
             2.2.0 500
        • simatec
          simatec Developer Most Active @keksn last edited by
          @keksn
          Steht doch im Log …
          401 Unauthorized
          https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#token-für-influxdb-2x-backup-richtig-erstellen
          keksn 1 Reply Last reply Reply Quote 0
          • keksn
            keksn @simatec last edited by
            @simatec
            das habe ich alles schon mehrmals gemacht. Es hat ja auch schon funktioniert. Ich habe aber jetzt erst gesehen das das letzte Backup am 17.02 erstellt wurde.
            • simatec
              @keksn
              Dann musst du es nochmal nach dieser Anleitung machen.
              Dein Token ist nicht für ein Backup gültig.
              keksn 3 Replies Last reply Reply Quote 0
              • keksn
                @simatec
                Operator token steht bei mir da nirgends. Ich habe den obersten in der Liste genommen. jetzt kommt das
                	2023-04-09 11:17:45.061	error	[iobroker] Error: Command failed: "/usr/bin/influx" backup --bucket iobroker -t MJ-dVc5yNCpLtCN22GP_mrXrbJQR3mZxhy9bAOMUnzFGL2xs5T3FwZJxFG2P_QNZvlNYzV6RVd3pvZkFJ7koow==" "/opt/iobroker/backups/influxDB_2023_04_09-11_17_45_backupiobroker" /bin/sh: 1: Syntax error: Unterminated quoted string
                backitup.0
                2023-04-09 11:17:45.061	error	[iobroker/influxDB] /bin/sh: 1: Syntax error: Unterminated quoted string
                backitup.0
                2023-04-09 11:17:45.061	error	[iobroker/influxDB] Error: Command failed: "/usr/bin/influx" backup --bucket iobroker -t MJ-dVc5yNCpLtCN22GP_mrXrbJQR3mZxhy9bAOMUnzFGL2xs5T3FwZJxFG2P_QNZvlNYzV6RVd3pvZkFJ7koow==" "/opt/iobroker/backups/influxDB_2023_04_09-11_17_45_backupiobroker"
                • keksn
                  @simatec
                  wenn ich in der Konsole eingebe
                  influx backup --bucket iobroker --host http://192.168.1.166:8086 -t jDzlHe-luNvFjk_8XXDUoDfyLMt9MSQuVflszTB53x2g-JQkOAmP7B1JGpjW__7sZaXeBRACUyKs95uP-K7QWQ== "/tmp/influx-test"
                  kommt das
                  keksn@iobroker:~$ influx backup --bucket iobroker --host http://192.168.1.166:8086 -t jDzlHe-luNvFjk_8XXDUoDfyLMt9MSQuVflszTB53x2g-JQkOAmP7B1JGpjW__7sZaXeBRACUyKs95uP-K7QWQ== "/tmp/influx-test"
                  2023/04/09 11:22:39 INFO: Downloading metadata snapshot
                  keksn@iobroker:~$
                  • keksn
                    @simatec
                    das ist der Token lt Abfrage
                    keksn@iobroker:~$ influx auth list -t jDzlHe-luNvFjk_8XXDUoDfyLMt9MSQuVflszTB53x2g-JQkOAmP7B1JGpjW__7sZaXeBRACUyKs95uP-K7QWQ== --json
                                    "id": "0b046c7cd2da7000",
                                    "description": "admin",
                                    "token": "MJ-dVc5yNCpLtCN22GP_mrXrbJQR3mZxhy9bAOMUnzFGL2xs5T3FwZJxFG2P_QNZvlNYzV6RVd3pvZkFJ7koow==",
                                    "status": "active",
                                    "userName": "admin",
                                    "userID": "0b03f56869ede000",
                                    "permissions": [
                                            "read:orgs/0f2be3356ee1ee0a/annotations",
                                            "write:orgs/0f2be3356ee1ee0a/annotations",
                                            "read:orgs/0f2be3356ee1ee0a/authorizations",
                                            "write:orgs/0f2be3356ee1ee0a/authorizations",
                                            "read:orgs/0f2be3356ee1ee0a/buckets",
                                            "write:orgs/0f2be3356ee1ee0a/buckets",
                                            "read:orgs/0f2be3356ee1ee0a/checks",
                                            "write:orgs/0f2be3356ee1ee0a/checks",
                                            "read:orgs/0f2be3356ee1ee0a/dashboards",
                                            "write:orgs/0f2be3356ee1ee0a/dashboards",
                                            "read:orgs/0f2be3356ee1ee0a/dbrp",
                                            "write:orgs/0f2be3356ee1ee0a/dbrp",
                                            "read:orgs/0f2be3356ee1ee0a/documents",
                                            "write:orgs/0f2be3356ee1ee0a/documents",
                                            "read:orgs/0f2be3356ee1ee0a/labels",
                                            "write:orgs/0f2be3356ee1ee0a/labels",
                                            "read:orgs/0f2be3356ee1ee0a/notebooks",
                                            "write:orgs/0f2be3356ee1ee0a/notebooks",
                                            "read:orgs/0f2be3356ee1ee0a/notificationEndpoints",
                                            "write:orgs/0f2be3356ee1ee0a/notificationEndpoints",
                                            "read:orgs/0f2be3356ee1ee0a/notificationRules",
                                            "write:orgs/0f2be3356ee1ee0a/notificationRules",
                                            "read:/orgs/0f2be3356ee1ee0a",
                                            "read:orgs/0f2be3356ee1ee0a/remotes",
                                            "write:orgs/0f2be3356ee1ee0a/remotes",
                                            "read:orgs/0f2be3356ee1ee0a/replications",
                                            "write:orgs/0f2be3356ee1ee0a/replications",
                                            "read:orgs/0f2be3356ee1ee0a/scrapers",
                                            "write:orgs/0f2be3356ee1ee0a/scrapers",
                                            "read:orgs/0f2be3356ee1ee0a/secrets",
                                            "write:orgs/0f2be3356ee1ee0a/secrets",
                                            "read:orgs/0f2be3356ee1ee0a/sources",
                                            "write:orgs/0f2be3356ee1ee0a/sources",
                                            "read:orgs/0f2be3356ee1ee0a/tasks",
                                            "write:orgs/0f2be3356ee1ee0a/tasks",
                                            "read:orgs/0f2be3356ee1ee0a/telegrafs",
                                            "write:orgs/0f2be3356ee1ee0a/telegrafs",
                                            "read:/users/0b03f56869ede000",
                                            "write:/users/0b03f56869ede000",
                                            "read:orgs/0f2be3356ee1ee0a/variables",
                                            "write:orgs/0f2be3356ee1ee0a/variables",
                                            "read:orgs/0f2be3356ee1ee0a/views",
                                            "write:orgs/0f2be3356ee1ee0a/views"
                    • simatec
                      @keksn
                      Das ist aber ein anderer Token in deinen Einstellungen von Backitup.
                      Des Weiteren hast du in den Einstellungen von Backitup ein Anführungszeichen am Ende des Token drin, was sicher durch copy & paste dort reinkam.
                      keksn 2 Replies Last reply Reply Quote 0
                      • keksn
                        @simatec sorry nochmal mit dem ersten toke ohne """
                        ackitup.0
                        2023-04-09 11:40:58.513	error	[iobroker] Error: Command failed: "/usr/bin/influx" backup --bucket iobroker -t MJ-dVc5yNCpLtCN22GP_mrXrbJQR3mZxhy9bAOMUnzFGL2xs5T3FwZJxFG2P_QNZvlNYzV6RVd3pvZkFJ7koow== "/opt/iobroker/backups/influxDB_2023_04_09-11_40_58_backupiobroker" 2023/04/09 11:40:58 INFO: Downloading metadata snapshot Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
                        backitup.0
                        2023-04-09 11:40:58.513	error	[iobroker/influxDB] Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
                        backitup.0
                        2023-04-09 11:40:58.513	error	[iobroker/influxDB] 2023/04/09 11:40:58 INFO: Downloading metadata snapshot
                        backitup.0
                        2023-04-09 11:40:58.512	error	[iobroker/influxDB] Error: Command failed: "/usr/bin/influx" backup --bucket iobroker -t MJ-dVc5yNCpLtCN22GP_mrXrbJQR3mZxhy9bAOMUnzFGL2xs5T3FwZJxFG2P_QNZvlNYzV6RVd3pvZkFJ7koow== "/opt/iobroker/backups/influxDB_2023_04_09-11_40_58_backupiobroker"
                                        "status": "active",
                                        "permissions": [
                        • keksn
                          @simatec
                          keksn@iobroker:~$ influx backup --bucket iobroker --host http://192.168.1.166:8086 -t MJ-dVc5yNCpLtCN22GP_mrXrbJQR3mZxhy9bAOMUnzFGL2xs5T3FwZJxFG2P_QNZvlNYzV6RVd3pvZkFJ7koow== "/tmp/influx-test"
                          2023/04/09 11:46:50 INFO: Downloading metadata snapshot
                          • simatec
                            @keksn Gehe die Anleitung nochmal Schritt für Schritt durch und erstelle einen neuen Operator Token
                            keksn Glasfaser 3 Replies Last reply Reply Quote 0
                            • keksn
                              @simatec
                              zum verzweifeln...
                              keksn@iobroker:~$ influx auth list -t LpT1OUMTk3MNKV9fCwE7gfFHzu5CPr6dQI2VtdJ-31aFgFszpYIiZwaTfioaZMbj5ddxFTZT3HKACx23QpMgVg== --json
                                              "id": "0b055ae197aec000",
                                              "description": "iobroker_user_token",
                                              "token": "LpT1OUMTk3MNKV9fCwE7gfFHzu5CPr6dQI2VtdJ-31aFgFszpYIiZwaTfioaZMbj5ddxFTZT3HKACx23QpMgVg==",
                                              "status": "active",
                                              "permissions": [
                                      }t
                              keksn@iobroker:~$ influx backup --bucket iobroker --host http://192.168.1.166:8086 -t LpT1OUMTk3MNKV9fCwE7gfFHzu5CPr6dQI2VtdJ-31aFgFszpYIiZwaTfioaZMbj5ddxFTZT3HKACx23QpMgVg== "/tmp/influx-test"
                              2023/04/09 12:03:23 INFO: Downloading metadata snapshot
                              • keksn
                                • Marc Berg
                                  Marc Berg Most Active @keksn last edited by Marc Berg
                                  @keksn sagte in Backup Zugriffsproblem influxDB2.5:
                                  influx auth list
                                                  "status": "active",
                                                  "permissions": [
                                  Das ist kein Operator Token! Den erkennst Du daran, dass in den Permissions kein "orgs" drin steht. Ein Operator Token hat Rechte auf ALLE Organisationen.
                                  So in etwa:
                                  "permissions": [
                                                          "read:/annotations",
                                                          "write:/annotations",
                                                          "read:/authorizations",
                                                          "write:/authorizations",
                                                          "read:/buckets",
                                                          "write:/buckets",
                                                          "read:/checks",
                                                          "write:/checks",
                                                          "read:/dashboards",
                                                          "write:/dashboards",
                                                          "read:/dbrp",
                                                          "write:/dbrp",
                                  • Glasfaser
                                    Glasfaser @simatec last edited by Glasfaser
                                    @keksn
                                    @simatec sagte in Backup Zugriffsproblem influxDB2.5:
                                    Das ist nur ein User .. in deinem Log
                                    Hast du das gemacht ... :
                                    schau auch hier mit mal nach :
                                    cat /etc/influxdb2/influx-configs
                                    • keksn
                                      keksn @Marc Berg last edited by
                                      @marc-berg sagte in Backup Zugriffsproblem influxDB2.5:
                                      f2be3356ee1ee0a/
                                      danke, dann kann ich aber anscheinend keinen Operator token erstellen. Funkt nicht
                                      • keksn
                                        keksn @Glasfaser last edited by
                                        @glasfaser
                                        die Anleitung habe ich nun schon einige Male durch.
                                        config Datei fine ich aber nicht
                                        keksn@iobroker:~$ cd /etc/influxdb2/influx-configs
                                        -bash: cd: /etc/influxdb2/influx-configs: No such file or directory
                                        • keksn
                                          @glasfaser
                                          dürfte mir da irgendetwas zerschossen haben, da das Backup ja schon problemlos gelaufen ist
                                          • Glasfaser
                                            Glasfaser @keksn last edited by
                                            Funkt nicht
                                            und was heißt das für uns ...
                                            kannst du das mal alles zeigen !?
                                            55
                                            2886
