    4. Alpha Test js-controller 5.0
    • simatec
      simatec Developer Most Active @Guest last edited by
      @ilovegym Führe mal bitte das Backup über die CLI aus und poste mal die Ausgabe
      iob backup
        A Former User @simatec last edited by A Former User
        @simatec
        das wird lang.. Moment.. er macht... musste kuerzen, waren mehr als 100000 Zeichen..
        ilovegym@iobrokerS2:/opt/iobroker$ iob backup
        host.iobrokerS2 84652 states saved
        Can not copy File 0_userdata.0/Icons/blaue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/blaue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/braune_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/braune_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/braune_tonne1.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/braune_tonne1.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/gelbe_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/gelbe_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/graue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/graue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/gruene_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/gruene_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/hellblaue_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/hellblaue_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_blau.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_blau.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_gelb.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_gelb.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_grau.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_grau.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/muelltonne-mit-armen_gruen.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/muelltonne-mit-armen_gruen.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/schwarze_tonne.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/schwarze_tonne.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/state_leerung blaue tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung blaue tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/state_leerung braune tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung braune tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/state_leerung gelbe tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung gelbe tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/state_leerung gruene tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung gruene tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/state_leerung schwarze tonne.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/state_leerung schwarze tonne.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/Icons/undefined.0.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/Icons/undefined.0.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/htmlakku.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlakku.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/htmlbackitup.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlbackitup.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/htmldect2.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmldect2.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/htmlfussball1.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlfussball1.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/htmlfussball2.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmlfussball2.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/htmltrash1.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/htmltrash1.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Alarmpanel.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Alarmpanel.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD10.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD10.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD8.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_AlarmpanelHD8.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Frontdoor.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Frontdoor.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Guest.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Guest.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Home.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Home.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_HomeTV.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_HomeTV.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/0_userdata.0_minukodu_Mobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/0_userdata.0_minukodu_Mobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/AlarmpanelHD8.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/AlarmpanelHD8.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/Energy.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Energy.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/Home.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Home.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/HomeTV.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/HomeTV.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/Log.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Log.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/Mobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Mobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/OldMobile.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/OldMobile.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/TVOGB.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/TVOGB.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/Test.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Test.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/minukodu/Video.json to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/Video.json: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/screenshots/bundesliga2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/screenshots/bundesliga2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File 0_userdata.0/synology/Doorbell.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/synology/Doorbell.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File lovelace.0/cards/background.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/lovelace.0/cards/background.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File mihome-vacuum.0.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.0.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File mihome-vacuum.1.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.1.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File mihome-vacuum.2.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.2.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File mihome-vacuum.3.userfiles/actualMap.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/mihome-vacuum.3.userfiles/actualMap.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File synology.0/cover.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/cover.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File synology.0/snapshotCam_13.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_13.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File synology.0/snapshotCam_19.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_19.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File synology.0/snapshotCam_21.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_21.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File synology.0/snapshotCam_24.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_24.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File synology.0/snapshotCam_26.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_26.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File synology.0/snapshotCam_7.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.0/snapshotCam_7.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File synology.1/cover.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/synology.1/cover.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/cache.manifest to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/cache.manifest: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/cordova.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/cordova.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/css/add_kian.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/add_kian.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/css/app.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/app.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/css/backgrounds.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/backgrounds.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/css/doc.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/doc.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/css/montserrat-regular-webfont.woff to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/montserrat-regular-webfont.woff: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/css/styles.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/styles.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/css/vis-common-user.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis-common-user.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/css/vis-editor.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis-editor.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/css/vis.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/css/vis.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/edit.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/edit.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/edit.src.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/edit.src.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/add.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/add.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/align-height.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-height.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/align-horizontal-center-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-center-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/align-horizontal-left.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-left.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/align-horizontal-right-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-horizontal-right-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/align-vertical-bottom-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-bottom-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/align-vertical-center-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-center-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/align-vertical-top-2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-vertical-top-2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/align-width.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/align-width.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/bar.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/bar.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/cancel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/cancel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/checkbox.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/checkbox.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/container.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/container.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/control.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/control.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/copy.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/copy.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/dialog.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/dialog.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/distribute-horizontal-equal.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/distribute-horizontal-equal.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/distribute-vertical-equal.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/distribute-vertical-equal.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/door.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/door.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/filter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/filter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/groupFixed.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/groupFixed.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/groupVisibility.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/groupVisibility.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/info.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/info.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/lamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/lock.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lock.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/lockIcon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/lockIcon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/navigation.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/navigation.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/ok.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/ok.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/refresh-4.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/refresh-4.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/rename.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/rename.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/rgb.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/rgb.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/shutter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/shutter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/state.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/state.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/stateful.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/stateful.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/static.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/static.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/table.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/table.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/temperature.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/temperature.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/timestamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/timestamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/tools.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/tools.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/value.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/value.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/icon/window.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/icon/window.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/Heating.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Heating.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/Lamp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Lamp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/OutsideTemp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/OutsideTemp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/Window.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/Window.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/back/box-radial.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/box-radial.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/back/flowers.jpg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/flowers.jpg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/back/oblique-line-bk.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/back/oblique-line-bk.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bg-dots-10.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-10.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bg-dots-15.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-15.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bg-dots-20.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-20.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bg-dots-25.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-25.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bg-dots-30.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-30.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bg-dots-40.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-40.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bg-dots-5.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-5.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bg-dots-50.svg to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bg-dots-50.svg: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bulbOff.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulbOff.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bulbOn.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulbOn.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bulb_off.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulb_off.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/bulb_on.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/bulb_on.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/camera.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/camera.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/cc-nc-by.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/cc-nc-by.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/disconnect.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/disconnect.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/door-bell.mp3 to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/door-bell.mp3: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/editmode-pattern.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/editmode-pattern.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/eg_trans.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/eg_trans.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/favicon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/favicon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/faviconEdit.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/faviconEdit.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/garage-door-closed.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/garage-door-closed.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/garage-door-opened.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/garage-door-opened.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/gear-icon-md.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/gear-icon-md.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/hexabump.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/hexabump.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/kde_folder.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/kde_folder.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/no_filter.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/no_filter.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/sound.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/sound.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/tank.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/tank.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/vis.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/vis.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/img/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/img/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/index.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/index.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/index.src.html to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/index.src.html: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/app.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/app.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/config.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/config.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/conn.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/conn.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/connSignalR.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/connSignalR.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/fileManager.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/fileManager.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/fileManager.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/fileManager.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/add.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/add.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/back.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/back.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/down.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/down.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/edit-rename.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/edit-rename.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/folder-new-7.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/folder-new-7.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/folder-new.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/folder-new.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/icons.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/icons.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/list.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/list.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/play.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/play.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/refresh.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/refresh.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/stop.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/stop.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/actions/up.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/actions/up.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/circleLeftIcon.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/circleLeftIcon.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/JS.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/JS.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/bmp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/bmp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/css.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/css.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/folder-blue.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-blue.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/folder-brown.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-brown.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/folder-green.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/folder-green.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/gif.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/gif.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/img2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/img2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/jpg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/jpg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/misc.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/misc.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/mp3.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/mp3.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/png.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/png.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/prg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/prg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/svg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/svg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/undef.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/undef.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/wav.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/wav.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/128/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/128/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/bmp.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/bmp.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/css.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/css.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/folder-blue.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-blue.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/folder-brown.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-brown.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/folder-green.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/folder-green.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/gif.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/gif.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/img2.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/img2.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/jpg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/jpg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/js.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/js.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/misc.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/misc.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/mp3.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/mp3.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/png.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/png.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/prg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/prg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/svg.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/svg.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/undef.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/undef.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/wav.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/wav.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/fm/icon/mine/24/zip.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/fm/icon/mine/24/zip.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/vis.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/vis.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/visAbout.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visAbout.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/visEdit.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEdit.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/visEditExt.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditExt.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/visEditInspect.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditInspect.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/visEditTemplates.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditTemplates.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/visEditWelcome.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visEditWelcome.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/visUtils.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visUtils.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/visWizard.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/visWizard.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/js/words.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/js/words.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/ace/ace.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ace.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/ace/ext-language_tools.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ext-language_tools.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/ace/ext-searchbox.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/ext-searchbox.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/ace/mode-css.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-css.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/ace/mode-html.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-html.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/ace/mode-javascript.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/mode-javascript.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/ace/worker-css.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-css.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/ace/worker-html.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-html.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/ace/worker-javascript.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/ace/worker-javascript.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/add2home-2.0.8.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/add2home-2.0.8.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/fancytree/channel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/channel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/fancytree/device.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/device.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/fancytree/icons.gif to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/icons.gif: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/fancytree/loading.gif to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/loading.gif: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/fancytree/state.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/state.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/fancytree/ui.fancytree.jquery.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/ui.fancytree.jquery.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/fancytree/ui.fancytree.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/fancytree/ui.fancytree.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/farbtastic.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/farbtastic.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/jquery.jgrowl.min.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.jgrowl.min.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/jquery.multiselect-1.13.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.multiselect-1.13.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/jquery.multiselect.filter.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/jquery.multiselect.filter.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/superfish/megafish.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/megafish.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/superfish/superfish-navbar.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish-navbar.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/superfish/superfish-vertical.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish-vertical.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/css/superfish/superfish.css to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/css/superfish/superfish.css: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/img/delete.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/delete.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/img/edit-undo-8.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/edit-undo-8.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/img/logout.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/logout.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/img/marker.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/marker.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/img/mask.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/mask.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/img/shape_align_bottom.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_bottom.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/img/shape_align_left.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_left.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/img/shape_align_right.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_right.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/img/shape_align_top.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/shape_align_top.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/img/wheel.png to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/img/wheel.png: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/add2home-2.0.8.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/add2home-2.0.8.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/can.custom.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/can.custom.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/colResizable-1.5.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/colResizable-1.5.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/dropzone.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/dropzone.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/farbtastic.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/farbtastic.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/html2canvas.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/html2canvas.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/jquery.ba-resize.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.ba-resize.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/jquery.base64.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.base64.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/jquery.fancytree-all.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.fancytree-all.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        Can not copy File vis/lib/js/jquery.inputmask.bundle.min.js to /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/lib/js/jquery.inputmask.bundle.min.js: The "data" argument must be of type string or an instance of Buffer, TypedArray, or DataView. Received an instance of Object
        host.iobrokerS2 102072 objects saved
        Backup created: /opt/iobroker/backups/2023_04_07-11_18_10_backupiobroker.tar.gz
        This backup can only be restored with js-controller version up from 4.1
        ilovegym@iobrokerS2:/opt/iobroker$
        • simatec
          simatec Developer Most Active @Guest last edited by
          @ilovegym Mach da mal bitte ein Issue beim js-controller auf. Der Befehl "iob backup" wird direkt vom js-controller bearbeitet. Backitup bedient sich nur der Backup Funktionen des js-controllers
            A Former User @simatec last edited by
            @simatec
            Issue done
              apollon77 @Guest last edited by
              @ilovegym Und Danke, ist in der nächsten Alpha gefixt
                e-i-k-e @apollon77 last edited by
                @apollon77 sagte in Alpha Test js-controller 5.0:
                Ist die bereits verfügbar?
                • foxriver76
                  foxriver76 Developer @e-i-k-e last edited by
                  @e-i-k-e Nein
                  • BBTown
                    BBTown last edited by
                    Bei mir ging der Umstieg auf die v5 auch recht reibungslo über die Bühne.
                    Ich habe das bekannte Problem mit dem iQontrol-Adapter und ich musste einen Upload im VIS-Adapter manuell anwerfen, danach waren meine Visualisierungen auch wieder erreichbar
                      crunchip Forum Testing Most Active last edited by crunchip
                      hab soeben auch mal v5 aktiv, soweit läuft alles fürs erste, allerdings sind sehr viele meiner installierten Instanzen aktuell nicht aktiv/nicht in gebrauch.
                      admin.0 (945379) starting. Version 6.4.3 in /opt/iobroker/node_modules/iobroker.admin, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230406-4552d569
                      was nun zu Beginn auffiel und nur bedingt etwas mit dem controller zu tun hat, sind
                      • im mqtt Adapter war wie in der Instanz beschrieben, bis dato eingetragen
                        These states will be published. (Divided by comma, e.g. 'mqtt.0.,javascript.')
                        dies wurde nun aber angemeckert
                      2023-04-09 10:46:53.490 - warn: host.IoBroker-Server States 127.0.0.1:51508 Error from InMemDB: Error: The pattern "'mqtt.0.*" is not a valid ID pattern
                      at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2388:15)
                      at StatesInMemoryServer.handleSubscribe (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:324:59)
                      at StatesInMemoryServer._subscribeForClient (/opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:258:14)
                      at RedisHandler. (/opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:394:26)
                      at RedisHandler.emit (node:events:513:28)
                      at RedisHandler.emit (node:domain:489:12)
                      at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:209:37)
                      at processImmediate (node:internal/timers:476:21)
                      2023-04-09 10:46:53.607 - error: mqtt.0 (946388) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-04-09 10:46:53.611 - error: mqtt.0 (946388) unhandled promise rejection: Error The pattern "'mqtt.0.*" is not a valid ID pattern
                      2023-04-09 10:46:53.619 - error: mqtt.0 (946388) ReplyError: Error The pattern "'mqtt.0.*" is not a valid ID pattern
                      at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                      at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                      2023-04-09 10:46:53.620 - error: mqtt.0 (946388) Error The pattern "'mqtt.0.*" is not a valid ID pattern
                      2023-04-09 10:46:54.199 - warn: mqtt.0 (946388) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-04-09 10:46:55.271 - error: host.IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                      2023-04-09 10:46:55.272 - error: host.IoBroker Caught by controller[0]: ReplyError: Error The pattern "'mqtt.0.*" is not a valid ID pattern
                      2023-04-09 10:46:55.273 - error: host.IoBroker Caught by controller[0]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                      2023-04-09 10:46:55.274 - error: host.IoBroker Caught by controller[0]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                      2023-04-09 10:46:55.274 - error: host.IoBroker instance system.adapter.mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2023-04-09 10:46:55.275 - info: host.IoBroker Restart adapter system.adapter.mqtt.0 because enabled
                      2023-04-09 11:00:17.823 - error: mqtt.0 (955755) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-04-09 11:00:17.827 - error: mqtt.0 (955755) unhandled promise rejection: Error The pattern "javascript.*'" is not a valid ID pattern
                      2023-04-09 11:00:17.831 - error: mqtt.0 (955755) ReplyError: Error The pattern "javascript.*'" is not a valid ID pattern
                      2023-04-09 11:00:17.833 - error: mqtt.0 (955755) Error The pattern "javascript.*'" is not a valid ID pattern
                      2023-04-09 11:00:18.381 - warn: mqtt.0 (955755) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-04-09 11:00:19.111 - error: host.IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                      2023-04-09 11:00:19.112 - error: host.IoBroker Caught by controller[0]: ReplyError: Error The pattern "javascript.*'" is not a valid ID pattern
                      2023-04-09 11:00:19.112 - error: host.IoBroker Caught by controller[0]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
                      2023-04-09 11:00:19.113 - error: host.IoBroker Caught by controller[0]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
                      2023-04-09 11:00:19.113 - error: host.IoBroker instance system.adapter.mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2023-04-09 11:00:19.114 - info: host.IoBroker Restart adapter system.adapter.mqtt.0 because enabled
                      hab es nun auf mqtt.* geändert
                      • der Adapter Linux-control meckert nun über einen Service
                      2023-04-09 10:48:42.818 - warn: host.IoBroker-Server States 127.0.0.1:42674 Error from InMemDB: Error: The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-24e36031\x2d735b\x2d4199\x2da17d\x2d58b14117589e.start" is not a valid ID pattern
                      2023-04-09 10:48:42.825 - info: trashschedule.0 (947981) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230406-4552d569
                      2023-04-09 10:48:42.836 - error: linux-control.0 (947081) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-04-09 10:48:42.843 - error: linux-control.0 (947081) unhandled promise rejection: Error The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-0a2debdb\x2df60b\x2d494d\x2d8190\x2d5f1f98fbfef9.restart" is not a valid ID pattern
                      2023-04-09 10:48:42.855 - error: linux-control.0 (947081) ReplyError: Error The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-0a2debdb\x2df60b\x2d494d\x2d8190\x2d5f1f98fbfef9.restart" is not a valid ID pattern
                      2023-04-09 10:48:42.856 - error: linux-control.0 (947081) Error The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-0a2debdb\x2df60b\x2d494d\x2d8190\x2d5f1f98fbfef9.restart" is not a valid ID pattern
                      2023-04-09 10:48:42.915 - error: linux-control.0 (947081) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-04-09 10:48:42.917 - error: linux-control.0 (947081) unhandled promise rejection: Error The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-0a2debdb\x2df60b\x2d494d\x2d8190\x2d5f1f98fbfef9.start" is not a valid ID pattern
                      2023-04-09 10:48:42.922 - error: linux-control.0 (947081) ReplyError: Error The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-0a2debdb\x2df60b\x2d494d\x2d8190\x2d5f1f98fbfef9.start" is not a valid ID pattern
                      hab den vorübergehend nun mal deaktiviert in der Instanz
                      und was noch auftrat, direkt nach dem iob start mit v5 war nun bei mir ebenfalls die Log-Größe am rödeln, hat irgendwann aufgehört hochzuzählen und sich dann wieder normalisiert
                      Feuersturm foxriver76 2 Replies Last reply Reply Quote 0
                      • Feuersturm
                        Feuersturm @crunchip last edited by
                        @crunchip sagte in Alpha Test js-controller 5.0:
                        Das Problem mit der falsch angezeigten Log Größe wurde beim Admin gemeldet https://github.com/ioBroker/ioBroker.admin/issues/1913
                        crunchip 1 Reply Last reply Reply Quote 1
                        • foxriver76
                          foxriver76 Developer @crunchip last edited by
                          @crunchip Danke fürs Melden. Die Patterns haben beide jeweils ein ' in sich, das ist formal nicht erlaubt und scheint ein Bug im MQTT Adapter zu sein, bitte dort Issue machen.
                          • Feuersturm
                            Feuersturm @apollon77 last edited by
                            Alpha Update
                            Update auf meinem Master Slave System lief wieder ohne Probleme. Bisher keine Auffälligkeiten.
                              crunchip Forum Testing Most Active @Feuersturm last edited by
                              @feuersturm ich hatte das Problem vorher aber noch gar nicht, erst nach dem Controller upgrade trat es auf, aber ich häng es dort mal mit an
                              • foxriver76
                                foxriver76 Developer @crunchip last edited by foxriver76
                                @crunchip ja neuer Controller validiert die patterns
                                  Marty56 @foxriver76 last edited by
                                  Besteht mit der Version 5.0 eigentlich die Hoffnung, dass diese "Alias Error Bursts", die mich alle 2-3 Tage heimsuchen, aufhören.
                                  Das Error Log zeigt nur einen kleinen Ausschnitt. Es sind alle meine ca. 400 Aliases betroffen.
                                  Auswirkung auf die Funktion scheinen diese Fehlermeldung nicht zu haben. Sie nerven nur.
                                  2023-04-10 03:48:35.417 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.KEQ0971413.2.ENERGY_COUNTER, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","name":"K1_Waschen_Messen.ENERGY_COUNTER","role":"value.power.consumption"},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089040406,"_id":"hm-rpc.0.KEQ0971413.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                  2023-04-10 03:48:35.424 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.OEQ0125847.0.UNREACH, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator.unreach","name":"Deckenlampe im Wohnzimmer:0.UNREACH"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089035775,"_id":"hm-rpc.0.OEQ0125847.0.UNREACH","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                  2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.OEQ0125847.2.STATE, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":true,"write":true,"role":"switch","name":"WZ_Deckenlampe.STATE"},"native":{"CONTROL":"SWITCH.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089035853,"_id":"hm-rpc.0.OEQ0125847.2.STATE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                  2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.OEQ0125847.0.UNREACH, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator.unreach","name":"Deckenlampe im Wohnzimmer:0.UNREACH"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089035775,"_id":"hm-rpc.0.OEQ0125847.0.UNREACH","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                  2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.LEQ0413828.1.LEVEL, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":true,"min":0,"max":100,"unit":"%","role":"level.blind","workingID":"WORKING","name":"K3_Fensteroeffner.LEVEL"},"native":{"CONTROL":"BLIND.LEVEL","DEFAULT":0,"FLAGS":1,"ID":"LEVEL","MAX":1,"MIN":0,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"100%"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089036364,"_id":"hm-rpc.0.LEQ0413828.1.LEVEL","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                  2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.LEQ0413828.1.STOP, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":false,"write":true,"role":"button.stop","name":"K3_Fensteroeffner.STOP"},"native":{"CONTROL":"BLIND.STOP","DEFAULT":false,"FLAGS":1,"ID":"STOP","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":1,"TYPE":"ACTION","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089036367,"_id":"hm-rpc.0.LEQ0413828.1.STOP","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                    @marty56 reine Vermutung von mir, da ich dieses Problem auch hatte.
                                    Es wurden immer unterschiedliche alias angemeckert, nicht immer die selben,
                                    daher die Frage, wie hast du die alias angelegt, per alias manager oder mit dem device Adapter? Letzterer hat sowieso ein Problem in der Version 1.1.2
                                    https://github.com/ioBroker/ioBroker.devices/issues/217
                                    zu Beginn hatte ich auch alias mit dem device adapter angelegt, aber dann zum alias manager gewechselt und somit auch alle bestehenden alias, die mit dem device adapter erstellt wurden, gelöscht und neu mit dem alias manager erstellt.
                                    Seit dem ist Ruhe.
                                    Vllt hat es auch Einfluss, wenn alias mit unterschiedlichen Adapter Versionen angelegt wurden.
                                    Kann Zufall sein oder ein möglicher Ansatz.
                                      Marty56 @crunchip last edited by
                                      @crunchip Ich habe alle Aliases mit einem eigenenJavascript angelegt.
                                      • foxriver76
                                        foxriver76 Developer @Marty56 last edited by
                                        @marty56 Heißt das, du hast die 5.0 Alpha laufen und bekommst die Meldungen weiterhin?
                                        • wendy2702
                                          gerade den Master auf 5.0.1 angehoben:
                                          Web adapter crasht wegen Trashschedule fehler. Ich vermute das "ü" als Übeltäter wobei ich auch ein "ä" verwende was nicht angemeckert wird:
                                          2023-04-11 12:21:46.870  - error: web.0 (8220) uncaught exception: The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
                                          2023-04-11 12:21:46.873  - error: web.0 (8220) Error: The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
                                              at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2161:15)
                                              at pattern2RegEx (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:44)
                                              at SocketCommands.subscribe (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:267:13)
                                              at SocketCommands._subscribeStates (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:489:26)
                                              at commands.subscribe (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1356:25)
                                              at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1556:43)
                                              at Socket.emit (node:events:513:28)
                                              at /opt/iobroker/node_modules/socket.io/lib/socket.js:531:14
                                              at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
                                          2023-04-11 12:21:46.874  - error: web.0 (8220) The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
                                          Linux Control läuft nicht mehr zum steuern meiner Wandtablets
                                          mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker.current.log |grep linux
                                          2023-04-11 12:30:02.872  - info: host.iobroker instance system.adapter.linux-control.0 started with pid 8596
                                          2023-04-11 12:30:07.502  - warn: linux-control.0 (8596) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                          2023-04-11 12:30:07.503  - warn: linux-control.0 (8596) This object will not be created in future versions. Please report this to the developer.
                                          2023-04-11 12:30:07.544  - info: linux-control.0 (8596) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.linux-control, node: v18.14.2, js-controller: 5.0.1-alpha.0-20230406-4552d569
                                          2023-04-11 12:30:07.872  - warn: linux-control.0 (8596) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                                          2023-04-11 12:30:07.893  - warn: linux-control.0 (8596) This object will not be created in future versions. Please report this to the developer.
                                          2023-04-11 12:30:07.990  - info: linux-control.0 (8596) getting data from VIS-OG (192.168.178.215:22, Adapter start)
                                          2023-04-11 12:30:08.000  - info: linux-control.0 (8596) getting data from VIS-EG (192.168.178.216:22, Adapter start)
                                          2023-04-11 12:30:24.355  - warn: host.iobroker-Server States 127.0.0.1:33208 Error from InMemDB: Error: The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
                                          2023-04-11 12:30:24.359  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2023-04-11 12:30:24.360  - error: linux-control.0 (8596) unhandled promise rejection: Error The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
                                          2023-04-11 12:30:24.361  - error: linux-control.0 (8596) ReplyError: Error The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
                                          2023-04-11 12:30:24.361  - error: linux-control.0 (8596) Error The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
                                          2023-04-11 12:30:24.380  - info: linux-control.0 (8596) cleaned everything up...
                                          2023-04-11 12:30:24.381  - info: linux-control.0 (8596) terminating
                                          2023-04-11 12:30:24.381  - warn: linux-control.0 (8596) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          2023-04-11 12:30:24.385  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2023-04-11 12:30:24.386  - error: linux-control.0 (8596) unhandled promise rejection: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                                          2023-04-11 12:30:24.387  - error: linux-control.0 (8596) Error: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                                          2023-04-11 12:30:24.387  - error: linux-control.0 (8596) The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                                          2023-04-11 12:30:24.401  - warn: host.iobroker-Server States 127.0.0.1:33208 Error from InMemDB: Error: The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                                          2023-04-11 12:30:24.404  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2023-04-11 12:30:24.404  - error: linux-control.0 (8596) unhandled promise rejection: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                                          2023-04-11 12:30:24.405  - error: linux-control.0 (8596) ReplyError: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                                          2023-04-11 12:30:24.405  - error: linux-control.0 (8596) Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                                          2023-04-11 12:30:24.736  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2023-04-11 12:30:24.737  - error: linux-control.0 (8596) unhandled promise rejection: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                                          2023-04-11 12:30:24.737  - error: linux-control.0 (8596) Error: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                                          2023-04-11 12:30:24.737  - error: linux-control.0 (8596) The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                                          2023-04-11 12:30:24.783  - warn: host.iobroker-Server States 127.0.0.1:33208 Error from InMemDB: Error: The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                                          2023-04-11 12:30:24.792  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2023-04-11 12:30:24.792  - error: linux-control.0 (8596) unhandled promise rejection: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                                          2023-04-11 12:30:24.793  - error: linux-control.0 (8596) ReplyError: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                                          2023-04-11 12:30:24.793  - error: linux-control.0 (8596) Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                                          2023-04-11 12:30:24.888  - info: linux-control.0 (8596) terminating
                                          2023-04-11 12:30:24.900  - warn: linux-control.0 (8596) get state error: Connection is closed.
                                          2023-04-11 12:30:24.907  - error: linux-control.0 (8596) [servicesInfo] VIS-OG (192.168.178.215:22): error: DB closed, stack: Error: DB closed
                                          2023-04-11 12:30:25.038  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): datapoint-id: VIS_OG_ScreenOff, description: ViS-OG_ScreenOff
                                          2023-04-11 12:30:25.039  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): error: DB closed, stack: Error: DB closed
                                          2023-04-11 12:30:25.041  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): datapoint-id: VIS_OG_ScreenOn, description: VIS-OG_ScreenOn
                                          2023-04-11 12:30:25.042  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): error: DB closed, stack: Error: DB closed
                                          2023-04-11 12:30:25.494  - error: host.iobroker instance system.adapter.linux-control.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          2023-04-11 12:30:25.502  - info: host.iobroker Restart adapter system.adapter.linux-control.0 because enabled
                                          Nehme an es liegt an dem "dicken" Punkt im Namen und ist ein Adapter issue, oder?
                                          Enigma 2 Adapter läuft nicht mehr:
                                          mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker.current.log |grep enigma
                                          2023-04-11 12:36:12.099  - info: host.iobroker instance system.adapter.enigma2.0 started with pid 8762
                                          2023-04-11 12:36:12.802  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
                                          2023-04-11 12:36:12.802  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
                                          2023-04-11 12:36:12.802  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
                                          2023-04-11 12:36:12.805  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
                                          2023-04-11 12:36:12.805  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
                                          2023-04-11 12:36:12.805  - error: host.iobroker instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          2023-04-11 12:36:12.812  - info: host.iobroker Rebuild for adapter system.adapter.enigma2.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                          2023-04-11 12:36:28.124  - info: host.iobroker "system.adapter.enigma2.0" disabled
                                          2023-04-11 12:36:34.443  - info: host.iobroker "system.adapter.enigma2.0" enabled
                                          2023-04-11 12:36:34.613  - info: host.iobroker instance system.adapter.enigma2.0 started with pid 8775
                                          2023-04-11 12:36:36.424  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
                                          2023-04-11 12:36:36.425  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
                                          2023-04-11 12:36:36.425  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
                                          2023-04-11 12:36:36.426  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
                                          2023-04-11 12:36:36.426  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
                                          2023-04-11 12:36:36.426  - error: host.iobroker instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          2023-04-11 12:36:36.426  - info: host.iobroker Rebuild for adapter system.adapter.enigma2.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                          EDIT: Ergänzung zum Enigma2 Adapter:
                                          2023-04-11 12:48:29.329  - info: trashschedule.0 (10113) [ical] configurured ical preview is 34 days - increase this value to find more events in the future
                                          2023-04-11 12:48:46.571  - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
                                          2023-04-11 12:48:46.776  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
                                          2023-04-11 12:48:47.781  - info: host.iobroker iobroker npm-rebuild: exit 0
                                          2023-04-11 12:48:47.972  - info: host.iobroker instance system.adapter.enigma2.0 started with pid 10173
                                          2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1078
                                          2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]:   throw err;
                                          2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]:   ^
                                          2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                                          2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]: Require stack:
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:920:27)
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1141:19)
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1254:14)
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1117:32)
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:958:12)
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1141:19) {
                                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:   requireStack: [
                                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
                                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
                                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:   ]
                                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]: }
                                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]: Node.js v18.14.2
                                          2023-04-11 12:48:49.186  - error: host.iobroker instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          2023-04-11 12:48:49.186  - info: host.iobroker Adapter system.adapter.enigma2.0 needs rebuild and will be restarted afterwards.
                                          2023-04-11 12:48:49.186  - info: host.iobroker system.adapter.enigma2.0 will be rebuilt
                                          2023-04-11 12:48:49.186  - warn: host.iobroker adapter "enigma2" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                          2023-04-11 12:48:49.187  - info: host.iobroker iobroker rebuild
                                          2023-04-11 12:48:52.129  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                                          • foxriver76
                                            foxriver76 Developer @wendy2702 last edited by
                                            @wendy2702 Legt Trashschedule wirklich States mit Umlauten an? Sollte eigentlich nicht möglich sein und entsprechend sollte der Adapter auch den subscribe entsprechend anpassen.
                                            Die anderen beiden sind sicher Adapter Issues.
                                            140
                                            20676
