    3. Einsteigerfragen
    4. Backup Zugriffsproblem influxDB2.5
    • keksn
      keksn @simatec last edited by
      @simatec
      zum verzweifeln...
      keksn@iobroker:~$ influx auth list -t LpT1OUMTk3MNKV9fCwE7gfFHzu5CPr6dQI2VtdJ-31aFgFszpYIiZwaTfioaZMbj5ddxFTZT3HKACx23QpMgVg== --json
                      "id": "0b055ae197aec000",
                      "description": "iobroker_user_token",
                      "token": "LpT1OUMTk3MNKV9fCwE7gfFHzu5CPr6dQI2VtdJ-31aFgFszpYIiZwaTfioaZMbj5ddxFTZT3HKACx23QpMgVg==",
                      "status": "active",
                      "userName": "admin",
                      "userID": "0b03f56869ede000",
                      "permissions": [
                              "read:orgs/0f2be3356ee1ee0a/annotations",
                              "write:orgs/0f2be3356ee1ee0a/annotations",
                              "read:orgs/0f2be3356ee1ee0a/authorizations",
                              "write:orgs/0f2be3356ee1ee0a/authorizations",
                              "read:orgs/0f2be3356ee1ee0a/buckets",
                              "write:orgs/0f2be3356ee1ee0a/buckets",
                              "read:orgs/0f2be3356ee1ee0a/checks",
                              "write:orgs/0f2be3356ee1ee0a/checks",
                              "read:orgs/0f2be3356ee1ee0a/dashboards",
                              "write:orgs/0f2be3356ee1ee0a/dashboards",
                              "read:orgs/0f2be3356ee1ee0a/dbrp",
                              "write:orgs/0f2be3356ee1ee0a/dbrp",
                              "read:orgs/0f2be3356ee1ee0a/documents",
                              "write:orgs/0f2be3356ee1ee0a/documents",
                              "read:orgs/0f2be3356ee1ee0a/labels",
                              "write:orgs/0f2be3356ee1ee0a/labels",
                              "read:orgs/0f2be3356ee1ee0a/notebooks",
                              "write:orgs/0f2be3356ee1ee0a/notebooks",
                              "read:orgs/0f2be3356ee1ee0a/notificationEndpoints",
                              "write:orgs/0f2be3356ee1ee0a/notificationEndpoints",
                              "read:orgs/0f2be3356ee1ee0a/notificationRules",
                              "write:orgs/0f2be3356ee1ee0a/notificationRules",
                              "read:/orgs/0f2be3356ee1ee0a",
                              "read:orgs/0f2be3356ee1ee0a/remotes",
                              "write:orgs/0f2be3356ee1ee0a/remotes",
                              "read:orgs/0f2be3356ee1ee0a/replications",
                              "write:orgs/0f2be3356ee1ee0a/replications",
                              "read:orgs/0f2be3356ee1ee0a/scrapers",
                              "write:orgs/0f2be3356ee1ee0a/scrapers",
                              "read:orgs/0f2be3356ee1ee0a/secrets",
                              "write:orgs/0f2be3356ee1ee0a/secrets",
                              "read:orgs/0f2be3356ee1ee0a/sources",
                              "write:orgs/0f2be3356ee1ee0a/sources",
                              "read:orgs/0f2be3356ee1ee0a/tasks",
                              "write:orgs/0f2be3356ee1ee0a/tasks",
                              "read:orgs/0f2be3356ee1ee0a/telegrafs",
                              "write:orgs/0f2be3356ee1ee0a/telegrafs",
                              "read:/users/0b03f56869ede000",
                              "write:/users/0b03f56869ede000",
                              "read:orgs/0f2be3356ee1ee0a/variables",
                              "write:orgs/0f2be3356ee1ee0a/variables",
                              "read:orgs/0f2be3356ee1ee0a/views",
                              "write:orgs/0f2be3356ee1ee0a/views"
              }t
      keksn@iobroker:~$ influx backup --bucket iobroker --host http://192.168.1.166:8086 -t LpT1OUMTk3MNKV9fCwE7gfFHzu5CPr6dQI2VtdJ-31aFgFszpYIiZwaTfioaZMbj5ddxFTZT3HKACx23QpMgVg== "/tmp/influx-test"
      2023/04/09 12:03:23 INFO: Downloading metadata snapshot
      Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
      • keksn
        • Marc Berg
          Marc Berg Most Active @keksn last edited by Marc Berg
          @keksn sagte in Backup Zugriffsproblem influxDB2.5:
          influx auth list
                          "status": "active",
                          "permissions": [
          Das ist kein Operator Token! Den erkennst Du daran, dass in den Permissions kein "orgs" drin steht. Ein Operator Token hat Rechte auf ALLE Organisationen.
          So in etwa:
          "permissions": [
                                  "read:/annotations",
                                  "write:/annotations",
                                  "read:/authorizations",
                                  "write:/authorizations",
                                  "read:/buckets",
                                  "write:/buckets",
                                  "read:/checks",
                                  "write:/checks",
                                  "read:/dashboards",
                                  "write:/dashboards",
                                  "read:/dbrp",
                                  "write:/dbrp",
          keksn 1 Reply Last reply Reply Quote 0
          • Glasfaser
            Glasfaser @simatec last edited by Glasfaser
            @keksn
            @simatec sagte in Backup Zugriffsproblem influxDB2.5:
            @keksn Gehe die Anleitung nochmal Schritt für Schritt durch und erstelle einen neuen Operator Token
            Das ist nur ein User .. in deinem Log
            Hast du das gemacht ... :
            https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup#token-für-influxdb-2x-backup-richtig-erstellen
            schau auch hier mit mal nach :
            cat /etc/influxdb2/influx-configs
            keksn 2 Replies Last reply Reply Quote 0
            • keksn
              keksn @Marc Berg last edited by
              @marc-berg sagte in Backup Zugriffsproblem influxDB2.5:
              f2be3356ee1ee0a/
              danke, dann kann ich aber anscheinend keinen Operator token erstellen. Funkt nicht
              • keksn
                keksn @Glasfaser last edited by
                @glasfaser
                die Anleitung habe ich nun schon einige Male durch.
                config Datei fine ich aber nicht
                keksn@iobroker:~$ cd /etc/influxdb2/influx-configs
                -bash: cd: /etc/influxdb2/influx-configs: No such file or directory
                • keksn
                  @glasfaser
                  dürfte mir da irgendetwas zerschossen haben, da das Backup ja schon problemlos gelaufen ist
                  • Glasfaser
                    Glasfaser @keksn last edited by
                    Funkt nicht
                    und was heißt das für uns ...
                    kannst du das mal alles zeigen !?
                    • keksn
                      @glasfaser was meinst Du mit alles?
                      • Glasfaser
                        Glasfaser @keksn last edited by Glasfaser
                        Error: Command failed: "/usr/bin/influx"
                        hast du Influx wo anders installiert !?
                        • Glasfaser
                          @Marc-Berg und ich haben dir etwas gezeigt .
                          halt die Ausgaben vom änderen usw. Operator anlegen usw.
                          • keksn
                            @glasfaser sagte in Backup Zugriffsproblem influxDB2.5:
                            led: "/usr/bin/infl
                            ich denke ich bin dal überfordert.
                            keksn@iobroker:~$ influx backup --bucket iobroker --host http://192.168.1.166:8086 -t l8itvH_Wzt2HUDUM_1w5Q3oKINRcSO0PGi1msZjhz-1TvZB6puxTftQ8n2EyL1x35SMqKYhbhJ5v7IdNfasvBQ== "/tmp/influx-test"
                            2023/04/09 14:31:35 INFO: Downloading metadata snapshot
                            keksn@iobroker:~$
                            Ich habe Influx nicht bewusst wo anders installiert. habe es laut einer Anleitung ein ubgrade von influx auf influxdb2 gemacht.
                            Wie schon erwähnt ist alles schon problemlos gelaufen.
                            • keksn
                              @glasfaser
                              eksn@iobroker:~$ influx auth list -t l8itvH_Wzt2HUDUM_1w5Q3oKINRcSO0PGi1msZjhz-1TvZB6puxTftQ8n2EyL1x35SMqKYhbhJ5v7IdNfasvBQ== --json
                                              "id": "0b057da10eeec000",
                                              "description": "Superneuertoken",
                                              "token": "l8itvH_Wzt2HUDUM_1w5Q3oKINRcSO0PGi1msZjhz-1TvZB6puxTftQ8n2EyL1x35SMqKYhbhJ5v7IdNfasvBQ==",
                                              "status": "active",
                                              "permissions": [
                              keksn@iobroker:~$
                              • Glasfaser
                                ... also auf dem gleichen System mit ioBroker , deshalb frage ich mich , warum du die IP mit angibst !?
                                so wäre das ein entfernte Installation auf einem anderen System , oder Docker oder ...
                                • Glasfaser
                                  @keksn
                                  Teste mal so :
                                  https://forum.iobroker.net/post/925640
                                  • keksn
                                    @glasfaser
                                    aso, ich habe es unter Proxmox im selben CT wie der Iobroker laufen
                                    • keksn
                                      @glasfaser
                                      meinst Du das manuelle Backup?
                                      keksn@iobroker:~$ mkdir -p /opt/iobroker/backups/influxdb-tmp
                                      influx backup --bucket iobroker -t l8itvH_Wzt2HUDUM_1w5Q3oKINRcSO0PGi1msZjhz-1TvZB6puxTftQ8n2EyL1x35SMqKYhbhJ5v7IdNfasvBQ== /opt/iobroker/backups/influxdb-tmp
                                      2023/04/09 14:48:45 INFO: Downloading metadata snapshotkups/influxdb-tmpZjhz-1TvZB6puxT
                                      keksn@iobroker:~$
                                      • Glasfaser
                                        @keksn
                                        was sagt :
                                        influx auth list --user admin
                                        • keksn
                                          keksn@iobroker:~$ influx auth list --user admin
                                          Error: could not find authorization with given parameters: 401 Unauthorized: unauthorized access
                                          keksn@iobroker:~$
                                          • Glasfaser
                                            @keksn
                                            und nur :
                                            influx auth list
                                            55
                                            2886
