    • Armilar
      Armilar Most Active Forum Testing @draexler last edited by
      @draexler
      Ja, sollte funktionieren - sieht nach einen MQTT-Thema aus...
      sende mal deine Einstellungen zu den:
      • Verbindungsparametern in der Script Config.
      • MQTT-Instanz
      • Einen Blick auf den CustomSend in den MQTT-Objekten
      draexler 1 Reply Last reply Reply Quote 0
      • draexler
        draexler @Armilar last edited by
        @armilar
        export const config = <Config> {
            panelRecvTopic: 'mqtt.0.tasmota.NSPanel_Buero.tele.RESULT',       // Bitte anpassen
            panelSendTopic: 'mqtt.0.tasmota.NSPanel_Buero.cmnd.CustomSend',   // Bitte anpassen
        Bildschirmfoto 2023-04-08 um 18.13.36.pngBildschirmfoto 2023-04-08 um 18.14.16.png
          "common": {
            "name": "CustomSend",
            "desc": "Manuell erzeugt",
            "role": "state",
            "type": "string",
            "read": true,
            "write": true,
            "def": ""
          "type": "state",
          "native": {},
          "user": "system.user.admin",
          "ts": 1680882985700,
          "_id": "mqtt.0.tasmota.NSPanel_Buero.cmnd.CustomSend",
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.admin",
        Beim Starten des Skripts:
        javascript.0
        2023-04-08 18:14:43.893	info	script.js.common.NSPanels.NSPanel_Buero: Installed TFT Firmware: 50 / v4.0.5
        javascript.0
        2023-04-08 18:14:43.893	info	script.js.common.NSPanels.NSPanel_Buero: Desired TFT Firmware: 50 / v4.0.5
        javascript.0
        2023-04-08 18:14:43.567	info	script.js.common.NSPanels.NSPanel_Buero: registered 28 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
        javascript.0
        2023-04-08 18:14:43.525	info	script.js.common.NSPanels.NSPanel_Buero: weather alias for accuweather.0. already exists
        javascript.0
        2023-04-08 18:14:43.503	info	script.js.common.NSPanels.NSPanel_Buero: setObjects enabled - create Alias Channels possible
        javascript.0
        2023-04-08 18:14:43.407	info	script.js.common.NSPanels.NSPanel_Buero: source code did not change, using cached compilation result...
        javascript.0
        2023-04-08 18:14:42.967	info	script.js.common.NSPanels.NSPanel_Buero: compiling TypeScript source...
        javascript.0
        2023-04-08 18:14:41.343	info	Stop script script.js.common.NSPanels.NSPanel_Buero
        • Armilar
          @draexler
          Das Script arbeitet. Nimm mal den haken in der MQTT-Instanz raus:
          Ggfs. danach noch mal den MQTT durchstarten
          draexler 1 Reply Last reply Reply Quote 1
          • draexler
            @armilar Tja, was soll man sagen... Das wars. Bist einfach super 🙂 Genau deswegen gefällt mir der ioBroker so gut. Wegen der SUPER Community.
            Nochmal DANKE 🙂
            • draexler
              draexler @draexler last edited by
              Aber für Dummies. Wie sendet denn der MQTT dann jetzt?
              Die Einstellung war -> Nur bei Änderungen publizieren, was ja bedeutet nur wenn sich der Datenpunkt ändert... und jetzt? Jede Sekunde, alle 10 Minuten?!?
              Armilar J 2 Replies Last reply Reply Quote 0
              • Armilar
                @draexler
                Habe den Sinn hinter der Programmierung dieses Hakens nie verstanden 😉
                Nur das er irgendwie nicht das tut was er beschreibt 😕
                  TT-Tom @australien last edited by TT-Tom
                  @australien
                  so es gibt die erste Version von der Einbindung des Adapter Fahrplan.
                  benötigt wird dieses externe Script, welches die Daten aus dem Ordner "DepatureTimetableX.JSON" ausliest und für das Panel aufbereitet. Das Script liest maximal 6 Abfahrten pro Abfahrtstafel aus. Das Icon und die Farbe wird aus den Daten ermittelt. Grün alles okay / Rot Verspätung. Zur Zeit wird die Anzeige noch über die CradEntities realisiert und dadurch nur die ersten 4 Abfahrten dargestellt.
                  Die PageConfig für die erste Abfahrttafel sieht wie folgt aus:
                  let FahrplanEntities0 = <PageEntities>
                          'type': 'cardEntities',
                          'heading': 'Eisenstadt ',
                          'useColor': true,
                          'items': [
                              <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt0', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt0.Richtung').val"},
                              <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt1', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt1.Richtung').val"},
                              <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt2', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt2.Richtung').val"},
                              <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt3', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt3.Richtung').val"},
                              <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt4', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt4.Richtung').val"},
                              <PageItem>{ id: AliasUserPath + 'FahrplanAnzeiger.Haltestelle0.Abfahrt5', name: "getState('alias.0.FahrplanAnzeiger.Haltestelle0.Abfahrt5.Richtung').val"}
                  Das Script kann mehrere Abfahrtstafeln überwachen, einzustellen im Script unter
                  const AnzahlHaltestellen: number = 3;               // Anzahl der Haltestellen / Anzeigetafeln
                  einzige Bedingung -> sie müssen am Anfang in der Adapterconfig stehen und fortlaufend sein.
                  weitere Einstellungen sind
                  const DP_NSPanel: string = '0_userdata.0.NSPanel.1.';        // Standard 0_userdata.0.NSPanel.1.
                  const DP_userdata: string = '0_userdata.0.';        // Pafad unter 0_userdata.0    Automatisch wird "FahrplanAnzeiger.HaltestelleX.AbfahrtX" durch das Script erzeugt
                  const DP_AliasNSPanel: string = 'alias.0.';         // Pfad unter alias.0    Automatisch wird "FahrplanAnzeiger.HaltestelleX.AbfahrtX" durch das Script erzeugt
                  const VerspätungPopup: boolean = true;              // Bei Verspätung soll PopupNotifypage auf dem Panel angezeigt werden
                  Das Script kann auf Wunsch auch eine PopupNotifyPage bei einer Verspätung erzeugen.
                  Das ist lauffähig ab NSPanel Script Version 4.0.5.5 kommt die Tage
                  weitere Erläuterungen folgen im Wiki unter FAQ & Anleitungen
                  A 1 Reply Last reply Reply Quote 2
                  • eierfeile
                    eierfeile last edited by eierfeile
                    Hi, bin neu im NSPanel Thema. Hab Tasmota und Lovelace installiert. Es soll mein bestehendes Wandthermostat ersetzen. Würde daher auch das Relais1 vom NSPanel zum automatischen ein- und ausschalten der Heizung nutzen. Dachte das müsste einfach gehen. Ist aber bis jetzt nicht wirklich trivial ;-). Aber wird schon!
                    Also Alias für Thermostat hab ich erstellt.
                    Code sieht aktuell so aus:
                    let Kueche_Themostat = <PageThermo>
                        'type': 'cardThermo',
                        'heading': 'Thermostat Kueche',
                        'useColor': true,
                        'subPage': false,
                        'parent': undefined,
                        'items': [<PageItem>{
                                    minValue: 50,
                                    maxValue: 300,
                                    stepValue: 5,
                                  //  setThermoDestTemp2: 'ACTUAL1'
                    Aber ich sehe nicht mal die Karte im Panel? Was mach ich denn falsch?
                    • Armilar
                      Armilar Most Active Forum Testing @eierfeile last edited by Armilar
                      @eierfeile sagte in SONOFF NSPanel mit Lovelace UI:
                      Kueche_Themostat
                      Gibt es denn Kueche_Themostat als Page in der Config-Auflistung?
                      eierfeile 1 Reply Last reply Reply Quote 0
                      • eierfeile
                        eierfeile @Armilar last edited by
                        @armilar jap ist drin...hab erst mal alles nur auskommentiert was ich nicht brauche. Wird später gelöscht. b0009a68-f57f-4e9d-a78e-0c00e5d0cf56-image.png
                        • Armilar
                          @eierfeile
                          Sieht aber soweit erstmal okay aus...
                          Der Setpoint ist erreichbar und enthält einen numerischen Wert?
                          Gibt es Warnungen oder Fehler im Log?
                          eierfeile 1 Reply Last reply Reply Quote 1
                          • eierfeile
                            @armilar paar Warnungen hab ich noch drin. Die kann ich aber nicht deuten.
                            Mit Setpoint meinst du vermutlich das hier:
                            Der ist "0". Den Wert wollte ich künftig über das cardThermo pflegen....falls das geht?
                            • Armilar
                              @eierfeile
                              Da ist in den Chart-Pages ein Fehler
                              Kommentier mal alle Seiten bis auf die cardThermo aus
                              Ja der Setpoint wird auch über die cardThermo gesteuert...
                                joBr99 @draexler last edited by
                                @draexler
                                Nein, ohne "Nur Änderungen publizieren" sendet er die MQTT Nachrichten so wie sie tatsächlich kommen, also bei jedem Event.
                                Stell dir nen Button vor, immer wenn er gedrückt wird kommt nen Event, die Nachricht ist aber immer die gleiche. Bei nem Schalter würdest du auch bei jedem Schalten eine Event haben, aber die Nachricht ändert sich von an auf aus.
                                  Bhenyamin last edited by Bhenyamin
                                  Tach zusammen,
                                  nachdem ich mein Panel jetzt vor gut einer Woche mal in den Feldversuch (in die Wand) genommen habe zeigen sich die ersten kleinen Schwächen - auch wenn ich insg. sehr zufrieden bin.
                                  Ich habe aktuell nur 2 Hauptseiten + die NSPanel_Einstellungen Seite - alles weitere als Subpages darunter geordnet.
                                  pages: [
                                              FavKitchen
                                              KitchenTopMenu
                                              NSPanel_Service                            	//Auto-Alias Service Page
                                      subPages: [
                                                  NSPanel_Infos,                          //Auto-Alias Service Page
                                                      NSPanel_Wifi_Info_1,                //Auto-Alias Service Page
                                                      NSPanel_Wifi_Info_2,                //Auto-Alias Service Page
                                                      NSPanel_Sensoren,                   //Auto-Alias Service Page
                                                      NSPanel_Hardware,                   //Auto-Alias Service Page
                                                  NSPanel_Einstellungen,                  //Auto-Alias Service Page
                                                      NSPanel_Screensaver,                //Auto-Alias Service Page
                                                          NSPanel_ScreensaverDimmode,     //Auto-Alias Service Page
                                                          NSPanel_ScreensaverBrightness,  //Auto-Alias Service Page
                                                          NSPanel_ScreensaverLayout,      //Auto-Alias Service Page
                                                          NSPanel_ScreensaverWeather,     //Auto-Alias Service Page
                                                          NSPanel_ScreensaverDateformat,  //Auto-Alias Service Page
                                                          NSPanel_ScreensaverIndicators,  //Auto-Alias Service Page
                                                      NSPanel_Relays,                     //Auto-Alias Service Page
                                                  NSPanel_Firmware,                       //Auto-Alias Service Page
                                                      NSPanel_FirmwareTasmota,            //Auto-Alias Service Page
                                                      NSPanel_FirmwareBerry,              //Auto-Alias Service Page
                                                      NSPanel_FirmwareNextion,            //Auto-Alias Service Page
                                                  FavLichtWzEzK                           //Favoitenmenü Lichtszenen Wohnbereich
                                                      FavLichtWzEzKSingle,                    //NUR aus Favoritenmenü heraus: Einzelsteuerung Licht Wohnbereich
                                                  FavKinder
                                              Haus                                        //Top-Menü Haus Strg.
                                                  OG,                                     //Obergeschoss Mainpage
                                                      Bad,                                //Bad
                                                          BadRadiator,                    //Heizkörper Bad
                                                          BadFBH,                         // Fußbodenheizung Bad
                                                      Schlafzimmer,                       //Schlafzimmer
        EG,                                     //Erdgeschoss Mainpage
                                                      Wohnbereich,                        //Wohnbereich Wohnzimmer / Esszimmer / Küche Sublevel 1
                                                          LichtWzEzK,                     //Einzelsteuerung Licht Wohnzimmer / Esszimmer / Küche
                                                          RollosWzEzK,                    //Rollosteuerung WZ
                                                      Hausflur,                           //Gesamter Hausflur
                                                      Büro,                               //Büro
                                                      Gästebad,                           //Gäste Bad (WC) Erdgeschoss
                                                  Garage,                                 //Garage
                                                  Aussen,                                 //Außenbereich
                                                  Photovoltaik,                           //Übersicht PV
                                                  Abfall                                  //Abfallkalender
                                  Wenn ich nun per Doppeltippen aus dem Screensaver raus komme, lande ich auf der Favoritenseite "FavKitchen".
                                  Pfeil rechts bringt mich auch (meist) zur 2. Hauptseite "KitchenTopMenu" von wo aus ich alles weitere verzweige.
                                  Leider nur meistens: Oft springt er beim 2. Druck auf den Rechtspfeil auch direkt auf die NSPanel Einstellungen, sodass ich dann noch 2 x nach rechts drücken muss um auf die gewünscht KitchenTopMenu Seite zu kommen. Ich komme nur nicht dahinter, woran es liegen kann. Auch habe ich immer mal Hänger, bei denen ich bis zum nächsten Screensaver einfach einen Blankscreen bekomme.
                                  Noch habe ich meine bessere Hälfte nicht umfassend in die Bedienung eingeführt - dafür muss es erst reibungslos laufen um die Akzeptanz nicht unnötig zu kompromittieren 😬
                                  Vielleicht habt ihr 'ne Idee?
                                    TT-Tom @Bhenyamin last edited by
                                    @bhenyamin
                                    mir ist auf gefallen, das bei deinen Hauptseiten das Komma fehlt. zeige mal bitte auch die Config der beiden Seiten.
                                    Armilar B 2 Replies Last reply Reply Quote 0
                                    • Armilar
                                      Armilar Most Active Forum Testing @TT-Tom last edited by Armilar
                                      @tt-tom
                                      @Bhenyamin
                                      Bei den Subpages fehlen zum Teil auch die Kommas, z.B. bei:
                                      • FavLichtWzEzK
                                      • FavKinder
                                      • Haus
                                      Der Blankscreen ist oft eine schlechte WLAN-Verbindung. Alternativ, wenn zu viele Seiten auf einmal aufgerufen werden.
                                        mading last edited by mading
                                        Moin zusammen,
                                        ich habe erfolgreich das Skript auf 4.0.5.2 gehoben. Das Panel zeigt auch alles im Advanced Screensaver an. Echt tolle Arbeit, Armilar! Habe dir einen Obulus per Paypal geschickt.
                                        Zwei Fragen: Gerne würde ich für die aktuelle Temperatur meinen Datenpunkt nehmen, statt dem von daswetter. Kann ich das anpassen?
                                        Ich passe für mich den DP 0_userdata.0.NSPanel.1.ScreensaverInfo.activeDimmodeBrightness an, so dass im Screensaver das Display nicht zu dunkel ist. Sobald ich das ts Skript anpasse, zieht er den Parameter aber nicht mehr und das Display ist viel dunkler. Erst wenn ich den Wert im DP wieder anpasse, ist das Display wieder im Screensaver heller. Ist das schon einmal aufgefallen?
                                        Eine weitere Frage habe ich: bei Waschmaschine und Trockner funktioniert es, dass wenn sie aus sind, die "Off-Icons" angezeigt werden. Beim Plug Stat (mqtt.0.openWB.lp.1.boolPlugStat) nicht. Kann es daran liegen, dass es kein true/ false ist sondern 0/1? Der Datenpunkt ist definitiv 0, zeigt aber das Icon power-plug-outline an.
                                        indicatorScreensaverEntity:
                                                    //icons mitte unter Uhr
                                                    // indicatorScreensaverEntity 1 (only Advanced Screensaver)
                                                        ScreensaverEntity: 'viessmannapi.0.64851.0.features.heating.compressors.0.properties.active.value',
                                                        ScreensaverEntityFactor: 1,
                                                        ScreensaverEntityDecimalPlaces: 0,
                                                        ScreensaverEntityIconOn: 'heat-pump-outline',
                                                        ScreensaverEntityIconOff: 'heat-pump',
                                                        ScreensaverEntityText: 'Heizung',
                                                        ScreensaverEntityUnitText: null,
                                                        ScreensaverEntityIconColor: { 'val_min': 0, 'val_max': 1 }
                                                    // indicatorScreensaverEntity 2 (only Advanced Screensaver)
                                                        ScreensaverEntity: 'hm-rpc.0.000F1D898C4EA9.1.MOTION',
                                                        ScreensaverEntityIconOn: 'garage-open',
                                                        ScreensaverEntityIconOff: 'garage-variant',
                                                        ScreensaverEntityText: 'Garage',
                                                        ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 1}
                                                    // indicatorScreensaverEntity 3 (only Advanced Screensaver)
                                                        ScreensaverEntity: 'mqtt.0.openWB.lp.1.boolPlugStat',
                                                        ScreensaverEntityIconOn: 'power-plug-outline',
                                                        ScreensaverEntityIconOff: 'power-plug-off-outline',
                                                        ScreensaverEntityText: 'verbunden',
                                                        //ScreensaverEntityIconColor: { 'val_min': 0, 'val_max': 1 }
                                                    // indicatorScreensaverEntity 4 (only Advanced Screensaver)
                                                        ScreensaverEntity: '0_userdata.0.EigeneDatenpunkte.Tasmota.WaschmaschineLaeuft',
                                                        ScreensaverEntityIconOn: 'washing-machine',
                                                        ScreensaverEntityIconOff: 'washing-machine-off',
                                                        ScreensaverEntityText: 'Wama',
                                                        ScreensaverEntityIconColor: { 'val_min': 1, 'val_max': 0 }
                                                    // indicatorScreensaverEntity 5 (only Advanced Screensaver)
                                                        ScreensaverEntity: '0_userdata.0.EigeneDatenpunkte.Tasmota.TrocknerLaeuft',
                                                        ScreensaverEntityIconOn: 'tumble-dryer',
                                                        ScreensaverEntityIconOff: 'tumble-dryer-off',
                                                        ScreensaverEntityText: 'Trockner',
                                                        ScreensaverEntityUnitText: '%',
                                          australien @TT-Tom last edited by australien
                                          @tt-tom
                                          Super! Danke, schaut sehr gut aus.
                                          Leider wird bei mir nichts angezeigt, ausser Warnungen beim Compilieren.
                                          Das Display am NSPanel beleibt leer, obwohl die aliase mit dem Script befühlt werden.
                                          Egal ob ich es mit der Version aus den FAQ oder denen hier versuche.
                                          Nachsatz, bei einer Verspätung kommt die Subpage.
                                          • Armilar
                                            Armilar Most Active Forum Testing @mading last edited by Armilar
                                            @mading
                                            Jederzeit. Einfach den Datenpunkt mit der Temperatur austauschen
                                            Ich denke du meinst den Neustart des Scriptes. Der Datenpunkt 0_userdata.0.NSPanel.1.ScreensaverInfo.activeDimmodeBrightness wird aktuell im Zuge eines Scriptstarts nicht berücksichtigt, sondern nur wenn der Trigger Änderungen erfasst --> Wird kurzfristig in die nächste Version kommen...
                                            Muss ein Boolean, d.h. true/false sein.
                                            Zwei Möglichkeiten:
                                            • du machst aus dem mqtt.0 Datenpunkt ein einen boolschen DP oder
                                            • du legst einen Alias an und konvertierst die 0 und 1 über die Funktion zu true und false.
                                            lovelace ui nspanel sonoff
                                            271
                                            7725
                                            6654376
