    3. Off Topic
    4. (Gelöst)Mist gebaut beim entfernen von Pihole
    • OliverIO
      OliverIO @Damrak2022 last edited by
      @damrak2022
      sudo apt-get update
      sudo apt-get install ca-certificates
      Probier das mal. Wenn es dann noch nicht geht evtl noch einen weiteren Befehl den ich gleich raussuche
      • Damrak2022
        Damrak2022 @OliverIO last edited by
        @oliverio sagte in Mist gebaut beim entfernen von Pihole:
        Ich glaube das sieht schon ziemlich gut aus:
        pi@homebridge:~ $ sudo apt-get update
        OK:1 http://deb.debian.org/debian bullseye InRelease
        OK:2 http://deb.debian.org/debian bullseye-updates InRelease
        Fehl:3 https://apt.grafana.com stable InRelease
          Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a04:4e42:8d::729 443]
        OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
        OK:5 http://security.debian.org/debian-security bullseye-security InRelease
        Fehl:6 https://download.docker.com/linux/debian bullseye InRelease
          Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:236e:aa00:3:db06:4200:93a1 443]
        Fehl:7 https://repos.influxdata.com/debian stable InRelease
          Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:8600:11:fe8d:7d40:93a1 443]
        Fehl:8 https://deb.nodesource.com/node_16.x bullseye InRelease
          Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:e600::687c:b29 443]
        Fehl:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
          Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6901:8fe8:7515:8dd2:b18d 443]
        Paketlisten werden gelesen… Fertig
        W: https://apt.grafana.com/dists/stable/InRelease: No system certificates available. Try installing ca-certificates.
        W: https://download.docker.com/linux/debian/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
        W: https://repos.influxdata.com/debian/dists/stable/InRelease: No system certificates available. Try installing ca-certificates.
        W: https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
        W: https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
        W: Fehlschlag beim Holen von https://download.docker.com/linux/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:236e:aa00:3:db06:4200:93a1 443]
        W: Fehlschlag beim Holen von https://apt.grafana.com/dists/stable/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a04:4e42:8d::729 443]
        W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/stable/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:8600:11:fe8d:7d40:93a1 443]
        W: Fehlschlag beim Holen von https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:e600::687c:b29 443]
        W: Fehlschlag beim Holen von https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6901:8fe8:7515:8dd2:b18d 443]
        W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
        pi@homebridge:~ $ sudo apt-get install ca-certificates
        Abhängigkeitsbaum wird aufgebaut… Fertig
        Statusinformationen werden eingelesen… Fertig
        Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
          alsa-topology-conf alsa-ucm-conf alsa-utils bluez bluez-firmware dos2unix git-man libasound2 libasound2-data libatopology2 liberror-perl libfftw3-single3 libsamplerate0
          libsodium23 libxslt1.1 python3-distro python3-idna python3-six python3-toml python3-urllib3 raspinfo rfkill triggerhappy
        Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
        Die folgenden NEUEN Pakete werden installiert:
          ca-certificates
        0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        Es müssen 158 kB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 391 kB Plattenplatz zusätzlich benutzt.
        Holen:1 http://deb.debian.org/debian bullseye/main arm64 ca-certificates all 20210119 [158 kB]
        Es wurden 158 kB in 0 s geholt (1.696 kB/s).
        Vorkonfiguration der Pakete ...
        Vormals nicht ausgewähltes Paket ca-certificates wird gewählt.
        (Lese Datenbank ... 53798 Dateien und Verzeichnisse sind derzeit installiert.)
        Vorbereitung zum Entpacken von .../ca-certificates_20210119_all.deb ...
        Entpacken von ca-certificates (20210119) ...
        ca-certificates (20210119) wird eingerichtet ...
        Updating certificates in /etc/ssl/certs...
        129 added, 0 removed; done.
        Trigger für man-db (2.9.4-2) werden verarbeitet ...
        Trigger für ca-certificates (20210119) werden verarbeitet ...
        0 added, 0 removed; done.
        Running hooks in /etc/ca-certificates/update.d...
        done.
        pi@homebridge:~ $ iob stop
        pi@homebridge:~ $ sudo apt update
        OK:3 http://security.debian.org/debian-security bullseye-security InRelease
        OK:5 https://repos.influxdata.com/debian stable InRelease
        OK:6 https://download.docker.com/linux/debian bullseye InRelease
        OK:7 https://deb.nodesource.com/node_16.x bullseye InRelease
        OK:8 https://apt.grafana.com stable InRelease
        OK:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
        Alle Pakete sind aktuell.
        pi@homebridge:~ $ sudo apt full-upgrade
        Paketaktualisierung (Upgrade) wird berechnet… Fertig
        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        pi@homebridge:~ $
          Thomas Braun Most Active @Damrak2022 last edited by
          @damrak2022
          Betrifft nur ThirdParty-Repos, wenn ich das richtig sehe.
          cat /etc/apt/sources.list.d/*
          sagt?
          • Damrak2022
            Damrak2022 @Thomas Braun last edited by
            @thomas-braun sagte in Mist gebaut beim entfernen von Pihole:
            pi@homebridge:~ $ cat /etc/apt/sources.list.d/*
            deb [arch=arm64 signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/debian bullseye stable
            deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main
            deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
            deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
            # this file was generated by packagecloud.io for
            # the repository at https://packagecloud.io/ookla/speedtest-cli
            deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
            deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
            deb http://archive.raspberrypi.org/debian/ bullseye main
            # Uncomment line below then 'apt-get update' to enable 'apt-get source'
            #deb-src http://archive.raspberrypi.org/debian/ bullseye main
              @damrak2022
              Funktioniert ja wieder.
              • OliverIO
                @damrak2022
                Das letzt apt update hat ja fehlerfrei funktioniert.
                Ich glaub aber nicht das es mit pihole zu tun hatte.
                Evtl ist eines der root Zertifikate abgelaufen auf die einige basierten
                • Damrak2022
                  @thomas-braun Danke an Dich und die anderen. Ich denke mein Fehler war das ich bei dem Befehl "Phiole uninstall" alle Abfragen was er löschen soll, mit "ja" beantwortet habe. Somit waren wohl die Zertifikate weg.
                  Geändert hat sich jetzt, das ich bei einem sudo apt update nochmal erneut mein Passwort eingeben muss, was ich ja vorher bei der Anmeldung via ssh schon eingegeben hatte. Kann ich das auch korrigieren?
                  OliverIO Quarkmax 2 Replies Last reply Reply Quote 0
                  • OliverIO
                    OliverIO @Damrak2022 last edited by OliverIO
                    @damrak2022
                    Du musst da dein Passwort nicht eingeben wegen neuer Anmeldung, sondern wegen Bestätigung, dass du auch sudo berechtigt bist
                    Sudo merkt sich einige Zeit das Passwort und verlangt es dann erneut. Da gibt es eine time out Einstellungen aber die würde ich jetzt nicht verändern. Sudo ist ja kein alltäglicher Befehl
                    Und man wird selbst darauf hingewiesen, dass man jetzt etwas macht, was ins System eingreift und etwas wichtiger Ist
                    • DJMarc75
                      DJMarc75 last edited by
                      Prinzipiell sollte sich jeder selbst die Frage stellen WARUM man PiHole installiert...
                      Ich selbst rein wegen den vielen, vielen Werbeteilen im Browser.
                      Aber dazu stelle ich im Router ja nix um (!) sondern gebe halt meinen PCs den dementsprechenden Eintrag in den Netzwerkeinstellungen mit.
                      PiHole ist für mich ein reiner WerbeBlocker in der GUI - nicht mehr und nicht weniger.
                      OliverIO Marc Berg 2 Replies Last reply Reply Quote 0
                      • Quarkmax
                        Quarkmax @Damrak2022 last edited by
                        @damrak2022
                        sudo visudo /etc/sudoers
                        am Ende einfügen
                        pi ALL=(ALL:ALL) NOPASSWD:ALL
                        Thomas Braun OliverIO 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @Quarkmax last edited by Thomas Braun
                          @quarkmax
                          Dafür gibt es die Datei
                          /etc/sudoers.d/010_pi-nopasswd
                          Da steht das drin:
                          user_der_ausgenommen_ist ALL=(ALL) NOPASSWD: ALL
                          • OliverIO
                            OliverIO @Quarkmax last edited by
                            @quarkmax
                            Wer Zugang zum user pi erhält, kann dann halt auch alles machen wie root
                            • OliverIO
                              OliverIO @DJMarc75 last edited by OliverIO
                              @djmarc75 sagte in Mist gebaut beim entfernen von Pihole:
                              Ich verwende pihole auch als dhcp server
                              Und nutze dann noch das Mapping von meines Hostnamen auf ip
                              • DJMarc75
                                DJMarc75 @OliverIO last edited by
                                kann man machen 👍
                                PiHole ist eigentlich ja auch ein "mächtiges" Tool ... wenn man weiss damit umzugehen 😀
                                • Marc Berg
                                  Marc Berg Most Active @DJMarc75 last edited by Marc Berg
                                  Das muss sich ja nicht ausschließen. Ich benutze Pi-Hole auch nur als Werbeblocker, habe dazu aber am Router (bei mir 'ne Fritzbox) zentral eingestellt, dass per DHCP der DNS-Server (nun Pi-Hole) verteilt wird. Damit muss ich nicht mehr an allen Phones, Tablets, Fernsehern, PCs an den DNS Einstellungen rumwerkeln und kann bei Bedarf das Ganze auch einer einer Stelle wieder rückgängig machen.
                                  Ist aber natürlich abhängig von den jeweiligen lokalen Gegebenheiten.
                                  • Damrak2022
                                    @thomas-braun Anscheinend ist doch noch etwas im Argen.
                                    Wenn ich den Iobroker öffnen will:
                                    Wenn ich es vom Router aus direkt versuche, indem ich "Homebridge" anklicke, lande ich hier:
                                    Hast Du eine Idee, warum das nicht geht.
                                    In der FritzBox habe ich bei DNS Server wieder unter IP4 und IP6 wieder die ursprünglichen Werte eingetragen.
                                    Bildschirmfoto 2023-04-10 um 14.27.09.png Bildschirmfoto 2023-04-10 um 14.26.39.png
                                    Den Router habe ich jetzt schon zweimal neugestartet.
                                      @damrak2022
                                      Mach das mal aus:
                                      DNSv6-Server auch über Router Advertisement bekanntgeben (RFC 5006)
                                      • Damrak2022
                                        Damrak2022 @Thomas Braun last edited by Damrak2022
                                        @thomas-braun Ich habe das ausgeschaltet, gespeichert und Rechner sowie FritzBox neugestartet. Fehler bleibt
                                        Jetzt kann ich allerdings "Homebridge" auch nicht mehr in der FritzBox direkt anklicken.
                                        Ich wollte gerade mal einen ping machen, was aber nicht geht:
                                        pi@homebridge:~ $ ping 192.168.178.24
                                        -bash: ping: Kommando nicht gefunden.
                                        pi@homebridge:~ $
                                        • haselchen
                                          haselchen Most Active @Damrak2022 last edited by haselchen
                                          @damrak2022
                                          Benutzt Du Firefox als Browser?
                                          Ah sehe gerade, Safari.
                                          Sonst hätte ich auf die Verbindungseinstellungen dort getippt.
                                          • Damrak2022
                                            Damrak2022 @haselchen last edited by
                                            @haselchen Nein, eigentlich nur Safari
                                            142
                                            15691
