    3. Off Topic
    4. (Gelöst)Mist gebaut beim entfernen von Pihole
    • Damrak2022
      Damrak2022 @OliverIO last edited by
      @oliverio sagte in Mist gebaut beim entfernen von Pihole:
      sudo apt-get install ca-certificates
      Ich glaube das sieht schon ziemlich gut aus:
      pi@homebridge:~ $ sudo apt-get update
      OK:1 http://deb.debian.org/debian bullseye InRelease
      OK:2 http://deb.debian.org/debian bullseye-updates InRelease
      Fehl:3 https://apt.grafana.com stable InRelease
        Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a04:4e42:8d::729 443]
      OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:5 http://security.debian.org/debian-security bullseye-security InRelease
      Fehl:6 https://download.docker.com/linux/debian bullseye InRelease
        Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:236e:aa00:3:db06:4200:93a1 443]
      Fehl:7 https://repos.influxdata.com/debian stable InRelease
        Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:8600:11:fe8d:7d40:93a1 443]
      Fehl:8 https://deb.nodesource.com/node_16.x bullseye InRelease
        Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:e600::687c:b29 443]
      Fehl:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
        Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6901:8fe8:7515:8dd2:b18d 443]
      Paketlisten werden gelesen… Fertig
      W: https://apt.grafana.com/dists/stable/InRelease: No system certificates available. Try installing ca-certificates.
      W: https://download.docker.com/linux/debian/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
      W: https://repos.influxdata.com/debian/dists/stable/InRelease: No system certificates available. Try installing ca-certificates.
      W: https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
      W: https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease: No system certificates available. Try installing ca-certificates.
      W: Fehlschlag beim Holen von https://download.docker.com/linux/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:236e:aa00:3:db06:4200:93a1 443]
      W: Fehlschlag beim Holen von https://apt.grafana.com/dists/stable/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a04:4e42:8d::729 443]
      W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/stable/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:9000:2057:8600:11:fe8d:7d40:93a1 443]
      W: Fehlschlag beim Holen von https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2a02:26f0:e600::687c:b29 443]
      W: Fehlschlag beim Holen von https://packagecloud.io/ookla/speedtest-cli/debian/dists/bullseye/InRelease Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 2600:1f1c:2e5:6901:8fe8:7515:8dd2:b18d 443]
      W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
      pi@homebridge:~ $ sudo apt-get install ca-certificates
      Abhängigkeitsbaum wird aufgebaut… Fertig
      Statusinformationen werden eingelesen… Fertig
      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
        alsa-topology-conf alsa-ucm-conf alsa-utils bluez bluez-firmware dos2unix git-man libasound2 libasound2-data libatopology2 liberror-perl libfftw3-single3 libsamplerate0
        libsodium23 libxslt1.1 python3-distro python3-idna python3-six python3-toml python3-urllib3 raspinfo rfkill triggerhappy
      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
      Die folgenden NEUEN Pakete werden installiert:
        ca-certificates
      0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
      Es müssen 158 kB an Archiven heruntergeladen werden.
      Nach dieser Operation werden 391 kB Plattenplatz zusätzlich benutzt.
      Holen:1 http://deb.debian.org/debian bullseye/main arm64 ca-certificates all 20210119 [158 kB]
      Es wurden 158 kB in 0 s geholt (1.696 kB/s).
      Vorkonfiguration der Pakete ...
      Vormals nicht ausgewähltes Paket ca-certificates wird gewählt.
      (Lese Datenbank ... 53798 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../ca-certificates_20210119_all.deb ...
      Entpacken von ca-certificates (20210119) ...
      ca-certificates (20210119) wird eingerichtet ...
      Updating certificates in /etc/ssl/certs...
      129 added, 0 removed; done.
      Trigger für man-db (2.9.4-2) werden verarbeitet ...
      Trigger für ca-certificates (20210119) werden verarbeitet ...
      0 added, 0 removed; done.
      Running hooks in /etc/ca-certificates/update.d...
      done.
      pi@homebridge:~ $ iob stop
      pi@homebridge:~ $ sudo apt update
      OK:3 http://security.debian.org/debian-security bullseye-security InRelease
      OK:5 https://repos.influxdata.com/debian stable InRelease
      OK:6 https://download.docker.com/linux/debian bullseye InRelease
      OK:7 https://deb.nodesource.com/node_16.x bullseye InRelease
      OK:8 https://apt.grafana.com stable InRelease
      OK:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      Alle Pakete sind aktuell.
      pi@homebridge:~ $ sudo apt full-upgrade
      Paketaktualisierung (Upgrade) wird berechnet… Fertig
      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
      pi@homebridge:~ $
        Thomas Braun Most Active @Damrak2022 last edited by
        @damrak2022
        Betrifft nur ThirdParty-Repos, wenn ich das richtig sehe.
        cat /etc/apt/sources.list.d/*
        sagt?
        • Damrak2022
          Damrak2022 @Thomas Braun last edited by
          @thomas-braun sagte in Mist gebaut beim entfernen von Pihole:
          pi@homebridge:~ $ cat /etc/apt/sources.list.d/*
          deb [arch=arm64 signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/debian bullseye stable
          deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main
          deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
          deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
          deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
          # this file was generated by packagecloud.io for
          # the repository at https://packagecloud.io/ookla/speedtest-cli
          deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
          deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
          deb http://archive.raspberrypi.org/debian/ bullseye main
          # Uncomment line below then 'apt-get update' to enable 'apt-get source'
          #deb-src http://archive.raspberrypi.org/debian/ bullseye main
            @damrak2022
            Funktioniert ja wieder.
            • OliverIO
              OliverIO @Damrak2022 last edited by
              @damrak2022
              Das letzt apt update hat ja fehlerfrei funktioniert.
              Ich glaub aber nicht das es mit pihole zu tun hatte.
              Evtl ist eines der root Zertifikate abgelaufen auf die einige basierten
              • Damrak2022
                @thomas-braun Danke an Dich und die anderen. Ich denke mein Fehler war das ich bei dem Befehl "Phiole uninstall" alle Abfragen was er löschen soll, mit "ja" beantwortet habe. Somit waren wohl die Zertifikate weg.
                Geändert hat sich jetzt, das ich bei einem sudo apt update nochmal erneut mein Passwort eingeben muss, was ich ja vorher bei der Anmeldung via ssh schon eingegeben hatte. Kann ich das auch korrigieren?
                OliverIO Quarkmax 2 Replies Last reply Reply Quote 0
                • OliverIO
                  OliverIO @Damrak2022 last edited by OliverIO
                  @damrak2022
                  Du musst da dein Passwort nicht eingeben wegen neuer Anmeldung, sondern wegen Bestätigung, dass du auch sudo berechtigt bist
                  Sudo merkt sich einige Zeit das Passwort und verlangt es dann erneut. Da gibt es eine time out Einstellungen aber die würde ich jetzt nicht verändern. Sudo ist ja kein alltäglicher Befehl
                  Und man wird selbst darauf hingewiesen, dass man jetzt etwas macht, was ins System eingreift und etwas wichtiger Ist
                  • DJMarc75
                    DJMarc75 last edited by
                    Prinzipiell sollte sich jeder selbst die Frage stellen WARUM man PiHole installiert...
                    Ich selbst rein wegen den vielen, vielen Werbeteilen im Browser.
                    Aber dazu stelle ich im Router ja nix um (!) sondern gebe halt meinen PCs den dementsprechenden Eintrag in den Netzwerkeinstellungen mit.
                    PiHole ist für mich ein reiner WerbeBlocker in der GUI - nicht mehr und nicht weniger.
                    OliverIO Marc Berg 2 Replies Last reply Reply Quote 0
                    • Quarkmax
                      Quarkmax @Damrak2022 last edited by
                      @damrak2022
                      sudo visudo /etc/sudoers
                      am Ende einfügen
                      pi ALL=(ALL:ALL) NOPASSWD:ALL
                      Thomas Braun OliverIO 2 Replies Last reply Reply Quote 0
                        Thomas Braun Most Active @Quarkmax last edited by Thomas Braun
                        @quarkmax
                        Dafür gibt es die Datei
                        /etc/sudoers.d/010_pi-nopasswd
                        Da steht das drin:
                        user_der_ausgenommen_ist ALL=(ALL) NOPASSWD: ALL
                        • OliverIO
                          OliverIO @Quarkmax last edited by
                          @quarkmax
                          Wer Zugang zum user pi erhält, kann dann halt auch alles machen wie root
                          • OliverIO
                            OliverIO @DJMarc75 last edited by OliverIO
                            @djmarc75 sagte in Mist gebaut beim entfernen von Pihole:
                            Ich verwende pihole auch als dhcp server
                            Und nutze dann noch das Mapping von meines Hostnamen auf ip
                            • DJMarc75
                              DJMarc75 @OliverIO last edited by
                              kann man machen 👍
                              PiHole ist eigentlich ja auch ein "mächtiges" Tool ... wenn man weiss damit umzugehen 😀
                              • Marc Berg
                                Marc Berg Most Active @DJMarc75 last edited by Marc Berg
                                Das muss sich ja nicht ausschließen. Ich benutze Pi-Hole auch nur als Werbeblocker, habe dazu aber am Router (bei mir 'ne Fritzbox) zentral eingestellt, dass per DHCP der DNS-Server (nun Pi-Hole) verteilt wird. Damit muss ich nicht mehr an allen Phones, Tablets, Fernsehern, PCs an den DNS Einstellungen rumwerkeln und kann bei Bedarf das Ganze auch einer einer Stelle wieder rückgängig machen.
                                Ist aber natürlich abhängig von den jeweiligen lokalen Gegebenheiten.
                                • Damrak2022
                                  @thomas-braun Anscheinend ist doch noch etwas im Argen.
                                  Wenn ich den Iobroker öffnen will:
                                  Wenn ich es vom Router aus direkt versuche, indem ich "Homebridge" anklicke, lande ich hier:
                                  Hast Du eine Idee, warum das nicht geht.
                                  In der FritzBox habe ich bei DNS Server wieder unter IP4 und IP6 wieder die ursprünglichen Werte eingetragen.
                                  Bildschirmfoto 2023-04-10 um 14.27.09.png Bildschirmfoto 2023-04-10 um 14.26.39.png
                                  Den Router habe ich jetzt schon zweimal neugestartet.
                                    @damrak2022
                                    Mach das mal aus:
                                    DNSv6-Server auch über Router Advertisement bekanntgeben (RFC 5006)
                                    • Damrak2022
                                      Damrak2022 @Thomas Braun last edited by Damrak2022
                                      @thomas-braun Ich habe das ausgeschaltet, gespeichert und Rechner sowie FritzBox neugestartet. Fehler bleibt
                                      Jetzt kann ich allerdings "Homebridge" auch nicht mehr in der FritzBox direkt anklicken.
                                      Ich wollte gerade mal einen ping machen, was aber nicht geht:
                                      pi@homebridge:~ $ ping 192.168.178.24
                                      -bash: ping: Kommando nicht gefunden.
                                      pi@homebridge:~ $
                                      • haselchen
                                        haselchen Most Active @Damrak2022 last edited by haselchen
                                        @damrak2022
                                        Benutzt Du Firefox als Browser?
                                        Ah sehe gerade, Safari.
                                        Sonst hätte ich auf die Verbindungseinstellungen dort getippt.
                                        • Damrak2022
                                          Damrak2022 @haselchen last edited by
                                          @haselchen Nein, eigentlich nur Safari
                                            @damrak2022
                                            Ich kann nicht rekonstruieren was du da jetzt wann und wie gemacht hast.
                                            142
                                            15691
