    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      kaffeschluerfer @Newan last edited by kaffeschluerfer
      @newan Guten Morgen!
      habe dir gerade mein vollständigen debug log per Chat geschickt. Mir ist aufgefallen, dass das Feld "vin" bei contoller/userConfig leer bleibt (im Gegensatz zu "vehicleConfig")
      2023-04-10 09:13:40.956 debug [{"vehicleConfig":{"nickname":"xxxxxxx","name":"xxxxxxxx","regDate":"2022-xxxxxxx","brandIndicator":"H","id":"xxxxxx","vin":"KMHKN81FPPU1xxxxx","generation":"2023"},"controller":{"userConfig":{"username":"xxxx@xxxxxx.de","password":"xxxxxxxx","region":"EU","brand":"hyundai","autoLogin":true,"pin":"xxxx","vin":"","language":"de"},
        bigal @kaffeschluerfer last edited by
        @kaffeschluerfer said in Adapter Hyundai (Bluelink) oder KIA (UVO):
        Stimmt, hier auch VIN bei userConfig ist leer
        • Newan
          Schau mir das Heute Abend an, jetzt erst Ostern mit den Kids 😉
          K arteck 2 Replies Last reply Reply Quote 0
            @newan Dito! genieße es! 😉
            • Newan
              Neuer commit, pls test!
              Winni 1 Reply Last reply Reply Quote 2
              • Winni
                Winni @Newan last edited by
                @newan schaut gut aus 😀
                bluelink.0
                2023-04-10 13:16:28.679	info	Update for KMHKR81CPNU0xxxxx successfull
                bluelink.0
                2023-04-10 13:16:28.630	info	State value to set for "bluelink.0.KMHKR81CPNU0xxxxx.vehicleStatus.steerWheelHeat" has to be type "boolean" but received type "number"
                bluelink.0
                2023-04-10 13:16:13.910	info	Read new update for KMHKR81CPNU0xxxxx directly from the car
                bluelink.0
                2023-04-10 13:16:00.346	info	1 Vehicles found
                bluelink.0
                2023-04-10 13:15:53.021	info	Login to api
                bluelink.0
                2023-04-10 13:15:52.981	info	starting. Version 2.2.8 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.19.1, js-controller: 4.0.24
                Die Werte bei den Objekten passen auch. Super Job! Vielen Dank und einen schönen Rest-Feiertag
                  Michaelnorge last edited by
                  Genial, Daten kommen wieder rein! Danke für den Job an einem Feiertag!!
                  Frohe (Rest-)ostern Dir 🙂
                    arteck Developer Most Active @Newan last edited by arteck
                    @newan sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                    habs schon korrigiert
                    @all
                    hab mal neue version gemacht.. 2.3.1 ist unterwegs
                    ? K G 3 Replies Last reply Reply Quote 0
                      A Former User @arteck last edited by A Former User
                      @arteck @Newan
                      Hier läuft er noch nicht..
                      Edit: nachdem die App wieder geht, läuft auch der Adapter, super, Danke!
                        kaffeschluerfer @arteck last edited by
                        @arteck jeah - das funktioniert einwandfrei wie vorher! Vielen Dank euch beiden!!!
                        • Meister Mopper
                          Meister Mopper @kaffeschluerfer last edited by
                          @arteck @Newan
                          v2.3.1
                          Funzt bei mir.
                            fichte_112 last edited by
                            Bei mir funktioniert es auch wieder. Vielen Dank.
                              bigal last edited by
                              Läuft hier auch mit 2 Autos. Interessanterweise übermitteln bei de auch wieder einen 12V SOC ob er sich auch ändert werde ich loggen
                                bigal @DeeKay 0 last edited by
                                @arteck das ist in der aktuellen Version immernoch so...
                                @deekay-0 said in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                @arteck
                                Eine Sache dir mir gerade mit aktuellstem GitHub-Adapter aufgefallen ist: Ich habe zwei Hyunday EVs. Nutze ich nun force_refresh bei einem der Autos, schickt der Adapter Aktualisierungsanfragen für beide Autos raus. Ist das so gewollt?
                                Falls ja, sollte force_refresh ggf. aus dem Fahrzeug-Node in einen separaten allgemeinen Node wandern.
                                  arteck Developer Most Active @bigal last edited by arteck
                                  @bigal sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                  hmm.. sollte nicht sein..ich guck mal
                                  ohhhhhhhhh gefunden... dauert aber .. muss was umbauen
                                    bigal @arteck last edited by
                                    @arteck Top danke schomal fürs Feedback
                                      ich steh noch etwas auf dem Schlauch, was die richtige Nutzung force_refresh und force_update angeht.
                                      So wie ich es verstanden habe, holt force_update die Daten von Auto und force_refresh nur vom zuletzt gespeichertem Zustand auf dem Server. Ist das richtig?
                                      Leider bewirkt seit der 2.3.1 keiner der beiden, dass etwas passiert... (z.B. wenn ich manuell auf die Glocke drücke, aber auch beim schreiben per script). Mache ich was falsch?
                                      Ich würde weitestgehend auf das regelmäßige Pollen verzichten (also im Adapter vllt. auf +-4 stellen), dafür aber immer, wenn ich etwas vom Auto brauche (z.B. in der visu, oder zur Abfrage des SOC beim laden) per force_xxxx die Daten abholen.
                                        A Former User @kaffeschluerfer last edited by
                                        @kaffeschluerfer
                                        Mit force_update = true holt er die Daten vom Auto, mit force_update = false vom server
                                        Ausgelöst wird immer ! Mit force_refresh = true
                                        Also force_ update schaltest du um zwischen server oder car..
                                          auch auch wenn force_update = true macht er bei jedem Update über das Intervall im Adapter auch ein Fahrzeug update
                                          @arteck wenn du da jetzt sowieso ran geht, nochmal die idee force_update so zu lassen wie es ist für den adapter cron update, aber statt nur einen force_refresh würde ich hier zwei getrennte machen
                                          force_refresh_from_server
                                          force_refresh_from_car
                                          ich lasse ja immer alle 60 min vom auto direct zusätzlich zu den 5 minütigen serverabfragen pollen und da muss ich dann immer das force_update hin und her schalten...
                                          anders wäre es glaube ich für den ein oder anderen auch ganz praktisch
                                            shipper last edited by shipper
                                            seit Tagen läuft der Adapter nicht mehr. Im Protokoll die Fehlermeldung:
                                            logout und relogin auf der Smartphone App hat nichts gebracht
                                            Auch Neuinstallation auf einen jungfräulichen iobroker nicht
                                            2260
                                            845321
