    3. Off Topic
    4. Proxmox
    5. Proxmox VM friert ein
      crunchip Forum Testing Most Active @Trooper last edited by
      @trooper vllt. läuft da irgend etwas aus dem Ruder....script/e, falsch Logstufeneinstellung(debug) oder was auch immer
        Thomas Braun Most Active @Trooper last edited by
        @trooper
        Wie sind da die Gegebenheiten?
        Mal
        iob diag
        ausführen, damit man was sehen kann.
          Trooper @Thomas Braun last edited by Trooper
          iob.pdf
          1 ======== Start marking the full check here =========
          3 ```
          4 Skript v.2023-04-02
          6 *** BASE SYSTEM ***
          7 Architecture : aarch64
          8 Docker : false
          9 Virtualization : none
          10 Distributor ID: Ubuntu
          11 Description: Ubuntu 22.04.2 LTS
          12 Release: 22.04
          13 Codename: jammy
          14
          15 PRETTY_NAME="Armbian 23.02.2 Jammy"
          16 NAME="Ubuntu"
          17 VERSION_ID="22.04"
          18 VERSION="22.04.2 LTS (Jammy Jellyfish)"
          19 VERSION_CODENAME=jammy
          20 ID=ubuntu
          21 ID_LIKE=debian
          22 HOME_URL="https://www.ubuntu.com/"
          23 SUPPORT_URL="https://help.ubuntu.com/"
          24 BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
          25 PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy "
          26 UBUNTU_CODENAME=jammy
          27
          28 Systemuptime and Load:
          29 18:42:12 up 2 min, 2 users, load average: 3.94, 1.64, 0.61
          30 CPU threads: 6
          31
          32 *** Time and Time Zones ***
          33 Local time: Mon 2023-04-10 18:42:12 CEST
          34 Universal time: Mon 2023-04-10 16:42:12 UTC
          35 RTC time: Mon 2023-04-10 16:42:12
          36 Time zone: Europe/Berlin (CEST, +0200)
          37 System clock synchronized: yes
          38 NTP service: active
          39 RTC in local TZ: no
          40
          41 *** User and Groups ***
          42 root
          43 /root
          44 root
          45
          46 *** X-Server-Setup ***
          47 X-Server: false
          48 Desktop:
          49 Terminal: tty
          50 Boot Target: graphical.target
          51
          52 *** MEMORY ***
          53 total used free shared buff/cache available
          54 Mem: 3.9G 1.9G 1.3G 5.0M 590M 1.8G
          55 Swap: 1.9G 0B 1.9G
          56 Total: 5.8G 1.9G 3.3G
          57
          58 3863 M total memory
          59 1943 M used memory
          60 298 M active memory
          61 2044 M inactive memory
          62 1329 M free memory
          63 29 M buffer memory
          64 561 M swap cache
          65 1931 M total swap
          66 0 M used swap
          67 1931 M free swap
          68
          69 *** FILESYSTEM ***
          70 Filesystem Type Size Used Avail Use% Mounted on
          71 tmpfs tmpfs 387M 5.8M 381M 2% /run
          72 /dev/mmcblk1p1 ext4 29G 4.2G 24G 15% /
          73 tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm
          74 tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock
          75 tmpfs tmpfs 1.9G 36K 1.9G 1% /tmp
          76 /dev/zram1 ext4 47M 2.5M 41M 6% /var/log
          77 tmpfs tmpfs 387M 0 387M 0% /run/user/0
          78
          79 Messages concerning ext4 filesystem in dmesg:
          80 [Mon Apr 10 18:39:55 2023] Kernel command line:
          root=UUID=d2ca5998-a4b5-4be3-a461-968167bef317 rootwait rootfstype=ext4
          splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1
          ubootpart=b7307320-01 usb-storage.quirks= cgroup_enable=cpuset cgroup_memory=1
          cgroup_enable=memory swapaccount=1
          81 [Mon Apr 10 18:40:01 2023] EXT4-fs (mmcblk1p1): mounted filesystem with writeback
          data mode. Opts: (null). Quota mode: none.
          82 [Mon Apr 10 18:40:03 2023] EXT4-fs (mmcblk1p1): re-mounted. Opts:
          commit=600,errors=remount-ro. Quota mode: none.
          83 [Mon Apr 10 18:40:05 2023] EXT4-fs (zram1): mounted filesystem without journal. Opts:
          discard. Quota mode: none.
          84
          85 Show mounted filesystems (real ones only):
          86 TARGET SOURCE FSTYPE OPTIONS
          87 / /dev/mmcblk1p1 ext4 rw,noatime,errors=remount-ro,commit=600
          88 |-/var/log.hdd /dev/mmcblk1p1[/var/log] ext4 rw,noatime,errors=remount-ro,commit=600
          89 `-/var/log /dev/zram1 ext4 rw,relatime,discard
          90
          91 Files in neuralgic directories:
          92
          93 /var:
          94 776M /var/
          95 507M /var/lib
          96 307M /var/lib/unifi/db
          97 307M /var/lib/unifi
          98 301M /var/lib/unifi/db/journal
          99
          100 /opt/iobroker/backups:
          101 35M /opt/iobroker/backups/
          102
          103 /opt/iobroker/iobroker-data:
          104 269M /opt/iobroker/iobroker-data/
          105 223M /opt/iobroker/iobroker-data/files
          106 51M /opt/iobroker/iobroker-data/files/javascript.admin
          107 42M /opt/iobroker/iobroker-data/files/devices.admin
          108 41M /opt/iobroker/iobroker-data/files/devices.admin/static/js
          109
          110 The five largest files in iobroker-data are:
          111 33M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
          112 20M /opt/iobroker/iobroker-data/objects.jsonl
          113 9.1M
          /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
          114 8.9M /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
          115 8.9M
          /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.ma
          p
          116
          117 *** NodeJS-Installation ***
          118
          119 /usr/bin/nodejs v16.19.1
          120 /usr/bin/node v16.19.1
          121 /usr/bin/npm 8.19.3
          122 /usr/bin/npx 8.19.3
          123
          124 nodejs:
          125 Installed: 16.19.1-deb-1nodesource1
          126 Candidate: 16.19.1-deb-1nodesource1
          127 Version table:
          128 *** 16.19.1-deb-1nodesource1 500
          129 500 https://deb.nodesource.com/node_16.x jammy/main arm64 Packages
          130 100 /var/lib/dpkg/status
          131 12.22.9~dfsg-1ubuntu3 500
          132 500 http://ports.ubuntu.com jammy/universe arm64 Packages
          133
          134 Temp directories causing npm8 problem: 0
          135 No problems detected
          136
          137 *** ioBroker-Installation ***
          138
          139 ioBroker Status
          140 iobroker is running on this host.
          141
          142
          143 Objects type: jsonl
          144 States type: jsonl
          145
          146 Core adapters versions
          147 js-controller: 4.0.24
          148 admin: 6.3.5
          149 javascript: 6.1.4
          150
          151 Adapters from github: 1
          152
          153 Adapter State
          154 + system.adapter.accuweather.0 : accuweather :
          rockpi-4c - enabled
          155 + system.adapter.admin.0 : admin :
          rockpi-4c - enabled, port: 8081, bind: 0.0.0.0, run
          as: admin
          156 + system.adapter.backitup.0 : backitup :
          rockpi-4c - enabled
          157 + system.adapter.bidirectional-counter.0 : bidirectional-counter :
          rockpi-4c - enabled
          158 system.adapter.birthdays.0 : birthdays :
          rockpi-4c - enabled
          159 + system.adapter.bring.0 : bring :
          rockpi-4c - enabled
          160 system.adapter.devices.0 : devices :
          rockpi-4c - disabled
          161 + system.adapter.discovery.0 : discovery :
          rockpi-4c - enabled
          162 + system.adapter.echarts.0 : echarts :
          rockpi-4c - enabled
          163 system.adapter.feiertage.0 : feiertage :
          rockpi-4c - enabled
          164 + system.adapter.history.0 : history :
          rockpi-4c - enabled
          165 system.adapter.icons-material-png.0 : icons-material-png :
          166 system.adapter.icons-mfd-svg.0 : icons-mfd-svg :
          167 system.adapter.javascript.0 : javascript :
          168 system.adapter.net-tools.0 : net-tools :
          169 system.adapter.ping.0 : ping :
          170 system.adapter.proxmox.0 : proxmox :
          rockpi-4c - disabled, port: 8006
          171 system.adapter.reolink.0 : reolink :
          172 + system.adapter.shelly.0 : shelly :
          rockpi-4c - enabled, port: 1882, bind: 0.0.0.0
          173 + system.adapter.shelly.1 : shelly :
          174 + system.adapter.tankerkoenig.0 : tankerkoenig :
          rockpi-4c - enabled
          175 system.adapter.unifi.0 : unifi :
          176 system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges :
          177 system.adapter.vis-google-fonts.0 : vis-google-fonts :
          rockpi-4c - enabled
          178 system.adapter.vis-hqwidgets.0 : vis-hqwidgets :
          179 system.adapter.vis-icontwo.0 : vis-icontwo :
          180 + system.adapter.vis-inventwo.0 : vis-inventwo :
          rockpi-4c - enabled
          181 system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd :
          182 system.adapter.vis-justgage.0 : vis-justgage :
          183 system.adapter.vis-lcars.0 : vis-lcars :
          184 system.adapter.vis-players.0 : vis-players :
          185 system.adapter.vis-timeandweather.0 : vis-timeandweather :
          186 system.adapter.vis.0 : vis :
          rockpi-4c - enabled
          187 + system.adapter.web.0 : web :
          rockpi-4c - enabled, port: 8082, bind: 0.0.0.0, run
          as: admin
          188 + system.adapter.ws.0 : ws :
          rockpi-4c - enabled, port: 8084, bind: 0.0.0.0, run
          as: admin
          189
          190 + instance is alive
          191
          192 Enabled adapters with bindings
          193 + system.adapter.admin.0 : admin :
          as: admin
          194 + system.adapter.shelly.0 : shelly :
          195 + system.adapter.shelly.1 : shelly :
          196 + system.adapter.web.0 : web :
          as: admin
          197 + system.adapter.ws.0 : ws :
          as: admin
          198
          199 ioBroker-Repositories
          200 stable : http://download.iobroker.net/sources-dist.json
          201 beta : http://download.iobroker.net/sources-dist-latest.json
          202
          203 Active repo(s): stable
          204
          205 Installed ioBroker-Instances
          206 Used repository: stable
          207 Adapter "accuweather" : 1.2.1 , installed 1.2.1
          208 Adapter "admin" : 6.3.5 , installed 6.3.5
          209 Adapter "backitup" : 2.6.16 , installed 2.6.16
          210 Adapter "bidirectional-counter": 2.0.8, installed 2.0.8
          211 Adapter "birthdays" : 2.2.0 , installed 2.2.0
          212 Adapter "bring" : 1.8.1 , installed 1.8.1
          213 Adapter "devices" : 1.1.2 , installed 1.1.2
          214 Adapter "discovery" : 3.1.0 , installed 3.1.0
          215 Adapter "echarts" : 1.0.12 , installed 1.0.12
          216 Adapter "feiertage" : 1.1.0 , installed 1.1.0
          217 Adapter "history" : 2.2.4 , installed 2.2.4
          218 Adapter "icons-material-png": 0.1.0, installed 0.1.0
          219 Adapter "icons-mfd-svg": 1.1.0 , installed 1.1.0
          220 Adapter "javascript" : 6.1.4 , installed 6.1.4
          221 Controller "js-controller": 4.0.24 , installed 4.0.24
          222 Adapter "net-tools" : 0.2.0 , installed 0.2.0
          223 Adapter "ping" : 1.5.3 , installed 1.5.3
          224 Adapter "proxmox" : 1.3.4 , installed 1.3.4
          225 Adapter "shelly" : 6.3.1 , installed 6.3.1
          226 Adapter "simple-api" : 2.7.2 , installed 2.7.2
          227 Adapter "socketio" : 4.2.0 , installed 4.2.0
          228 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7
          229 Adapter "unifi" : 0.5.10 , installed 0.5.10
          230 Adapter "vis" : 1.4.16 , installed 1.4.16
          231 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
          232 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
          233 Adapter "vis-hqwidgets": 1.3.0 , installed 1.3.0
          234 Adapter "vis-icontwo" : 0.93.0 , installed 0.90.0 [Updatable]
          235 Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1
          236 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12
          237 Adapter "vis-justgage" : 1.0.2 , installed 1.0.2
          238 Adapter "vis-lcars" : 1.0.4 , installed 1.0.4
          239 Adapter "vis-players" : 0.1.6 , installed 0.1.6
          240 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
          241 Adapter "web" : 4.3.0 , installed 4.3.0
          242 Adapter "ws" : 1.3.0 , installed 1.3.0
          243
          244 Objects and States
          245 Please stand by - This may take a while
          246 Objects: 7225
          247 States: 6474
          248
          249 *** OS-Repositories and Updates ***
          250 Hit:1 http://ports.ubuntu.com jammy InRelease
          251 Hit:2 http://ports.ubuntu.com jammy-security InRelease
          252 Ign:3 https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.6 InRelease
          253 Hit:4 http://ports.ubuntu.com jammy-updates InRelease
          254 Hit:5 https://deb.nodesource.com/node_16.x jammy InRelease
          255 Hit:6 http://ports.ubuntu.com jammy-backports InRelease
          256 Hit:7 https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.6 Release
          257 Hit:9 https://dl.ubnt.com/unifi/debian stable InRelease
          258 Get:8 http://mirrors.xtom.de/armbian jammy InRelease [52.4 kB]
          259 Fetched 52.4 kB in 3s (17.8 kB/s)
          260 Reading package lists...
          261 Pending Updates: 0
          262
          263 *** Listening Ports ***
          264 Active Internet connections (only servers)
          265 Proto Recv-Q Send-Q Local Address Foreign Address State
          User Inode PID/Program name
          266 tcp 0 0 127.0.0.1:27117 0.0.0.0:* LISTEN
          111 24577 1708/bin/mongod
          267 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN
          1000 25742 1928/io.shelly.1
          268 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN
          1000 23428 848/iobroker.js-con
          269 tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN
          1000 21277 848/iobroker.js-con
          270 tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN
          101 21031 701/systemd-resolve
          271 tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN
          0 11320 1/init
          272 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
          0 23246 915/sshd: /usr/sbin
          273 tcp6 0 0 :::8082 :::* LISTEN
          1000 25006 2331/io.web.0
          274 tcp6 0 0 :::8081 :::* LISTEN
          1000 22139 1821/io.admin.0
          275 tcp6 0 0 :::8080 :::* LISTEN
          111 21319 1037/java
          276 tcp6 0 0 :::8084 :::* LISTEN
          1000 25005 2338/io.ws.0
          277 tcp6 0 0 :::8880 :::* LISTEN
          111 22040 1037/java
          278 tcp6 0 0 :::6789 :::* LISTEN
          111 26659 1037/java
          279 tcp6 0 0 :::8843 :::* LISTEN
          111 749 1037/java
          280 tcp6 0 0 :::111 :::* LISTEN
          0 8499 1/init
          281 tcp6 0 0 :::22 :::* LISTEN
          0 23248 915/sshd: /usr/sbin
          282 tcp6 0 0 :::8443 :::* LISTEN
          111 11964 1037/java
          283 udp 0 0 0.0.0.0:5683 0.0.0.0:*
          1000 24852 1890/io.shelly.0
          284 udp 0 0 127.0.0.53:53 0.0.0.0:*
          101 21030 701/systemd-resolve
          285 udp 0 0 0.0.0.0:111 0.0.0.0:*
          0 11321 1/init
          286 udp 0 0 127.0.0.1:323 0.0.0.0:*
          0 21137 948/chronyd
          287 udp6 0 0 :::10001 :::*
          111 22115 1037/java
          288 udp6 0 0 :::111 :::*
          0 8500 1/init
          289 udp6 0 0 ::1:323 :::*
          0 21138 948/chronyd
          290 udp6 0 0 192.168.1.4:37425 :::*
          111 1014 1037/java
          291 udp6 0 0 :::5514 :::*
          111 24722 1037/java
          292 udp6 0 0 :::3478 :::*
          111 24684 1037/java
          293
          294 *** Log File - Last 25 Lines ***
          295
          296 2023-04-10 18:41:50.166 - info: shelly.0 (1890) [CoAP] Device 192.168.1.94 (shelly1
          / shelly1-BCDDC2773921 / SHSW-1#BCDDC2773921#1) connected! Polltime set to 15 sec.
          297 2023-04-10 18:41:50.168 - info: shelly.0 (1890) [CoAP] Device 192.168.1.85 (shelly1
          / shelly1-500291F0ABF6 / SHSW-1#500291F0ABF6#1) connected! Polltime set to 15 sec.
          298 2023-04-10 18:41:50.182 - info: shelly.0 (1890) [CoAP] Device 192.168.1.72 (shelly1
          / shelly1-E8DB84A23407 / SHSW-1#E8DB84A23407#1) connected! Polltime set to 15 sec.
          299 2023-04-10 18:41:51.011 - info: shelly.0 (1890) [CoAP] Device 192.168.1.91
          (shellyplug-s / shellyplug-s-80646F82506E / SHPLG-S#80646F82506E#1) connected!
          300 2023-04-10 18:41:51.818 - info: host.rockpi-4c instance
          system.adapter.tankerkoenig.0 started with pid 2303
          301 2023-04-10 18:41:52.480 - info: shelly.0 (1890) [CoAP] Device 192.168.1.90 (shelly1
          / shelly1-500291F04717 / SHSW-1#500291F04717#1) connected! Polltime set to 15 sec.
          302 2023-04-10 18:41:52.483 - info: shelly.0 (1890) [CoAP] Device 192.168.1.88 (shelly1
          / shelly1-84CCA8A561C7 / SHSW-1#84CCA8A561C7#1) connected! Polltime set to 15 sec.
          303 2023-04-10 18:41:54.585 - info: tankerkoenig.0 (2303) starting. Version 3.3.7 in
          /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v16.19.1, js-controller:
          4.0.24
          304 2023-04-10 18:41:54.655 - info: tankerkoenig.0 (2303) Adapter is already in daemon
          mode
          305 2023-04-10 18:41:54.656 - info: tankerkoenig.0 (2303) Sync time set to 15 minutes or
          900000 ms
          306 2023-04-10 18:41:59.351 - info: shelly.1 (1928) [MQTT] Device with client id
          "shellypro4pm-84cca87e70b0" connected!
          307 2023-04-10 18:41:59.397 - info: shelly.1 (1928) [MQTT] Device with client id
          "shellyplusi4-c049ef86566c" connected!
          308 2023-04-10 18:41:59.846 - info: host.rockpi-4c instance
          system.adapter.vis-inventwo.0 started with pid 2318
          309 2023-04-10 18:42:02.000 - info: host.rockpi-4c instance system.adapter.web.0 started
          with pid 2331
          310 2023-04-10 18:42:02.893 - info: host.rockpi-4c instance system.adapter.ws.0 started
          with pid 2338
          311 2023-04-10 18:42:03.015 - info: vis-inventwo.0 (2318) starting. Version 3.3.1 in
          /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v16.19.1, js-controller:
          4.0.24
          312 2023-04-10 18:42:05.061 - info: host.rockpi-4c instance
          system.adapter.bidirectional-counter.0 started with pid 2369
          313 2023-04-10 18:42:05.500 - info: web.0 (2331) starting. Version 4.3.0 in
          /opt/iobroker/node_modules/iobroker.web, node: v16.19.1, js-controller: 4.0.24
          314 2023-04-10 18:42:05.894 - info: ws.0 (2338) starting. Version 1.3.0 in
          /opt/iobroker/node_modules/iobroker.ws, node: v16.19.1, js-controller: 4.0.24
          315 2023-04-10 18:42:06.018 - info: ws.0 (2338) socket.io server listening on port 8084
          316 2023-04-10 18:42:06.158 - info: web.0 (2331) socket.io server listening on port 8082
          317 2023-04-10 18:42:06.201 - info: web.0 (2331) http server listening on port 8082
          318 2023-04-10 18:42:07.467 - info: bidirectional-counter.0 (2369) starting. Version
          2.0.8 in /opt/iobroker/node_modules/iobroker.bidirectional-counter, node: v16.19.1,
          319 2023-04-10 18:42:08.654 - info: tankerkoenig.0 (2303) Start first request
          320 2023-04-10 18:42:09.633 - info: shelly.1 (1928) [MQTT] Device with client id
          "shellyplusi4-c049ef868878" connected!
          321
          322 ```
          323
          324 ============ Mark until here for C&P =============
          325
          326 iob diag has finished.
          327
          328
          so siehts aus sehe da nix auffälliges
          @crunchip
          Scripte laufen keine von mir nur die adapter.
          Logstufen sind alle wieder auf Standard
          auf der VM war es sogar so, das bei einer sauberen Installation sich das ding aufgehangen hat nur mit den normale adaptern ohne was dazu.
          Thomas Braun DJMarc75 3 Replies Last reply Reply Quote 0
            @trooper
            Was soll man mit einem pdf?
            Kopier den Kram hier in CodeTags eingebettet rein.
            • DJMarc75
              DJMarc75 @Trooper last edited by
              @trooper sagte in Proxmox VM friert ein:
              so siehts aus
              bitte alles hier in Codetags (</>) reinsetzen - keine Datei
                @DJMarc75
                hab ich gemacht sah in der Vorschau aus als würde er die ganze seit voll packen das wollte ich nicht.
                  Ja nicht den Kram aus dem pdf hier reinkopieren, da sind ja die Formatierungen genauso kaputt...
                  Kopier das direkt aus der Konsole hier rein.
                  root
                  Meld dich NIE als root an. Leg dir einen user an, wenn es noch keinen gibt.
                  Das mongodb-Repository ist mit Sicherheit falsch. xenial ist Ubuntu 16.04. und das hat sein EOL erreicht. Auf jammy anpassen.
                    iobroker fordert mongodb 2.4.0 bei der Installation eine aktuelle Version hat den iobroker nicht interessiert.
                    jetzt hatte ich eine neu Installation mit einem Skript da hat er das halt so installiert.
                    das mit root ist mir momentan egal bevor das nicht läuft lohnt der aufwand nicht.
                    Aber danke für die mühe aber ich such mir glaub ich alternativen die Arbeit die ich da schon rein gesteckt habe ist es einfach nicht mehr wert.
                      Dann ist das Skript falsch. Und seit wann braucht der ioBroker mongodb?
                      Das ist nicht egal, weil es falsch ist und dir das Rechtegefüge ratzfatz verbiegt.
                        Die musst du allerdings auch sauber installieren. Sonst wird das auch mit den Alternativen nix.
                          Es lief auf dem Raspberry ohne Fehler oder Probleme
                          genau mit der root Installation.
                          Mit dem mongodb hast du erst angefangen :-), das hab ich mit was anderen durch einander gebracht (unifi).
                          jetzt installie ich den kram nochmal neu mit sauberen ARMbian (Jammy) mit eigenem user mal sehen wie es läuft.
                            Das ist wie gesagt grundsätzlich falsch.
                              Ja, weil es mir ins Auge gesprungen ist und mit Sicherheit so falsch ist.
                                So hab eine Sauber Installation gemacht.
                                Benutze einen RockpiSE.
                                Installiert habe ich: ARMbian Jammy alle Updates gemacht und dann neu gestartet.
                                Iobroker installiert mit Skript von der iobroker Seite
                                Adapter: nur VIS installiert mit dem Webserver und die Standard Adapter auch alles aktuell.
                                und hängt sich wieder auf alles nicht im Root installiert 🙂
                                läuft nicht mal einen Nacht durch
                                Skript v.2023-04-02
                                *** BASE SYSTEM ***
                                Docker          : false
                                Release:        22.04
                                Codename:       jammy
                                NAME="Ubuntu"
                                VERSION_ID="22.04"
                                ID=ubuntu
                                ID_LIKE=debian
                                PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
                                 10:31:46 up 3 min,  2 users,  load average: 0.13, 0.12, 0.05
                                CPU threads: 6
                                               Local time: Thu 2023-04-13 10:31:46 CEST
                                           Universal time: Thu 2023-04-13 08:31:46 UTC
                                                 RTC time: Thu 2023-04-13 08:31:46
                                              NTP service: active
                                          RTC in local TZ: no
                                root
                                /root
                                root
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.9G        355M        3.0G        5.0M        495M        3.4G
                                Swap:           1.9G          0B        1.9G
                                Total:          5.8G        355M        4.9G
                                         3863 M total memory
                                          355 M used memory
                                          165 M active memory
                                          531 M inactive memory
                                         3012 M free memory
                                           21 M buffer memory
                                          474 M swap cache
                                         1931 M total swap
                                            0 M used swap
                                         1931 M free swap
                                *** FILESYSTEM ***
                                /dev/mmcblk1p1 ext4    29G  2.0G   27G   8% /
                                tmpfs          tmpfs  1.9G     0  1.9G   0% /tmp
                                /dev/zram1     ext4    47M  2.3M   42M   6% /var/log
                                [Thu Apr 13 10:27:50 2023] Kernel command line: root=UUID=d2ca5998-a4b5-4be3-a461-968167bef317 rootwait rootfstype=ext4            splash=verbose console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=b7307320-01 usb-storage.quirks=              cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
                                [Thu Apr 13 10:27:56 2023] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: n           one.
                                [Thu Apr 13 10:27:57 2023] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
                                [Thu Apr 13 10:27:59 2023] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none.
                                /var:
                                413M    /var/
                                212M    /var/cache
                                208M    /var/cache/apt
                                197M    /var/lib
                                174M    /var/lib/apt/lists
                                4.0K    /opt/iobroker/backups/
                                35M     /opt/iobroker/iobroker-data/files
                                13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_as           sets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                4.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/2.b1d56998.chunk.js.map
                                3.7M    /opt/iobroker/iobroker-data/objects.jsonl
                                2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_as           sets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                1.9M    /opt/iobroker/iobroker-data/states.jsonl
                                /usr/bin/npm            8.19.3
                                /usr/bin/npx            8.19.3
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.5
                                javascript:     "javascript" not found
                                Adapters from github:   0
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : rockpi-4c                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.backitup.0               : backitup              : rockpi-4c                                -  enabled
                                + system.adapter.discovery.0              : discovery             : rockpi-4c                                -  enabled
                                  system.adapter.vis.0                    : vis                   : rockpi-4c                                -  enabled
                                + system.adapter.web.0                    : web                   : rockpi-4c                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + instance is alive
                                Objects and States
                                Objects:        179
                                States:         143
                                Hit:3 http://ports.ubuntu.com jammy-updates InRelease
                                Hit:4 http://ports.ubuntu.com jammy-backports InRelease
                                Hit:6 http://fi.mirror.armbian.de/apt jammy InRelease
                                Pending Updates: 0
                                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        19818      688/systemd-resolve
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11337      1/init
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19894      915/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       23327      849/iobroker.js-con
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       23320      849/iobroker.js-con
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       11247      1504/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       23429      1561/io.web.0
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          11339      1/init
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          19896      915/sshd: /usr/sbin
                                udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        19817      688/systemd-resolve
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11338      1/init
                                udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          23277      938/chronyd
                                udp6       0      0 :::111                  :::*                                0          11340      1/init
                                udp6       0      0 ::1:323                 :::*                                0          23278      938/chronyd
                                2023-04-13 10:28:21.311  - error: host.rockpi-4c instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                2023-04-13 10:28:21.312  - info: host.rockpi-4c Restart adapter system.adapter.web.0 because enabled
                                2023-04-13 10:28:24.436  - info: vis.0 (1487) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.1, js-controller: 4.0.24
                                2023-04-13 10:28:24.705  - info: vis.0 (1487) vis license is OK.
                                2023-04-13 10:28:25.451  - info: vis.0 (1487) Terminated (NO_ERROR): Without reason
                                2023-04-13 10:28:26.038  - info: host.rockpi-4c instance system.adapter.vis.0 terminated while should be started once
                                2023-04-13 10:28:40.146  - info: host.rockpi-4c instance system.adapter.admin.0 started with pid 1504
                                2023-04-13 10:28:42.491  - info: admin.0 (1504) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.1, js-controller: 4.0.24
                                2023-04-13 10:28:42.588  - info: admin.0 (1504) requesting all states
                                2023-04-13 10:28:42.590  - info: admin.0 (1504) requesting all objects
                                2023-04-13 10:28:43.051  - info: host.rockpi-4c instance system.adapter.discovery.0 started with pid 1527
                                2023-04-13 10:28:43.119  - info: admin.0 (1504) received all objects
                                2023-04-13 10:28:43.488  - info: admin.0 (1504) http server listening on port 8081
                                2023-04-13 10:28:43.491  - info: admin.0 (1504) Use link "http://localhost:8081" to configure.
                                2023-04-13 10:28:43.513  - info: admin.0 (1504) socket.io server listening on port 8081
                                2023-04-13 10:28:45.337  - info: discovery.0 (1527) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
                                2023-04-13 10:28:47.149  - info: host.rockpi-4c instance system.adapter.backitup.0 started with pid 1546
                                2023-04-13 10:28:49.340  - info: backitup.0 (1546) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
                                2023-04-13 10:28:49.506  - info: backitup.0 (1546) [iobroker] backup was activated at 02:40 every 1 day(s)
                                2023-04-13 10:28:51.368  - info: host.rockpi-4c instance system.adapter.web.0 started with pid 1561
                                2023-04-13 10:28:53.538  - info: web.0 (1561) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v16.19.1, js-controller: 4.0.24
                                2023-04-13 10:28:53.818  - info: web.0 (1561) socket.io server listening on port 8082
                                2023-04-13 10:28:53.824  - info: web.0 (1561) http server listening on port 8082
                                2023-04-13 10:29:14.091  - info: admin.0 (1504) ==> Connected system.user.admin from ::ffff:192.168.1.61
                                2023-04-13 10:32:35.677  - info: admin.0 (1504) ==> Connected system.user.admin from ::ffff:192.168.1.61
                                                     v.2023-04-02
                                Operatingsystem:        Ubuntu 22.04.2 LTS
                                Kernel:                 5.15.80-rockchip64
                                Installation:           Native
                                Timezone:               Europe/Berlin (CEST, +0200)
                                User-ID:                0
                                X-Server:               false
                                Pending OS-Updates:     0
                                Pending iob updates:    0
                                Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                                        /usr/bin/npm            8.19.3
                                                        /usr/bin/npx            8.19.3
                                Recommended versions are nodejs 18.x.y and npm 9.x.y
                                MEMORY:
                                Mem:            3.9G        371M        3.0G        5.0M        521M        3.4G
                                Swap:           1.9G          0B        1.9G
                                Total:          5.8G        371M        4.9G
                                Active iob-Instances:   5
                                ioBroker Core:          js-controller           4.0.24
                                                        admin                   6.3.5
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                179
                                States:                 143
                                Size of iob-Database:
                                6.8M    /opt/iobroker/iobroker-data/objects.jsonl
                                  crunchip Forum Testing Most Active @Trooper last edited by crunchip
                                  *** User and Groups *** root /root root
                                  mal ne andere Speicherkarte testen
                                    Trooper @crunchip last edited by
                                    @crunchip
                                    diese anzeige richtet sich nur danach wie man die diag abfragt:
                                    selbe abfrage mit dem user:
                                    Skript v.2023-04-02
                                    *** BASE SYSTEM ***
                                    Docker          : false
                                    Release:        22.04
                                    Codename:       jammy
                                    NAME="Ubuntu"
                                    VERSION_ID="22.04"
                                    ID=ubuntu
                                    ID_LIKE=debian
                                     10:48:36 up 20 min,  2 users,  load average: 0.11, 0.15, 0.16
                                    CPU threads: 6
                                                   Local time: Thu 2023-04-13 10:48:36 CEST
                                               Universal time: Thu 2023-04-13 08:48:36 UTC
                                                     RTC time: Thu 2023-04-13 08:48:36
                                                  NTP service: active
                                              RTC in local TZ: no
                                    iobroker
                                    /home/iobroker
                                    iobroker tty disk dialout sudo audio video plugdev games users systemd-journal input netdev i2c
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            3.9G        398M        2.9G        5.0M        544M        3.4G
                                    Swap:           1.9G          0B        1.9G
                                    Total:          5.8G        398M        4.9G
                                             3863 M total memory
                                              398 M used memory
                                              302 M active memory
                                              474 M inactive memory
                                             2920 M free memory
                                               30 M buffer memory
                                              514 M swap cache
                                             1931 M total swap
                                                0 M used swap
                                             1931 M free swap
                                    *** FILESYSTEM ***
                                    tmpfs          tmpfs  387M     0  387M   0% /run/user/1000
                                    [sudo] password for iobroker:
                                    [Thu Apr 13 10:27:56 2023] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none.
                                    /var:
                                    413M    /var/
                                    212M    /var/cache
                                    208M    /var/cache/apt
                                    197M    /var/lib
                                    8.8M    /opt/iobroker/backups/
                                    45M     /opt/iobroker/iobroker-data/
                                    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                    2.0M    /opt/iobroker/iobroker-data/states.jsonl
                                    /usr/bin/npm            8.19.3
                                    /usr/bin/npx            8.19.3
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.3.5
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        179
                                    States:         143
                                    Hit:6 http://mirrors.dotsrc.org/armbian-apt jammy InRelease
                                    Pending Updates: 0
                                    2023-04-13 10:44:22.053  - info: host.rockpi-4c stopInstance system.adapter.backitup.0 send kill signal
                                    2023-04-13 10:44:22.068  - info: admin.0 (1504) <== Disconnect system.user.admin from ::ffff:192.168.1.61
                                    2023-04-13 10:44:22.634  - info: host.rockpi-4c instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-04-13 10:44:25.113  - info: host.rockpi-4c instance system.adapter.backitup.0 started with pid 3751
                                    2023-04-13 10:44:25.394  - info: admin.0 (1504) ==> Connected system.user.admin from ::ffff:192.168.1.61
                                    2023-04-13 10:44:27.219  - info: backitup.0 (3751) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
                                    2023-04-13 10:44:27.381  - info: backitup.0 (3751) [iobroker] backup was activated at 11:00 every 1 day(s)
                                    2023-04-13 10:44:46.624  - info: admin.0 (1504) <== Disconnect system.user.admin from ::ffff:192.168.1.61
                                    2023-04-13 10:45:01.463  - info: admin.0 (1504) ==> Connected system.user.admin from ::ffff:192.168.1.61
                                    2023-04-13 10:45:24.514  - info: host.rockpi-4c stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2023-04-13 10:45:24.528  - info: backitup.0 (3751) Got terminate signal TERMINATE_YOURSELF
                                    2023-04-13 10:45:24.532  - info: backitup.0 (3751) cleaned everything up...
                                    2023-04-13 10:45:24.535  - info: backitup.0 (3751) terminating
                                    2023-04-13 10:45:24.539  - info: backitup.0 (3751) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-04-13 10:45:24.569  - info: admin.0 (1504) <== Disconnect system.user.admin from ::ffff:192.168.1.61
                                    2023-04-13 10:45:24.573  - info: host.rockpi-4c stopInstance system.adapter.backitup.0 send kill signal
                                    2023-04-13 10:45:25.156  - info: host.rockpi-4c instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-04-13 10:45:27.651  - info: host.rockpi-4c instance system.adapter.backitup.0 started with pid 3793
                                    2023-04-13 10:45:29.799  - info: backitup.0 (3793) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
                                    2023-04-13 10:45:29.965  - info: backitup.0 (3793) [iobroker] backup was activated at 11:00 every 1 day(s)
                                    2023-04-13 10:45:36.282  - info: admin.0 (1504) ==> Connected system.user.admin from ::ffff:192.168.1.61
                                    2023-04-13 10:45:45.562  - info: admin.0 (1504) <== Disconnect system.user.admin from ::ffff:192.168.1.61
                                    2023-04-13 10:45:47.050  - info: admin.0 (1504) ==> Connected system.user.admin from ::ffff:192.168.1.61
                                    2023-04-13 10:46:07.543  - info: admin.0 (1504) <== Disconnect system.user.admin from ::ffff:192.168.1.61 web
                                    2023-04-13 10:46:09.595  - info: admin.0 (1504) <== Disconnect system.user.admin from ::ffff:192.168.1.61 admin
                                    Eine Speicherkarte nutze ich nicht Sondern einen EPROM
                                    Ich teste dann nochmal mit eine SD mal sehen
                                      Natürlich. Aber da man auch nie als root direkt eingeloggt ist passt das schon.
                                        crunchip Forum Testing Most Active @Thomas Braun last edited by
                                        @thomas-braun sagte in Proxmox VM friert ein:
                                        und bei einem ubuntu dann wohl eher auch noch bewusst freigeschaltet
                                        Thomas Braun T 2 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @crunchip last edited by
                                          @crunchip sagte in Proxmox VM friert ein:
                                          Bei so etwas exotischeren Varianten wie hier weiß ich es nicht.
                                          Aber bei den gängigen ubuntus müsste man den aktiv ausbuddeln, der root ist im Standard nicht direkt zugänglich.
                                            @crunchip
                                            bei armbian ist es schon freigeschaltet war auch überrascht
                                            hab den root auch gerade nur genutzt um die abfrage zu machen.
                                            Ich frage mich was der iobroker in der Nacht macht das er sich da immer aufhängt mir ist es am tag noch nicht aufgefallen.
                                            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                            1.0k
                                            81.1k
                                            186
                                            29435
