    4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
      Thomas Braun Most Active @tombox last edited by Thomas Braun
      @tombox
      Der erste LogIn ist jetzt wie oben schon geschrieben okay.
      Allerdings rappelt es nach genau einer Stunde jeweils im Log:
      2023-04-10 11:28:33.811  - info: parcel.0 (106785) starting. Version 0.0.26 in /opt/iobroker/node_modules/iobroker.parcel, node: v19.8.1, js-controller: 5.0.1-alpha.0-20230406-4552d569
      2023-04-10 11:28:33.904  - info: parcel.0 (106785) Login to DHL
      2023-04-10 11:28:36.939  - info: parcel.0 (106785) Login to DHL successful
      2023-04-10 11:28:37.003  - info: parcel.0 (106785) Login to DPD
      2023-04-10 11:28:39.661  - info: parcel.0 (106785) Login to DPD successful
      2023-04-10 11:29:45.721  - info: parcel.0 (106785) Login to T17 User
      2023-04-10 11:29:46.188  - info: parcel.0 (106785) Login to T17 User successful
      2023-04-10 11:29:46.198  - info: parcel.0 (106785) Login to Amazon
      2023-04-10 11:29:48.650  - info: parcel.0 (106785) Login to Amazon successful
      2023-04-10 11:29:48.701  - info: parcel.0 (106785) Login to GLS
      2023-04-10 11:29:49.401  - info: parcel.0 (106785) Login to GLS successful
      2023-04-10 11:29:49.422  - info: parcel.0 (106785) Login to Hermes
      2023-04-10 11:29:49.861  - info: parcel.0 (106785) Login to Hermes successful
      2023-04-10 12:29:17.131  - error: parcel.0 (106785) refresh token failed
      2023-04-10 12:29:17.134  - error: parcel.0 (106785) AxiosError: Request failed with status code 500
      2023-04-10 12:29:17.135  - error: parcel.0 (106785) "<HTML><HEAD>\n<TITLE>Internal Server Error</TITLE>\n</HEAD><BODY>\n<H1>Internal Server Error - Read</H1>\nThe server encountered an internal error or misconfiguration and was unable to\ncomplete your request.<P>\nReference&#32;&#35;3&#46;456b7b5c&#46;1681122557&#46;62118ad9\n</BODY></HTML>\n"
      2023-04-10 12:29:17.136  - error: parcel.0 (106785) Start relogin in 1min
      2023-04-10 12:30:17.606  - error: parcel.0 (106785) AxiosError: Request failed with status code 500
      2023-04-10 12:30:17.606  - error: parcel.0 (106785) "<HTML><HEAD>\n<TITLE>Internal Server Error</TITLE>\n</HEAD><BODY>\n<H1>Internal Server Error - Read</H1>\nThe server encountered an internal error or misconfiguration and was unable to\ncomplete your request.<P>\nReference&#32;&#35;3&#46;6c6b7b5c&#46;1681122617&#46;1a90983b\n</BODY></HTML>\n"
      2023-04-10 12:30:17.607  - info: parcel.0 (106785) Login to DHL
      2023-04-10 12:30:17.855  - error: parcel.0 (106785) AxiosError: Request failed with status code 500
      2023-04-10 12:30:17.855  - error: parcel.0 (106785) "<HTML><HEAD>\n<TITLE>Internal Server Error</TITLE>\n</HEAD><BODY>\n<H1>Internal Server Error - Read</H1>\nThe server encountered an internal error or misconfiguration and was unable to\ncomplete your request.<P>\nReference&#32;&#35;3&#46;456b7b5c&#46;1681122617&#46;620c9bc6\n</BODY></HTML>\n"
      2023-04-10 13:27:37.197  - error: parcel.0 (106785) refresh token failed
      2023-04-10 13:27:37.200  - error: parcel.0 (106785) AxiosError: Request failed with status code 500
      2023-04-10 13:27:37.201  - error: parcel.0 (106785) "<HTML><HEAD>\n<TITLE>Internal Server Error</TITLE>\n</HEAD><BODY>\n<H1>Internal Server Error - Read</H1>\nThe server encountered an internal error or misconfiguration and was unable to\ncomplete your request.<P>\nReference&#32;&#35;3&#46;5c4f655f&#46;1681126057&#46;246d3d7\n</BODY></HTML>\n"
      2023-04-10 13:27:37.202  - error: parcel.0 (106785) Start relogin in 1min
      2023-04-10 13:28:38.133  - error: parcel.0 (106785) AxiosError: Request failed with status code 500
      2023-04-10 13:28:38.134  - error: parcel.0 (106785) "<HTML><HEAD>\n<TITLE>Internal Server Error</TITLE>\n</HEAD><BODY>\n<H1>Internal Server Error - Read</H1>\nThe server encountered an internal error or misconfiguration and was unable to\ncomplete your request.<P>\nReference&#32;&#35;3&#46;554f655f&#46;1681126118&#46;385d145\n</BODY></HTML>\n"
      2023-04-10 13:28:38.134  - info: parcel.0 (106785) Login to DHL
      2023-04-10 13:28:38.606  - error: parcel.0 (106785) AxiosError: Request failed with status code 500
      2023-04-10 13:28:38.607  - error: parcel.0 (106785) "<HTML><HEAD>\n<TITLE>Internal Server Error</TITLE>\n</HEAD><BODY>\n<H1>Internal Server Error - Read</H1>\nThe server encountered an internal error or misconfiguration and was unable to\ncomplete your request.<P>\nReference&#32;&#35;3&#46;5c4f655f&#46;1681126118&#46;2470555\n</BODY></HTML>\n"
      • BjoernF
        BjoernF @tombox last edited by
        @tombox oh okay, dass der PIN nicht mehr seitens DHL kommt war mir nicht bewusst. Update auf 0.0.26 und es funktioniert wieder. VIELEN DANK!
        • Ro75
          Ro75 last edited by
          Leider funktioniert die Version 0.0.26 noch nicht richtig. Amazon geht nicht. Es wird der Fehler
          2023-04-10 15:54:29.911 - error: parcel.0 (1843730) AxiosError: Request failed with status code 404
          ausgeworfen.
          Ro75.
            tombox @Thomas Braun last edited by
            @thomas-braun mit 0.0.27 müsste auch refresh funktionieren
            Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
              @tombox
              Okay, ich schau in einer Stunde nochmal was
              parcel@0.0.27 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#620e88b5007ecd936e511d429a969b7cb49e899c
              so sagt.
              • haselchen
                haselchen Most Active @tombox last edited by
                @tombox
                Gleicher Fehler wie @Ro75
                parcel.0	2023-04-10 19:19:42.045	error	AxiosError: Request failed with status code 404
                Version 0.26
                • Nashra
                  Habe gerade die 0.0.27 installiert, leider zickt da Amazon
                  2023-04-10 19:21:15.169 - error: parcel.0 (1637287) AxiosError: Request failed with status code 404
                  2023-04-10 19:21:15.170 - error: parcel.0 (1637287) "\n \n\n\n\n\n\n\n\n \n\n\n\n\n \n\n\n\n\n\n\n\n\n \n\n\n\n\n\n\n\n\n \n \n \n \n \n \n \n \n \n\n\n\n \n\n\n\n\n\n\n\n
                  \n
                  \n\n\n\n\n\n\n\n\n
                  \n \n
                  \n\n\n \n \n \n
                  \n \n 	\n
                  \n
                  Suchst du etwas?
                  \n
                  \n
                  \n Tut uns leid: Die Web-Adresse, die du eingegeben hast, gibt es auf unserer Website nicht.\n
                  \n \n \n Zur Amazon.de Homepage \n\n \n
                  \n
                  \n\n \n\n
                  \n
                  \n \n\n\n
                  \n
                  \n\n
                  \n\n\n\n\n\n"
                  2023-04-10 19:21:15.315 - error: parcel.0 (1637287) "\n \n\n\n\n\n\n\n\n \n\n\n\n\n \n\n\n\n\n\n\n\n\n \n\n\n\n\n\n\n\n\n \n \n \n \n \n \n \n \n \n\n\n\n \n\n\n\n\n\n\n\n
                  \n
                  \n\n\n\n\n\n\n\n\n
                  \n \n
                  \n\n\n \n \n \n
                  \n \n 	\n
                  \n
                  Suchst du etwas?
                  \n
                  \n
                  \n
                  \n\n \n\n
                  \n
                  \n \n\n\n
                  \n
                  \n\n
                  \n\n\n\n\n\n"
                  2023-04-10 19:21:15.317 - error: parcel.0 (1637287) AxiosError: Request failed with status code 404
                  Ro75 T 2 Replies Last reply Reply Quote 0
                  • Ro75
                    Ro75 @Nashra last edited by
                    @nashra richtig, die Meldung bekomme ich auch in der 0.0.27 in Verbindung mit Axios 404.
                      Thomas Braun Most Active @Thomas Braun last edited by
                      @thomas-braun sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                      so sagt.
                      Bei mir ist das Log jetzt ruhig, Logins sind auch alle ohne Probleme erfolgt.
                      Ro75 1 Reply Last reply Reply Quote 0
                      • Ro75
                        Ro75 @Thomas Braun last edited by
                        @thomas-braun Login soweit auch. Aber es kommen keine Daten. Bei Amazon fehlt es. Das kann ich definitiv so sagen, da ich heute was bestellt habe und es kommt nix.
                          tombox @Nashra last edited by
                          @nashra für das amazon problem bräuchte ich mal ein debug log gerne via pn.. denn bei mir funktioniert es
                          • Nashra
                            Nashra Most Active Forum Testing @tombox last edited by
                            @tombox sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                            Das Log:
                            2023-04-11 10:19:35.766 - info: parcel.0 (2279308) Login to Amazon
                            2023-04-11 10:19:36.087 - debug: parcel.0 (2279308) "\n\n\n\n \n\n\n\n\n\n \n \n\n \n \n \n\n \n \n \n \n\n\n\n\n \n \n \n\n\n \n\n\n\n\n\n
                            \n
                            \n \n \n \n\n\n\n\n\n\n\n\n \n\n\n\n\"\"/\n\n\n\n\n \n \n \n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n \n\n\n\n\n\n\n\n\n\n\n\n\n\n \n\n\n\n\n\n
                            \n \n
                            \n
                            \n
                            \n \n \n \n \n
                            \n \n \n \n .de\n \n
                            \n\n
                            \n
                            \n \n \n \n \n
                            \n
                            \n \n\n \n \n \n\n \n \n \n\n \n\n \n \n \n \n \n
                            \n \n \n
                            \n \n
                            \n
                            \n\n
                            \n
                            \n \n
                            \n\n \n\n
                            \n \n\n\n\n\n\n\n\n \n\n \n\n \n\n\n\n \n\n\n
                            \n\n
                            \n \n \n\n\n\n\n
                            \n
                            \n
                            \n
                            \n
                            \n \n
                            \n
                            \n
                            \n
                            \n
                            \n
                            \n\n \n \n \n\n
                            \n \n
                            \n \n \n \n \n
                            \n \n\n\n\n\n
                            Deutsch\n\n\n\n\n \n \n\n\n Deutschland\n\n\n
                            \n \n \n \n \n
                                \n
                                \n Nutzungsbedingungen\n
                                \n
                                \n Datenschutzerklärung\n
                                \n
                                \n Impressum\n
                                \n
                                \n Hinweise zu Cookies\n
                                \n
                                \n Hinweise zu interessenbasierter Werbung\n
                                \n
                            \n\n
                            \n© 1996–2023 Amazon.com, Inc. oder ihre Tochtergesellschaften\n
                            \n\n
                            \n
                            \n
                            \n\n \n\n\n \n \n\n\n\n\n\n\n
                            \n\n \n\n\n\n\n\n \n \n\n\n\n\n \n\n\n\n \n\n\n\n
                            \n\n\n\n\n\n"
                            2023-04-11 10:19:36.227 - error: parcel.0 (2279308) AxiosError: Request failed with status code 404
                            2023-04-11 10:19:36.228 - error: parcel.0 (2279308) "\n \n\n\n\n\n\n\n\n \n\n\n\n\n \n\n\n\n\n\n\n\n\n \n\n\n\n\n\n\n\n\n \n \n \n \n \n \n \n \n \n\n\n\n \n\n\n\n\n\n\n\n
                            \n
                            \n\n\n\n\n\n\n\n\n
                            \n \n
                            \n\n\n \n \n \n
                            \n \n 	\n
                            \n
                            Suchst du etwas?
                            \n
                            \n
                            \n
                            \n\n \n\n
                            \n
                            \n \n\n\n
                            \n
                            \n\n
                            \n\n\n\n\n\n"
                            2023-04-11 10:19:36.373 - error: parcel.0 (2279308) "\n \n\n\n\n\n\n\n\n \n\n\n\n\n \n\n\n\n\n\n\n\n\n \n\n\n\n\n\n\n\n\n \n \n \n \n \n \n \n \n \n\n\n\n \n\n\n\n\n\n\n\n
                            \n
                            \n\n\n\n\n\n\n\n\n
                            \n \n
                            \n\n\n \n \n \n
                            \n \n 	\n
                            \n
                            Suchst du etwas?
                            \n
                            \n
                            \n
                            \n\n \n\n
                            \n
                            \n \n\n\n
                            \n
                            \n\n
                            \n\n\n\n\n\n"
                            2023-04-11 10:19:36.375 - error: parcel.0 (2279308) AxiosError: Request failed with status code 404
                              @nashra Wie gesagt ein debug log via privat Nachricht
                              • Nashra
                                Log zu groß, wie kann man das als private Nachricht als zip schicken
                                  @nashra tombox2020@gmail.com
                                  • Nashra
                                    unterwegs
                                      @nashra bitte mal die github version testen ich habe da noch mehr logs eingebaut
                                      • Nashra
                                        Habe ich gemacht aber leider das selbe Problem mit Amazon
                                          @nashra Ja aber bitte nochmal die logs mit der neuen version
                                          • Nashra
                                            unterwegs
                                            BjoernF 1 Reply Last reply Reply Quote 0
                                            1.2k
                                            81.1k
                                            17track amazon briefe dhl dpd gls ups
                                            123
                                            1537
                                            532452
