    3. Off Topic
    4. (Gelöst)Mist gebaut beim entfernen von Pihole
    • Damrak2022
      Damrak2022 @Meister Mopper last edited by
      @meister-mopper PiHole ist deinstalliert. Damit fing mein Drama ja an.
      • Damrak2022
        Damrak2022 @Guest last edited by
        @dp20eic sagte in Mist gebaut beim entfernen von Pihole:
        sudo systemctl disable docker.socket
        Das sieht so aus:
        pi@homebridge:~ $ sudo systemctl disable docker.service
        [sudo] Passwort für pi:
        Failed to disable unit: Unit file docker.service does not exist.
        pi@homebridge:~ $ sudo systemctl disable docker.socket
        Failed to disable unit: Unit file docker.socket does not exist.
        pi@homebridge:~ $
        Und das so:
        ● docker.socket
             Loaded: not-found (Reason: Unit docker.socket not found.)
             Active: active (listening) since Mon 2023-04-10 14:20:26 CEST; 5h 31min ago
                CPU: 4ms
             CGroup: /system.slice/docker.socket
        Apr 10 14:20:26 homebridge systemd[1]: Starting Docker Socket for the API.
        Apr 10 14:20:26 homebridge systemd[1]: Listening on Docker Socket for the API.
        Apr 10 19:33:47 homebridge systemd[1]: docker.socket: Socket unit configuration has changed while unit has been running, no open socket file descriptor left. The socket unit is not f>
        Apr 10 19:33:49 homebridge systemd[1]: docker.socket: Socket unit configuration has changed while unit has been running, no open socket file descriptor left. The socket unit is not f>
        Apr 10 19:33:51 homebridge systemd[1]: docker.socket: Socket unit configuration has changed while unit has been running, no open socket file descriptor left. The socket unit is not f>
        Apr 10 19:33:52 homebridge systemd[1]: docker.socket: Socket unit configuration has changed while unit has been running, no open socket file descriptor left. The socket unit is not f>
        • wendy2702
          wendy2702 last edited by
          Nur mal so.
          Wenn auf dem Pi nur noch iobroker laufen soll.
          Mach ein Backup von iobroker.
          Sichere das Backup
          Installiere ein aktuelles Bullseye Image neu auf der SD/SSD oder was immer dein Speicher Medium ist
          Dann iobroker per Einzeiler und Backup restore.
          • Ro75
            Ro75 last edited by
            Wenn mich nicht alles täuscht läuft da noch InfluxDB und Grafana.
            • OliverIO
              OliverIO @Damrak2022 last edited by OliverIO
              @damrak2022
              ich bin etwas erschrocken.
              ein einzelner sagt docker ist mist.
              dann wird nicht mal versucht herauszufinden warum docker da ist und was für images da sind bzw auch laufen.
              wenn du jetzt versuchst docker runter zu hauen, evtl fehlt dir dann noch was anderes nachher, wo du nicht weißt das es über docker läuft. (sudo docker container ls)
              aber so steuerst du direkt auf einen kompletten neuaufbau deines systems zu, was evtl auch besser ist.
              die installation von pihole wie du es installiert hast, hat dir sicherlich nicht docker noch zusätzlich installiert.
              auch wenn ich dir jetzt nicht direkt docker empfehlen will, da du dann noch eine weitere technologie lernen müsstest und du noch mit linus ziemlich beschäftigt bist. wenn du pihole als docker image installiert hättest, wäre das entfernen rückstandslos in wenigen minuten erledigt gewesen. docker kapselt applikationen zusammen mit seinem eigenen betriebssystem so vom rest ab (als image). so das man das an/ab schalten kann und auch jederzeit wieder löschen kann.
              mit docker kann man auch gefahrlos mehrere applikationen auf basis verschiedener linux betriebssysteme parallel laufen lassen ohne das sich da etwas beißt.
              aber das nur am rande. (ich betreibe hier pihole in einem docker container und noch einige andere applikationen wie auch iobroker in docker)
              crunchip Damrak2022 2 Replies Last reply Reply Quote 0
                crunchip Forum Testing Most Active @OliverIO last edited by
                @oliverio sagte in Mist gebaut beim entfernen von Pihole:
                zumindest hat er https://hub.docker.com/r/bbricardo/fritzinfluxdb drauf, siehe
                https://forum.iobroker.net/post/976074
                • Damrak2022
                  Damrak2022 @OliverIO last edited by
                  @oliverio Das mit dem Mist bezog sich eher darauf wie blöd ich war, als ich jemandem erlaubt habe da was zu installieren, ohne an die Konsequenzen zu denken. Docker ist vielleicht prima, wenn man damit umgehen kann. Aber ich gehöre da nicht dazu.
                  • Damrak2022
                    Damrak2022 @Ro75 last edited by Damrak2022
                    @ro75 Du hast recht InfluxDB und Grafana läuft da auch noch
                    Wie kann ich das im Terminal sichern, denn ich komme ja nicht auf die Oberfläche vom ioBroker?
                    • DJMarc75
                      DJMarc75 @Damrak2022 last edited by
                      @damrak2022 sagte in Mist gebaut beim entfernen von Pihole:
                      Seit wann ? Davon war bisher nicht die Rede... was treibst Du denn ?
                      Und was sagt
                      iob diag
                      • Damrak2022
                        Damrak2022 @DJMarc75 last edited by
                        @djmarc75
                        pi@homebridge:~ $ iob diag
                        sudo: curl: Befehl nicht gefunden
                        pi@homebridge:~ $
                        Auf die Oberfläche komme ich seit der Deinstallation von Pihole nicht mehr.
                        • DJMarc75
                          Du hast ja mal wieder Dein komplettes System zerbröselt.
                          Ich würde das neu aufsetzen - sonst wird auch dieser Beitrag die 500 Meilengrenze durchbrechen...
                          • Damrak2022
                            @djmarc75 Werde ich wohl machen
                            • Damrak2022
                              Damrak2022 @DJMarc75 last edited by Damrak2022
                              @djmarc75 Was bedeutet das denn jetzt:
                              damrak2022@iMac ~ % ssh pi@homebridge
                              @    WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!     @
                              IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
                              Someone could be eavesdropping on you right now (man-in-the-middle attack)!
                              It is also possible that a host key has just been changed.
                              The fingerprint for the ED25519 key sent by the remote host is
                              SHA256:WG/hIg1fpzg8xLR1Ch7bkq2n3h/RgAPC9ofwvT9acxE.
                              Please contact your system administrator.
                              Add correct host key in /Users/damrak2022/.ssh/known_hosts to get rid of this message.
                              Offending ECDSA key in /Users/damrak2022/.ssh/known_hosts:3
                              Host key for homebridge has changed and you have requested strict checking.
                              Host key verification failed.
                              damrak2022@iMac ~ %
                              Jetzt kommt auf einmal das:
                              damrak2022@iMac ~ % ssh pi@192.168.178.24
                              The authenticity of host '192.168.178.24 (192.168.178.24)' can't be established.
                              ED25519 key fingerprint is SHA256:WG/hIg1fpzg8xLR1Ch7bkq2n3h/RgAPC9ofwvT9acxE.
                              This key is not known by any other names
                              Are you sure you want to continue connecting (yes/no/[fingerprint])? y
                              Please type 'yes', 'no' or the fingerprint: yes
                              Warning: Permanently added '192.168.178.24' (ED25519) to the list of known hosts.
                              pi@192.168.178.24's password:
                              Permission denied, please try again.
                              • haselchen
                                haselchen Most Active @Damrak2022 last edited by
                                @damrak2022
                                Hattest du nicht neue Zertifikate installiert ?
                                • Damrak2022
                                  Damrak2022 @haselchen last edited by Damrak2022
                                  @haselchen Ich habe alles runtergeschmissen und mit Raspberry Imager Bullseye 64 Bit neu auf die SSD installiert. Jetzt hänge ich schon wieder fest, dabei will ich doch nur iobroker installieren.
                                  Mein Passwort was ich im Raspberry Imager festgelegt habe, wird aber seltsamerweise nicht genommen.
                                  • mickym
                                    mickym Most Active last edited by mickym
                                    Du musst die known_hosts im Verzeichnis .ssh mit den Schlüsseln löschen.
                                    Steht doch da:
                                    Bei der nächsten Anmeldung wirst Du gefragt, ob die Schlüssel wieder aufgenommen werden sollen - da gibst du vollständig:
                                    yes
                                    ein.
                                    • Damrak2022
                                      @mickym Gelöscht habe ich die alle, aber bei der Eingabe des Passworts wird mir der Zugriff verweigert.
                                      damrak2022@iMac ~ % nano ~/.ssh/known_hosts
                                      The authenticity of host 'homebridge (2a02:908:177:3540:b4be:af64:a052:1ce7)' can't be established.
                                      Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
                                      Warning: Permanently added 'homebridge' (ED25519) to the list of known hosts.
                                      pi@homebridge's password:
                                      • mickym
                                        mickym Most Active @Damrak2022 last edited by
                                        @damrak2022 dann passt das Passwort nicht.
                                        • Damrak2022
                                          @mickym Okay, ich mache das alles nochmal, denn ich weiß ja jetzt wie ich Keys lösche. Kann sein, das ich mich verschrieben habe.
                                          • mickym
                                            Ja und dann nimm halt erstmal was einfaches ohne Umlaute und kein y und z im Passwort. Wenn alles eingerichtet ist, dann kannst das immer noch ändern.
                                            142
                                            9931
