    4. Alpha Test js-controller 5.0
      crunchip Forum Testing Most Active last edited by crunchip
      hab soeben auch mal v5 aktiv, soweit läuft alles fürs erste, allerdings sind sehr viele meiner installierten Instanzen aktuell nicht aktiv/nicht in gebrauch.
      admin.0 (945379) starting. Version 6.4.3 in /opt/iobroker/node_modules/iobroker.admin, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230406-4552d569
      was nun zu Beginn auffiel und nur bedingt etwas mit dem controller zu tun hat, sind
      • im mqtt Adapter war wie in der Instanz beschrieben, bis dato eingetragen
        These states will be published. (Divided by comma, e.g. 'mqtt.0.,javascript.')
        dies wurde nun aber angemeckert
      2023-04-09 10:46:53.490 - warn: host.IoBroker-Server States 127.0.0.1:51508 Error from InMemDB: Error: The pattern "'mqtt.0.*" is not a valid ID pattern
      at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2388:15)
      at StatesInMemoryServer.handleSubscribe (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:324:59)
      at StatesInMemoryServer._subscribeForClient (/opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:258:14)
      at RedisHandler. (/opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:394:26)
      at RedisHandler.emit (node:events:513:28)
      at RedisHandler.emit (node:domain:489:12)
      at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:209:37)
      at processImmediate (node:internal/timers:476:21)
      2023-04-09 10:46:53.607 - error: mqtt.0 (946388) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-04-09 10:46:53.611 - error: mqtt.0 (946388) unhandled promise rejection: Error The pattern "'mqtt.0.*" is not a valid ID pattern
      2023-04-09 10:46:53.619 - error: mqtt.0 (946388) ReplyError: Error The pattern "'mqtt.0.*" is not a valid ID pattern
      at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
      at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      2023-04-09 10:46:53.620 - error: mqtt.0 (946388) Error The pattern "'mqtt.0.*" is not a valid ID pattern
      2023-04-09 10:46:54.199 - warn: mqtt.0 (946388) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-04-09 10:46:55.271 - error: host.IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-04-09 10:46:55.272 - error: host.IoBroker Caught by controller[0]: ReplyError: Error The pattern "'mqtt.0.*" is not a valid ID pattern
      2023-04-09 10:46:55.273 - error: host.IoBroker Caught by controller[0]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
      2023-04-09 10:46:55.274 - error: host.IoBroker Caught by controller[0]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      2023-04-09 10:46:55.274 - error: host.IoBroker instance system.adapter.mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-04-09 10:46:55.275 - info: host.IoBroker Restart adapter system.adapter.mqtt.0 because enabled
      2023-04-09 11:00:17.823 - error: mqtt.0 (955755) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-04-09 11:00:17.827 - error: mqtt.0 (955755) unhandled promise rejection: Error The pattern "javascript.*'" is not a valid ID pattern
      2023-04-09 11:00:17.831 - error: mqtt.0 (955755) ReplyError: Error The pattern "javascript.*'" is not a valid ID pattern
      2023-04-09 11:00:17.833 - error: mqtt.0 (955755) Error The pattern "javascript.*'" is not a valid ID pattern
      2023-04-09 11:00:18.381 - warn: mqtt.0 (955755) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-04-09 11:00:19.111 - error: host.IoBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2023-04-09 11:00:19.112 - error: host.IoBroker Caught by controller[0]: ReplyError: Error The pattern "javascript.*'" is not a valid ID pattern
      2023-04-09 11:00:19.112 - error: host.IoBroker Caught by controller[0]: at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
      2023-04-09 11:00:19.113 - error: host.IoBroker Caught by controller[0]: at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      2023-04-09 11:00:19.113 - error: host.IoBroker instance system.adapter.mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2023-04-09 11:00:19.114 - info: host.IoBroker Restart adapter system.adapter.mqtt.0 because enabled
      hab es nun auf mqtt.* geändert
      • der Adapter Linux-control meckert nun über einen Service
      2023-04-09 10:48:42.818 - warn: host.IoBroker-Server States 127.0.0.1:42674 Error from InMemDB: Error: The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-24e36031\x2d735b\x2d4199\x2da17d\x2d58b14117589e.start" is not a valid ID pattern
      2023-04-09 10:48:42.825 - info: trashschedule.0 (947981) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v18.15.0, js-controller: 5.0.1-alpha.0-20230406-4552d569
      2023-04-09 10:48:42.836 - error: linux-control.0 (947081) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-04-09 10:48:42.843 - error: linux-control.0 (947081) unhandled promise rejection: Error The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-0a2debdb\x2df60b\x2d494d\x2d8190\x2d5f1f98fbfef9.restart" is not a valid ID pattern
      2023-04-09 10:48:42.855 - error: linux-control.0 (947081) ReplyError: Error The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-0a2debdb\x2df60b\x2d494d\x2d8190\x2d5f1f98fbfef9.restart" is not a valid ID pattern
      2023-04-09 10:48:42.856 - error: linux-control.0 (947081) Error The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-0a2debdb\x2df60b\x2d494d\x2d8190\x2d5f1f98fbfef9.restart" is not a valid ID pattern
      2023-04-09 10:48:42.915 - error: linux-control.0 (947081) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2023-04-09 10:48:42.917 - error: linux-control.0 (947081) unhandled promise rejection: Error The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-0a2debdb\x2df60b\x2d494d\x2d8190\x2d5f1f98fbfef9.start" is not a valid ID pattern
      2023-04-09 10:48:42.922 - error: linux-control.0 (947081) ReplyError: Error The pattern "linux-control.0.proxmox531.services.systemd-fsck@dev-disk-by\x2duuid-0a2debdb\x2df60b\x2d494d\x2d8190\x2d5f1f98fbfef9.start" is not a valid ID pattern
      hab den vorübergehend nun mal deaktiviert in der Instanz
      und was noch auftrat, direkt nach dem iob start mit v5 war nun bei mir ebenfalls die Log-Größe am rödeln, hat irgendwann aufgehört hochzuzählen und sich dann wieder normalisiert
      Feuersturm foxriver76 2 Replies Last reply Reply Quote 0
      • Feuersturm
        Feuersturm @crunchip last edited by
        @crunchip sagte in Alpha Test js-controller 5.0:
        Das Problem mit der falsch angezeigten Log Größe wurde beim Admin gemeldet https://github.com/ioBroker/ioBroker.admin/issues/1913
        crunchip 1 Reply Last reply Reply Quote 1
        • foxriver76
          foxriver76 Developer @crunchip last edited by
          @crunchip Danke fürs Melden. Die Patterns haben beide jeweils ein ' in sich, das ist formal nicht erlaubt und scheint ein Bug im MQTT Adapter zu sein, bitte dort Issue machen.
          • Feuersturm
            Feuersturm @apollon77 last edited by
            @apollon77 sagte in Alpha Test js-controller 5.0:
            Alpha Update
            Update auf meinem Master Slave System lief wieder ohne Probleme. Bisher keine Auffälligkeiten.
              crunchip Forum Testing Most Active @Feuersturm last edited by
              @feuersturm ich hatte das Problem vorher aber noch gar nicht, erst nach dem Controller upgrade trat es auf, aber ich häng es dort mal mit an
              • foxriver76
                foxriver76 Developer @crunchip last edited by foxriver76
                @crunchip ja neuer Controller validiert die patterns
                  Marty56 @foxriver76 last edited by
                  Besteht mit der Version 5.0 eigentlich die Hoffnung, dass diese "Alias Error Bursts", die mich alle 2-3 Tage heimsuchen, aufhören.
                  Das Error Log zeigt nur einen kleinen Ausschnitt. Es sind alle meine ca. 400 Aliases betroffen.
                  Auswirkung auf die Funktion scheinen diese Fehlermeldung nicht zu haben. Sie nerven nur.
                  2023-04-10 03:48:35.417 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.KEQ0971413.2.ENERGY_COUNTER, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":false,"min":0,"max":838860.7,"unit":"Wh","name":"K1_Waschen_Messen.ENERGY_COUNTER","role":"value.power.consumption"},"native":{"CONTROL":"POWERMETER.ENERGY_COUNTER","DEFAULT":0,"FLAGS":1,"ID":"ENERGY_COUNTER","MAX":838860.7,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"Wh"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089040406,"_id":"hm-rpc.0.KEQ0971413.2.ENERGY_COUNTER","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                  2023-04-10 03:48:35.424 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.OEQ0125847.0.UNREACH, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator.unreach","name":"Deckenlampe im Wohnzimmer:0.UNREACH"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089035775,"_id":"hm-rpc.0.OEQ0125847.0.UNREACH","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                  2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.OEQ0125847.2.STATE, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":true,"write":true,"role":"switch","name":"WZ_Deckenlampe.STATE"},"native":{"CONTROL":"SWITCH.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089035853,"_id":"hm-rpc.0.OEQ0125847.2.STATE","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                  2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.OEQ0125847.0.UNREACH, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":true,"write":false,"role":"indicator.unreach","name":"Deckenlampe im Wohnzimmer:0.UNREACH"},"native":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089035775,"_id":"hm-rpc.0.OEQ0125847.0.UNREACH","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                  2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.LEQ0413828.1.LEVEL, sourceObj={"type":"state","common":{"def":0,"type":"number","read":true,"write":true,"min":0,"max":100,"unit":"%","role":"level.blind","workingID":"WORKING","name":"K3_Fensteroeffner.LEVEL"},"native":{"CONTROL":"BLIND.LEVEL","DEFAULT":0,"FLAGS":1,"ID":"LEVEL","MAX":1,"MIN":0,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"FLOAT","UNIT":"100%"},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089036364,"_id":"hm-rpc.0.LEQ0413828.1.LEVEL","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                  2023-04-10 03:48:35.425 - error: web.0 (900) Alias subscription error. Please check your alias definitions: sourceId=hm-rpc.0.LEQ0413828.1.STOP, sourceObj={"type":"state","common":{"def":false,"type":"boolean","read":false,"write":true,"role":"button.stop","name":"K3_Fensteroeffner.STOP"},"native":{"CONTROL":"BLIND.STOP","DEFAULT":false,"FLAGS":1,"ID":"STOP","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":1,"TYPE":"ACTION","UNIT":""},"from":"system.adapter.hm-rega.0","user":"system.user.admin","ts":1671089036367,"_id":"hm-rpc.0.LEQ0413828.1.STOP","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                    @marty56 reine Vermutung von mir, da ich dieses Problem auch hatte.
                    Es wurden immer unterschiedliche alias angemeckert, nicht immer die selben,
                    daher die Frage, wie hast du die alias angelegt, per alias manager oder mit dem device Adapter? Letzterer hat sowieso ein Problem in der Version 1.1.2
                    https://github.com/ioBroker/ioBroker.devices/issues/217
                    zu Beginn hatte ich auch alias mit dem device adapter angelegt, aber dann zum alias manager gewechselt und somit auch alle bestehenden alias, die mit dem device adapter erstellt wurden, gelöscht und neu mit dem alias manager erstellt.
                    Seit dem ist Ruhe.
                    Vllt hat es auch Einfluss, wenn alias mit unterschiedlichen Adapter Versionen angelegt wurden.
                    Kann Zufall sein oder ein möglicher Ansatz.
                      Marty56 @crunchip last edited by
                      @crunchip Ich habe alle Aliases mit einem eigenenJavascript angelegt.
                      • foxriver76
                        foxriver76 Developer @Marty56 last edited by
                        @marty56 Heißt das, du hast die 5.0 Alpha laufen und bekommst die Meldungen weiterhin?
                        • wendy2702
                          gerade den Master auf 5.0.1 angehoben:
                          Web adapter crasht wegen Trashschedule fehler. Ich vermute das "ü" als Übeltäter wobei ich auch ein "ä" verwende was nicht angemeckert wird:
                          2023-04-11 12:21:46.870  - error: web.0 (8220) uncaught exception: The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
                          2023-04-11 12:21:46.873  - error: web.0 (8220) Error: The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
                              at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/tools.js:2161:15)
                              at pattern2RegEx (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:44)
                              at SocketCommands.subscribe (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:267:13)
                              at SocketCommands._subscribeStates (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:489:26)
                              at commands.subscribe (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1356:25)
                              at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js:1556:43)
                              at Socket.emit (node:events:513:28)
                              at /opt/iobroker/node_modules/socket.io/lib/socket.js:531:14
                              at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
                          2023-04-11 12:21:46.874  - error: web.0 (8220) The pattern "trashschedule.0.type.Restmüll.daysleft" is not a valid ID pattern
                          Linux Control läuft nicht mehr zum steuern meiner Wandtablets
                          mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker.current.log |grep linux
                          2023-04-11 12:30:02.872  - info: host.iobroker instance system.adapter.linux-control.0 started with pid 8596
                          2023-04-11 12:30:07.502  - warn: linux-control.0 (8596) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                          2023-04-11 12:30:07.503  - warn: linux-control.0 (8596) This object will not be created in future versions. Please report this to the developer.
                          2023-04-11 12:30:07.544  - info: linux-control.0 (8596) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.linux-control, node: v18.14.2, js-controller: 5.0.1-alpha.0-20230406-4552d569
                          2023-04-11 12:30:07.872  - warn: linux-control.0 (8596) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
                          2023-04-11 12:30:07.893  - warn: linux-control.0 (8596) This object will not be created in future versions. Please report this to the developer.
                          2023-04-11 12:30:07.990  - info: linux-control.0 (8596) getting data from VIS-OG (192.168.178.215:22, Adapter start)
                          2023-04-11 12:30:08.000  - info: linux-control.0 (8596) getting data from VIS-EG (192.168.178.216:22, Adapter start)
                          2023-04-11 12:30:24.355  - warn: host.iobroker-Server States 127.0.0.1:33208 Error from InMemDB: Error: The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
                          2023-04-11 12:30:24.359  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2023-04-11 12:30:24.360  - error: linux-control.0 (8596) unhandled promise rejection: Error The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
                          2023-04-11 12:30:24.361  - error: linux-control.0 (8596) ReplyError: Error The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
                          2023-04-11 12:30:24.361  - error: linux-control.0 (8596) Error The pattern "linux-control.0.VIS-OG.services.●.restart" is not a valid ID pattern
                          2023-04-11 12:30:24.380  - info: linux-control.0 (8596) cleaned everything up...
                          2023-04-11 12:30:24.381  - info: linux-control.0 (8596) terminating
                          2023-04-11 12:30:24.381  - warn: linux-control.0 (8596) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2023-04-11 12:30:24.385  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2023-04-11 12:30:24.386  - error: linux-control.0 (8596) unhandled promise rejection: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                          2023-04-11 12:30:24.387  - error: linux-control.0 (8596) Error: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                          2023-04-11 12:30:24.387  - error: linux-control.0 (8596) The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                          2023-04-11 12:30:24.401  - warn: host.iobroker-Server States 127.0.0.1:33208 Error from InMemDB: Error: The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                          2023-04-11 12:30:24.404  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2023-04-11 12:30:24.404  - error: linux-control.0 (8596) unhandled promise rejection: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                          2023-04-11 12:30:24.405  - error: linux-control.0 (8596) ReplyError: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                          2023-04-11 12:30:24.405  - error: linux-control.0 (8596) Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                          2023-04-11 12:30:24.736  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2023-04-11 12:30:24.737  - error: linux-control.0 (8596) unhandled promise rejection: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                          2023-04-11 12:30:24.737  - error: linux-control.0 (8596) Error: The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                          2023-04-11 12:30:24.737  - error: linux-control.0 (8596) The pattern "io.linux-control.0.VIS-OG.services.●.start" is not a valid ID pattern
                          2023-04-11 12:30:24.783  - warn: host.iobroker-Server States 127.0.0.1:33208 Error from InMemDB: Error: The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                          2023-04-11 12:30:24.792  - error: linux-control.0 (8596) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2023-04-11 12:30:24.792  - error: linux-control.0 (8596) unhandled promise rejection: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                          2023-04-11 12:30:24.793  - error: linux-control.0 (8596) ReplyError: Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                          2023-04-11 12:30:24.793  - error: linux-control.0 (8596) Error The pattern "linux-control.0.VIS-OG.services.●.stop" is not a valid ID pattern
                          2023-04-11 12:30:24.888  - info: linux-control.0 (8596) terminating
                          2023-04-11 12:30:24.900  - warn: linux-control.0 (8596) get state error: Connection is closed.
                          2023-04-11 12:30:24.907  - error: linux-control.0 (8596) [servicesInfo] VIS-OG (192.168.178.215:22): error: DB closed, stack: Error: DB closed
                          2023-04-11 12:30:25.038  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): datapoint-id: VIS_OG_ScreenOff, description: ViS-OG_ScreenOff
                          2023-04-11 12:30:25.039  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): error: DB closed, stack: Error: DB closed
                          2023-04-11 12:30:25.041  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): datapoint-id: VIS_OG_ScreenOn, description: VIS-OG_ScreenOn
                          2023-04-11 12:30:25.042  - error: linux-control.0 (8596) [userCommandExecute] VIS-OG (192.168.178.215:22): error: DB closed, stack: Error: DB closed
                          2023-04-11 12:30:25.494  - error: host.iobroker instance system.adapter.linux-control.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          2023-04-11 12:30:25.502  - info: host.iobroker Restart adapter system.adapter.linux-control.0 because enabled
                          Nehme an es liegt an dem "dicken" Punkt im Namen und ist ein Adapter issue, oder?
                          Enigma 2 Adapter läuft nicht mehr:
                          mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker.current.log |grep enigma
                          2023-04-11 12:36:12.099  - info: host.iobroker instance system.adapter.enigma2.0 started with pid 8762
                          2023-04-11 12:36:12.802  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
                          2023-04-11 12:36:12.802  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
                          2023-04-11 12:36:12.802  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
                          2023-04-11 12:36:12.805  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
                          2023-04-11 12:36:12.805  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
                          2023-04-11 12:36:12.805  - error: host.iobroker instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2023-04-11 12:36:12.812  - info: host.iobroker Rebuild for adapter system.adapter.enigma2.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                          2023-04-11 12:36:28.124  - info: host.iobroker "system.adapter.enigma2.0" disabled
                          2023-04-11 12:36:34.443  - info: host.iobroker "system.adapter.enigma2.0" enabled
                          2023-04-11 12:36:34.613  - info: host.iobroker instance system.adapter.enigma2.0 started with pid 8775
                          2023-04-11 12:36:36.424  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
                          2023-04-11 12:36:36.425  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
                          2023-04-11 12:36:36.425  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
                          2023-04-11 12:36:36.426  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
                          2023-04-11 12:36:36.426  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
                          2023-04-11 12:36:36.426  - error: host.iobroker instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2023-04-11 12:36:36.426  - info: host.iobroker Rebuild for adapter system.adapter.enigma2.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                          EDIT: Ergänzung zum Enigma2 Adapter:
                          2023-04-11 12:48:29.329  - info: trashschedule.0 (10113) [ical] configurured ical preview is 34 days - increase this value to find more events in the future
                          2023-04-11 12:48:46.571  - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
                          2023-04-11 12:48:46.776  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
                          2023-04-11 12:48:47.781  - info: host.iobroker iobroker npm-rebuild: exit 0
                          2023-04-11 12:48:47.972  - info: host.iobroker instance system.adapter.enigma2.0 started with pid 10173
                          2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1078
                          2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]:   throw err;
                          2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]:   ^
                          2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
                          2023-04-11 12:48:49.184  - error: host.iobroker Caught by controller[0]: Require stack:
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.enigma2/main.js
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:920:27)
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1141:19)
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js:46:25)
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1254:14)
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1308:10)
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1117:32)
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:958:12)
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1141:19) {
                          2023-04-11 12:48:49.185  - error: host.iobroker Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:   requireStack: [
                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/lib/utils.js',
                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.enigma2/main.js'
                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]:   ]
                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]: }
                          2023-04-11 12:48:49.186  - error: host.iobroker Caught by controller[0]: Node.js v18.14.2
                          2023-04-11 12:48:49.186  - error: host.iobroker instance system.adapter.enigma2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2023-04-11 12:48:49.186  - info: host.iobroker Adapter system.adapter.enigma2.0 needs rebuild and will be restarted afterwards.
                          2023-04-11 12:48:49.186  - info: host.iobroker system.adapter.enigma2.0 will be rebuilt
                          2023-04-11 12:48:49.186  - warn: host.iobroker adapter "enigma2" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                          2023-04-11 12:48:49.187  - info: host.iobroker iobroker rebuild
                          2023-04-11 12:48:52.129  - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
                          • foxriver76
                            foxriver76 Developer @wendy2702 last edited by
                            @wendy2702 Legt Trashschedule wirklich States mit Umlauten an? Sollte eigentlich nicht möglich sein und entsprechend sollte der Adapter auch den subscribe entsprechend anpassen.
                            Die anderen beiden sind sicher Adapter Issues.
                            • wendy2702
                              wendy2702 @foxriver76 last edited by wendy2702
                              @foxriver76 Ja, legt der Adapter an:
                              Zum Enigma2 Adapter: habe den zum testen mal komplett gelöscht, also Instanz und Adapter. Jetzt kann ich ihn nicht mehr installieren:
                              2023-04-11 12:54:08.072  - info: host.iobroker iobroker add enigma2 auto --host iobroker --debug
                              2023-04-11 12:54:11.281  - error: host.iobroker iobroker host.iobroker Unknown packetName enigma2. Please install packages from outside the repository using npm!
                              2023-04-11 12:54:12.335  - info: host.iobroker iobroker exit 12
                              EDIT: OK, der hing wohl noch im Cache in der Anzeige der verfügbaren Adapter.
                              • foxriver76
                                @wendy2702 enigma2 ist nicht im offiziellen Repo
                                • wendy2702
                                  @foxriver76 Ja, ist mir dann auch wieder auf/eingefallen.
                                  Komplette neu installation leider auch erfolglos. Da, der Adapter wenn ich das richtig sehe nicht mehr gepflegt wird, es hier doch einige User gibt sollte man eventuell einen Hinweis geben oder bin ich der einzige bei dem er mit Controller V5 nicht mehr läuft ?
                                    Thomas Braun Most Active @wendy2702 last edited by
                                    @wendy2702
                                    Arbeit am Adapter enigma2 abgebrochen. Projekt Übernehmer gesucht!
                                    Sieht sehr eindeutig nach verwaist aus.
                                    • foxriver76
                                      @wendy2702 Wird bei keinem laufen, lässt sich relativ einfach fixen. Habe gesehen dass nicht gepflegt, wäre gut wenn der damalige Entwickler den Adapter wie vorgeschlagen in community-adapters übergibt.
                                      Ok, Umlaute sind tatsächlich nicht verboten, entsprechend sollte Pattern auch nicht meckern bei einem richtigen ü. Allerdings scheint der Adapter dein ü als ü zu speichern, evtl Encoding-Problem beim Speichern der Daten vom Frontend. Damit auch Adapter Fehler.
                                      Enigma 2 kann ich vorbereiten, allerdings muss der Dev mergen.
                                      • wendy2702
                                        @foxriver76 OK.
                                        Und was genau heisst das jetzt für den Trashschedule Adapter?
                                        foxriver76 3 Replies Last reply Reply Quote 0
                                        • foxriver76
                                          @wendy2702 Issue anlegen bitte
                                          • foxriver76
                                            @wendy2702 Probier gerne mal Enigma von folgender URL: https://github.com/foxriver76/ioBroker.enigma2
                                            PR ist gestellt: https://github.com/Matten-Matten/ioBroker.enigma2/pull/63
                                            140
                                            20676
