    4. JavaScript
    5. E3DC Hauskraftwerk steuern
      ArnoD @jh537 last edited by
      @jh537
      Kannst du bitte mal die Version 1.2.9 von Github testen.
      jh537 1 Reply Last reply Reply Quote 1
      • jh537
        jh537 @ArnoD last edited by
        @arnod Danke für fix 🙂
        Leider lädt er trotz unterer Ladekor. 1180 W mit den errechneten 400 W. Aber er pendelt nicht mehr gegen 0.
        javascript.0
        	2023-04-10 16:34:36.014	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 452 M_Power = 452 ====-"}##
        javascript.0
        	2023-04-10 16:34:30.023	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 452 M_Power = 452 ====-"}##
        javascript.0
        	2023-04-10 16:34:24.013	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 452 M_Power = 452 ====-"}##
        javascript.0
        	2023-04-10 16:34:18.017	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 452 M_Power = 452 ====-"}##
        javascript.0
        	2023-04-10 16:34:12.015	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 451 M_Power = 452 ====-"}##
        javascript.0
        	2023-04-10 16:34:12.007	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 3 M_Power:452 = Math.round(((Ladeende2_Proz:85 - Batterie_SOC_Proz:78)* Speichergroesse_kWh:12 * 10 * 3600)/(tSommerladeende_milisek:1681143940597 - Zeit_aktuell_milisek:1681137252001)) ====- "}##
        javascript.0
        	2023-04-10 16:34:09.018	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 450 M_Power = 450 ====-"}##
        javascript.0
        	2023-04-10 16:34:03.014	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 450 M_Power = 450 ====-"}##
        javascript.0
        	2023-04-10 16:33:57.014	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 450 M_Power = 450 ====-"}##
        javascript.0
        	2023-04-10 16:33:51.026	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 450 M_Power = 450 ====-"}##
        javascript.0
        	2023-04-10 16:33:45.015	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 450 M_Power = 450 ====-"}##
        javascript.0
        	2023-04-10 16:33:39.019	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 449 M_Power = 450 ====-"}##
        javascript.0
        	2023-04-10 16:33:39.012	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 3 M_Power:450 = Math.round(((Ladeende2_Proz:85 - Batterie_SOC_Proz:78)* Speichergroesse_kWh:12 * 10 * 3600)/(tSommerladeende_milisek:1681143940597 - Zeit_aktuell_milisek:1681137219006)) ====- "}##
        javascript.0
        	2023-04-10 16:33:33.016	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 448 M_Power = 448 ====-"}##
        javascript.0
        	2023-04-10 16:33:27.014	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 448 M_Power = 448 ====-"}##
        javascript.0
        	2023-04-10 16:33:21.016	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 448 M_Power = 448 ====-"}##
        javascript.0
        	2023-04-10 16:33:15.018	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 448 M_Power = 448 ====-"}##
        javascript.0
        	2023-04-10 16:33:09.017	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 447 M_Power = 448 ====-"}##
        javascript.0
        	2023-04-10 16:33:09.009	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 3 M_Power:448 = Math.round(((Ladeende2_Proz:85 - Batterie_SOC_Proz:78)* Speichergroesse_kWh:12 * 10 * 3600)/(tSommerladeende_milisek:1681143940597 - Zeit_aktuell_milisek:1681137189000)) ====- "}##
        javascript.0
        	2023-04-10 16:33:08.397	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== User Parameter UntererLadekorridor_2 wurde in 1180 geändert ====-"}##
        javascript.0
        	2023-04-10 16:33:06.031	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 446 M_Power = 446 ====-"}##
        javascript.0
        	2023-04-10 16:33:00.033	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 446 M_Power = 446 ====-"}##
        javascript.0
        	2023-04-10 16:32:54.017	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 446 M_Power = 446 ====-"}##
        javascript.0
        	2023-04-10 16:32:48.015	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 446 M_Power = 446 ====-"}##
        javascript.0
        	2023-04-10 16:32:42.017	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 446 M_Power = 446 ====-"}##
        javascript.0
        	2023-04-10 16:32:36.109	warn	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":"-==== Batterie laden. Schritt = 3 LadenStoppen = false Set_Power_Mode = 3 laden Set_Power_Value_W = 446 M_Power = 446 ====-"}##
        javascript.0
        	2023-04-10 16:32:36.059	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 3 M_Power:446 = Math.round(((Ladeende2_Proz:85 - Batterie_SOC_Proz:78)* Speichergroesse_kWh:12 * 10 * 3600)/(tSommerladeende_milisek:1681143940597 - Zeit_aktuell_milisek:1681137156002)) ====- "}##
          @jh537
          Im Schritt 2 sollte es richtig funktionieren, habe es jetzt im Schritt 3 auch angepasst.
          Bitte nochmal die Version 1.2.9 testen.
          jh537 2 Replies Last reply Reply Quote 1
            as @ArnoD last edited by
            @arnod ?TAG_EMS_REQ_POWER_PV heißt dieses Register genau so
            bei mir werden viel mehr angezeigt dieser jedoch nicht - es gibt nur einen ähnlichen TAG_EMS_REQ_POWER_PV_AC........
            führt das dann zu fehlenden Werten o Fehlfunktion
            wie bekomme ich die Daten des E3DC Zusatzwechselrichter mit integriert, u das diese auch in die Kurven kommen aktuell zeigt er mir da keine Daten an
            Vielen Dank
            • jh537
              @arnod Moin Arno, habe die 1.29 nochmal neu kopiert und jetzt habe ich paar Fehler:
              javascript.0
              	2023-04-11 07:11:51.009	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:541 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189911003)) ====- "}##
              javascript.0
              	2023-04-11 07:11:50.415	info	State value to set for "0_userdata.0.Charge_Control.Allgemein.Autonomiezeit" has to be type "number" but received type "string"
              javascript.0
              	2023-04-11 07:11:50.384	warn	at Object.<anonymous> (script.js.common.Charge_Control:1865:15)
              javascript.0
              	2023-04-11 07:11:50.384	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:81:16
              javascript.0
              	2023-04-11 07:11:50.384	warn	at new Promise (<anonymous>)
              javascript.0
              	2023-04-11 07:11:50.384	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:82:16
              javascript.0
              	2023-04-11 07:11:50.384	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
              javascript.0
              	2023-04-11 07:11:50.383	warn	You are assigning a string to the state "0_userdata.0.Charge_Control.Allgemein.Autonomiezeit" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
              javascript.0
              	2023-04-11 07:11:48.014	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:48.010	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:541 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189908000)) ====- "}##
              javascript.0
              	2023-04-11 07:11:45.012	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:45.008	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:541 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189905002)) ====- "}##
              javascript.0
              	2023-04-11 07:11:42.010	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:42.007	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:541 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189902001)) ====- "}##
              javascript.0
              	2023-04-11 07:11:40.366	info	State value to set for "0_userdata.0.Charge_Control.Allgemein.Autonomiezeit" has to be type "number" but received type "string"
              javascript.0
              	2023-04-11 07:11:40.364	warn	at Object.<anonymous> (script.js.common.Charge_Control:1865:15)
              javascript.0
              	2023-04-11 07:11:40.364	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:81:16
              javascript.0
              	2023-04-11 07:11:40.364	warn	at new Promise (<anonymous>)
              javascript.0
              	2023-04-11 07:11:40.363	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:82:16
              javascript.0
              	2023-04-11 07:11:40.363	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
              javascript.0
              	2023-04-11 07:11:40.363	warn	You are assigning a string to the state "0_userdata.0.Charge_Control.Allgemein.Autonomiezeit" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
              javascript.0
              	2023-04-11 07:11:39.012	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:39.009	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:540 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189899002)) ====- "}##
              javascript.0
              	2023-04-11 07:11:36.011	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:36.008	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:540 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189896001)) ====- "}##
              javascript.0
              	2023-04-11 07:11:35.373	info	State value to set for "0_userdata.0.Charge_Control.Allgemein.Autonomiezeit" has to be type "number" but received type "string"
              javascript.0
              	2023-04-11 07:11:35.369	warn	at Object.<anonymous> (script.js.common.Charge_Control:1865:15)
              javascript.0
              	2023-04-11 07:11:35.369	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:81:16
              javascript.0
              	2023-04-11 07:11:35.369	warn	at new Promise (<anonymous>)
              javascript.0
              	2023-04-11 07:11:35.368	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:82:16
              javascript.0
              	2023-04-11 07:11:35.368	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
              javascript.0
              	2023-04-11 07:11:35.366	warn	You are assigning a string to the state "0_userdata.0.Charge_Control.Allgemein.Autonomiezeit" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
              javascript.0
              	2023-04-11 07:11:33.011	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:33.008	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:540 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189893001)) ====- "}##
              javascript.0
              	2023-04-11 07:11:30.011	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:30.008	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:540 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189890002)) ====- "}##
              javascript.0
              	2023-04-11 07:11:27.011	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:27.008	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:540 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189887001)) ====- "}##
              javascript.0
              	2023-04-11 07:11:24.011	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:24.007	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:540 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189884001)) ====- "}##
              javascript.0
              	2023-04-11 07:11:21.011	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:21.008	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:540 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189881002)) ====- "}##
              javascript.0
              	2023-04-11 07:11:18.056	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:18.008	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== 2 M_Power:540 = Math.round(((Ladeende_Proz:75 - Batterie_SOC_Proz:39)*Speichergroesse_kWh:12*10*3600) / (tRegelende_milisek:1681218675037 - Zeit_aktuell_milisek:1681189878001)) ====- "}##
              javascript.0
              	2023-04-11 07:11:18.008	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Nach Regelbeginn vor Regelende ====- "}##
              javascript.0
              	2023-04-11 07:11:15.057	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Regelung E3DC überlassen. Schritt = 1 SET_POWER_MODE = 0 normal ====- "}##
              javascript.0
              	2023-04-11 07:11:15.054	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Laderegelung wird gestoppt ====- "}##
              javascript.0
              	2023-04-11 07:11:15.051	info	script.js.common.Charge_Control: ##{"from":"Charge-Control", "message":" -==== Vor Regelbeginn ====- "}##
              javascript.0
              	2023-04-11 07:11:15.007	warn	script.js.common.Charge_Control: Ladesteuerung: Notstrom_SOC_erreicht= false NotstromVerwenden= false Batterie_SOC_Proz= 39 Notstrom_SOC_Proz= 10
              • jh537
                jh537 @ArnoD last edited by jh537
                scheint doch zu laufen, ich beobachte weiter...
                jh537 1 Reply Last reply Reply Quote 0
                • jh537
                  jh537 @jh537 last edited by
                  @ArnoD Es sieht gut aus, keine Pendelei mehr. Mich hat der Sicherheitspuffer von 500 W etwas irritiert. Danke
                    ArnoD @as last edited by
                    @as sagte in E3DC Hauskraftwerk steuern:
                    Ist der erste Eintrag in der Liste und heißt genau so.
                    ohne die PV-Leistung macht das Script keinen Sinn und führt auch zu einer Fehlermeldung.
                    Vielen Dank
                    Welche Kurven meinst du ?
                    Ein zweiter Wechselrichter wird bereits im Script berücksichtigt.
                      ArnoD @ArnoD last edited by
                      Neue Version Charge-Control auf GitHub hochgeladen.
                      Version: 1.2.9
                      Änderungen:
                      • Neuer User Parameter 10_Systemwirkungsgrad.
                        Max. Systemwirkungsgrad inkl. Batterie in % aus den technischen Daten E3DC (beim S10E 88%).
                        Wird für die Berechnung der Batteriekapazität in kWh zur Anzeige in VIS verwendet.
                        Neue Objekt ID: 0_userdata.0.Charge_Control.Allgemein.Batteriekapazität_kWh
                      • Berechnung Autonomiezeit für Anzeige in VIS integriert.
                        Neue Objekt ID: 0_userdata.0.Charge_Control.Allgemein.Autonomiezeit
                      • Fehler behoben, dass der unterer Ladekorridor ignoriert wurde.
                      Der Modbus Adapter wird nun nicht mehr benötigt und die Script Sammlung Modbus Adapter somit auch nicht mehr.
                      Einziger Grund für den Modbus Adapter ist, wenn jemand die Firmware Version noch anzeigen will. Das geht aktuell nicht über den E3DC-RSCP Adapter.
                      bluebean A 2 Replies Last reply Reply Quote 0
                      • bluebean
                        bluebean @ArnoD last edited by bluebean
                        @arnod
                        Du definierst in 1.2.9 einen Timer4, der aber im Script nicht weiter benutzt wird. Plan für etwas, was kommt, oder schlicht überflüssig?
                        Ich frage deshalb, weil ich Dein Script mit ein paar Ergänzungen anreichere, u.a. einem Timer4 (das würde ich dann rechtzeitig auf einen anderen Timer legen, wenn Du den 4er nutzen wirst).
                          ArnoD @bluebean last edited by
                          @bluebean
                          Kannst du verwenden, ich werden diesen bei mir löschen.
                            @arnod diesen Eintrag gibt es komischerweise gar nicht nur mit dem ac-all
                            hab jz mal einen Eintrag von den Wallboxen umbenannt- ab das wirklich dann auch so ausgelesen wird kann ich noch nicht sagen. Wollt den Adapter nicht vollständig entfernen müssen.
                            es fehlen die AC L1,2,3 Spannungen -hab zwar in den FlottLink meine IP eingetragen jedoch kommt keine Anzeige
                              Annnndy last edited by
                              ihr kennt euch so super aus da würde es mich freuen wenn ihr mir kurz weiterhelfen könnt.
                              Bei mir scheitert es och an der Modbus datenabfrage
                              https://forum.iobroker.net/topic/63655/e3dc-datenabfrage-mit-modbus
                              Der Registereintrag des Netzbezug wird nahezu immer falsch ausgelesen. Ich bekomme dort Werte im 6xxxx stelligen Bereich geliefert.
                              gefühlt ist der Wert dann falsch wenn eingespeist wird.... also wenn er negativ sein sollte.
                              Vielen Dank im Voraus
                                ArnoD @as last edited by ArnoD
                                @as
                                Denn muss es geben.
                                Kannst du mal ein Bild schicken, wie es bei dir aussieht.
                                Ist das bei dir alles angewählt ?
                                  ArnoD @Annnndy last edited by ArnoD
                                  @annnndy
                                  Was hast du für ein Hauskraftwerk?
                                  Ist alles richtig beim Modbus Adapter eingetragen?
                                  Hier würden Bilder von deinen Einstellungen helfen.
                                    Annnndy @ArnoD last edited by
                                    @arnod Hallo,
                                    ich habe ein E3DC S10 E.
                                    Ich habe bei den Register -2 machen müssen um die richtigen zu bekommen. Allerdings habe ich die Probleme mit den negativen Werten.
                                    Habe heute auch eine History migeschrieben, die zeigt das gleiche Problem.
                                    Teilweise stimmen die Werte und dann wieder nicht.
                                    Kann es sein das es mit den Typ Einstellungen zu tun hat?
                                      @annnndy
                                      mach mal ein Screenshot von den Modbus Allgemein Einstellungen und dann von den Holding-Register.
                                      Dann kann man das vergleichen.
                                        Annnndy @ArnoD last edited by Annnndy
                                        @arnod
                                        ok.
                                        die Rolle habe ich gerade Versuchsweise von "Value" auf "State" geändert
                                          @annnndy sagte in E3DC Hauskraftwerk steuern:
                                          Bei mir sieht das so aus:
                                            @annnndy
                                            Aktiviere als erstes Aliases benutzen und importiere dann mal die Holdingregister von meiner Github Seite :
                                            Modbus_E3DC_Import_V1.90_2022-01-28.tsv
                                            3439
                                            1577107
