    4. Test Adapter EnOcean v0.8.x
      TimoWald @Jey Cee last edited by
      @jey-cee hallo, ich bekomme meinen USB300 auch nicht grün. Woran liegt es bei mir?
      Version 0.8.5 ist installiert.
      2023-03-28 17:15:10.250 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
      2023-03-28 17:15:10.256 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-03-28 17:15:10.258 - info: host.raspberrypi hostname: raspberrypi, node: v16.19.1
      2023-03-28 17:15:10.259 - info: host.raspberrypi ip addresses: 192.168.9.166 2003:e1:ef09:2800:7e02:d79a:15c2:6ccb fe80::66bf:f25a:da47:f65f
      2023-03-28 17:15:10.669 - info: host.raspberrypi connected to Objects and States
      2023-03-28 17:15:10.697 - info: host.raspberrypi Node.js version has changed from unknown to 16.19.1
      2023-03-28 17:15:10.768 - info: host.raspberrypi added notifications configuration of host
      2023-03-28 17:15:11.300 - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2023-03-28 17:15:11.334 - info: host.raspberrypi 3 instances found
      2023-03-28 17:15:11.344 - info: host.raspberrypi starting 3 instances
      2023-03-28 17:15:11.411 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 6846
      2023-03-28 17:15:13.842 - info: admin.0 (6846) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:15:13.906 - info: admin.0 (6846) requesting all states
      2023-03-28 17:15:13.907 - info: admin.0 (6846) requesting all objects
      2023-03-28 17:15:14.023 - info: admin.0 (6846) received all objects
      2023-03-28 17:15:14.292 - info: admin.0 (6846) http server listening on port 8081
      2023-03-28 17:15:14.292 - info: admin.0 (6846) Use link "http://localhost:8081" to configure.
      2023-03-28 17:15:14.301 - info: admin.0 (6846) socket.io server listening on port 8081
      2023-03-28 17:15:14.384 - warn: admin.0 (6846) Repository cannot be read: Active repo - stable
      2023-03-28 17:15:14.386 - warn: admin.0 (6846) Active repository "stable" cannot be read
      2023-03-28 17:15:15.379 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 6873
      2023-03-28 17:15:17.203 - info: discovery.0 (6873) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:15:19.400 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 6888
      2023-03-28 17:15:21.335 - info: backitup.0 (6888) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:16:04.837 - info: backitup.0 (6888) [iobroker] backup was activated at 02:40 every 1 day(s)
      2023-03-28 17:23:07.582 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:23:07.693 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-03-28 17:26:04.944 - info: host.raspberrypi iobroker url https://github.com/Jey-Cee/ioBroker.enocean.git --host raspberrypi --debug
      2023-03-28 17:26:07.469 - info: host.raspberrypi iobroker install Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a
      2023-03-28 17:26:08.464 - info: host.raspberrypi iobroker NPM version: 8.19.3
      2023-03-28 17:26:08.467 - info: host.raspberrypi iobroker Installing Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a... (System call)
      2023-03-28 17:28:12.153 - info: host.raspberrypi iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/Jey-Cee/ioBroker.enocean.git
      2023-03-28 17:29:40.588 - info: host.raspberrypi iobroker
      2023-03-28 17:29:40.590 - info: host.raspberrypi iobroker added 21 packages in 4m
      2023-03-28 17:29:40.593 - info: host.raspberrypi iobroker 48 packages are looking for funding
      2023-03-28 17:29:40.597 - info: host.raspberrypi iobroker run `npm fund` for details
      2023-03-28 17:29:40.700 - info: host.raspberrypi iobroker upload [6] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/admin.d.ts admin.d.ts video/mp2t
      2023-03-28 17:30:06.380 - info: host.raspberrypi iobroker upload [5] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/components.js components.js application/javascript
      2023-03-28 17:30:07.708 - info: host.raspberrypi iobroker upload [4] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/enocean.png enocean.png image/png
      2023-03-28 17:30:07.719 - info: host.raspberrypi iobroker upload [3] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/github.js github.js application/javascript
      2023-03-28 17:30:07.733 - info: host.raspberrypi iobroker upload [2] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/index_m.html index_m.html text/html
      2023-03-28 17:30:07.745 - info: host.raspberrypi iobroker upload [1] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/style.css style.css text/css
      2023-03-28 17:30:07.755 - info: host.raspberrypi iobroker upload [0] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/words.js words.js application/javascript
      2023-03-28 17:30:08.822 - info: host.raspberrypi iobroker exit 0
      2023-03-28 17:32:31.388 - info: host.raspberrypi iobroker add enocean auto --host raspberrypi --debug
      2023-03-28 17:32:34.135 - info: host.raspberrypi iobroker host.raspberrypi create instance enocean
      2023-03-28 17:32:34.152 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.alive created
      2023-03-28 17:32:34.163 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.connected created
      2023-03-28 17:32:34.172 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.compactMode created
      2023-03-28 17:32:34.181 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.cpu created
      2023-03-28 17:32:34.189 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.cputime created
      2023-03-28 17:32:34.196 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.memHeapUsed created
      2023-03-28 17:32:34.204 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.memHeapTotal created
      2023-03-28 17:32:34.212 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.memRss created
      2023-03-28 17:32:34.220 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.uptime created
      2023-03-28 17:32:34.228 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.inputCount created
      2023-03-28 17:32:34.235 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.outputCount created
      2023-03-28 17:32:34.245 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.eventLoopLag created
      2023-03-28 17:32:34.252 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.sigKill created
      2023-03-28 17:32:34.264 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.logLevel created
      2023-03-28 17:32:34.270 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.info created
      2023-03-28 17:32:34.276 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.info.connection created
      2023-03-28 17:32:34.282 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway created
      2023-03-28 17:32:34.288 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway.teachin created
      2023-03-28 17:32:34.294 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway.lastID created
      2023-03-28 17:32:34.300 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway.repeater created
      2023-03-28 17:32:34.307 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway.repeater.mode created
      2023-03-28 17:32:34.312 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway.repeater.level created
      2023-03-28 17:32:34.318 - info: host.raspberrypi iobroker host.raspberrypi Set default value of enocean.0.info.connection: false
      2023-03-28 17:32:34.328 - info: host.raspberrypi iobroker host.raspberrypi Set default value of enocean.0.gateway.teachin: false
      2023-03-28 17:32:34.344 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0 created
      2023-03-28 17:32:35.372 - info: host.raspberrypi iobroker exit 0
      2023-03-28 17:32:36.844 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:32:37.379 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7145
      2023-03-28 17:32:39.229 - info: enocean.0 (7145) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:33:25.115 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
      2023-03-28 17:33:25.126 - info: enocean.0 (7145) Got terminate signal TERMINATE_YOURSELF
      2023-03-28 17:33:25.131 - info: enocean.0 (7145) cleaned everything up...
      2023-03-28 17:33:25.134 - info: enocean.0 (7145) terminating
      2023-03-28 17:33:25.137 - info: enocean.0 (7145) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-03-28 17:33:25.162 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
      2023-03-28 17:33:25.725 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-03-28 17:33:28.191 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7161
      2023-03-28 17:33:30.013 - info: enocean.0 (7161) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:33:33.615 - info: admin.0 (6846) <== Disconnect system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:33:40.765 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:33:40.852 - info: enocean.0 (7161) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
      2023-03-28 17:33:46.872 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
      2023-03-28 17:33:46.877 - info: enocean.0 (7161) Got terminate signal TERMINATE_YOURSELF
      2023-03-28 17:33:46.880 - info: enocean.0 (7161) cleaned everything up...
      2023-03-28 17:33:46.881 - info: enocean.0 (7161) terminating
      2023-03-28 17:33:46.883 - info: enocean.0 (7161) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-03-28 17:33:46.917 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
      2023-03-28 17:33:47.424 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-03-28 17:33:49.942 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7177
      2023-03-28 17:33:51.721 - info: enocean.0 (7177) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:33:53.539 - error: enocean.0 (7177) Timeout for response: Get version information
      2023-03-28 17:33:55.068 - error: enocean.0 (7177) Timeout for response: Get repeater mode and level
      2023-03-28 17:33:56.575 - error: enocean.0 (7177) Timeout for response: Get frequency
      2023-03-28 17:33:58.076 - error: enocean.0 (7177) Timeout for response: Get base ID
      2023-03-28 17:33:59.646 - error: enocean.0 (7177) Timeout for response: Read learnd devices
      2023-03-28 17:33:59.652 - info: enocean.0 (7177) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
      2023-03-28 17:34:02.059 - info: admin.0 (6846) <== Disconnect system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:34:05.620 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:34:05.692 - info: enocean.0 (7177) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
      2023-03-28 17:35:52.958 - info: enocean.0 (7177) Create objects for A5-14-01 from WINKHAUS with id: 059565A8
      2023-03-28 17:36:03.833 - info: enocean.0 (7177) Create objects for A5-14-01 from WINKHAUS with id: 059565A8
      2023-03-28 17:36:37.245 - info: admin.0 (6846) <== Disconnect system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:36:41.591 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:36:41.667 - info: enocean.0 (7177) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
      2023-03-28 17:37:23.001 - info: enocean.0 (7177) Create objects for A5-14-0A from WINKHAUS with id: 059565A8
      2023-03-28 17:37:32.199 - info: enocean.0 (7177) Create objects for A5-14-0A from WINKHAUS with id: 059565A8
      2023-03-28 17:37:34.602 - info: admin.0 (6846) <== Disconnect system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:37:36.306 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
      2023-03-28 17:37:36.331 - info: enocean.0 (7177) Got terminate signal TERMINATE_YOURSELF
      2023-03-28 17:37:36.355 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
      2023-03-28 17:37:37.358 - info: host.raspberrypi stopInstance system.adapter.enocean.0 killing pid 7177
      2023-03-28 17:37:36.346 - info: enocean.0 (7177) cleaned everything up...
      2023-03-28 17:37:36.347 - info: enocean.0 (7177) terminating
      2023-03-28 17:37:36.348 - info: enocean.0 (7177) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-03-28 17:37:39.395 - warn: enocean.0 (7177) Error sending data: Error: Port is not open
      2023-03-28 17:37:39.400 - warn: enocean.0 (7177) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:37:39.401 - warn: enocean.0 (7177) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:37:39.403 - warn: enocean.0 (7177) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:37:39.404 - warn: enocean.0 (7177) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:37:39.406 - warn: enocean.0 (7177) An error occured at serial port: Error: Port is not open
      2023-03-28 17:37:39.407 - info: enocean.0 (7177) The serial port was closed.
      2023-03-28 17:37:39.413 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7266
      2023-03-28 17:37:39.412 - info: enocean.0 (7177) The serial port was closed.
      2023-03-28 17:37:39.743 - warn: enocean.0 (7177) Got terminate signal. Checking desired PID: 0 vs own PID 7177
      2023-03-28 17:37:39.748 - warn: enocean.0 (7177) Got terminate signal. Checking desired PID: 7266 vs own PID 7177
      2023-03-28 17:37:39.790 - warn: enocean.0 (7177) get state error: DB closed
      2023-03-28 17:37:39.792 - warn: enocean.0 (7177) get state error: DB closed
      2023-03-28 17:37:39.827 - warn: enocean.0 (7177) get state error: Connection is closed.
      2023-03-28 17:37:40.290 - error: host.raspberrypi instance system.adapter.enocean.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2023-03-28 17:37:40.293 - info: host.raspberrypi Do not restart adapter system.adapter.enocean.0 because desired by instance
      2023-03-28 17:37:43.424 - info: enocean.0 (7266) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:37:45.362 - error: enocean.0 (7266) Timeout for response: Get version information
      2023-03-28 17:37:46.864 - error: enocean.0 (7266) Timeout for response: Get repeater mode and level
      2023-03-28 17:37:48.366 - error: enocean.0 (7266) Timeout for response: Get frequency
      2023-03-28 17:37:49.869 - error: enocean.0 (7266) Timeout for response: Get base ID
      2023-03-28 17:37:51.370 - error: enocean.0 (7266) Timeout for response: Read learnd devices
      2023-03-28 17:37:51.371 - info: enocean.0 (7266) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
      2023-03-28 17:39:25.468 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:39:25.564 - info: enocean.0 (7266) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
      2023-03-28 17:40:17.980 - info: admin.0 (6846) <== Disconnect system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:41:02.791 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:41:02.877 - info: enocean.0 (7266) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
      2023-03-28 17:43:06.011 - error: host.raspberrypi Caught by controller[0]: <--- Last few GCs --->
      2023-03-28 17:43:06.013 - error: host.raspberrypi Caught by controller[0]: [7266:0x4244cc20] 322568 ms: Scavenge 919.9 (939.2) -> 918.5 (939.2) MB, 2.7 / 0.0 ms (average mu = 0.275, current mu = 0.331) task
      2023-03-28 17:43:06.013 - error: host.raspberrypi Caught by controller[0]: [7266:0x4244cc20] 322594 ms: Scavenge 920.0 (939.2) -> 918.5 (939.2) MB, 2.7 / 0.0 ms (average mu = 0.275, current mu = 0.331) task
      2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[0]: [7266:0x4244cc20] 322620 ms: Scavenge 920.1 (939.2) -> 918.6 (943.2) MB, 3.2 / 0.0 ms (average mu = 0.275, current mu = 0.331) task
      2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[0]: <--- JS stacktrace --->
      2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
      2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[1]: 1: 0xb00584 node::Abort() [io.enocean.0]
      2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[2]: 2: 0xa21604 void node::FPrintF<>(_IO_FILE*, char const*) [io.enocean.0]
      2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[3]: 3: 0xccfb50 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.enocean.0]
      2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[4]: 4: 0xccfd20 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.enocean.0]
      2023-03-28 17:43:06.015 - error: host.raspberrypi Caught by controller[5]: 5: 0xe8ba3c [io.enocean.0]
      2023-03-28 17:43:06.015 - error: host.raspberrypi Caught by controller[6]: 6: 0xe8c4c4 [io.enocean.0]
      2023-03-28 17:43:06.015 - error: host.raspberrypi Caught by controller[7]: 7: 0xe9a90c [io.enocean.0]
      2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[8]: 8: 0xe9b12c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.enocean.0]
      2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[9]: 9: 0xe9c178 v8::internal::Heap::FinalizeIncrementalMarkingIfComplete(v8::internal::GarbageCollectionReason) [io.enocean.0]
      2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[9]: 10: 0xe9f85c v8::internal::IncrementalMarkingJob::Task::RunInternal() [io.enocean.0]
      2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[9]: 11: 0xd99d38 non-virtual thunk to v8::internal::CancelableTask::Run() [io.enocean.0]
      2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[9]: 12: 0xb62824 [io.enocean.0]
      2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[9]: 13: 0xb65dc8 node::PerIsolatePlatformData::FlushForegroundTasksInternal() [io.enocean.0]
      2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[9]: 14: 0x14f8b74 [io.enocean.0]
      2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[9]: 15: 0x150abd8 [io.enocean.0]
      2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[9]: 16: 0x14f95b0 uv_run [io.enocean.0]
      2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[10]: 17: 0xa4a0ac node::SpinEventLoop(node::Environment*) [io.enocean.0]
      2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[11]: 18: 0xb3d340 node::NodeMainInstance::Run() [io.enocean.0]
      2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[11]: 19: 0xac7c78 node::Start(int, char**) [io.enocean.0]
      2023-03-28 17:43:06.018 - error: host.raspberrypi Caught by controller[11]: 20: 0x7fb8ec9e18 __libc_start_main [/lib/aarch64-linux-gnu/libc.so.6]
      2023-03-28 17:43:06.018 - error: host.raspberrypi Caught by controller[12]: 21: 0xa48724 [io.enocean.0]
      2023-03-28 17:43:06.018 - warn: host.raspberrypi instance system.adapter.enocean.0 terminated due to SIGABRT
      2023-03-28 17:43:06.018 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code NaN ()
      2023-03-28 17:43:06.018 - info: host.raspberrypi Restart adapter system.adapter.enocean.0 because enabled
      2023-03-28 17:43:36.084 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7291
      2023-03-28 17:43:37.916 - info: enocean.0 (7291) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:43:39.738 - error: enocean.0 (7291) Timeout for response: Get version information
      2023-03-28 17:43:41.240 - error: enocean.0 (7291) Timeout for response: Get repeater mode and level
      2023-03-28 17:43:42.742 - error: enocean.0 (7291) Timeout for response: Get frequency
      2023-03-28 17:43:44.244 - error: enocean.0 (7291) Timeout for response: Get base ID
      2023-03-28 17:43:45.745 - error: enocean.0 (7291) Timeout for response: Read learnd devices
      2023-03-28 17:43:45.746 - info: enocean.0 (7291) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
      2023-03-28 17:48:56.116 - error: host.raspberrypi Caught by controller[0]: <--- Last few GCs --->
      2023-03-28 17:48:56.117 - error: host.raspberrypi Caught by controller[0]: [7291:0x360d6c20] 316116 ms: Scavenge 919.6 (938.7) -> 918.2 (938.9) MB, 2.9 / 0.0 ms (average mu = 0.228, current mu = 0.175) task
      2023-03-28 17:48:56.117 - error: host.raspberrypi Caught by controller[0]: [7291:0x360d6c20] 316141 ms: Scavenge 919.7 (938.9) -> 918.3 (938.9) MB, 2.7 / 0.0 ms (average mu = 0.228, current mu = 0.175) task
      2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[0]: [7291:0x360d6c20] 316168 ms: Scavenge 919.8 (938.9) -> 918.3 (942.9) MB, 3.2 / 0.0 ms (average mu = 0.228, current mu = 0.175) task
      2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[0]: <--- JS stacktrace --->
      2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
      2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[1]: 1: 0xb00584 node::Abort() [io.enocean.0]
      2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[2]: 2: 0xa21604 void node::FPrintF<>(_IO_FILE*, char const*) [io.enocean.0]
      2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[3]: 3: 0xccfb50 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.enocean.0]
      2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[4]: 4: 0xccfd20 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.enocean.0]
      2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[5]: 5: 0xe8ba3c [io.enocean.0]
      2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[6]: 6: 0xe8c4c4 [io.enocean.0]
      2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[6]: 7: 0xe9a90c [io.enocean.0]
      2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[6]: 8: 0xe9b12c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.enocean.0]
      2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[6]: 9: 0xe9c178 v8::internal::Heap::FinalizeIncrementalMarkingIfComplete(v8::internal::GarbageCollectionReason) [io.enocean.0]
      2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[6]: 10: 0xe9f85c v8::internal::IncrementalMarkingJob::Task::RunInternal() [io.enocean.0]
      2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[7]: 11: 0xd99d38 non-virtual thunk to v8::internal::CancelableTask::Run() [io.enocean.0]
      2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[8]: 12: 0xb62824 [io.enocean.0]
      2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[9]: 13: 0xb65dc8 node::PerIsolatePlatformData::FlushForegroundTasksInternal() [io.enocean.0]
      2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[10]: 14: 0x14f8b74 [io.enocean.0]
      2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[11]: 15: 0x150abd8 [io.enocean.0]
      2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[12]: 16: 0x14f95b0 uv_run [io.enocean.0]
      2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[13]: 17: 0xa4a0ac node::SpinEventLoop(node::Environment*) [io.enocean.0]
      2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[14]: 18: 0xb3d340 node::NodeMainInstance::Run() [io.enocean.0]
      2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[15]: 19: 0xac7c78 node::Start(int, char**) [io.enocean.0]
      2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[15]: 20: 0x7fb202fe18 __libc_start_main [/lib/aarch64-linux-gnu/libc.so.6]
      2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[16]: 21: 0xa48724 [io.enocean.0]
      2023-03-28 17:48:56.121 - warn: host.raspberrypi instance system.adapter.enocean.0 terminated due to SIGABRT
      2023-03-28 17:48:56.121 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code NaN ()
      2023-03-28 17:48:56.121 - info: host.raspberrypi Restart adapter system.adapter.enocean.0 because enabled
      2023-03-28 17:49:26.179 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7391
      2023-03-28 17:49:28.893 - info: enocean.0 (7391) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:49:30.812 - error: enocean.0 (7391) Timeout for response: Get version information
      2023-03-28 17:49:32.314 - error: enocean.0 (7391) Timeout for response: Get repeater mode and level
      2023-03-28 17:49:33.816 - error: enocean.0 (7391) Timeout for response: Get frequency
      2023-03-28 17:49:35.318 - error: enocean.0 (7391) Timeout for response: Get base ID
      2023-03-28 17:49:36.819 - error: enocean.0 (7391) Timeout for response: Read learnd devices
      2023-03-28 17:49:36.820 - info: enocean.0 (7391) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
      2023-03-28 17:49:40.783 - info: host.raspberrypi received SIGTERM
      2023-03-28 17:49:40.787 - info: backitup.0 (6888) cleaned everything up...
      2023-03-28 17:49:40.786 - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
      2023-03-28 17:49:40.788 - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
      2023-03-28 17:49:40.789 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
      2023-03-28 17:49:40.790 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
      2023-03-28 17:49:40.789 - info: admin.0 (6846) terminating http server on port 8081
      2023-03-28 17:49:40.806 - info: enocean.0 (7391) cleaned everything up...
      2023-03-28 17:49:40.816 - info: backitup.0 (6888) Got terminate signal TERMINATE_YOURSELF
      2023-03-28 17:49:40.821 - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
      2023-03-28 17:49:40.821 - info: backitup.0 (6888) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2023-03-28 17:49:40.823 - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
      2023-03-28 17:49:40.828 - info: admin.0 (6846) Got terminate signal TERMINATE_YOURSELF
      2023-03-28 17:49:40.824 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
      2023-03-28 17:49:40.824 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
      2023-03-28 17:49:40.846 - info: admin.0 (6846) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2023-03-28 17:49:40.955 - warn: enocean.0 (7391) Error sending data: Error: Port is not open
      2023-03-28 17:49:40.958 - warn: enocean.0 (7391) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:49:40.959 - warn: enocean.0 (7391) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:49:40.960 - warn: enocean.0 (7391) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:49:40.961 - warn: enocean.0 (7391) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:49:40.962 - warn: enocean.0 (7391) An error occured at serial port: Error: Port is not open
      2023-03-28 17:49:40.963 - info: enocean.0 (7391) The serial port was closed.
      2023-03-28 17:49:40.965 - info: enocean.0 (7391) The serial port was closed.
      2023-03-28 17:49:40.970 - info: enocean.0 (7391) Got terminate signal TERMINATE_YOURSELF
      2023-03-28 17:49:41.018 - info: enocean.0 (7391) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2023-03-28 17:49:41.372 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-03-28 17:49:41.567 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-03-28 17:49:41.823 - info: host.raspberrypi stopInstance system.adapter.admin.0 killing pid 6846
      2023-03-28 17:49:41.824 - info: host.raspberrypi stopInstance system.adapter.discovery.0 killing pid 6873
      2023-03-28 17:49:42.749 - warn: host.raspberrypi instance system.adapter.discovery.0 terminated due to SIGTERM
      2023-03-28 17:49:42.749 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code null ()
      2023-03-28 17:49:42.750 - info: host.raspberrypi All instances are stopped.
      2023-03-28 17:49:43.984 - warn: host.raspberrypi Cannot get view: Connection is closed.
      2023-03-28 17:49:43.986 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-03-28 17:49:43.987 - info: host.raspberrypi All instances are stopped.
      2023-03-28 17:49:46.435 - info: host.raspberrypi terminated
      2023-03-28 17:50:01.860 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
      2023-03-28 17:50:01.867 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-03-28 17:50:01.868 - info: host.raspberrypi hostname: raspberrypi, node: v16.19.1
      2023-03-28 17:50:01.869 - info: host.raspberrypi ip addresses: 2003:e1:ef09:2800:7e02:d79a:15c2:6ccb fe80::66bf:f25a:da47:f65f
      2023-03-28 17:50:14.561 - info: host.raspberrypi connected to Objects and States
      2023-03-28 17:50:14.635 - info: host.raspberrypi added notifications configuration of host
      2023-03-28 17:50:18.272 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
      2023-03-28 17:50:18.283 - info: host.raspberrypi 4 instances found
      2023-03-28 17:50:18.301 - info: host.raspberrypi starting 4 instances
      2023-03-28 17:50:19.732 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
      2023-03-28 17:50:19.768 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
      2023-03-28 17:50:19.798 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
      2023-03-28 17:50:19.831 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1091
      2023-03-28 17:50:19.848 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
      2023-03-28 17:50:19.914 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
      2023-03-28 17:50:19.934 - info: host.raspberrypi Some obsolete host states deleted.
      2023-03-28 17:50:22.357 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 1213
      2023-03-28 17:50:46.461 - info: admin.0 (1091) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:50:46.536 - info: admin.0 (1091) requesting all states
      2023-03-28 17:50:46.537 - info: admin.0 (1091) requesting all objects
      2023-03-28 17:50:47.168 - info: admin.0 (1091) received all objects
      2023-03-28 17:50:47.690 - info: discovery.0 (1213) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:50:47.786 - info: admin.0 (1091) http server listening on port 8081
      2023-03-28 17:50:47.788 - info: admin.0 (1091) Use link "http://localhost:8081" to configure.
      2023-03-28 17:50:47.817 - info: admin.0 (1091) socket.io server listening on port 8081
      2023-03-28 17:50:47.882 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:50:47.898 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50 admin
      2023-03-28 17:50:48.678 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1324
      2023-03-28 17:50:50.273 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:50:51.258 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:50:52.990 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1697
      2023-03-28 17:50:53.515 - info: backitup.0 (1324) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:50:56.393 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:51:09.110 - info: backitup.0 (1324) [iobroker] backup was activated at 02:40 every 1 day(s)
      2023-03-28 17:51:11.419 - info: enocean.0 (1697) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:51:13.251 - error: enocean.0 (1697) Timeout for response: Get version information
      2023-03-28 17:51:14.752 - error: enocean.0 (1697) Timeout for response: Get repeater mode and level
      2023-03-28 17:51:16.258 - error: enocean.0 (1697) Timeout for response: Get frequency
      2023-03-28 17:51:17.759 - error: enocean.0 (1697) Timeout for response: Get base ID
      2023-03-28 17:51:19.260 - error: enocean.0 (1697) Timeout for response: Read learnd devices
      2023-03-28 17:51:19.261 - info: enocean.0 (1697) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
      2023-03-28 17:51:43.130 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50 admin
      2023-03-28 17:51:47.110 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:51:47.120 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50 admin
      2023-03-28 17:51:50.463 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:52:09.168 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:52:09.258 - info: enocean.0 (1697) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
      2023-03-28 17:52:14.389 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
      2023-03-28 17:52:14.405 - info: enocean.0 (1697) Got terminate signal TERMINATE_YOURSELF
      2023-03-28 17:52:14.448 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
      2023-03-28 17:52:14.419 - info: enocean.0 (1697) cleaned everything up...
      2023-03-28 17:52:14.420 - info: enocean.0 (1697) terminating
      2023-03-28 17:52:14.421 - info: enocean.0 (1697) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-03-28 17:52:15.026 - warn: enocean.0 (1697) Error sending data: Error: Port is not open
      2023-03-28 17:52:15.028 - warn: enocean.0 (1697) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:52:15.029 - warn: enocean.0 (1697) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:52:15.031 - warn: enocean.0 (1697) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:52:15.032 - warn: enocean.0 (1697) An error occured at serial port: Error: Port is not open
      2023-03-28 17:52:15.033 - info: enocean.0 (1697) The serial port was closed.
      2023-03-28 17:52:15.035 - info: enocean.0 (1697) The serial port was closed.
      2023-03-28 17:52:15.056 - warn: enocean.0 (1697) get state error: DB closed
      2023-03-28 17:52:15.062 - warn: enocean.0 (1697) get state error: Connection is closed.
      2023-03-28 17:52:15.065 - warn: enocean.0 (1697) get state error: Connection is closed.
      2023-03-28 17:52:15.140 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-03-28 17:52:17.485 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1774
      2023-03-28 17:52:19.391 - info: enocean.0 (1774) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:52:21.174 - error: enocean.0 (1774) Timeout for response: Get version information
      2023-03-28 17:52:22.675 - error: enocean.0 (1774) Timeout for response: Get repeater mode and level
      2023-03-28 17:52:24.178 - error: enocean.0 (1774) Timeout for response: Get frequency
      2023-03-28 17:52:25.679 - error: enocean.0 (1774) Timeout for response: Get base ID
      2023-03-28 17:52:27.180 - error: enocean.0 (1774) Timeout for response: Read learnd devices
      2023-03-28 17:52:27.181 - info: enocean.0 (1774) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
      2023-03-28 17:52:53.765 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:52:55.651 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
      2023-03-28 17:52:55.662 - info: enocean.0 (1774) Got terminate signal TERMINATE_YOURSELF
      2023-03-28 17:52:55.699 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
      2023-03-28 17:52:55.666 - info: enocean.0 (1774) cleaned everything up...
      2023-03-28 17:52:55.668 - info: enocean.0 (1774) terminating
      2023-03-28 17:52:55.669 - info: enocean.0 (1774) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-03-28 17:52:55.863 - warn: enocean.0 (1774) Error sending data: Error: Port is not open
      2023-03-28 17:52:55.865 - warn: enocean.0 (1774) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:52:55.866 - warn: enocean.0 (1774) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:52:55.867 - warn: enocean.0 (1774) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:52:55.868 - warn: enocean.0 (1774) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:52:55.869 - warn: enocean.0 (1774) An error occured at serial port: Error: Port is not open
      2023-03-28 17:52:55.870 - info: enocean.0 (1774) The serial port was closed.
      2023-03-28 17:52:56.043 - info: enocean.0 (1774) The serial port was closed.
      2023-03-28 17:52:56.185 - warn: enocean.0 (1774) get state error: Connection is closed.
      2023-03-28 17:52:56.187 - warn: enocean.0 (1774) get state error: DB closed
      2023-03-28 17:52:56.242 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-03-28 17:52:58.725 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1790
      2023-03-28 17:53:00.564 - info: enocean.0 (1790) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:53:02.385 - error: enocean.0 (1790) Timeout for response: Get version information
      2023-03-28 17:53:03.890 - error: enocean.0 (1790) Timeout for response: Get repeater mode and level
      2023-03-28 17:53:05.391 - error: enocean.0 (1790) Timeout for response: Get frequency
      2023-03-28 17:53:06.893 - error: enocean.0 (1790) Timeout for response: Get base ID
      2023-03-28 17:53:08.394 - error: enocean.0 (1790) Timeout for response: Read learnd devices
      2023-03-28 17:53:08.395 - info: enocean.0 (1790) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
      2023-03-28 17:53:51.903 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:53:51.982 - info: enocean.0 (1790) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
      2023-03-28 17:54:10.343 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
      2023-03-28 17:54:10.349 - info: enocean.0 (1790) Got terminate signal TERMINATE_YOURSELF
      2023-03-28 17:54:10.391 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
      2023-03-28 17:54:10.353 - info: enocean.0 (1790) cleaned everything up...
      2023-03-28 17:54:10.354 - info: enocean.0 (1790) terminating
      2023-03-28 17:54:10.355 - info: enocean.0 (1790) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-03-28 17:54:11.038 - warn: enocean.0 (1790) Error sending data: Error: Port is not open
      2023-03-28 17:54:11.040 - warn: enocean.0 (1790) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:54:11.041 - warn: enocean.0 (1790) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:54:11.042 - warn: enocean.0 (1790) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:54:11.043 - warn: enocean.0 (1790) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:54:11.045 - warn: enocean.0 (1790) An error occured at serial port: Error: Port is not open
      2023-03-28 17:54:11.045 - info: enocean.0 (1790) The serial port was closed.
      2023-03-28 17:54:11.048 - info: enocean.0 (1790) The serial port was closed.
      2023-03-28 17:54:11.067 - warn: enocean.0 (1790) get state error: Connection is closed.
      2023-03-28 17:54:11.068 - warn: enocean.0 (1790) get state error: DB closed
      2023-03-28 17:54:11.075 - warn: enocean.0 (1790) get state error: Connection is closed.
      2023-03-28 17:54:11.140 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-03-28 17:54:13.420 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1807
      2023-03-28 17:54:15.250 - info: enocean.0 (1807) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:54:15.526 - warn: enocean.0 (1807) An error occured at serial port: Error: Error: No such file or directory, cannot open Choose
      2023-03-28 17:55:03.052 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:55:04.898 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:55:04.965 - info: enocean.0 (1807) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
      2023-03-28 17:55:08.653 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
      2023-03-28 17:55:08.659 - info: enocean.0 (1807) Got terminate signal TERMINATE_YOURSELF
      2023-03-28 17:55:08.662 - info: enocean.0 (1807) cleaned everything up...
      2023-03-28 17:55:08.662 - info: enocean.0 (1807) terminating
      2023-03-28 17:55:08.663 - info: enocean.0 (1807) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-03-28 17:55:08.665 - warn: enocean.0 (1807) An error occured at serial port: Error: Port is not open
      2023-03-28 17:55:08.702 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
      2023-03-28 17:55:09.201 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-03-28 17:55:11.305 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:55:11.751 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1826
      2023-03-28 17:55:13.610 - info: enocean.0 (1826) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:55:15.395 - error: enocean.0 (1826) Timeout for response: Get version information
      2023-03-28 17:55:16.896 - error: enocean.0 (1826) Timeout for response: Get repeater mode and level
      2023-03-28 17:55:18.398 - error: enocean.0 (1826) Timeout for response: Get frequency
      2023-03-28 17:55:19.900 - error: enocean.0 (1826) Timeout for response: Get base ID
      2023-03-28 17:55:21.401 - error: enocean.0 (1826) Timeout for response: Read learnd devices
      2023-03-28 17:55:21.402 - info: enocean.0 (1826) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
      2023-03-28 17:56:24.597 - info: host.raspberrypi iobroker url https://github.com/iobroker-community-adapters/ioBroker.enocean.git --host raspberrypi --debug
      2023-03-28 17:56:28.237 - info: host.raspberrypi iobroker install iobroker-community-adapters/ioBroker.enocean#62d2b5b1fcbdd1c24af22ae3b9225b7e1ec57db4
      2023-03-28 17:56:29.387 - info: host.raspberrypi iobroker NPM version: 8.19.3
      2023-03-28 17:56:29.391 - info: host.raspberrypi iobroker Installing iobroker-community-adapters/ioBroker.enocean#62d2b5b1fcbdd1c24af22ae3b9225b7e1ec57db4... (System call)
      2023-03-28 17:56:46.117 - info: host.raspberrypi iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.enocean.git
      2023-03-28 17:56:56.916 - info: host.raspberrypi iobroker npm ERR! code 1
      2023-03-28 17:56:56.920 - info: host.raspberrypi iobroker npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
      2023-03-28 17:56:56.928 - info: host.raspberrypi iobroker npm ERR! command failed
      2023-03-28 17:56:56.933 - info: host.raspberrypi iobroker npm ERR! command sh -c -- prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
      2023-03-28 17:56:56.938 - info: host.raspberrypi iobroker npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
      2023-03-28 17:56:56.944 - info: host.raspberrypi iobroker npm ERR! CXX(target) Release/obj.target/bindings/src/serialport.onpm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassennpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@9.1.0npm ERR! gyp info using node@16.19.1 | linux | arm64npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"npm ERR! gyp http GET https://nodejs.org/download/release/v16.19.1/node-v16.19.1-headers.tar.gznpm ERR! gyp http 200 https://nodejs.org/download/release/v16.19.1/node-v16.19.1-headers.tar.gznpm ERR! gyp http GET https://nodejs.org/download/release/v16.19.1/SHASUMS256.txtnpm ERR! gyp http 200 https://nodejs.org/download/release/v16.19.1/SHASUMS256.txtnpm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [
      2023-03-28 17:56:56.946 - info: host.raspberrypi iobroker npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/16.19.1/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/16.19.1',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/16.19.1/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! gyp info spawn makenpm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:270:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 270 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:314:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 314 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      2023-03-28 17:56:56.952 - info: host.raspberrypi iobroker npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local, Nan::imp::FactoryBase::return_t)’npm ERR! 329 | results->Set(Nan::New("cts").ToLocalChecked(), Nan::New(data->cts));npm ERR! | ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, v8::Local, v8::Local)’npm ERR! 3961 | V8_WARN_UNUSED_RESULT Maybe Set(Local context,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, uint32_t, v8::Local)’npm ERR! 3964 | V8_WARN_UNUSED_RESULT Maybe Set(Local context, uint32_t index,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local, Nan::imp::FactoryBase::return_t)’npm ERR! 330 | results->Set(Nan::New("dsr").ToLocalChecked(), Nan::New(data->dsr));npm ERR! | ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, v8::Local, v8::Local)’npm ERR! 3961 | V8_WARN_UNUSED_RESULT Maybe Set(Local context,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, uint32_t, v8::Local)’npm ERR! 3964 | V8_WARN_UNUSED_RESULT Maybe Set(Local context, uint32_t index,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local, Nan::imp::FactoryBase::return_t)’npm ERR! 331 | results->Set(Nan::New("dcd").ToLocalChecked(), Nan::New(data->dcd));npm ERR! | ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, v8::Local, v8::Local)’npm ERR! 3961 | V8_WARN_UNUSED_RESULT Maybe Set(Local context,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, uint32_t, v8::Local)’npm ERR! 3964 | V8_WARN_UNUSED_RESULT Maybe Set(Local context, uint32_t index,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:363:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 363 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local, Nan::imp::IntegerFactory::return_t)’npm ERR! 378 | results->Set(Nan::New("baudRate").ToLocalChecked(), Nan::New(data->baudRate));npm ERR! | ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, v8::Local, v8::Local)’npm ERR! 3961 | V8_WARN_UNUSED_RESULT Maybe Set(Local context,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, uint32_t, v8::Local)’npm ERR! 3964 | V8_WARN_UNUSED_RESULT Maybe Set(Local context, uint32_t index,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:409:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 409 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: At global scope:npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
      2023-03-28 17:56:56.966 - info: host.raspberrypi iobroker npm ERR! 430 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local& v8str)) {npm ERR! | ^npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]npm ERR! 449 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {npm ERR! | ^npm ERR! In file included from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:887:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type]npm ERR! 887 | (node::addon_register_func) (regfunc), \npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:921:3: note: in expansion of macro ‘NODE_MODULE_X’npm ERR! 921 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm ERR! | ^~~~~~~~~~~~~npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’npm ERR! 483 | NODE_MODULE(serialport, init);npm ERR! | ^~~~~~~~~~~npm ERR! make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/serialport.o] Fehler 1npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:201:23)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:293:12)npm ERR! gyp ERR! System Linux 6.1.19-v8+npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsnpm ERR! gyp ERR! node -v v16.19.1npm ERR! gyp ERR! node-gyp -v v9.1.0npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-03-28T15_56_30_480Z-debug-0.log
      2023-03-28 17:56:57.060 - info: host.raspberrypi iobroker upload [6] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/admin.d.ts admin.d.ts video/mp2t
      2023-03-28 17:56:57.105 - info: host.raspberrypi iobroker upload [5] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/components.js components.js application/javascript
      2023-03-28 17:56:57.127 - info: host.raspberrypi iobroker upload [4] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/enocean.png enocean.png image/png
      2023-03-28 17:56:57.153 - info: host.raspberrypi iobroker upload [3] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/github.js github.js application/javascript
      2023-03-28 17:56:57.177 - info: host.raspberrypi iobroker upload [2] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/index_m.html index_m.html text/html
      2023-03-28 17:56:57.212 - info: host.raspberrypi iobroker upload [1] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/style.css style.css text/css
      2023-03-28 17:56:57.254 - info: host.raspberrypi iobroker upload [0] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/words.js words.js application/javascript
      2023-03-28 17:56:57.316 - info: host.raspberrypi iobroker Update "system.adapter.enocean.0"
      2023-03-28 17:56:57.327 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
      2023-03-28 17:56:57.338 - info: enocean.0 (1826) Got terminate signal TERMINATE_YOURSELF
      2023-03-28 17:56:57.376 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
      2023-03-28 17:56:57.348 - info: enocean.0 (1826) cleaned everything up...
      2023-03-28 17:56:57.349 - info: enocean.0 (1826) terminating
      2023-03-28 17:56:57.350 - info: enocean.0 (1826) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-03-28 17:56:57.841 - warn: enocean.0 (1826) Error sending data: Error: Port is not open
      2023-03-28 17:56:57.843 - warn: enocean.0 (1826) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:56:57.844 - warn: enocean.0 (1826) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:56:57.845 - warn: enocean.0 (1826) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      2023-03-28 17:56:57.847 - warn: enocean.0 (1826) An error occured at serial port: Error: Port is not open
      2023-03-28 17:56:57.848 - info: enocean.0 (1826) The serial port was closed.
      2023-03-28 17:56:58.292 - info: enocean.0 (1826) The serial port was closed.
      2023-03-28 17:56:58.318 - warn: enocean.0 (1826) get state error: Connection is closed.
      2023-03-28 17:56:58.319 - warn: enocean.0 (1826) get state error: DB closed
      2023-03-28 17:56:58.325 - warn: enocean.0 (1826) get state error: Connection is closed.
      2023-03-28 17:56:58.361 - info: host.raspberrypi iobroker exit 0
      2023-03-28 17:56:58.380 - info: host.raspberrypi stopInstance system.adapter.enocean.0 killing pid 1826
      2023-03-28 17:56:58.417 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-03-28 17:57:00.414 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1921
      2023-03-28 17:57:03.048 - info: enocean.0 (1921) starting. Version 0.8.5 (non-npm: iobroker-community-adapters/ioBroker.enocean#62d2b5b1fcbdd1c24af22ae3b9225b7e1ec57db4) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
      2023-03-28 17:57:04.841 - error: enocean.0 (1921) Timeout for response: Get version information
      2023-03-28 17:57:06.343 - error: enocean.0 (1921) Timeout for response: Get repeater mode and level
      2023-03-28 17:57:07.844 - error: enocean.0 (1921) Timeout for response: Get frequency
      2023-03-28 17:57:09.348 - error: enocean.0 (1921) Timeout for response: Get base ID
      2023-03-28 17:57:10.852 - error: enocean.0 (1921) Timeout for response: Read learnd devices
      2023-03-28 17:57:10.853 - info: enocean.0 (1921) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
      2023-03-28 17:59:00.437 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2023-03-28 17:59:00.520 - info: enocean.0 (1921) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
      2023-03-28 18:00:57.399 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50
      • Jey Cee
        Jey Cee Developer @TimoWald last edited by
        @timowald sorry für die Späte Antwort. Du musst schon den richtigen Port auswählen.
          blackbirdN510 @Black-Raven last edited by
          @black-raven darf ich fragen wie du den FTS14EM zum laufen bekommen hast? Braucht man einen FTS14FA oder geht das auch ohne? Allgemein funktioniert es mit meinen FUD und FSR aber den FTS bekomme ich nicht in den ioBroker.
          Viele Grüße
          Matthias
          R B 2 Replies Last reply Reply Quote 0
            RoGo @blackbirdN510 last edited by
            @blackbirdn510 bei Verwendung des USB 300 wird der FTS14FA benötigt, da Zustände der Eingänge nicht über das FAM 14 in den Gebäudefunk gesendet werden. Das macht dann der FTS14FA. Bei Verwendung des FGW14USB wird der FTS14FA nicht benötigt, da dort die Eingänge vom RS485 mit über USB ausgegeben werden.
            Das war auch der Grund meiner Umstellung auf USB. Die Häufigkeit, in der die Telegramme über Funk versendet werden erhöht sich mit den 3 "Sendern" FTS14FA, USB300 und FAM14 enorm. Erkennt man auch an der roten LED am FAM 14. Ein Tastendruck verursacht mehrere Funktelegramme. Wenn man bedenkt, dass das Enocean darauf basiert, lediglich 2 Telegramme abzusetzen und davon ausgeht, dass der Empfänger das Telegramm auch empfangen haben muss (ohne Rückmeldung ob das geschehen ist) sollte das Telegrammaufkommen niedrig gehalten werden. Gleichzeitig versendete Telegramme von mehreren Teilnehmern kann zu Störungen führen.
            Mein FTS14FA liegt jetzt jedenfalls nutzlos herum 🙂
              Black-Raven @blackbirdN510 last edited by
              @blackbirdn510 RoGo hat eigentlich alles gesagt. Übers FGW14USB geht das FTS14EM auch ohne das FTS14FA.
                @RoGo @Black-Raven vielen Dank! Dann werde ich wohl mal einen FGW14USB besorgen. Kabel ist eh besser ;).
                  ares44 @Jey Cee last edited by
                  @jey-cee Version 0.8.5 soll ja jetzt schon seit 2 Monaten verfügbar sein. Bei mir ist die Version nicht verfügbar. Da haben andere wohl mehr Glück. An ein paar Änderungen der Version wäre ich sehr interessiert. Wie kommt man da dran?
                  • Jey Cee
                    Jey Cee Developer @ares44 last edited by
                    @ares44 die Version kann man von Github installieren.
                      @jey-cee Ok, gemacht. Adapterübersicht zeigt Version 0.85 an. Die Werte für DSZ14 werden aber weiterhin falsch ausgelesen. Es wird ein Tages- und Nachtzähler angezeigt. Die kennt das DSZ eigentlich nicht.
                      • Jey Cee
                        @ares44 sagte in Test Adapter EnOcean v0.8.x:
                        • Jey Cee
                          So hat jetzt länger gedauert die nächste Version fertig zu machen. Die 0.8.5 ist ab sofort über npm installierbar.
                          Die Änderungen findet ihr im ersten Post.
                          • Basti Liciouz
                            Basti Liciouz last edited by
                            Hi zusammen,
                            Ich probiere gerade den Adapter zum Laufen zu bringen. FGW14-USB wird soweit auch erkannt. Nun tue ich mich nur schwer mir dem Hinzufügen der Adapter: Was ist die Bus ID der Gruppe und wo kann ich diese auslesen? Die Basis ID des FAM14 habe ich über das PCT14 auslesen können.
                            Ich hatte mal zum Spaß die ID des jeweiligen Kanals angegeben, wie es ebenfalls im PCT14 steht. Ist aber nicht von Erfolg gekrönt. Sende ich das Teach-in im Objekt, reagiert der im LRN-Modus befindliche Aktor nicht.
                            Danke im Voraus für die Hilfe!
                            Basti Liciouz Jey Cee 2 Replies Last reply Reply Quote 0
                              Thuryaz @Jey Cee last edited by Thuryaz
                              Bei der Installation bekomme ich volgende Fehlermeldung:
                              $ iobroker url gh repo clone Jey-Cee/ioBroker.enocean --host iobroker --debug
                              install gh
                              NPM version: 9.5.1
                              Installing gh... (System call)
                              up to date in 19s
                              93 packages are looking for funding run npm fund for details
                              host.iobroker Cannot install gh: 0
                              ERROR: Process exited with code 25
                              Was läuft da fasch ?
                              • Basti Liciouz
                                Basti Liciouz @Basti Liciouz last edited by
                                @basti-liciouz sagte in Test Adapter EnOcean v0.8.x:
                                Hi zusammen,
                                Update: Ich habe nun mal probiert, das FWS61 einzulernen. Auch dies schlägt fehl. Das Gerät wurde zwar hinzugefügt, gut das tut er immer, aber alle Werte im Objekt bleiben leer.
                                Nun stehe ich absolut auf dem Schlauch, wo ich den Fehler suchen könnte. Vielleicht habe ich auch etwas bei der Einrichtung vergessen? Bin um jede Hilfe und jeden Hinweis dankbar. Vielleicht hat auch jemand eine Schritt für Schritt Anleitung von Anfang an? Gerne auch per PN.
                                • Jey Cee
                                  @thuryaz sagte in Test Adapter EnOcean v0.8.x:
                                  Such mal im Forum danach, gibt Unzählige Themen zu diesem Problem.
                                  Außerdem solltest du den Adapter aus dem Beta Repository installieren und nicht von Github.
                                  • Jey Cee
                                    Jey Cee Developer @Basti Liciouz last edited by
                                    Von welcher Gruppe? In ioBroker oder PCT14?
                                    Die wird doch in der Adapter-Konfiguration von ioBroker rechts oben angezeigt.
                                    Ziemlich sicher sogar. Aber ohne das du dein vorgehen Schritt für Schritt mit allen Informationen darlegst ist es unmöglich zu sagen was.
                                    Nein, bisher hat niemand eine Schritt für Schritt Anleitung erstellt.
                                    Ich erstelle jetzt eine.
                                    Basti Liciouz 1 Reply Last reply Reply Quote 0
                                    • Basti Liciouz
                                      Basti Liciouz @Jey Cee last edited by
                                      @jey-cee sagte in Test Adapter EnOcean v0.8.x:
                                      In der Schritt für Schritt Anleitung bei der Einrichtung von Geräten in der Instanz ("Geräte ID eintragen. Sie setzt sich aus der Basis ID des Funk-Antennenmodul (z.B. FAM14) und der Bus ID der Gruppe zusammen...")
                                      Bei mir nicht, bzw. dort steht die Base-ID 00010000. Das hat mich schon irritiert.
                                      • FGW14-USB an FAM14 eingelernt und USB-Anschluss mit Raspi 4 verbunden
                                      • Prüfung auf Raspi, ob das USB-Device erkannt wurde >> Passt
                                      • Installation Adapter über GitHub (0.8.4, Version sollte laut Changelog bei 0.8.5 keinen Unterschied für das Fehlerbild machen)
                                      • Erzeugung der Instanz, in den Einstellungen FGW14-USB sowie Schnittstelle ausgewählt (ob nun /dev/serial/... oder dev/ttyUSB0, bei beiden ist er nun laut Status der Instanz mit Gerät/Host verbunden)
                                      Mehr habe ich nicht gemacht, nun wollte ich Geräte hinzufügen. Habe ich etwas vergessen?
                                      • Bei der Geräte ID, bspw. ich möchte ein FUD14 anlernen, habe ich die Base-ID genommen und die Adresse, die ich im PCT14 für den Kanal sehe (Hier: 29). Ergibt bei mir dann: FFEC3400 + 1D (29 in Dez) = FFEC341D.
                                      • Danach den Aktor in den Lernmodus versetzt und Teach-in gesetzt >> Keine Reaktion.
                                      • Da ich nun nicht weiß ob ich mit der Bus ID = Adresse richtig lag, habe ich noch das FGW61 angelernt. Hier habe ich nur die mir bekannte Hex-Adresse eingegeben, damit sollte der Anlernvorgang gemäß der Schrittanleitung schon abgeschlossen sein. Aber auch hier keine Werte, die ich im Objekt sehen kann. Steht alles noch auf den Dummy Werten.
                                      Klasse danke!
                                      • Jey Cee
                                        @basti-liciouz https://www.all-smart.net/verwendung-von-einem-fgw14-usb-mit-iobroker/
                                        Darfst mir gerne Feedback geben wenn daran etwas verbessert werden kann.
                                        • Basti Liciouz
                                          Perfekt, danke! Kann man gut nachvollziehen. Mein Fehler war die falsche Baudrate. Zudem ist in der Step-by-Step Anleitung in iobroker der Hinweis der Base-ID, dort steht (z.B. des FAM14), m.E. irreführend. Nun geht aus dem Tutorial klar hervor, dass die iobroker Base-ID gemeint ist.
                                          • Basti Liciouz
                                            Moin, ich schon wieder 😉
                                            Gestern habe ich am Raspberry selbst gearbeitet und ihn mehrfach neu gestartet. Seitdem mag die Instanz für Enocean nichts mehr auslesen und in die Influx schreiben. Alle anderen laufenden Adapter scheinen damit kein Problem zu haben.
                                            Ich hatte den Fall schonmal vor ca 2 Wochen, allerdings noch mit der 0.8.4 Dort hat sich der Adapter bzw die Instanz dann um Mitternacht wie von selbst gefangen. Dieses mal ist das nicht der Fall. Restart der Instanz blieb erfolglos.
                                            Hat jemand Tips, wie ich die Instanz wieder zum Laufen bekomme? Löschen und neu anlegen ist keine Option, sind mittlerweile 45 Objekte angelegt. Das wollte ich nicht nochmal durchmachen. 🙂
                                            enocean
                                            25
                                            248
                                            45027
