    4. Heizungssteuerung mit Siemens-Webserver OZW 672
      gerry22 last edited by
      Ich glaube das ich den Fehler gefunden habe.
      Wenn ich//Session ID in variable speichern sessionID = object.SessionId; //Session ID ins log schreiben log (sessionID);direkt unter````
      objekt = JSON.parse(results);
      Hier nochmal das komplette Script mit ein paar Test-log`s````
      schedule("*/1 * * * *", function () {
          var objekt;
          //Username und password variable setzen
          var username = "Admin3";
          var password = "Password_3";
          var sessionId;
          //(TEST)
          log('http://192.168.178.58/api/auth/login.json?user=' + username + '&pwd=' + password);
          //URL request fuer die session ID
          try {
              require("request")
              ('http://192.168.178.58/api/auth/login.json?user=' + username + '&pwd=' + password, function (error, response, results) {
          //(TEST)results ins log schreiben
              log (results);
              sessionId = objekt.SessionId;
              log (sessionId);
          //(TEST)URL zur Json-Abfrage der Außentemperatur (Id=1143) erzeugen
              log('http://192.168.178.58/api/menutree/read_datapoint.json?sessionId=' + sessionId + '&Id=1143');
              } catch (e) { console.error(e); }
      ````Und hier die Log-Datei:  ` > 00:10:00.593 [info] javascript.0 Start javascript script.js.test32
      > 00:10:00.594 [info] javascript.0 script.js.test32: registered 0 subscriptions and 1 schedule
      > 00:10:00.594 [info] javascript.0 script.js.test32: [http://192.168.178.58/api/auth/login.js … Password_3](http://192.168.178.58/api/auth/login.json?user=Admin3&pwd=Password_3)
      > 00:10:01.681 [info] javascript.0 script.js.test32: { "SessionId": "1cb30bc6-ea9f-43d7-878d-afda7943a5a1", "Result": { "Success": "true" } }
      > 00:10:01.683 [info] javascript.0 script.js.test32: 1cb30bc6-ea9f-43d7-878d-afda7943a5a1
      > 00:10:01.683 [info] javascript.0 script.js.test32: [http://192.168.178.58/api/menutree/read … a1&Id=1143](http://192.168.178.58/api/menutree/read_datapoint.json?sessionId=1cb30bc6-ea9f-43d7-878d-afda7943a5a1&Id=1143)
      > 00:10:37.880 [info] javascript.0 Stop script script.js.test32 `
      Aber leider funktioniert die erzeugte URL zur Abfrage des Datenpunktes nicht. Ich erhalte eine "session not valid" Meldung.
      • Dutchman
        ehm ja du hast den fehler gefunden war auch bloede von mir um die log variable auserhalb der function ab zu fragen das kan natuerlich nicht gehen 😕
        warum jezt aber die meldung "session not valid" kommt ist mor nicht ganz klar, eventuell kan man dieselbe session ID nicht abfragen UND im browser aufrufen
        was passiert den wen du einfach in der function die abfrager der URL zur temperatur hinzufuegst, dieser code hier sollte das machen.
        Ist eine erweiterung deines codes mit abfrage der URL temperatur und schreiber der varible value aus der JSON ins log:
            var objekt;
            var sessionId;
        	var value
            //(TEST)
            try {
                require("request")
                log (objekt);
                log (sessionId);
        	// URL der Temperatur abfragen und in eine variable schreiben
        		require("request")
        		('http://192.168.178.58/api/menutree/read_datapoint.json?sessionId=' + sessionId + '&Id=1143'){
        		value = objekt.Value;
        		log (objekt)
        		log(value)
          Leider wieder ein error.
          ` > Log
          13:23:14.920 [info] javascript.0 Start javascript script.js.test33
          13:23:14.921 [error] javascript.0 script.js.test33 compile failed: SyntaxError: Unexpected token { `
          • Dutchman
            hatte einen fehler in der request function, nochmal:
                var objekt;
                var sessionId;
                var value;
                //(TEST)
                try {
                    require("request")
                    log (objekt);
                    log (sessionId);
                    require("request")
                    ('http://192.168.178.58/api/menutree/read_datapoint.json?sessionId=' + sessionId + '&Id=1143', function (error, response, results){
                       log (objekt);
                       log(value);
              ` > Log
              13:58:33.457 [info] javascript.0 Start javascript script.js.test34
              13:58:33.458 [info] javascript.0 script.js.test34: registered 0 subscriptions and 1 schedule
              13:59:00.463 [info] javascript.0 script.js.test34: http://192.168.178.58/api/auth/login.js … Password_3
              13:59:01.471 [info] javascript.0 script.js.test34: [object Object]
              13:59:01.472 [info] javascript.0 script.js.test34: 6e35b358-92a5-4e38-ba99-636db9829d64
              13:59:01.472 [info] javascript.0 script.js.test34: http://192.168.178.58/api/menutree/read … 64&Id=1143
              13:59:01.525 [info] javascript.0 script.js.test34: [object Object]
              13:59:01.526 [info] javascript.0 script.js.test34: undefined
              13:59:06.980 [info] javascript.0 Stop script script.js.test34 `
                Ich habe unten mal ein````
                log (results);
                Leider erhalte ich den "valid"-Fehler.
                Log
                14:47:49.788 [info] javascript.0 Stop script script.js.test34
                14:47:50.050 [info] javascript.0 Start javascript script.js.test34
                14:47:50.051 [info] javascript.0 script.js.test34: registered 0 subscriptions and 1 schedule
                14:48:00.173 [info] javascript.0 script.js.test34: http://192.168.178.58/api/auth/login.json?user=Admin3&pwd=Password_3
                14:48:01.068 [info] javascript.0 script.js.test34: [object Object]
                14:48:01.070 [info] javascript.0 script.js.test34: 1c8248fb-ead5-40db-8304-99e536d23193
                14:48:01.070 [info] javascript.0 script.js.test34: http://192.168.178.58/api/menutree/read_datapoint.json?sessionId=1c8248fb-ead5-40db-8304-99e536d23193&Id=1143
                14:48:01.126 [info] javascript.0 script.js.test34: { "Result": { "Success": "false", "Error": { "Txt": "session not valid", "Nr": "2" } } }
                14:48:01.128 [info] javascript.0 script.js.test34: [object Object]
                14:48:01.128 [info] javascript.0 script.js.test34: undefined
                Auf der CCU2 hole ich die SessionId so:````
                var url = "https://192.168.178.58/api/auth/login.json?user=Administrator&pwd=Password.2";
                dom.GetObject("CUxD.CUX2801001:1.CMD_SETS").State("wget -q --no-check-certificate -O - '"#url#"'");
                dom.GetObject("CUxD.CUX2801001:1.CMD_QUERY_RET").State(1);
                string srueck = dom.GetObject("CUxD.CUX2801001:1.CMD_RETS").State();
                ! if ( (srueck.Find("false") == -1) && (srueck) ) {
                string tmpa  = srueck.StrValueByIndex(",",0).StrValueByIndex(":",1);
                string sSID = tmpa.Substr(2, tmpa.Length()-3);
                WriteLine(" SessionID erfolgreich geholt:"#sSID);
                Wenn ich es hier mit ioBroker nicht hinbekomme dann muss ich das Script wohl auf der CCU2 weiter laufen lassen und die SessionId von dort an ioBroker übergeben. Das müsste doch gehen.
                • Dutchman
                  Es liegt nicht am ioBroker sondern unserer Dummheit 😉
                  Ich verstehe nur nicht wo der Fehler liegt die Session ID sieht ok aus, trotzdem schluckt er die nicht
                  Send from mobile device
                  • Dutchman
                    Probier Mal objekt.Data.Value anstatt Objekt.Value
                      Ich habe bei der zweiten Abfrage die Apostroph durch Anführungszeichen ersetzt.````
                      var objekt;
                      var sessionId;
                      var value;
                      //(TEST)
                      try {
                          require("request")
                          log (objekt);
                          log (sessionId);
                          require("request")
                          ("http://192.168.178.58/api/menutree/read_datapoint.json?SessionId=" + sessionId + "&Id=1143", function (error, response, results){
                             log (results);
                             value = objekt.Data.Value;
                             log(value);
                      ergibt folgendes Log:
                        ` > Log
                      > 01:14:10.660 [info] javascript.0 Start javascript script.js.test40
                      > 01:14:10.661 [info] javascript.0 script.js.test40: registered 0 subscriptions and 1 schedule
                      > 01:15:00.661 [info] javascript.0 script.js.test40: [http://192.168.178.58/api/auth/login.js … Password_3](http://192.168.178.58/api/auth/login.json?user=Admin3&pwd=Password_3)
                      > 01:15:01.563 [info] javascript.0 script.js.test40: [object Object]
                      > 01:15:01.564 [info] javascript.0 script.js.test40: 04b3cec8-5e9b-4792-95c1-85dbfdd7cf0d
                      > 01:15:01.565 [info] javascript.0 script.js.test40: [http://192.168.178.58/api/menutree/read … 0d&Id=1143](http://192.168.178.58/api/menutree/read_datapoint.json?sessionId=04b3cec8-5e9b-4792-95c1-85dbfdd7cf0d&Id=1143)
                      > 01:15:01.894 [info] javascript.0 script.js.test40: { "Data": { "Type": "Numeric", "Value": " 14.2", "Unit": "°C" }, "Result": { "Success": "true" } }
                      > 01:15:01.897 [info] javascript.0 script.js.test40: 14.2
                      > 01:15:08.812 [info] javascript.0 Stop script script.js.test40 `
                      • Dutchman
                        Und siehe da im Log steht jetzt auch der Wert 14.2 also geschafft !
                        Als nästen Schritt wolltest du das jetzt in ein object schreiben und dan alle x Minuten Update ?
                        4383
