    4. ioBroker plötzlich über Weboberfläche nicht mehr erreichbar
    • N
      netfriend @crunchip last edited by netfriend
      @crunchip
                                                     Skript v.2023-04-02
      *** BASE SYSTEM ***                                         Model           : Raspberry Pi 4 Model B Rev 1.1
      Architecture    : aarch64
      Docker          : false                                     Virtualization  : none
      Distributor ID: Debian                                      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       21:10:07 up 36 min,  1 user,  load average: 0.17, 0.42, 0.38
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Wed 2023-04-12 21:10:07 CEST
                 Universal time: Wed 2023-04-12 19:10:07 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev docker gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        431M        2.3G        1.0M        1.0G        3.3G
      Swap:            99M          0B         99M
      Total:          3.9G        431M        2.4G
               3793 M total memory
                431 M used memory
                401 M active memory
                854 M inactive memory
               2344 M free memory
                 92 M buffer memory
                925 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /dev/root      ext4       58G   15G   41G  27% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.3M  758M   1% /run
      /dev/sdb1      vfat      253M   31M  222M  13% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Wed Apr 12 20:33:17 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:49:07:15 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=495f82d0-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed Apr 12 20:33:21 2023] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Wed Apr 12 20:33:21 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:18.
      [Wed Apr 12 20:33:24 2023] EXT4-fs (sdb2): re-mounted. Opts: (null). Quota mode: none.
      Show mounted filesystems (real ones only):
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sdb2 ext4   rw,noatime
      `-/boot /dev/sdb1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      9.8G    /var/
      6.5G    /var/log
      4.0G    /var/log/journal/131bbf4012434f1fbf85765663b6a868
      2.8G    /var/lib
      /opt/iobroker/backups:
      2.6G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      139M    /opt/iobroker/iobroker-data/
      98M     /opt/iobroker/iobroker-data/files
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      8.8M    /opt/iobroker/iobroker-data/objects.json.old
      6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
      6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      4.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/848.7424922d.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v16.19.1
      /usr/bin/node           v16.19.1
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Installed: 16.19.1-deb-1nodesource1
        Candidate: 16.19.1-deb-1nodesource1
        Version table:
       *** 16.19.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u3 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
       Cannot read system.config: null (OK when migrating or restoring)
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + instance is alive
      ioBroker-Repositories
      List is empty
      Installed ioBroker-Instances
      Error: Object "system.config" not found
      Objects and States
      Objects:        34
      States:         2448
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:7 https://download.docker.com/linux/debian bullseye InRelease
      Hit:8 https://packages.grafana.com/oss/deb stable InRelease
      Reading package lists...
      Pending Updates: 21
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:7575            0.0.0.0:*               LISTEN      0          13585      528/vhusbdarm64
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13638      502/cupsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14204      993/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14197      993/iobroker.js-con
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          14906      974/docker-proxy
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13613      562/sshd: /usr/sbin
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        14708      699/influxd
      tcp6       0      0 :::80                   :::*                    LISTEN      0          15469      980/docker-proxy
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13615      562/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13637      502/cupsd
      tcp6       0      0 ::1:8888                :::*                    LISTEN      0          14408      416/pigpiod
      tcp6       0      0 :::3000                 :::*                    LISTEN      111        14182      693/grafana
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14564      576/cups-browsed
      udp        0      0 0.0.0.0:51894           0.0.0.0:*                           108        13564      396/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13562      396/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11882      691/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        13563      396/avahi-daemon: r
      udp6       0      0 :::48646                :::*                                108        13565      396/avahi-daemon: r
      2023-04-12 20:31:06.166  - error: host.Raspi4 Cannot find view "system" for search "instance"
      2023-04-12 20:31:06.168  - error: host.Raspi4 Could not collect system.host.Raspi4 states to check for obsolete states: Error: Cannot find view "system"
      2023-04-12 20:31:06.169  - error: host.Raspi4  _design/system missing - call node iobroker.js setup
      2023-04-12 20:31:06.169  - info: host.Raspi4  no instances found
      2023-04-12 20:31:06.170  - info: host.Raspi4 no instances found
      2023-04-12 20:31:33.128  - info: host.Raspi4 received SIGTERM
      2023-04-12 20:31:33.283  - info: host.Raspi4 terminated
      2023-04-12 20:33:37.536  - info: host.Raspi4 iobroker.js-controller version 4.0.24 js-controller starting
      2023-04-12 20:33:37.544  - info: host.Raspi4 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-04-12 20:33:37.546  - info: host.Raspi4 hostname: Raspi4, node: v16.19.1
      2023-04-12 20:33:37.547  - info: host.Raspi4 ip addresses: 192.168.170.45 fe80::e0d2:838e:bc5c:2a51 172.18.0.1 fe80::42:91ff:fe75:786 fe80::9467:b275:8ba2:ecf5 fe80::24c3:e8ff:febf:3d2d
      2023-04-12 20:33:37.780  - error: host.Raspi4 Cannot read system.config: null (OK when migrating or restoring)
      2023-04-12 20:33:37.841  - error: host.Raspi4 Cannot find view "system" for search "host"
      2023-04-12 20:33:38.139  - info: host.Raspi4 connected to Objects and States
      2023-04-12 20:33:38.211  - info: host.Raspi4 added notifications configuration of host
      2023-04-12 20:33:38.264  - error: host.Raspi4 Cannot find view "system" for search "instance"
      2023-04-12 20:33:38.266  - error: host.Raspi4 Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2023-04-12 20:33:38.294  - info: host.Raspi4 Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2023-04-12 20:33:38.371  - error: host.Raspi4 Cannot find view "system" for search "host"
      2023-04-12 20:33:38.384  - error: host.Raspi4 Cannot find view "system" for search "state"
      2023-04-12 20:33:38.386  - error: host.Raspi4 Cannot find view "system" for search "instance"
      2023-04-12 20:33:38.388  - error: host.Raspi4 Could not collect system.host.Raspi4 states to check for obsolete states: Error: Cannot find view "system"
      2023-04-12 20:33:38.389  - error: host.Raspi4  _design/system missing - call node iobroker.js setup
      2023-04-12 20:33:38.389  - info: host.Raspi4  no instances found
      iob diag has finished.
      Press any key for a summary
      Und hier das summary:
      ======================= SUMMARY =======================                          v.2023-04-02
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Kernel:                 5.15.84-v8+                         Installation:           Native
      Timezone:               Europe/Berlin (CEST, +0200)         User-ID:                1000
      X-Server:               false                               Boot Target:            multi-user.target
      Pending OS-Updates:     21
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            3.8G        427M        2.3G        1.0M        1.0G        3.3G
      Swap:            99M          0B         99M
      Total:          3.9G        427M        2.4G
      Active iob-Instances:   1
      List is empty
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      ioBroker Status:         Cannot read system.config: null (OK when migrating or restoring)
      Objects type: jsonl
      States  type: jsonl
      Objects:                34
      States:                 2448
      Size of iob-Database:
      40K     /opt/iobroker/iobroker-data/objects.jsonl
      28K     /opt/iobroker/iobroker-data/objects.jsonl.old
      996K    /opt/iobroker/iobroker-data/states.jsonl.old
      968K    /opt/iobroker/iobroker-data/states.jsonl
      884K    /opt/iobroker/iobroker-data/states.json.old
      iob diag
      kannte ich noch nicht. Aber was mir komisch vorkommt ist : "javascript" not found
      • wendy2702
        wendy2702 last edited by
        Wie lange hast du nach dem Restore gewartet?
        Was kommt aktuell im iobroker log ?
        • N
          netfriend @Thomas Braun last edited by
          Schwund?
          Vermutlich durch
          "Den ersten Versuch habe ich am 11.04. Abends unternommen, daher sind danach die Backups wohl deutlich kleiner geworden"
            Thomas Braun Most Active @netfriend last edited by
            @netfriend
            Bring das OS erstmal auf Stand. Da wird ein Kernelupdate mit dabei sein, also reboot erforderlich.
            Dann ist dein Backup-Verzeichnis rappelvoll. Wie groß sind denn die Files?
            Und das journal ist auch riesig. Was steht da so drin?
            • N
              netfriend @wendy2702 last edited by
              @wendy2702 sagte in ioBroker plötzlich über Weboberfläche nicht mehr erreichbar:
              Zwischen restore und was?
              Nach dem kopieren und entpacken? Nur vielleicht 10 sec. dann iobroker Start. Danach auch mal einen reboot.
              Wo finde ich das log mittels Kommandozeile?
              Thomas Braun wendy2702 crunchip 3 Replies Last reply Reply Quote 0
                @netfriend
                iobroker logs
                Alte logs in /opt/iobroker/log
                • wendy2702
                  wendy2702 @netfriend last edited by wendy2702
                  @netfriend hä?
                  Wie kopieren und entpacken?
                  Ein Backup stellt man eigentlich mit dem Befehl
                  iobroker restore
                  Wieder her.
                  Oder was genau hast du entpackt und wohin kopiert?
                  Logfile liegt im Ordner
                  /opt/iobroker/log/
                  • N
                    Dachte, das System ist up-to-date. Hab's vor 2 Wochen neu aufgesetzt. Bin gerade unterwegs, ich wollte nicht 3 Tage vor Abwesenheit noch am System rumspielen. "Never change a running system" hat sich bisher bewährt, wenn man sich nicht genügend Zeit nimmt und vor Ort ist.
                    Am WE bin ich wieder vor Ort, da kann ich Updates machen.
                      @netfriend
                      Ist nicht aktuell. Es gab auch kürzlich ein Kernelupgrade auf 6.1.
                        crunchip Forum Testing Most Active @netfriend last edited by
                        @netfriend sagte in ioBroker plötzlich über Weboberfläche nicht mehr erreichbar:
                        iobroker restore
                        er meinte mit backup die jsonl wiederherstellen
                        • N
                          @netfriend hä?
                          iobroker restore
                          Wieder her.
                          /opt/iobroker/log/
                          So wie hier beschrieben im 1. Post:
                          https://forum.iobroker.net/post/599758
                          • N
                            @thomas-braun sagte in ioBroker plötzlich über Weboberfläche nicht mehr erreichbar:
                            @netfriend
                            Mach ich wenn ich wieder vor Ort bin.
                            Aber das ist ja nicht die Ursache von meinem Problem.
                            Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                              Weiß man's...
                                kann muss aber nicht, oder Stromausfall, schwaches Netzteil, gibt viele Möglichkeiten
                                  Homoran Global Moderator Administrators @netfriend last edited by
                                  -rw-rwxr--+ 1 iobroker iobroker 1,7M 11. Apr 02:10 2023-04-11_02-09_objects.jsonl.gz
                                  -rw-rwxr--+ 1 iobroker iobroker 3,8K 11. Apr 23:33 2023-04-11_23-33_objects.jsonl.gz
                                  da ist doch der Übeltäter
                                    crunchip Forum Testing Most Active @Homoran last edited by
                                    @homoran sagte in ioBroker plötzlich über Weboberfläche nicht mehr erreichbar:
                                    Vermutlich durch
                                      Homoran Global Moderator Administrators @crunchip last edited by
                                      @crunchip henne und Ei Problem?
                                        @homoran keine Ahnung was da gemacht wurde, aber zumindest sind da
                                        • N
                                          netfriend last edited by Homoran
                                          ich möchte mich nochmal melden. Ich bin nun wieder zu Hause und habe mir alles nochmal am PC mit dem großen Bildschirm angesehen. Ist doch etwas übersichtlicher als von unterwegs mit dem Tablet.
                                          Ich habe meinen Fehler gefunden. Zuerst hatte ich mich nach der Anleitung https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiepbf8l67-AhX6XfEDHQLqCFoQtwJ6BAgLEAI&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DFZeWNwXC7rk&usg=AOvVaw3oZLIhYRBFm8hav-chw12X gerichtet.
                                          Dort wird leider nicht darauf hingewiesen, dass es in den Backup-Objects entweder *.json oder *.jsonl Dateien gibt. Beim Umkopieren der vermeintlich noch funktionierenden Dateien habe ich dann die gepackten *.jsonl in *.json entpackt. Das habe ich dann erst nicht gesehen und mich gewundert. Alle Versuche danach haben mich nur noch mehr verwirrt.
                                          Nun habe ich aufgrund des Hinweises von @crunchip mir die
                                          angesehen und nach objects.jsonl umbenannt, die zeitlich passende states.json.old gesucht und ebenfalls noch states.jsonl umbenannt und iobroker neugestartet....und siehe da, läuft wieder.
                                          Damit hatte ich noch Glück, den die anderen zeitlich passenden gepackten Dateien sind nun wirklich aus dem Puffer rausgerutscht. Also Glück im Unglück 🙂
                                          Alternativ hätte ich noch eine SD-Karten-Kopie gehabt und auch ein mittels BackitUp-Adapter erzeugtes Backup. Aber prima wenn es so funktioniert hat.
                                          Danke an alle, die mir soweit versucht haben, zu helfen. Die Anleitung von @Thomas-Braun (Link) weißt explizit auf die Unterschiede json/jsonl hin, das habe ich aber überlesen.
                                          Nun habe ich auch mein System wieder soweit aktualisiert und auch das Kernel-Update auf die 6.1.23-v8+ durchgeführt.
                                          Ihr hattet mich noch auf die großen Logfiles hingewiesen. Aktuell sieht es so aus:
                                          /var:
                                          9.3G    /var/
                                          6.0G    /var/log
                                          2.8G    /var/lib
                                          3.3G    /opt/iobroker/backups/
                                          Die iobroker/backups stammen vom BackitUp-Adapter, der immer 10 Updates vorhält. Eigentlich werden diese in GoogleDrive gespeichert, bleiben hier aber offenbar auch noch erhalten. Die Größe kommt davon, weil noch eine InfluxDB auf diesem Raspi läuft - und davon noch 10 Backups hier liegen.
                                          Was mich mehr interessiert, sind die in /var enthaltenen Logs.
                                          Was kann ich mit dem journal anfangen? Kann man die irgendwie ansehen bzw. die Logtiefe reduzieren?
                                          Könnt Ihr mir hier bitte nochmal helfen. Bin nicht so fit mit linux und lerne noch jeden Tag dazu.
                                          MOD-EDIT: externen Link sichtbar gemacht!
                                          • Damrak2022
                                            Damrak2022 @Thomas Braun last edited by Damrak2022
                                            @thomas-braun Habe gestern Abend Minen Rechner ganz normal aus und eben wieder angemacht. Jetzt komme ich auch nicht mehr auf die Weboberfläche
                                            Ping auf den Raspi funktioniert
                                            Habe den Raspi dann runtergefahren und neu gestartet. Jetzt geht das alles wieder, aber mich würde interessieren, wie das passieren kann.
                                            Ich bekomme aber des öfteren die Meldung Cannot get repository - timeout
                                            Bei erneuten ab und anmelden ist dann alles normals
                                            Thomas Braun Homoran ? 3 Replies Last reply Reply Quote 0
                                            4739
