    4. Solarman PV, Bosswerk MI & Deye
      meexx @Rene55 last edited by
      @rene55 OK ist erledigt 👍 Mal sehen ob sich mein Protokoll etwas beruhigt 😀
        meexx last edited by
        Hi, kurzes Feedback meinerseits, habe ja die 0.3.2 draufgespielt und der DB Fehler ist nicht mehr vorgekommen das freut mich sehr Danke nochmals dafür
        • Rene55
          Rene55 @meexx last edited by Rene55
          @meexx Merci. 😳 Adapter wird auch jetzt im Stable gelistet sein.
            ralle @Rene55 last edited by
            @Rene55
            Hi, Hab heute von Solarman eine Mail erhalten , dort wird am Server gearbeitet / Update, keine Ahnung od die Mail alle erhalten die einen API Key haben......
            "Dear valued customer,
            We are delighted to inform you that SOLARMAN platform will upgrade data centers from 2023-04-16 09:00 to 2023-04-16 18:00 (UTC+8) , as part of our continued efforts to offer you a premium product.
            Please note that your account and data will not be accessible via the interface until the upgrade is completed.
            Once upgrade is completed, if you are using the "International Data Center", we kindly remind that you use the new OPENAPI domain https://globalapi.solarmanpv.com to access the platform, replacing the previous domain https://api.solarmanpv.com. Your APPID and APPSECRET will remain the same, but you will need to obtain a new token to access the platform.
            If you require historical data during the upgrade, we recommend that you use the historical data interface (Interface 3.4 and Interface 4.3) to supplement it after the upgrade is completed.
            Should you have any questions or concerns, please do not hesitate to contact us at customerservice@solarmanpv.com.
            Thank you for choosing SOLARMAN platform, and we look forward to providing you with an even better user experience.
            Sincerely,
            The SOLARMAN Team"
            mal sehen was auf uns zukommt....
            Rene55 T 2 Replies Last reply Reply Quote 0
            • Rene55
              Rene55 @ralle last edited by
              @ralle Danke für die Info. Hab Augen und Ohren schon offen.
                thilo.frank @ralle last edited by
                @ralle Hallo,
                gleiche Mail habe ich auch bekommen und seit 10.30 Uhr werden die Erträger nicht mehr erfasst (aktuell wird immer der Wert von 10.30 Uhr angeszeigt)
                Leider kann ich die API-Domain nicht ändern, um auszuprobieren, ob die Umstellung vllt schon heute erfolgt ist.
                • Rene55
                  Rene55 @thilo.frank last edited by
                  @thilo-frank Also keine Panik - noch läuft die Solarman-Api. Könnte bei dir eine andere Störung vorliegen?
                    thilo.frank @Rene55 last edited by
                    @rene55 Tja, ich habe gerade nochmal alles geprüft:
                    Deine dejeidc-Adapter liefert korrekte Werte, ebenfalls die solarman-Webanwendung.
                    Leider reicht mein log nur 1 Std in die Vergangenheit (kann man das irgendwo anpassen?), liefert aber dafür derzeit immer das Folgende:
                    solarmanpv.0 2023-04-12 21:26:03.690 warn [initializeStation] error: undefined
                    solarmanpv.0 2023-04-12 21:26:01.632 info starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v16.19.0, js-controller: 4.0.23
                    solarmanpv.0 2023-04-12 21:24:04.281 info Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                    Vielleicht hilft da ja, das problem einzugrenzen.
                    • Rene55
                      @thilo-frank Das sagt eigentlich nur aus, dass der Adapter die Daten nicht abholen konnte. Ich denke/hoffe, dass der morgen wieder normal läuft.
                        @rene55 Leider ist heute morgen weiterhin kein Datenabruf möglich. Ich habe gerade eine zweite Adapterinstanz angelegt, diese zeigt bei Objekten lediglich "CheckSumUserData" an, sonst nichts.
                        Auch ein Neustart der Wechselrichter (sowohl per Software als auch per aus/einschalten) hat leider nichts gebracht...
                        Hast du noch eine Idee, was ich machen kann oder woran es liegen könnte?
                        • Rene55
                          @thilo-frank Schwer zu sagen. Ich habe eben noch mal "meine" Stationen überprüft: bis auf eine liefern die alle ihre Daten regelmäßig ab. Bei dir sieht es so aus, als könntest du keinen neuen Token abrufen - da weisen die Ergebnisse der zweiten Instanz drauf hin.
                          Ich kann mir aber nur schlecht vorstellen, dass eine Umstellung auf das neue Portal schon in Teilen begonnen hat.
                            @rene55 Ok, ich werrde einfach mal abwarten, was sich nach der Umstellung tut (da musst du dann im Adapter was umprogrammieren, oder?).
                            Die Überlegung, dass die Umstellung in Teilen schon vorzeit passiert, hatte ich aber auch schon....
                            Bis dahin werde ich auf den deyeidc umsteigen, das Prinzip gefällt mir ohnehin besser (und ich hoffe, dass du hier eine Aktualisierung in kürzerern Zeitabständen hingebastelst bekommst..)
                            • Ralf Roessler
                              Ralf Roessler last edited by
                              Seit der neuen Version 0.4.0 bekomme ich eine Warnung " [initializeStation] error: ERR_BAD_REQUEST"
                              • Rene55
                                Rene55 @Ralf Roessler last edited by Rene55
                                @ralf-roessler Ich vermute mal, entweder ist die Umstellung noch nicht vollzogen oder die API hat sich grundlegend geändert. Versuche mal, auf die alte 0.3.2 zurückzugehen, möglicherweise läuft die noch. 😠
                                Bis ich hier mehr weiß, bitte noch nicht auf 0.4.0 upgraden!
                                • Ralf Roessler
                                  @rene55 seit 16.33 Uhr tut alles wie es soll
                                    A Former User @Rene55 last edited by
                                    @rene55
                                    Der Fehler kommt bei mir auch mit der 0.4.0, aber er holt Daten… hmm brauchst du n debug log oder Zugangsdaten?
                                    Rene55 2 Replies Last reply Reply Quote 0
                                    • Rene55
                                      Rene55 @Guest last edited by Rene55
                                      @ilovegym Danke für das Angebot. Ich bin derzeit unterwegs und kann nicht so gut an meinen Entwicklungsrechner.
                                      Ich habe gerade nochmal versucht, mit der 0.4.0 Daten abzurufen - geht aber nicht. Mit der alten Platform (= 0.3.2) läuft es bei mir noch. Möglicherweise stellen die die Accounts nach und nach um - daher läuft es bei @ralf-roessler schon.
                                        @rene55
                                        Bei mir scheint alles zu laufen, Hab vorhin auch das Update durchgeführt.
                                        Aber mir ist auch nicht aufgefallen das es am Wochenende nicht funktioniert hat...... mmmmhhhh!
                                        Das einige was bei mir seit einigen Tagen ist, in den logs ist eine Warnmeldung
                                        solarmanpv.0
                                        25997	2023-04-17 19:42:07.860	warn	[initializeStation] error: undefined
                                        • Rene55
                                          @ralle Muss ich mir nächste Tage mal genauer ansehen. Sollte ja 'nur' ein Umzug auf eine neue Platform sein. Vielleicht ist doch mehr geändert worden.
                                          Ich hab beim Support nach möglichen Änderungen nachgefragt - aber noch keine Antwort bekommen.
                                          • Rene55
                                            @ilovegym @ralle Eine Nachricht von Solarman ist eben gekommen:
                                            Es tut uns sehr leid, dass das Upgrade der Datenzentren am 16. April nicht so erfolgreich war wie erwartet und Sie die vorherige OPENAPI-Domain verwenden mussten. Jetzt freuen wir uns, Ihnen mitteilen zu können, dass wir die Datenzentren erfolgreich aktualisiert haben.
                                            Ich gehe davon aus, dass wir jetzt sukzessiv auf die 0.4.0 umstellen können. Mögliche Fehlermeldungen werde ich in den nächsten Tagen analysieren und beheben.
                                            jetz
                                            67
                                            564
                                            136765
